GPIO pin value are read incorrectly from the .overlay file
I generated an overlay file with the following info:
// To get started, press Ctrl+Space to bring up the completion menu and view the available nodes.
// You can also use the buttons in the sidebar to perform actions on nodes.
// Actions currently available include:
// * Enabling / disabling the node
// * Adding the bus to a bus
// * Removing the node
// * Connecting ADC channels
// For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
// You can also visit the nRF DeviceTree extension documentation at https://docs.nordicsemi.com/bundle/nrf-connect-vscode/page/guides/ncs_configure_app.html#devicetree-support-in-the-extension
&gpio0 {
	status = "okay";
&gpiote {
	status = "okay";
	leds {
		compatible = "gpio-leds";
		yellow_led: led {
			label = "led";
			gpios = <&gpio0 6 0>;
and there is my main.c file:
// have some useful utility functions provided by zeyphr kernal.
#include <zephyr/kernel.h>
// include the GPIO driver
// get the gpio pin properties from the .overlay file
static struct gpio_dt_spec led = GPIO_DT_SPEC_GET(DT_NODELABEL(yellow_led), gpios);
        // check if the pin is ready to use (the function returns 0 if everything is ok)
        if(!gpio_is_ready_dt(&led))
                // end the program
                return 0;
        // check if the pin is configured successfully (the function returns 0 if everything is ok)
        if(gpio_pin_configure_dt(&led, GPIO_OUTPUT_INACTIVE) < 0)
                // end the program
                return 0;
        // loop infinitely
        while(1)
                // toggle the led and check if it was toggled successfully
                if(gpio_pin_toggle_dt(&led) < 0)
                        return 0;
                // sleep for 1 second
                k_msleep(1000);
        return 0;
However, when I tried to debug my code to understand what was wrong, I got the following value of the led variable at the start of the main:
$1 = {port = 0x395f <notify_monitors+40>, pin = 0 '\000', dt_flags = 0}
which is incorrect because the pin value should be 6 not 0.
  • nothing changed. I am still trying to understand why. I am pretty sure it has something to do with the configuration files because I used the same blinky example code (which works with nrf52 dk configuration files) with my board configuration and it didn't work.
  • Now, I am having new behavior after clean build. the led variable pin field is set to 17 which is only defined in the 'nrf52 dk - nrf52832' board configuration files but I am using my board configuration files.
  • now after editing the code to be like this:
    #include <stdio.h>
    /* 1000 msec = 1 sec */
    #define SLEEP_TIME_MS   1000
    /* The devicetree node identifier for the "led0" alias. */
    #define LED23_NODE DT_ALIAS(led23)
     * A build error on this line means your board is unsupported.
     * See the sample documentation for information on how to fix this.
    // DT_NODELABEL(led21)
    static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED23_NODE, gpios);
    	int ret;
    	bool led_state = true;
    	if (!gpio_is_ready_dt(&led)) {
    		return 0;
    	ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
    	if (ret < 0) {
    		return 0;
    	while (1) {
    		ret = gpio_pin_toggle_dt(&led);
    		if (ret < 0) {
    			return 0;
    		led_state = !led_state;
    		printf("LED state: %s\n", led_state ? "ON" : "OFF");
    		k_msleep(SLEEP_TIME_MS);
    	return 0;
    and the .overlay file to be like this:
    &gpio0 {
    	status = "okay";
    &gpiote {
    	status = "okay";
    	leds {
    		led20: led21 {
    			label = "led";
    			gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>;
    	aliases {
    		led23 = &led20;
    I am getting a strange behavior that no matter what led21 gpio pin is defined to, it's always 17 during runtime and actually pin 17 is the one toggling on the actual hardware.
  • Now, nRF connect SDK is driving me crazy, I have modified the code to be as follows:
    #include <stdio.h>
    	led.pin = 6;
    	int ret;
    		return 0;
    	if (ret < 0) {
    		return 0;
    	while (1) {
    		if (ret < 0) {
    			return 0;
    	return 0;
    but I noticed during debugging that the line "led.pin = 6" doesn't do anything. upon being added the "led" pin field variable is initialized to the value "0" and the line "led.pin = 6" doesn't change its value for some reason.
  • UPDATE: it's working. it seems like it has something to do with the debugger. Once I used the debugger as a downloading tool, it worked seamlessly. I am trying to understand why a gdb session messes up the working of the application (I guess it may have something to do with timing Zephyr OS tasks have to be met).
