I'm working with nRF52840, my function will read wav file from SD card and play it using Zephyr I2S driver. My source code about playing sound in below.
The strange is the code only work if I has the line "LOG_INF("[PLAYING] Read bytes: %d", the_read_bytes);"
If I comment the line, the I2S throw error in log: i2s_nrfx: Next buffers not supplied on time.
If I uncomment the line, the I2S work normally, and it play whole a song
Please someone can explain what wrong in my source code ?
#define THE_BLOCK_SIZE 4 * 1024
#define THE_NUMBER_OF_BLOCK 8
#define THE_NUMBER_OF_INIT_BUFFER 4
K_MEM_SLAB_DEFINE(the_i2s_mem_slab, THE_BLOCK_SIZE, THE_NUMBER_OF_BLOCK, 4);
// Init function
static void do_init_i2s(void) {
struct i2s_config the_config = {
.word_size = 16U,
.channels = 2U,
.format = I2S_FMT_DATA_FORMAT_I2S,
.frame_clk_freq = 44100,
.block_size = THE_BLOCK_SIZE,
.timeout = 2000,
.options = I2S_OPT_FRAME_CLK_MASTER | I2S_OPT_BIT_CLK_MASTER,
.mem_slab = &the_i2s_mem_slab,
int error = i2s_configure(the_i2s_device, I2S_DIR_TX, &the_config);
if (error) {
LOG_ERR("Configure I2S failed: %d", error);
static void do_play_sound_from_sd(char *the_file_path) {
struct fs_file_t the_file;
do_open_file(the_file_path, &the_file);
bool the_i2s_started = false;
uint8_t the_number_of_init_buffer = 0;
while (1) {
void *the_tx_mem_block;
int error = k_mem_slab_alloc(&the_i2s_mem_slab, &the_tx_mem_block, K_NO_WAIT);
if (error) {
LOG_ERR("Failed to allocate TX block: %d", error);
ssize_t the_read_bytes = fs_read(&the_file, the_tx_mem_block, THE_BLOCK_SIZE);
if (the_read_bytes <= 0) {
LOG_INF("End file");
k_mem_slab_free(&the_i2s_mem_slab, the_tx_mem_block);
break; // done when end of file
// LOG_INF("[PLAYING] Read bytes: %d", the_read_bytes);
error = i2s_write(the_i2s_device, the_tx_mem_block, THE_BLOCK_SIZE);
if (error) {
LOG_ERR("Failed to write data: %d", error);
the_number_of_init_buffer++;
if (the_number_of_init_buffer == THE_NUMBER_OF_INIT_BUFFER &&
the_i2s_started == false) {
// make sure to filled THE_NUMBER_OF_INIT_BUFFER before starting i2s
LOG_INF("Start I2S: %d", the_number_of_init_buffer);
the_i2s_started = true;
i2s_trigger(the_i2s_device, I2S_DIR_TX, I2S_TRIGGER_START);
i2s_trigger(the_i2s_device, I2S_DIR_TX, I2S_TRIGGER_STOP);
do_close_file(&the_file);
