Fails to verify device in QuickStart 1.2.0
I just received my Thingy91x. I followed the onboarding and created a provisioning profile in NRF Cloud. The device did not connect and no logs appeared in Serial terminal stating it did. (Only connected to serial port)
I tried to follow the quickstart again, but same issue. Then I turned the device off/on and tried again, after deleting the provisioning profiles created earlier.
Now It get stuck on step 4 - verify with error "Failed to verify device". If I skip that step, it stops also on providing a token.
2025-01-16T08:26:21.514Z INFO Initialising the bundled nrfutil device
2025-01-16T08:26:21.522Z DEBUG Started watching devices
2025-01-16T08:26:22.259Z INFO Using the bundled core version for nrfutil device: 7.13.0
2025-01-16T08:26:22.282Z INFO Using nrfutil-device version: 2.7.5
2025-01-16T08:26:22.282Z INFO Using nrf-device-lib version: 0.17.41
2025-01-16T08:26:22.282Z INFO Using nrfjprog DLL version: Unknown
2025-01-16T08:26:22.282Z INFO Using JLink version: JLink_V8.12a
2025-01-16T08:26:22.282Z INFO Your version of SEGGER J-Link (8.12a) is newer than the one this app was tested with (7.94i). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
2025-01-16T08:26:24.516Z DEBUG Selected device: Nordic Thingy:91 X
2025-01-16T08:26:24.527Z DEBUG Changed step: Info
2025-01-16T08:26:26.297Z DEBUG Changed step: Rename
2025-01-16T08:26:28.187Z DEBUG Changed step: Program
2025-01-16T08:26:31.263Z ERROR [jlink] [NRFJPROG][nRF][-] Exception encountered while attempting to initialize multiprocess client: Operation not permitted
2025-01-16T08:26:31.263Z ERROR [jlink] NRFJPROG_open_dll_inst returned -254
2025-01-16T08:26:31.267Z ERROR [jlink] [NRFJPROG][nRF][-] Exception encountered while attempting to initialize multiprocess client: Operation not permitted
2025-01-16T08:26:31.267Z ERROR plugin(jlink) enumerate failed with error: 9, msg: [jlink] INTERNAL_ERROR
2025-01-16T08:26:32.381Z ERROR [mcuboot] delete package returns error 607
2025-01-16T08:27:54.023Z DEBUG Changed step: Verify
2025-01-16T08:27:57.062Z INFO Opened port with options: {"path":"/dev/tty.usbmodem1102","baudRate":115200}
2025-01-16T08:27:58.066Z ERROR Error: Received ERROR as return value from AT command
2025-01-16T08:27:58.069Z INFO Closed port: /dev/tty.usbmodem1102
2025-01-16T08:31:02.258Z DEBUG Changed step: Program
2025-01-16T08:31:03.512Z DEBUG Changed step: Verify
2025-01-16T08:31:04.609Z DEBUG Changed step: SIM
2025-01-16T08:31:05.853Z DEBUG Changed step: Verify
2025-01-16T08:31:06.774Z INFO Opened port with options: {"path":"/dev/tty.usbmodem1102","baudRate":115200}
2025-01-16T08:31:07.775Z ERROR Error: Received ERROR as return value from AT command
2025-01-16T08:31:07.777Z INFO Closed port: /dev/tty.usbmodem1102
2025-01-16T08:31:15.597Z INFO Opened port with options: {"path":"/dev/tty.usbmodem1102","baudRate":115200}
2025-01-16T08:31:15.628Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set
2025-01-16T08:31:15.629Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set
2025-01-16T08:31:15.629Z DEBUG Shell Parser: found shell prompt: "uart:~$ "
2025-01-16T08:31:16.598Z ERROR Error: Received ERROR as return value from AT command
2025-01-16T08:31:16.600Z INFO Closed port: /dev/tty.usbmodem1102
2025-01-16T08:31:17.659Z DEBUG Changed step: SIM
2025-01-16T08:31:19.187Z DEBUG Changed step: Evaluate
2025-01-16T08:31:19.224Z INFO Opened port with options: {"path":"/dev/tty.usbmodem1102","baudRate":115200}
2025-01-16T08:31:19.583Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set
2025-01-16T08:31:19.584Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set
2025-01-16T08:31:19.584Z DEBUG Shell Parser: found shell prompt: "uart:~$ "
2025-01-16T08:31:20.225Z ERROR Error: Received ERROR as return value from AT command
2025-01-16T08:31:20.227Z INFO Closed port: /dev/tty.usbmodem1102
2025-01-16T08:31:28.112Z DEBUG Changed step: SIM
2025-01-16T08:31:29.224Z DEBUG Changed step: Verify
I connected a nRF9151DK and tried that, and it stops on the program step as well.
2025-01-16T14:40:13.714Z INFO Initialising the bundled nrfutil device
2025-01-16T14:40:13.717Z DEBUG Started watching devices
2025-01-16T14:40:14.111Z INFO Using the bundled core version for nrfutil device: 7.13.0
2025-01-16T14:40:14.135Z INFO Using nrfutil-device version: 2.7.5
2025-01-16T14:40:14.135Z INFO Using nrf-device-lib version: 0.17.41
2025-01-16T14:40:14.135Z INFO Using nrfjprog DLL version: Unknown
2025-01-16T14:40:14.135Z INFO Using JLink version: JLink_V7.94i
2025-01-16T14:40:16.715Z DEBUG Selected device: nRF9151 DK
2025-01-16T14:40:16.729Z DEBUG Changed step: Info
2025-01-16T14:40:17.940Z DEBUG Changed step: Rename
2025-01-16T14:40:18.448Z DEBUG Changed step: Program
2025-01-16T14:40:20.765Z ERROR [jlink] [NRFJPROG][nRF][-] Exception encountered while attempting to initialize multiprocess client: Operation not permitted
2025-01-16T14:40:20.765Z ERROR [jlink] NRFJPROG_open_dll_inst returned -254
2025-01-16T14:40:20.769Z ERROR [jlink] [NRFJPROG][nRF][-] Exception encountered while attempting to initialize multiprocess client: Operation not permitted
2025-01-16T14:40:20.769Z ERROR plugin(jlink) enumerate failed with error: 9, msg: [jlink] INTERNAL_ERROR
2025-01-16T14:40:21.363Z ERROR [jlink] [NRFJPROG][nRF][-] Exception encountered while attempting to initialize multiprocess client: Operation not permitted
I've tried to install both latest, and newer versions of Segger, but the problem persists.
System: Mac ARM (M2, latest macOS)
Please advice!
