Compiler Error in SDK nRF5_SDK_15.3.0 when using ARM compiler version 6.18 (ARM MDK 5.37)
Please found following error message:
*** Using Compiler 'V6.18', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'
Build target 'nrf52832_xxaa'
../../../../../../components/libraries/util/app_error_handler_keil.c(45): error: expected '(' after 'asm'
__ASM void app_error_handler(ret_code_t error_code, uint32_t line_num, const uint8_t * p_file_name)
../../../../../../components/libraries/util/app_error_handler_keil.c(45): error: expected ';' after top-level asm block
../../../../../../components/libraries/util/app_error_handler_keil.c(47): error: use of undeclared identifier 'PRESERVE8'
PRESERVE8 {TRUE}
3 errors generated.
compiling app_error_handler_keil.c...
".\_build\nrf52832_Rabit.axf" - 3 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:01
However, using Arm Compiler V5 (MDK 5.29) to compile, no errors will occur.
Thank you
