Bluetooth Mesh - No cdb entry for subnet 0x000
I recently purchased a nRF52840 dongle with the intention of creating a Bluetooth mesh provisioner with it. The first thing I tried was flashing the mesh_shell example. The flash was successful, but once I started the provisioning process described in https://docs.zephyrproject.org/latest/connectivity/bluetooth/api/mesh/shell.html, the application threw some errors that I do not seem to understand. Has anyone faced the same problem? Thanks.
*** Booting Zephyr OS build v4.0.0-2778-g1b70bfa14e28 ***
Initializing...
[00:00:00.326,110] <inf> fs_nvs: 4 Sectors of 4096 bytes
[00:00:00.326,110] <inf> fs_nvs: alloc wra: 0, e70
[00:00:00.326,141] <inf> fs_nvs: data wra: 0, 2d8
[00:00:00.330,902] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,024] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,146] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,268] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,390] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,481] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,604] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,726] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,848] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,970] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.332,061] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.332,092] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.332,122] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 4.0 Build 99
uart:~$ > mesh init
mesh init
Mesh shell initialized
uart:~$ > mesh prov local 0 0x0001
    It seems to be coming from https://docs.nordicsemi.com/bundle/zephyr-apis-latest/page/group_net_buf.html#ga534366f3b5c7f41a28372c12149ca005. Could you verify the following:
    1. Which version of nRF Connect SDK are you using?
      1. If you're running it from the Zephyr RTOS, do you see the same thing when using nRF Connect SDK?
    2. If you have one available, do you see the same behavior on a nRF52840DK as well (no worries if you don't have one available, I will use that board to see if I can recreate it)
    3. Is the result you're describing coming from an unmodified shell sample from the SDK?
    Andreas
  • Hi
    I don't think, this question is applicable to my problem since I'm using the stock Zephyr RTOS sample, but correct me if I'm wrong. I cannot seem to find a sample that does the same thing in the nRF Connect SDK. From what I understand, nRF Connect sdk does not include a sample application of mesh provisioner. Most of the samples are provisioned by the mobile application.
    Unfortunately I have only one dongle development kit by me.
    Yes, I haven't modified any of sample code. Also to add to this, I also tried to flash a mesh provisioner sample from the Zephyr RTOS repository, but ended up getting the same error messages -
    Thanks for your assistance,
    Viktor
    To angle it the other way: Is there a difference if you follow the steps in the downstream version of Zephyr that is present within nRF Connect SDK or if you use the upstream Zephyr RTOS version
    No worries
    Thank you for verifying. I'll try to set the shell sample (from NCS, i.e zephyr downstream) and provision some devices to see if I see the same thing
    Andreas
    First of all I would like to thank you for your help so far. I installed the nRF connect sdk on a clean windows installation and tried flashing the dongle using the sample program. Unfortunately the whole process failed, the device will not communicate via the built in UART and just becomes unresponsive. This also happens with the default mesh_provisioner sample. Just to note, the blinky sample works as intended without any problems. Have you tried flashing it to find the problem?
    Viktor
    mesh init
    I believe I've found the reason. The reason for why you don't get any cdb entry for subnet 0x000 is because you haven't created a CDB yet. Use 'mesh cdb create <NetKey>' to create one.
    Let me know if you're able to provision the device after creating the CDB (worked for me at least)
    Andreas
