Bluetooth Mesh - No cdb entry for subnet 0x000
I recently purchased a nRF52840 dongle with the intention of creating a Bluetooth mesh provisioner with it. The first thing I tried was flashing the mesh_shell example. The flash was successful, but once I started the provisioning process described in https://docs.zephyrproject.org/latest/connectivity/bluetooth/api/mesh/shell.html, the application threw some errors that I do not seem to understand. Has anyone faced the same problem? Thanks.
*** Booting Zephyr OS build v4.0.0-2778-g1b70bfa14e28 ***
Initializing...
[00:00:00.326,110] <inf> fs_nvs: 4 Sectors of 4096 bytes
[00:00:00.326,110] <inf> fs_nvs: alloc wra: 0, e70
[00:00:00.326,141] <inf> fs_nvs: data wra: 0, 2d8
[00:00:00.330,902] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,024] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,146] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,268] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,390] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,481] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,604] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,726] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,848] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.331,970] <wrn> net_buf: Timeout discarded. No blocking in syswq
[00:00:00.332,061] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.332,092] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.332,122] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 4.0 Build 99
uart:~$ > mesh init
mesh init
Mesh shell initialized
uart:~$ > mesh prov local 0 0x0001
  • You're right. This is the trouble of working with the nRF52840 dongle which does not have an onboard debugger. It's hard to delete stored network data since the way you program it is over SDFU, and this way just overwrites the with the previous firmware.
    But here's a zip that my colleague wrote a few years ago that "fixes" this problem. What this does is basically to replace everything except the bootloader, MBR and this new "flasherase application" with nothing.
    Steps:
    1. Program the hex within this zip through the steps mentioned in  https://devzone.nordicsemi.com/support-private/support/251146#permalink=568907
    2. Retrace the steps you've done to get the Mesh shell up and running
    3. Create the keys as previously suggested
      7382.flasherase_nrf52840_dongle_sdk16.zip
    If this doesn't work, I would like to recommend you to use a nRF52840DK for prototyping and developing, since it has an onboard debugger and is much easier to use than the Dongle.
    Andreas
  • I don't even know if I'm just doing something wrong in general or if the whole thing is just cursed. It seems I cannot flash the binary you provided. I tried on 2 different machines, even with CLI and it failed. In the nRF programmer application the button to flash the project is not clicakble as you can see on the picture provided.
    OK, if I were to change hardware, what would you recommend for my use case? I am creating a Bluetooth mesh gateway. The first idea was to use the dongle as it has a much better sdk for mesh in general along with the raspberry pi and communicate between the two using uart. (just to note, i need more fine-grained control over the whole program, so the built-in meshctl utility in most linux distros is unsuitable for my use case).
    Thanks for your patience and help so far.
    Viktor
  • Hi Viktor,
    Happy to help
    Within the zip there is an application hex at the path "flasherase_nrf52840_dongle_sdk16.zip/flasherase/hex/flasherace_pca10059.hex"
    If you extract the zip and try to program the flasherace_pca10059.hex you should be successful (I just tested and verified that I were able to do it in the programmer application)! :)
    It is fine to use the nRF52840dongle, but I personally find it much easier to use the nRF52840 Development Kit, due to it's onboard debugger, for development and prototyping and then when you have a working product I would simply port it, or in most cases just build it, for the nRF52840 Dongle.
    But as mentioned, you can stick with the Dongle if you wish, I just wanted you to know that there might be an option with a less steep curve to use
    Andreas
    Even after flashing the firmware you provided, I still have the same problem as before.
    uart:~$ mesh cdb create 0
    Failed to create CDB (err -120)
    I thought that the dongle would be sufficient for my case, but unfortunately it seems that either my device is broken or there is something wrong with the SDK. I would consider buying the full SDK board, but that would not help me in this case as I cannot perform the tasks on the dongle. Do you have any other ideas on how to solve this problem? Thanks.
    Vitkor
    Any update on this problem? I decided to order the nRF52 DK myself to see if it would fix the issue, but that does not solve the dongle problem. Do you have any more insights on this? Thanks
    Viktor
