nRF54L15 - NFCT Pins as GPIO with TF-M
Good day,
I'm trying to use pin 1.02 as a GPIO in a TF-M build using a (custom) non-secure board target, and I'm struggling to find the appropriate way to accomplish this.
All current resources point to deprecated Kconfig defines (USE_NFCT_PINS_AS_GPIO), do not support non-secure targets (uisng the &uicr node in devicetree), are for older SoCs (
TFM_NFCT_PINS_AS_GPIOS only applies to nRF5340 according to v2.9.0 SDK). The only working option I've found is to edit the NFCT PADCONFIG register (which worked); are there any other options?
Thank you
Mark Laloo
  • Hi Justin,
    Can you get a very simplified test going where you only control the pin as a GPIO?
    Here is my project where I overlayed the Devicetree to have P1.02 as LED1 and toggle it.
    Hieu
  • Hi Hieu, Justin
    I've noticed (due to recommendations in other tickets to upgrade our SDK) that the solution we have been using (NRF_NFCT_NS->PADCONFIG=0) no longer works in our project. We previously built using NCS v2.9.1 (where it worked), and have moved to v3.1.1 (no longer working). Tests were completed using non-secure build target, building with TF-M.
    I have also tested on v3.1.1 with TF-M removed (and building with secure target), and NFCT config now works as expected (using NRF_NFCT_S).
    Note, in this specific test, the GPIO was used to drive an LED.
    Mark Laloo
  • Hi Mark,
    Thanks for the additional information on this case, this helps.
    I configured the NRF5L15 dev kit and resoldered the connections to output to the IO headers. I can observe the same behavior as metioned that the IO does not get unlocked when building with TF-M and the application running non-secured. I can toggle the pin when it is unlocked in a secured build.
    I did some additional testing and noticed that the NRF_NFCT_NS->PADCONFIG is set to 0 inside the driver init as it gets cleared by the POST_KERNEL function I have but the debugger says the register is still set.
    Trying to write to it does alter NRF_NFCT_NS->PADCONFIG but it does not correlate to the actual register as shown by the debugger.
    Justin Verkade
  • Hi Justin and Mark,
    Sorry for the late reply. I broke the environment on my machines and can't test anything for a while.
    That is fixed now, but I still can't reproduce your issue with NVS v3.1.1.
    Do you have a minimal setup I can reproduce the issue with?
    Here is my copy of modified zephyr/samples/basic/blinky sample, where P1.02 works as expected.
    c339307-251106_01.zip
    Hieu
  • Hi Hieu,
    Sorry for the delay, We only have one nRF54L15 dev kit laying around and we modified it to function exactly as in the prototype hardware so getting an exact working example is difficult and I also do not have enough time to prepare a minimal repoducable example.
    I cut and soldered the connections such that the external 32kHz crystal is disconnected and redirected to the IO headers just like the NFC pins. I use the dev kit board files as base with an overlay file to redirect the debug uart pins on the P1 block to other pins since I needed the default UART pins for different connections. My project Kconfig contains some additional configurations to enable the internal RC oscilator.
    I attempted to write the PADCONFIG register in the main function while in secured and non-secured to attempt to change it with the mentioned results. The results reflect the same on the prototype hardware in that we are unable to change the register in non-secured mode.
    Sadly I do not have enough time to dive much deeper since we internally decided to just use different pins and avoid the problem in our next revision of the hardware. If required I can provide more information but I do not have the time to setup a dev kit for further testing.
    Sadly it is not a quick fix and you provided good support but we need to continue.
    Justin Verkade
