I'm trying to move my project based on the xiao_ble board from using SDK 2.6.2 with Adafruit_bootloader to SDK 2.9.0 with MCUBoot/sysbuild.
To keep things simple, I'm trying to run the "zephyr/samples/sysbuild/with_mcuboot" code, the only difference being that I added my custom board/overlay. After a few tweaks, I managed to run the application fine when using only the internal flash for both mcuboot_primary and mcuboot_secondary partitions.
Due to constraints on the project however, I have to declare mcuboot_secondary on the external flash, hence my troubles. The code compile fine, but when I run it, I get the following dynamic error:
*** Booting MCUboot v2.1.0-dev-12e5ee106034 *** *** Using nRF Connect SDK v2.9.0-7787b2649840 *** *** Using Zephyr OS v3.7.99-1f8f3dc29142 *** E: Failed to open flash area ID 2 (image 0 slot 1): -19, cannot continue
Here is what my sysbuild.conf file looks like:
SB_CONFIG_BOOTLOADER_MCUBOOT=y SB_CONFIG_PARTITION_MANAGER=y SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
(The last line "SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y" is dubious but it doesn't appear to do any good nor harm).
prj.conf:
CONFIG_GPIO=y CONFIG_MULTITHREADING=y CONFIG_NORDIC_QSPI_NOR=y
sysbuild/mcuboot.conf:
CONFIG_MCUBOOT_LOG_LEVEL_WRN=y CONFIG_BOOT_UPGRADE_ONLY=y CONFIG_MCUBOOT_DOWNGRADE_PREVENTION=y CONFIG_MULTITHREADING=y CONFIG_NORDIC_QSPI_NOR=y
pm_static.yml:
app:
address: 0xf200
end_address: 0x87000
region: flash_primary
external_flash:
address: 0x0
end_address: 0x200000
region: external_flash
default_driver_kconfig: CONFIG_NORDIC_QSPI_NOR
device: DT_CHOSEN(nordic_pm_ext_flash)
mcuboot:
address: 0x0
end_address: 0xf000
placement:
align:
end: 0x1000
before:
- mcuboot_primary
mcuboot_pad:
address: 0xf000
end_address: 0xf200
placement:
align:
start: 0x1000
before:
- mcuboot_primary_app
mcuboot_primary:
address: 0xf000
end_address: 0x100000
orig_span: &id001
- app
- mcuboot_pad
sharers: 0x1
span: *id001
mcuboot_primary_app:
address: 0xf200
orig_span: &id002
- app
span: *id002
mcuboot_secondary:
address: 0x0
end_address: 0x0f1000
placement:
align:
start: 0x1000
align_next: 0x1000
share_size:
- mcuboot_primary
sram_primary:
address: 0x20000000
end_address: 0x20040000
region: sram_primary
Relevant board.overlay code snippet:
chosen {
nordic,pm-ext-flash = &p25q16h;
I have successfully tested that I can access the external flash by testing my custom board with the spi_flash sample, as provided (aka without bootloader nor partition manager):
*** Booting nRF Connect SDK v2.9.0-7787b2649840 *** *** Using Zephyr OS v3.7.99-1f8f3dc29142 *** ext_flash SPI flash testing ========================== Perform test on single sector Test 1: Flash erase Flash erase succeeded! Test 2: Flash write Attempting to write 4 bytes
How should I take it from there ? My main lead for solving the problem is about the regions.yml file that is generated in the build directory:
external_flash: base_address: 0x0 default_driver_kconfig: CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK device: DT_CHOSEN(nordic_pm_ext_flash) dynamic_partition: null name: external_flash placement_strategy: start_to_end size: 0x40000 flash_primary: base_address: 0x0 default_driver_kconfig: CONFIG_SOC_FLASH_NRF device: flash_controller dynamic_partition: null name: flash_primary placement_strategy: complex size: 0x100000 sram_primary: base_address: 0x20000000 default_driver_kconfig: '' device: '' dynamic_partition: sram_primary name: sram_primary placement_strategy: complex size: 0x40000
which is almost good, but for the size of the external flash region. How am I supposed to edit this file ? The only documentation I found about regions is this. I have written a partition_manager.cmake which looks like this:
add_region( external_flash 200000 0x0 start_to_end )
but I am unsure if a) this is proper code, b) how to call the actual thing (while sitting in the root directory the file doesn't have any effect on the generated regions.yml file). Of course all of this regions.yml consideration could be unrelated to the actual problem.
Thank you for your time !
