Apply dts board_variant.overlay specific to mcuboot instead of generic one from board root.
NCS 2.7, nrf52840, sysbuild with mcuboot
2 applications: manufacturing and customer
3 board variants implemented through revisions in boards.yml.  Board revisions enable additional components and configuration which will be used in the application but should not be included into mcuboot.  The two applications use common overlays from the board root directory.
I am having problems because devicetree is taking the board directory overlay instead of the more specific one in sysbuild/mcuboot/boards/.   As I understand it the philosophy is that the most specific file should be used, which in this case would be the sysbuild/mcuboot/boards directory, however devicetree processing uses the overlays from the board directory instead of the mcuboot specific version.  The mcuboot overlay needs to disable or not define the components are that application specific.
Any recommendations for how to structure my directories and builds to avoid duplicating files in many places, which tends to lead to errors when a file is changed in one place but not all other places.
    For board variants, you need to add the board variant to the filename of the MCUboot overlay to select it instead of the overlay from the board directory in this case. For example, if you are using revision 0.14.0 of the nRF9160 DK, the overlays in sysbuild/mcuboot/boards should be named nrf9160dk_nrf9160_0_14_0.overlay, nrf9160dk_nrf9160_ns_0_14_0.overlay, and nrf9160dk_nrf52840_0_14_0.overlay.
    Marte
  • Unfortunately that did not work.
    -- Using NCS Toolchain 2.6.20240605.885759407716 for building. (C:/ncs/toolchains/ce3b5ff664/cmake)
    -- Found Python3: C:/ncs/toolchains/ce3b5ff664/opt/bin/python.exe (found suitable version "3.9.13", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: D:/Flipperz/flipper_workspace2/zephyr/.cache
    -- Zephyr version: 3.6.99 (D:/Flipperz/flipper_workspace2/zephyr)
    -- Board: thomas_c, Revision: 6.2.1, qualifiers: nrf52840
    -- Found host-tools: zephyr 0.16.5 (C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.5 (C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/ce3b5ff664/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: D:/Flipperz/flipper_workspace2/app.git/boards/ciye/thomas/thomas_c_nrf52840.dts
    -- Found devicetree overlay: D:/Flipperz/flipper_workspace2/app.git/boards/ciye/thomas/thomas_c_6_2_1.overlay
    -- Generated zephyr.dts: D:/Flipperz/flipper_workspace2/app.git/mfg_app/build_thomas_c_6_2_1_x/mfg_app/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/Flipperz/flipper_workspace2/app.git/mfg_app/build_thomas_c_6_2_1_x/mfg_app/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/Flipperz/flipper_workspace2/app.git/mfg_app/build_thomas_c_6_2_1_x/mfg_app/zephyr/dts.cmake
    Despite having the file sysbuild/mcuboot/boards/thomas_c_nrf52840_6_2_1.overlay
    antho@Lenny-Laptop MINGW64 /d/Flipperz/flipper_workspace2/app.git/mfg_app (asterisk/mfg_app)
    $ find ./ -name "thomas_c*.overlay" -print
    ./sysbuild/mcuboot/boards/thomas_c_nrf52840_6_2_1.overlay
    Can you share a minimal project to reproduce this? When I tested revision 0.14.0 of the nRF9160 DK with the Hello World sample, the overlay in sysbuild/mcuboot/boards was correctly picked up and used.
    Marte
  • It would have been much easier if you could have shared with me your example application folder, but I'll try to get one working with sysbuild and a mcuboot application folder.  I'm a bit unsure about what should go into sysbuild/mcuboot/prj.conf...
  • My apologies, I'm testing today and indeed it is picking up files from mcuboot.  I suspect I was looking at the devicetree generation for the app, or perhpas I had some other file that was breaking it.  I believe I have it working in a way I can use now, thank you!
