Assertion fail on first dfu_target_offset_get() call after FW update
We are using DFU target library with MCUboot (Connect SDK v2.9.0):
uint32_t offset = 0;
dfu_target_mcuboot_set_buf(mcuboot_buf, sizeof(mcuboot_buf));
dfu_target_init(DFU_TARGET_IMAGE_TYPE_MCUBOOT, 0, 0, dfu_target_callback_handler);
dfu_target_offset_get(&offset);
And we are getting assertion fail on first dfu_target_offset_get() call after FW update:
ASSERTION FAIL [handler != ((void *)0)] @ WEST_TOPDIR/zephyr/kernel/work.c:687
On second attempt, after watchdog reboots MCU, everything works fine.
What could cause this issue?
    Thank you for your response.
    We do not want to update FW via Bluetooth. We are updating FW via serial interface using our own protocol. The problem we are facing is assert fail on the first FW boot after update. Our example project demonstrates that assert fail occurs even without FW update procedure. All we have to do is erase entire memory, write fresh image to the memory and upon the first boot assert failure occurs. However this can be reproduced only if BT settings are enabled for reasons unknown to us. Despite the fact our example code does not use any BT functionality. Assert failure upon the first boot is the problem we are trying to resolve.
    Please note in order to successfully build our example project our devicetree overlay file must be included and "use sysbuild" must be set. Please see build configuration picture attached.
    Do you get any issues while running the new image without issue before updating?
    Is it possible to provide a simple project as your real case to reproduce the issue?
    I am not sure if they are the same issue causing the assert or not. There are two Devzone cases (this and this) with the "[handler != ((void *)0)]" assert, but they are caused by different issues. For your upload project, it can be fixed by adding the following code:
    	int err;
    	err = bt_enable(NULL);
    	if (err) {
    		printk("Bluetooth init failed (err %d)\n", err);
    		return 0;
    Here is the test project : assert_fail_updated.7z
    I would suggest you refer to Debugging with addr2line to figure out which file name and line number are associated with the address.
    Could you use the addr2line application to provide the file name and line number of r14/lr and r15/pc?
    -Amanda H.
    Your suggestion helps to eliminate "assert fail" problem in both cases, our example project as well our main project. Thank you.
    In both cases PC points to "ncs/v2.9.0/zephyr/lib/os/assert.c:44" and LR points to "ncs/v2.9.0/zephyr/include/zephyr/spinlock.h:147".
    Yes, it is possible, however it would take considerable amount of time to prepare. As far as we understand, our initial simple example is sufficient for "assert fail" reproduction. As well, it is evident now the problem is about to be resolved. Is there something else on your mind you would like to confirm with additional project example we are not aware of?
    Calling of bt_enable() at the beginning of main() solves assert fail on the first boot. Could you please clarify if calling bt_enable() would not increase power consumption in case we are not using BT functionality?
    In order to be sure of minimum power consumption we call bt_disable() immediately after bt_enable():
    However we found a comment in bluetooth.h file, which states that bt_disable() can only be called after bt_enable has completed:
    Does it mean we should wait for a callback to confirm bt_enable has completed before we call bt_disable() or is it not necessary?
    Besides, is there a clear explanation why bt_enable() solves the "assert fail" upon initial boot problem?
  • In your uploaded project, the assert is caused by CONFIG_BT_SETTINGS=y, and bt_enable() will call bt_settings_init. That fixes the assertion. See this similar post.
    I am a colleague of dairup, working on the bluetooth side of the project. This workaround worked for fixing the assertion, however, we do not intend on using the bluetooth on boot, so we need to disable it. We noticed that calling bt_disable() immediately after bt_enable() causes issues with the bluetooth functionality. bt_enable() has a callback that can be used as an argument, which is suppose to indicate that the bluetooth has been successfully initialized, however, that is not the case. We run in to a problem where immediate disabling of BT does not give enough time for BT ID to initialize, and causes different functionality problems, which are not acceptable. I found a command bt_is_ready(), which, if returned "true", and then disabling bluetooth does not cause any more problems and everything works as intended. However, we would like to avoid holding up our boot sequence by polling for bt_is_ready() to return true. Is there a better way to know whether bluetooth is successfully enabled?
