I am moving my project from SDK 2.6.2 with Adafruit_bootloader to SDK 2.9.0 with MCUboot/sysbuild. The problem I face is that I can't access the external flash using NVS anymore.
Here is my relevant zephyr_code.c, where "user_partition" is declared in the external flash:
#define NVS_PARTITION user_partition #define NVS_PARTITION_DEVICE FIXED_PARTITION_DEVICE(NVS_PARTITION) #define NVS_PARTITION_OFFSET FIXED_PARTITION_OFFSET(NVS_PARTITION) int nvs_init(const uint16_t max_retries) { int rc = 0; struct flash_pages_info info; LOG_INF("NVS init"); fs.flash_device = NVS_PARTITION_DEVICE; if (!device_is_ready(fs.flash_device)) { LOG_ERR("Flash device %s is not ready\n", fs.flash_device->name); return EXIT_FAILURE; } fs.offset = NVS_PARTITION_OFFSET; rc = flash_get_page_info_by_offs(fs.flash_device, fs.offset, &info); if (rc) { LOG_ERR("Unable to get page info\n"); return EXIT_FAILURE; } fs.sector_size = info.size; fs.sector_count = NVS_SECTOR_COUNT; rc = nvs_mount(&fs); return EXIT_SUCCESS; }
The code fails in the following line:
When I inspect it in debugger mode, I can localize the problem to this line of flash_page_layout.c:
The layout retrieved by the driver has 64 pages of 4096 bytes each, which is 0x40000 bytes total, instead of the expected 0x200000 bytes. As a result, the external device's size is assessed shorter than the base address of user_partition and an error is returned.
Here is the output of "west build -t partition_manager_report", for an overview of how I expect my partitions to behave:
external_flash (0x200000 - 2048kB): +---------------------------------------------+ +---0x0: external_flash (0x200000 - 2048kB)---+ | 0x0: mcuboot_secondary (0xf1000 - 964kB) | | 0xf1000: storage_partition (0x10000 - 64kB) | | 0x101000: user_partition (0x10000 - 64kB) | +---------------------------------------------+ flash_primary (0x100000 - 1024kB): +-------------------------------------------------+ | 0x0: mcuboot (0xf000 - 60kB) | +---0xf000: mcuboot_primary (0xee000 - 952kB)-----+ | 0xf000: mcuboot_pad (0x200 - 512B) | +---0xf200: mcuboot_primary_app (0xede00 - 951kB)-+ | 0xf200: app (0xece00 - 947kB) | | 0xfc000: settings_storage (0x2000 - 8kB) | | 0xfe000: internal_storage (0x2000 - 8kB) | +-------------------------------------------------+ sram_primary (0x40000 - 256kB): +--------------------------------------------+ | 0x20000000: sram_primary (0x40000 - 256kB) |
Now this 0x40000 value reminds me of the auto-generated regions.yml file which looks like this:
external_flash: base_address: 0x0 default_driver_kconfig: CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK device: DT_CHOSEN(nordic_pm_ext_flash) dynamic_partition: null name: external_flash placement_strategy: start_to_end size: 0x40000 flash_primary: base_address: 0x0 default_driver_kconfig: CONFIG_SOC_FLASH_NRF device: flash_controller dynamic_partition: null name: flash_primary placement_strategy: complex size: 0x100000 sram_primary: base_address: 0x20000000 default_driver_kconfig: '' device: '' dynamic_partition: sram_primary name: sram_primary placement_strategy: complex size: 0x40000
Here the size of the external_flash region is 0x40000 which is really suspicious. Is this the root of my problem ? If yes, how do I change this value ? The only doc I found is very unclear, or at least I don't manage to change the region size this way.
As additional info, here is the device.overlay I'm using to access the external flash:
&qspi { status = "okay"; pinctrl-0 = <&qspi_default>; pinctrl-1 = <&qspi_sleep>; pinctrl-names = "default", "sleep"; p25q16h: p25q16h@0 { compatible = "nordic,qspi-nor"; reg = <0>; sck-frequency = <104000000>; quad-enable-requirements = "S2B1v1"; jedec-id = [85 60 15]; sfdp-bfp = [ e5 20 f1 ff ff ff ff 00 44 eb 08 6b 08 3b 80 bb ee ff ff ff ff ff 00 ff ff ff 00 ff 0c 20 0f 52 10 d8 08 81 ]; size = <2000000>; has-dpd; t-enter-dpd = <3000>; t-exit-dpd = <8000>; }; };
Thank you for your time !
