Hi folks,
I've been trying to use the sw_pwm to generate two PWM outputs. I'm using sw_pwm because I want to achieve lower frequencies (1-100Hz) and the hardware PWM API only supports lower frequencies up to 4 HZ.
My issue is when I run both channels, the channel 0 stops working while channel 1 still working as we expect.
This is my overlay file:
&pwm0 {
status = "disabled";
&sw_pwm {
status = "okay";
channel-gpios = <&gpio0 30 PWM_POLARITY_NORMAL>, <&gpio0 31 PWM_POLARITY_INVERTED>;
my_pwm_leds {
compatible = "pwm-leds";
pwm_led01: pwm_led_01 {
pwms = <&sw_pwm 0 PWM_MSEC(200) PWM_POLARITY_NORMAL>;
pwm_led02: pwm_led_02 {
pwms = <&sw_pwm 1 PWM_MSEC(100) PWM_POLARITY_INVERTED>;
aliases {
pwm-led01 = &pwm_led01;
pwm-led02 = &pwm_led02;
And this is my app code:
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/pwm.h>
static const struct pwm_dt_spec pwm_led1 = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led01));
static const struct pwm_dt_spec pwm_led2 = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led02));
uint32_t max_period;
printk("PWM-based blinky\n");
if (!pwm_is_ready_dt(&pwm_led1)) {
printk("Error: PWM device %s is not ready\n",
pwm_led1.dev->name);
return 0;
if (!pwm_is_ready_dt(&pwm_led2)) {
pwm_led2.dev->name);
return 0;
max_period = PWM_HZ(10U);
pwm_set_dt(&pwm_led1, max_period, max_period / 2U);
pwm_set_dt(&pwm_led2, max_period, max_period / 2U);
return 0;
Does anyone previously integrated multiple sw_pwm instances? O what other options should I follow to achieve lower frequencies for the pwm output (below to 4Hz)?
Regards!
