Is the mcuboot supposed to be running during application time?
~Using nrf Connect sdk and toolchain at version V2.9.0
Attached is the app.zip project.
0334.app.zip
Basically it consists of a single main funct that prints ("AAAAAAAAAAA") to the screen.
What I've discovered is that during app runtime (when AAAAA ...is being printed to rtt) I can communicate with mcumgr or smpmgr
I want to put another application onto slot 0.
app2.zip
The output of the .bin files is show below
❯ find . -iname "*.bin"
./app/build_sdk_guide/app/zephyr/zephyr.bin
./app/build_sdk_guide/app/zephyr/zephyr.signed.bin
./app/build_sdk_guide/mcuboot/zephyr/zephyr.bin
./app2/build/app2/zephyr/zephyr.bin
Now the question(s) part.
  1. Why is mcuboot running during application runtime?
  2. Can I get it to only run during bootup? In the app dir under the .git logs you can see I have a file called my_defconfig....which is some of the behaviour i wanted during the mcuboot bootup.
  3. When trying to "mcumgr --conntype=serial --connstring='dev=/dev/ttyACM0,baud=115200' image upload $path/app2/zephyr/zyphyr.bin" I am unable to flash it. Using v2.6.1 and a west build command with -DMCUBOOT_OVERLAY_CONFIG we were able to get a app_update.bin generated. This allowed mcumgr to do a firmware update.
  4. Do I need to have mcuboot config info in the app2 build? The plan was to never jtag or nrfproj the chip again. All dfu would be done by uart during bootup, such that we only ever overwrite the slot 0 / app.
    MCUboot does not run after starting the application. What is it you are seeing that indicate that it is? What is the initial proglem you are seeing?
    The application includes MCUmgr with UART transport. This means that images can be transfered when in the application (this is normally how it is done, and always if using transprots like BLE). However, serial transports (UART or USB) are supported both in the app and bootloader, so you can choose one or the other (or both).
    Yes, you need the app_udpate.bin or an update zip that incnludes it. Ths includes the trailer used by the bootloaer holding information like hash, version number, etc. I suggest gooing through Lesson 8 – Bootloaders and DFU/FOTA. You may also find these unofficial samples relevant.
  • Given that the v2.9.0 has moved away from the parent child setup. Where do i place the .conf info as shown in , does the fact I have config_mcumgr_params etc mean that it puts the smp_svr on the app, rather than in the Bootloader as shown in serial_recovery
    Are there any examples of the link using v2.9.0? I'm not sure where to put the my_defconfig (mcuboot.conf) file.
    I'm looking into sysbuild example
    Tak for hjælpen
    You are right that configs and the build procedure is a bit different with sysbuild. You can refer to the smp_svr sample, which has support for sysbuild.
  • Why doesn't this sysbuild example build? I've attached the log.
     *  Executing task: nRF Connect: Generate config ubx_bmd360eval/nrf52811 for /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild
    Building mcuboot_serial_recovery_uart_sysbuild
    west build --build-dir /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild --pristine --board ubx_bmd360eval/nrf52811 -- -DNCS_TOOLCHAIN_VERSION=NONE
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /home/wtr/ncs/toolchains/b77d8c1312/usr/local/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /home/wtr/.cache/zephyr
    -- Board: ubx_bmd360eval, qualifiers: nrf52811
    Parsing /home/wtr/ncs/v2.9.0/zephyr/share/sysbuild/Kconfig
    Loaded configuration '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/_sysbuild/empty.conf'
    Merged configuration '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/sysbuild.conf'
    Configuration saved to '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/zephyr/.config'
    Kconfig header saved to '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: /home/wtr/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Found Python3: /home/wtr/ncs/toolchains/b77d8c1312/usr/local/bin/python (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
    -- Zephyr version: 3.7.99 (/home/wtr/ncs/v2.9.0/zephyr)
    -- Found host-tools: zephyr 0.17.0 (/home/wtr/ncs/toolchains/b77d8c1312/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/home/wtr/ncs/toolchains/b77d8c1312/opt/zephyr-sdk)
    -- Found Dtc: /home/wtr/ncs/toolchains/b77d8c1312/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/wtr/ncs/v2.9.0/zephyr/boards/u-blox/ubx_bmd360eval/ubx_bmd360eval_nrf52811.dts
    -- Found devicetree overlay: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/sysbuild/mcuboot.overlay
    -- Generated zephyr.dts: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr/dts.cmake
    Parsing /home/wtr/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '/home/wtr/ncs/v2.9.0/zephyr/boards/u-blox/ubx_bmd360eval/ubx_bmd360eval_nrf52811_defconfig'
    Merged configuration '/home/wtr/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/sysbuild/mcuboot.conf'
    Merged configuration '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr/.config'
    Kconfig header saved to '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /home/wtr/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /home/wtr/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Setting build type to 'MinSizeRel' as none was specified.
    -- Using ccache: /home/wtr/ncs/toolchains/b77d8c1312/usr/bin/ccache
    CMake Warning at /home/wtr/ncs/v2.9.0/zephyr/CMakeLists.txt:952 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
    MCUBoot bootloader key file: /home/wtr/ncs/v2.9.0/bootloader/mcuboot/root-rsa-2048.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot
       * Running CMake for mcuboot_serial_recovery_uart_sysbuild *
    -- Application: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild
    -- Generated zephyr.dts: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot_serial_recovery_uart_sysbuild/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot_serial_recovery_uart_sysbuild/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot_serial_recovery_uart_sysbuild/zephyr/dts.cmake
    warning: UPDATEABLE_IMAGE_NUMBER (defined at
    /home/wtr/ncs/v2.9.0/nrf/samples/common/mcumgr_bt_ota_dfu/Kconfig:89, subsys/dfu/Kconfig:95) was
    assigned the value '1' but got the value ''. Check these unsatisfied dependencies:
    (((BOARD_THINGY53_NRF5340_CPUAPP || BOARD_THINGY53_NRF5340_CPUAPP_NS) && SOC_SERIES_NRF53X &&
    NCS_SAMPLE_MCUMGR_BT_OTA_DFU) || (!MCUBOOT && IMG_MANAGER)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UPDATEABLE_IMAGE_NUMBER and/or look up
    UPDATEABLE_IMAGE_NUMBER in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: MCUBOOT_UPDATE_FOOTER_SIZE (defined at subsys/dfu/Kconfig:54) was assigned the value
    '0x2000' but got the value ''. Check these unsatisfied dependencies: MCUBOOT_IMG_MANAGER (=n),
    IMG_MANAGER (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE and/or look up
    MCUBOOT_UPDATE_FOOTER_SIZE in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    might be helpful too.
    Parsing /home/wtr/ncs/v2.9.0/zephyr/Kconfig
    Merged configuration '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/prj.conf'
    Merged configuration '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot_serial_recovery_uart_sysbuild/zephyr/.config.sysbuild'
    Configuration saved to '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot_serial_recovery_uart_sysbuild/zephyr/.config'
    Kconfig header saved to '/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot_serial_recovery_uart_sysbuild/zephyr/include/generated/zephyr/autoconf.h'
    -- Including signing script: /home/wtr/ncs/v2.9.0/nrf/cmake/sysbuild/image_signing.cmake
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot_serial_recovery_uart_sysbuild
    CMake Warning at /home/wtr/ncs/v2.9.0/nrf/cmake/sysbuild/partition_manager.cmake:106 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      /home/wtr/ncs/v2.9.0/nrf/cmake/sysbuild/partition_manager.cmake:634 (partition_manager)
      /home/wtr/ncs/v2.9.0/nrf/sysbuild/CMakeLists.txt:703 (include)
      cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
      cmake/modules/sysbuild_images.cmake:23 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:20 (include)
      /home/wtr/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      /home/wtr/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      /home/wtr/ncs/v2.9.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    -- Configuring done
    -- Generating done
    [1/312] Preparing syscall dependency handling
    [7/312] Generating include/generated/zephyr/version.h
    -- Zephyr version: 3.7.99 (/home/wtr/ncs/v2.9.0/zephyr), build: v3.7.99-ncs2
    [307/312] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr/zephyr_pre0.map
    : && ccache /home/wtr/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -Os -DNDEBUG -gdwarf-4 -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf52811/libsoc__nordic.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  modules/mbedtls/libmodules__mbedtls.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  modules/zcbor/libmodules__zcbor.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L/home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr  zephyr/arch/common/libisr_tables.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie -L"/home/wtr/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp" -lc -lgcc && cd /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot/zephyr && /home/wtr/ncs/toolchains/b77d8c1312/usr/local/bin/cmake -E true
    /home/wtr/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `noinit' will not fit in region `RAM'
    /home/wtr/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `RAM' overflowed by 3328 bytes
    collect2: error: ld returned 1 exit status
    [10/20] No configure step for 'mcuboot_serial_recovery_uart_sysbuild'
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cd /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build/mcuboot && /home/wtr/ncs/toolchains/b77d8c1312/usr/local/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /home/wtr/ncs/toolchains/b77d8c1312/usr/local/bin/cmake --build /home/wtr/work/nordicsemi_devzone/samples_for_nrf_connect_sdk/bootloader_samples/serial_recovery/mcuboot_serial_recovery_uart_sysbuild/build
     *  The terminal process terminated with exit code: 1.
    Do i need to change the west build command?
    The buildl og here shows that the RAM overflows:
