i want to commission matter compatible smart switch into thread network.
but i'm getting internal error .
but other device like matter samples light_bulb (nrf52840dk) & light_switch (nrf52840dk) successfully added into thread network.
following txt file shows the error while trying to add smart switch into thread network.
nistantritech@nistantritech-HP-EliteDesk-800-G3-SFF:~/Downloads$ chip-tool pairing ble-thread 0000000000001111 hex:0e08000000000001000000030000144a0300001835060004001fffe00208e46ccccc8c8fb6180708fdf2c4129a0f4a7b05106c76430194504d6adb453b3436a66ac4030f4f70656e5468726561642d663466660102f4ff04101c88f16b2dd34424a5332f873c0a9e800c0402a0f7f8 64814042 597
[1737615319.433] [44082:44082] [DL] ChipLinuxStorage::Init: Using KVS config file: /home/nistantritech/snap/chip-tool/common/chip_tool_kvs
[1737615319.433] [44082:44082] [DL] ChipLinuxStorage::Init: Attempt to re-initialize with KVS config file: /tmp/chip_kvs
[1737615319.435] [44082:44082] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1737615319.435] [44082:44082] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1737615319.435] [44082:44082] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1737615319.443] [44082:44082] [DL] Wrote settings to /tmp/chip_counters.ini
[1737615319.443] [44082:44082] [DL] NVS set: chip-counters/reboot-count = 36 (0x24)
[1737615319.443] [44082:44082] [DL] Got Ethernet interface: eno1
[1737615319.443] [44082:44082] [DL] Found the primary Ethernet interface:eno1
[1737615319.443] [44082:44082] [DL] Got WiFi interface: wlx00e0312d188c
[1737615319.444] [44082:44082] [DL] Found the primary WiFi interface:wlx00e0312d188c
[1737615319.444] [44082:44082] [IN] UDP::Init bind&listen port=0
[1737615319.444] [44082:44082] [IN] UDP::Init bound to port=36207
[1737615319.444] [44082:44082] [IN] UDP::Init bound to port=52032
[1737615319.444] [44082:44082] [IN] BLEBase::Init - setting/overriding transport
[1737615319.444] [44082:44082] [IN] TransportMgr initialized
[1737615319.444] [44082:44082] [FP] Initializing FabricTable from persistent storage
[1737615319.444] [44082:44082] [TS] Last Known Good Time: 2023-10-14T01:16:48
[1737615319.445] [44082:44082] [FP] Fabric index 0x1 was retrieved from storage. Compressed FabricId 0xB9028CB4D190F9C1, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1737615319.445] [44082:44082] [ZCL] Using ZAP configuration...
[1737615319.448] [44082:44082] [IM] WARNING ┌────────────────────────────────────────────────────
[1737615319.448] [44082:44082] [IM] WARNING │ Interaction Model Engine running in 'Checked' mode.
[1737615319.448] [44082:44082] [IM] WARNING │ This executes BOTH ember and data-model code paths.
[1737615319.448] [44082:44082] [IM] WARNING │ which is inefficient and consumes more flash space.
[1737615319.448] [44082:44082] [IM] WARNING │ This should be done for testing only.
[1737615319.448] [44082:44082] [IM] WARNING └────────────────────────────────────────────────────
[1737615319.448] [44082:44082] [CTL] System State Initialized...
[1737615319.448] [44082:44082] [CTL] Setting attestation nonce to random value
[1737615319.448] [44082:44082] [CTL] Setting CSR nonce to random value
[1737615319.448] [44082:44082] [IN] UDP::Init bind&listen port=5550
[1737615319.448] [44082:44082] [IN] UDP::Init bound to port=5550
[1737615319.448] [44082:44082] [IN] TransportMgr initialized
[1737615319.448] [44082:44117] [DL] CHIP task running
[1737615319.448] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 32786
[1737615319.448] [44082:44117] [CTL] Setting attestation nonce to random value
[1737615319.448] [44082:44117] [CTL] Setting CSR nonce to random value
[1737615319.448] [44082:44117] [CTL] Generating NOC
[1737615319.449] [44082:44117] [FP] Validating NOC chain
[1737615319.449] [44082:44117] [FP] NOC chain validation successful
[1737615319.449] [44082:44117] [FP] Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1737615319.449] [44082:44117] [TS] Last Known Good Time: 2023-10-14T01:16:48
[1737615319.449] [44082:44117] [TS] New proposed Last Known Good Time: 2021-01-01T00:00:00
[1737615319.449] [44082:44117] [TS] Retaining current Last Known Good Time
[1737615319.449] [44082:44117] [FP] Metadata for Fabric 0x1 persisted to storage.
[1737615319.450] [44082:44117] [TS] Committing Last Known Good Time to storage: 2023-10-14T01:16:48
[1737615319.450] [44082:44117] [CTL] Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: B9028CB4D190F9C1)
[1737615319.450] [44082:44117] [IN] UDP::Init bind&listen port=5550
[1737615319.450] [44082:44117] [IN] UDP::Init bound to port=5550
[1737615319.450] [44082:44117] [IN] TransportMgr initialized
[1737615319.453] [44082:44117] [CTL] Setting thread operational dataset from parameters
[1737615319.453] [44082:44117] [CTL] Setting attestation nonce to random value
[1737615319.453] [44082:44117] [CTL] Setting CSR nonce to random value
[1737615319.453] [44082:44117] [CTL] Commission called for node ID 0x0000000000000457
[1737615319.458] [44082:44116] [BLE] BLE removing known devices
[1737615319.458] [44082:44116] [BLE] BLE initiating scan
[1737615319.560] [44082:44117] [BLE] ChipDeviceScanner has started scanning!
[1737615319.560] [44082:44117] [DL] Long dispatch time: 107 ms, for event type 3
[1737615319.565] [44082:44116] [BLE] Device 52:AF:1F:BE:27:F7 does not look like a CHIP device.
[1737615319.579] [44082:44116] [BLE] Device 0D:7C:CF:64:22:57 does not look like a CHIP device.
[1737615319.608] [44082:44116] [BLE] Device 4E:7B:B8:02:73:04 does not look like a CHIP device.
[1737615319.611] [44082:44116] [BLE] Device 0F:2C:52:90:45:57 does not look like a CHIP device.
[1737615319.624] [44082:44116] [BLE] Device 66:C6:D2:92:90:C8 does not look like a CHIP device.
[1737615319.642] [44082:44116] [BLE] Device 6A:C6:D7:41:83:A9 does not look like a CHIP device.
[1737615319.649] [44082:44116] [BLE] Device 47:26:40:D8:D3:30 does not look like a CHIP device.
[1737615319.656] [44082:44116] [BLE] Device 04:FE:FC:FB:B7:8C does not look like a CHIP device.
[1737615319.677] [44082:44116] [BLE] New device scanned: C1:83:D7:27:41:CB
[1737615319.677] [44082:44116] [BLE] Device discriminator match. Attempting to connect.
[1737615319.685] [44082:44116] [BLE] ChipDeviceScanner has stopped scanning!
[1737615321.256] [44082:44116] [DL] ConnectDevice complete
[1737615321.256] [44082:44116] [BLE] New device connected: C1:83:D7:27:41:CB
[1737615321.598] [44082:44116] [DL] CHIP service found
[1737615321.598] [44082:44116] [DL] Valid C2 characteristic found
[1737615321.598] [44082:44116] [DL] Valid C1 characteristic found
[1737615321.598] [44082:44116] [DL] New BLE connection: conn=0x7388a001d560 device=C1:83:D7:27:41:CB path=/org/bluez/hci0/dev_C1_83_D7_27_41_CB
[1737615321.598] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16387
[1737615321.598] [44082:44117] [DIS] Closing all BLE connections
[1737615321.598] [44082:44117] [IN] BleConnectionComplete: endPoint 0x60a1e42efba0
[1737615321.598] [44082:44117] [IN] SecureSession[0x7388b0000df0]: Allocated Type:1 LSID:35766
[1737615321.598] [44082:44117] [SC] Assigned local session key ID 35766
[1737615321.598] [44082:44117] [EM] <<< [E:15628i S:0 M:171476972] (U) Msg TX from 22838512BB721A17 to 0:0000000000000000 [0000] [BLE] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
[1737615321.598] [44082:44117] [IN] Message appended to BLE send queue
[1737615321.598] [44082:44117] [SC] Sent PBKDF param request [II:500ms AI:300ms AT:4000ms)
[1737615321.956] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615322.057] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16390
[1737615322.057] [44082:44117] [BLE] subscribe complete, ep = 0x60a1e42efba0
[1737615322.058] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615322.058] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615322.058] [44082:44117] [BLE] peripheral chose BTP version 4; central expected between 4 and 4
[1737615322.058] [44082:44117] [BLE] using BTP fragment sizes rx 244 / tx 244.
[1737615322.058] [44082:44117] [BLE] local and remote recv window size = 5
[1737615322.058] [44082:44117] [IN] BLE EndPoint 0x60a1e42efba0 Connection Complete
[1737615322.155] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615322.159] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615322.160] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615322.160] [44082:44117] [EM] >>> [E:15628i S:0 M:125830913] (U) Msg RX from 0:0000000000000000 [0000] to 22838512BB721A17 --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:151)
[1737615322.160] [44082:44117] [EM] Found matching exchange: 15628i, Delegate: 0x7388b000e3b8
[1737615322.160] [44082:44117] [SC] Received PBKDF param response
[1737615322.160] [44082:44117] [SC] Peer assigned session ID 7740
[1737615322.160] [44082:44117] [SC] Found MRP parameters in the message
[1737615322.179] [44082:44117] [EM] <<< [E:15628i S:0 M:171476973] (U) Msg TX from 22838512BB721A17 to 0:0000000000000000 [0000] [BLE] --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
[1737615322.179] [44082:44117] [SC] Sent spake2p msg1
[1737615322.256] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615322.308] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615322.309] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615322.309] [44082:44117] [EM] >>> [E:15628i S:0 M:125830914] (U) Msg RX from 0:0000000000000000 [0000] to 22838512BB721A17 --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
[1737615322.309] [44082:44117] [EM] Found matching exchange: 15628i, Delegate: 0x7388b000e3b8
[1737615322.309] [44082:44117] [SC] Received spake2p msg2
[1737615322.310] [44082:44117] [EM] <<< [E:15628i S:0 M:171476974] (U) Msg TX from 22838512BB721A17 to 0:0000000000000000 [0000] [BLE] --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
[1737615322.310] [44082:44117] [SC] Sent spake2p msg3
[1737615322.406] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615322.407] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615322.407] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615322.407] [44082:44117] [EM] >>> [E:15628i S:0 M:125830915] (U) Msg RX from 0:0000000000000000 [0000] to 22838512BB721A17 --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
[1737615322.407] [44082:44117] [EM] Found matching exchange: 15628i, Delegate: 0x7388b000e3b8
[1737615322.407] [44082:44117] [SC] SecureSession[0x7388b0000df0, LSID:35766]: State change 'kEstablishing' --> 'kActive'
[1737615322.407] [44082:44117] [IN] SecureSession[0x7388b0000df0]: Activated - Type:1 LSID:35766
[1737615322.407] [44082:44117] [IN] New secure session activated for device <FFFFFFFB00000000, 0>, LSID:35766 PSID:7740!
[1737615322.407] [44082:44117] [CTL] Remote device completed SPAKE2+ handshake
[1737615322.407] [44082:44117] [TOO] Pairing Success
[1737615322.407] [44082:44117] [TOO] PASE establishment successful
[1737615322.407] [44082:44117] [CTL] Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1737615322.407] [44082:44117] [CTL] Performing next commissioning step 'ReadCommissioningInfo'
[1737615322.407] [44082:44117] [CTL] Sending read request for commissioning information
[1737615322.407] [44082:44117] [DMG] SendReadRequest ReadClient[0x7388b0009f60]: Sending Read Request
[1737615322.408] [44082:44117] [DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
[1737615322.408] [44082:44117] [EM] <<< [E:15629i S:35766 M:148821837] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest) (B:131)
[1737615322.408] [44082:44117] [DMG] MoveToState ReadClient[0x7388b0009f60]: Moving to [AwaitingIn]
[1737615322.408] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 32792
[1737615322.506] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615323.412] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615323.413] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615323.507] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615323.507] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615323.507] [44082:44117] [EM] >>> [E:15629i S:35766 M:99421346] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:05 (IM:ReportData) (B:258)
[1737615323.507] [44082:44117] [EM] Found matching exchange: 15629i, Delegate: 0x7388b0009f70
[1737615323.507] [44082:44117] [DMG] ReportDataMessage =
[1737615323.507] [44082:44117] [DMG] {
[1737615323.507] [44082:44117] [DMG] AttributeReportIBs =
[1737615323.507] [44082:44117] [DMG] [
[1737615323.507] [44082:44117] [DMG] AttributeReportIB =
[1737615323.507] [44082:44117] [DMG] AttributeDataIB =
[1737615323.507] [44082:44117] [DMG] DataVersion = 0x40b0ca82,
[1737615323.507] [44082:44117] [DMG] AttributePathIB =
[1737615323.508] [44082:44117] [DMG] Endpoint = 0x0,
[1737615323.508] [44082:44117] [DMG] Cluster = 0x31,
[1737615323.508] [44082:44117] [DMG] Attribute = 0x0000_0003,
[1737615323.508] [44082:44117] [DMG] }
[1737615323.508] [44082:44117] [DMG] Data = 20 (unsigned),
[1737615323.508] [44082:44117] [DMG] },
[1737615323.508] [44082:44117] [DMG] AttributeReportIB =
[1737615323.508] [44082:44117] [DMG] {
[1737615323.508] [44082:44117] [DMG] AttributeDataIB =
[1737615323.508] [44082:44117] [DMG] DataVersion = 0xf098e4b3,
[1737615323.508] [44082:44117] [DMG] AttributePathIB =
[1737615323.508] [44082:44117] [DMG] Cluster = 0x28,
[1737615323.508] [44082:44117] [DMG] Attribute = 0x0000_0004,
[1737615323.508] [44082:44117] [DMG] Data = 4097 (unsigned),
[1737615323.508] [44082:44117] [DMG] Attribute = 0x0000_0002,
[1737615323.508] [44082:44117] [DMG] Data = 5181 (unsigned),
[1737615323.509] [44082:44117] [DMG] {
[1737615323.509] [44082:44117] [DMG] AttributeDataIB =
[1737615323.509] [44082:44117] [DMG] DataVersion = 0x3422f44b,
[1737615323.509] [44082:44117] [DMG] AttributePathIB =
[1737615323.509] [44082:44117] [DMG] Endpoint = 0x0,
[1737615323.509] [44082:44117] [DMG] Cluster = 0x30,
[1737615323.509] [44082:44117] [DMG] Attribute = 0x0000_0003,
[1737615323.509] [44082:44117] [DMG] }
[1737615323.509] [44082:44117] [DMG] Data = 0 (unsigned),
[1737615323.509] [44082:44117] [DMG] },
[1737615323.509] [44082:44117] [DMG] AttributeReportIB =
[1737615323.509] [44082:44117] [DMG] Attribute = 0x0000_0002,
[1737615323.509] [44082:44117] [DMG] Attribute = 0x0000_0001,
[1737615323.510] [44082:44117] [DMG] {
[1737615323.510] [44082:44117] [DMG] 0x0 = 60 (unsigned),
[1737615323.510] [44082:44117] [DMG] 0x1 = 900 (unsigned),
[1737615323.510] [44082:44117] [DMG] },
[1737615323.510] [44082:44117] [DMG] AttributeReportIB =
[1737615323.510] [44082:44117] [DMG] AttributeDataIB =
[1737615323.510] [44082:44117] [DMG] DataVersion = 0x3422f44b,
[1737615323.510] [44082:44117] [DMG] AttributePathIB =
[1737615323.510] [44082:44117] [DMG] Endpoint = 0x0,
[1737615323.510] [44082:44117] [DMG] Cluster = 0x30,
[1737615323.510] [44082:44117] [DMG] Attribute = 0x0000_0000,
[1737615323.510] [44082:44117] [DMG] Data = 0 (unsigned),
[1737615323.510] [44082:44117] [DMG] DataVersion = 0x40b0ca82,
[1737615323.511] [44082:44117] [DMG] {
[1737615323.511] [44082:44117] [DMG] Endpoint = 0x0,
[1737615323.511] [44082:44117] [DMG] Cluster = 0x31,
[1737615323.511] [44082:44117] [DMG] Attribute = 0x0000_FFFC,
[1737615323.511] [44082:44117] [DMG] }
[1737615323.511] [44082:44117] [DMG] Data = 2 (unsigned),
[1737615323.511] [44082:44117] [DMG] },
[1737615323.511] [44082:44117] [DMG] ],
[1737615323.511] [44082:44117] [DMG] SuppressResponse = true,
[1737615323.511] [44082:44117] [DMG] InteractionModelRevision = 1
[1737615323.512] [44082:44117] [CTL] Successfully finished commissioning step 'ReadCommissioningInfo'
[1737615323.512] [44082:44117] [CTL] Commissioning stage next step: 'ReadCommissioningInfo' -> 'ReadCommissioningInfo2'
[1737615323.512] [44082:44117] [CTL] Performing next commissioning step 'ReadCommissioningInfo2'
[1737615323.512] [44082:44117] [DMG] SendReadRequest ReadClient[0x7388b0009f60]: Sending Read Request
[1737615323.512] [44082:44117] [DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
[1737615323.512] [44082:44117] [EM] <<< [E:15630i S:35766 M:148821838] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest) (B:106)
[1737615323.513] [44082:44117] [DMG] MoveToState ReadClient[0x7388b0009f60]: Moving to [AwaitingIn]
[1737615323.606] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615323.657] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615323.658] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615323.658] [44082:44117] [EM] >>> [E:15630i S:35766 M:99421347] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:05 (IM:ReportData) (B:180)
[1737615323.658] [44082:44117] [EM] Found matching exchange: 15630i, Delegate: 0x7388b0009f70
[1737615323.658] [44082:44117] [DMG] ReportDataMessage =
[1737615323.658] [44082:44117] [DMG] {
[1737615323.658] [44082:44117] [DMG] AttributeReportIBs =
[1737615323.658] [44082:44117] [DMG] [
[1737615323.658] [44082:44117] [DMG] AttributeReportIB =
[1737615323.658] [44082:44117] [DMG] AttributeStatusIB =
[1737615323.658] [44082:44117] [DMG] AttributePathIB =
[1737615323.658] [44082:44117] [DMG] Endpoint = 0x0,
[1737615323.658] [44082:44117] [DMG] Cluster = 0x46,
[1737615323.658] [44082:44117] [DMG] Attribute = 0x0000_0002,
[1737615323.658] [44082:44117] [DMG] }
[1737615323.658] [44082:44117] [DMG] StatusIB =
[1737615323.658] [44082:44117] [DMG] status = 0xc3 (UNSUPPORTED_CLUSTER),
[1737615323.658] [44082:44117] [DMG] },
[1737615323.659] [44082:44117] [DMG] {
[1737615323.659] [44082:44117] [DMG] AttributeStatusIB =
[1737615323.659] [44082:44117] [DMG] AttributePathIB =
[1737615323.659] [44082:44117] [DMG] Endpoint = 0x0,
[1737615323.659] [44082:44117] [DMG] Cluster = 0x46,
[1737615323.659] [44082:44117] [DMG] Attribute = 0x0000_0001,
[1737615323.659] [44082:44117] [DMG] }
[1737615323.659] [44082:44117] [DMG] StatusIB =
[1737615323.659] [44082:44117] [DMG] status = 0xc3 (UNSUPPORTED_CLUSTER),
[1737615323.659] [44082:44117] [DMG] },
[1737615323.659] [44082:44117] [DMG] AttributeReportIB =
[1737615323.659] [44082:44117] [DMG] Attribute = 0x0000_0000,
[1737615323.660] [44082:44117] [DMG] Cluster = 0x46,
[1737615323.660] [44082:44117] [DMG] Attribute = 0x0000_0007,
[1737615323.660] [44082:44117] [DMG] }
[1737615323.660] [44082:44117] [DMG] StatusIB =
[1737615323.660] [44082:44117] [DMG] {
[1737615323.660] [44082:44117] [DMG] status = 0xc3 (UNSUPPORTED_CLUSTER),
[1737615323.660] [44082:44117] [DMG] },
[1737615323.660] [44082:44117] [DMG] AttributeReportIB =
[1737615323.660] [44082:44117] [DMG] AttributeStatusIB =
[1737615323.660] [44082:44117] [DMG] AttributePathIB =
[1737615323.660] [44082:44117] [DMG] Endpoint = 0x0,
[1737615323.660] [44082:44117] [DMG] Attribute = 0x0000_0006,
[1737615323.660] [44082:44117] [DMG] AttributeDataIB =
[1737615323.660] [44082:44117] [DMG] DataVersion = 0x3422f44b,
[1737615323.660] [44082:44117] [DMG] Cluster = 0x30,
[1737615323.660] [44082:44117] [DMG] Attribute = 0x0000_0004,
[1737615323.660] [44082:44117] [DMG] Data = true,
[1737615323.661] [44082:44117] [DMG] },
[1737615323.661] [44082:44117] [DMG] ],
[1737615323.661] [44082:44117] [DMG] SuppressResponse = true,
[1737615323.661] [44082:44117] [DMG] InteractionModelRevision = 1
[1737615323.661] [44082:44117] [CTL] ----- NetworkCommissioning Features: has Thread. endpointid = 0
[1737615323.661] [44082:44117] [SVR] OnReadCommissioningInfo - vendorId=0x143D productId=0x1001
[1737615323.662] [44082:44117] [SVR] OnReadCommissioningInfo ICD - IdleModeDuration=0 activeModeDuration=0 activeModeThreshold=0
[1737615323.662] [44082:44117] [CTL] Successfully finished commissioning step 'ReadCommissioningInfo2'
[1737615323.662] [44082:44117] [CTL] Commissioning stage next step: 'ReadCommissioningInfo2' -> 'ArmFailSafe'
[1737615323.662] [44082:44117] [CTL] Performing next commissioning step 'ArmFailSafe'
[1737615323.662] [44082:44117] [CTL] Arming failsafe (60 seconds)
[1737615323.662] [44082:44117] [DMG] ICR moving to [AddingComm]
[1737615323.662] [44082:44117] [DMG] ICR moving to [AddedComma]
[1737615323.662] [44082:44117] [EM] <<< [E:15631i S:35766 M:148821839] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
[1737615323.662] [44082:44117] [DMG] ICR moving to [AwaitingRe]
[1737615323.755] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615323.758] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615323.758] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615323.759] [44082:44117] [EM] >>> [E:15631i S:35766 M:99421348] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1737615323.759] [44082:44117] [EM] Found matching exchange: 15631i, Delegate: 0x7388b000fa08
[1737615323.759] [44082:44117] [DMG] ICR moving to [ResponseRe]
[1737615323.759] [44082:44117] [DMG] InvokeResponseMessage =
[1737615323.759] [44082:44117] [DMG] {
[1737615323.759] [44082:44117] [DMG] suppressResponse = false,
[1737615323.759] [44082:44117] [DMG] InvokeResponseIBs =
[1737615323.759] [44082:44117] [DMG] [
[1737615323.759] [44082:44117] [DMG] InvokeResponseIB =
[1737615323.759] [44082:44117] [DMG] CommandDataIB =
[1737615323.759] [44082:44117] [DMG] CommandPathIB =
[1737615323.759] [44082:44117] [DMG] EndpointId = 0x0,
[1737615323.759] [44082:44117] [DMG] ClusterId = 0x30,
[1737615323.759] [44082:44117] [DMG] CommandId = 0x1,
[1737615323.759] [44082:44117] [DMG] },
[1737615323.759] [44082:44117] [DMG] CommandFields =
[1737615323.759] [44082:44117] [DMG] 0x0 = 0 (unsigned),
[1737615323.759] [44082:44117] [DMG] 0x1 = "" (0 chars),
[1737615323.759] [44082:44117] [DMG] ],
[1737615323.759] [44082:44117] [DMG] InteractionModelRevision = 1
[1737615323.760] [44082:44117] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1737615323.760] [44082:44117] [CTL] Received ArmFailSafe response errorCode=0
[1737615323.760] [44082:44117] [CTL] Successfully finished commissioning step 'ArmFailSafe'
[1737615323.760] [44082:44117] [CTL] Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1737615323.760] [44082:44117] [CTL] Performing next commissioning step 'ConfigRegulatory'
[1737615323.760] [44082:44117] [CTL] Setting Regulatory Config
[1737615323.760] [44082:44117] [CTL] Device does not support configurable regulatory location
[1737615323.760] [44082:44117] [DMG] ICR moving to [AddingComm]
[1737615323.760] [44082:44117] [DMG] ICR moving to [AddedComma]
[1737615323.760] [44082:44117] [EM] <<< [E:15632i S:35766 M:148821840] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:70)
[1737615323.760] [44082:44117] [DMG] ICR moving to [AwaitingRe]
[1737615323.760] [44082:44117] [DMG] ICR moving to [AwaitingDe]
[1737615323.856] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615323.858] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615323.859] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615323.859] [44082:44117] [EM] >>> [E:15632i S:35766 M:99421349] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1737615323.859] [44082:44117] [EM] Found matching exchange: 15632i, Delegate: 0x7388b0002c58
[1737615323.859] [44082:44117] [DMG] ICR moving to [ResponseRe]
[1737615323.859] [44082:44117] [DMG] InvokeResponseMessage =
[1737615323.859] [44082:44117] [DMG] {
[1737615323.859] [44082:44117] [DMG] suppressResponse = false,
[1737615323.859] [44082:44117] [DMG] InvokeResponseIBs =
[1737615323.859] [44082:44117] [DMG] [
[1737615323.859] [44082:44117] [DMG] InvokeResponseIB =
[1737615323.859] [44082:44117] [DMG] CommandDataIB =
[1737615323.859] [44082:44117] [DMG] CommandPathIB =
[1737615323.859] [44082:44117] [DMG] EndpointId = 0x0,
[1737615323.859] [44082:44117] [DMG] ClusterId = 0x30,
[1737615323.859] [44082:44117] [DMG] CommandId = 0x3,
[1737615323.859] [44082:44117] [DMG] },
[1737615323.859] [44082:44117] [DMG] CommandFields =
[1737615323.859] [44082:44117] [DMG] 0x0 = 0 (unsigned),
[1737615323.859] [44082:44117] [DMG] 0x1 = "" (0 chars),
[1737615323.859] [44082:44117] [DMG] ],
[1737615323.859] [44082:44117] [DMG] InteractionModelRevision = 1
[1737615323.860] [44082:44117] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1737615323.860] [44082:44117] [CTL] Received SetRegulatoryConfig response errorCode=0
[1737615323.860] [44082:44117] [CTL] Successfully finished commissioning step 'ConfigRegulatory'
[1737615323.860] [44082:44117] [CTL] Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
[1737615323.860] [44082:44117] [CTL] Performing next commissioning step 'SendPAICertificateRequest'
[1737615323.860] [44082:44117] [CTL] Sending request for PAI certificate
[1737615323.860] [44082:44117] [CTL] Sending Certificate Chain request to 0x7388b000e360 device
[1737615323.860] [44082:44117] [DMG] ICR moving to [AddingComm]
[1737615323.860] [44082:44117] [DMG] ICR moving to [AddedComma]
[1737615323.860] [44082:44117] [EM] <<< [E:15633i S:35766 M:148821841] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
[1737615323.860] [44082:44117] [DMG] ICR moving to [AwaitingRe]
[1737615323.860] [44082:44117] [DMG] ICR moving to [AwaitingDe]
[1737615323.955] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615323.961] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615323.961] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.061] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615324.061] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.157] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615324.157] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.157] [44082:44117] [EM] >>> [E:15633i S:35766 M:99421350] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:595)
[1737615324.157] [44082:44117] [EM] Found matching exchange: 15633i, Delegate: 0x7388b000fa08
[1737615324.157] [44082:44117] [DMG] ICR moving to [ResponseRe]
[1737615324.157] [44082:44117] [DMG] InvokeResponseMessage =
[1737615324.157] [44082:44117] [DMG] {
[1737615324.157] [44082:44117] [DMG] suppressResponse = false,
[1737615324.157] [44082:44117] [DMG] InvokeResponseIBs =
[1737615324.157] [44082:44117] [DMG] [
[1737615324.157] [44082:44117] [DMG] InvokeResponseIB =
[1737615324.157] [44082:44117] [DMG] CommandDataIB =
[1737615324.157] [44082:44117] [DMG] CommandPathIB =
[1737615324.157] [44082:44117] [DMG] EndpointId = 0x0,
[1737615324.157] [44082:44117] [DMG] ClusterId = 0x3e,
[1737615324.157] [44082:44117] [DMG] CommandId = 0x3,
[1737615324.157] [44082:44117] [DMG] },
[1737615324.157] [44082:44117] [DMG] CommandFields =
[1737615324.157] [44082:44117] [DMG] 0x0 = [
[1737615324.157] [44082:44117] [DMG] 0x30, 0x82, 0x02, 0x0f, 0x30, 0x82, 0x01, 0xb4, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x10, 0x02, 0x4e, 0xcb, 0xef, 0x9f, 0x14, 0xa0, 0x2b, 0x9c, 0x29, 0x69, 0x5c, 0xfe, 0x41, 0x0a, 0x29, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x51, 0x31, 0x1d, 0x30, 0x1b, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x14, 0x45, 0x73, 0x70, 0x72, 0x65, 0x73, 0x73, 0x69, 0x66, 0x20, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x50, 0x41, 0x41, 0x31, 0x1a, 0x30, 0x18, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x11, 0x45, 0x73, 0x70, 0x72, 0x65, 0x73, 0x73, 0x69, 0x66, 0x20, 0x53, 0x79, 0x73, 0x74, 0x65, 0x6d, 0x73, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x33, 0x31, 0x42, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x31, 0x31, 0x33, 0x30, 0x30, 0x35, 0x32, 0x35, 0x32, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x57, 0x31, 0x23, 0x30, 0x21, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1a, 0x45, 0x73, 0x70, 0x72, 0x65, 0x73, 0x73, 0x69, 0x66, 0x20, 0x50, 0x41, 0x49, 0x20, 0x32, 0x30, 0x32, 0x32, 0x31, 0x31, 0x33, 0x30, 0x31, 0x30, 0x31, 0x38, 0x31, 0x1a, 0x30, 0x18, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x11, 0x45, 0x73, 0x70, 0x72, 0x65, 0x73, 0x73, 0x69, 0x66, 0x20, 0x53, 0x79, 0x73, 0x74, 0x65, 0x6d, 0x73, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x33, 0x31, 0x42, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x1f, 0xa5, 0xa2, 0x75, 0x77, 0xf3, 0x65, 0x
[1737615324.157] [44082:44117] [DMG] ] (531 bytes)
[1737615324.157] [44082:44117] [DMG] ],
[1737615324.157] [44082:44117] [DMG] InteractionModelRevision = 1
[1737615324.157] [44082:44117] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1737615324.157] [44082:44117] [CTL] Received certificate chain from the device
[1737615324.157] [44082:44117] [CTL] Successfully finished commissioning step 'SendPAICertificateRequest'
[1737615324.158] [44082:44117] [CTL] Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1737615324.158] [44082:44117] [CTL] Performing next commissioning step 'SendDACCertificateRequest'
[1737615324.158] [44082:44117] [CTL] Sending request for DAC certificate
[1737615324.158] [44082:44117] [CTL] Sending Certificate Chain request to 0x7388b000e360 device
[1737615324.158] [44082:44117] [DMG] ICR moving to [AddingComm]
[1737615324.158] [44082:44117] [DMG] ICR moving to [AddedComma]
[1737615324.158] [44082:44117] [EM] <<< [E:15634i S:35766 M:148821842] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
[1737615324.158] [44082:44117] [DMG] ICR moving to [AwaitingRe]
[1737615324.158] [44082:44117] [DMG] ICR moving to [AwaitingDe]
[1737615324.255] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615324.261] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615324.261] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.361] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615324.361] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.457] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615324.457] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.457] [44082:44117] [EM] >>> [E:15634i S:35766 M:99421351] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:620)
[1737615324.457] [44082:44117] [EM] Found matching exchange: 15634i, Delegate: 0x7388b0002c58
[1737615324.458] [44082:44117] [DMG] ICR moving to [ResponseRe]
[1737615324.458] [44082:44117] [DMG] InvokeResponseMessage =
[1737615324.458] [44082:44117] [DMG] {
[1737615324.458] [44082:44117] [DMG] suppressResponse = false,
[1737615324.458] [44082:44117] [DMG] InvokeResponseIBs =
[1737615324.458] [44082:44117] [DMG] [
[1737615324.458] [44082:44117] [DMG] InvokeResponseIB =
[1737615324.458] [44082:44117] [DMG] CommandDataIB =
[1737615324.458] [44082:44117] [DMG] CommandPathIB =
[1737615324.458] [44082:44117] [DMG] EndpointId = 0x0,
[1737615324.458] [44082:44117] [DMG] ClusterId = 0x3e,
[1737615324.458] [44082:44117] [DMG] CommandId = 0x3,
[1737615324.458] [44082:44117] [DMG] },
[1737615324.458] [44082:44117] [DMG] CommandFields =
[1737615324.458] [44082:44117] [DMG] 0x0 = [
[1737615324.458] [44082:44117] [DMG] 0x30, 0x82, 0x02, 0x28, 0x30, 0x82, 0x01, 0xce, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x10, 0x78, 0x43, 0x05, 0x00, 0xf5, 0x03, 0xd8, 0xbf, 0x35, 0x0e, 0x5f, 0x3e, 0xf4, 0x30, 0x68, 0x50, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x57, 0x31, 0x23, 0x30, 0x21, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1a, 0x45, 0x73, 0x70, 0x72, 0x65, 0x73, 0x73, 0x69, 0x66, 0x20, 0x50, 0x41, 0x49, 0x20, 0x32, 0x30, 0x32, 0x32, 0x31, 0x31, 0x33, 0x30, 0x31, 0x30, 0x31, 0x38, 0x31, 0x1a, 0x30, 0x18, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x11, 0x45, 0x73, 0x70, 0x72, 0x65, 0x73, 0x73, 0x69, 0x66, 0x20, 0x53, 0x79, 0x73, 0x74, 0x65, 0x6d, 0x73, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x33, 0x31, 0x42, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x33, 0x30, 0x37, 0x32, 0x30, 0x31, 0x37, 0x34, 0x34, 0x31, 0x34, 0x5a, 0x18, 0x0f, 0x32, 0x31, 0x32, 0x33, 0x30, 0x37, 0x32, 0x30, 0x31, 0x38, 0x34, 0x34, 0x31, 0x34, 0x5a, 0x30, 0x5b, 0x31, 0x2d, 0x30, 0x2b, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x24, 0x33, 0x33, 0x33, 0x35, 0x61, 0x31, 0x61, 0x62, 0x2d, 0x39, 0x36, 0x31, 0x64, 0x2d, 0x34, 0x30, 0x32, 0x66, 0x2d, 0x39, 0x66, 0x66, 0x62, 0x2d, 0x37, 0x63, 0x61, 0x37, 0x61, 0x39, 0x31, 0x63, 0x33, 0x63, 0x61, 0x35, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x33, 0x31, 0x42, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x38, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x
[1737615324.458] [44082:44117] [DMG] ] (556 bytes)
[1737615324.458] [44082:44117] [DMG] ],
[1737615324.458] [44082:44117] [DMG] InteractionModelRevision = 1
[1737615324.458] [44082:44117] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1737615324.458] [44082:44117] [CTL] Received certificate chain from the device
[1737615324.458] [44082:44117] [CTL] Successfully finished commissioning step 'SendDACCertificateRequest'
[1737615324.458] [44082:44117] [CTL] Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1737615324.458] [44082:44117] [CTL] Performing next commissioning step 'SendAttestationRequest'
[1737615324.458] [44082:44117] [CTL] Sending Attestation Request to the device.
[1737615324.458] [44082:44117] [CTL] Sending Attestation request to 0x7388b000e360 device
[1737615324.458] [44082:44117] [DMG] ICR moving to [AddingComm]
[1737615324.458] [44082:44117] [DMG] ICR moving to [AddedComma]
[1737615324.458] [44082:44117] [EM] <<< [E:15635i S:35766 M:148821843] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:94)
[1737615324.458] [44082:44117] [DMG] ICR moving to [AwaitingRe]
[1737615324.458] [44082:44117] [CTL] Sent Attestation request, waiting for the Attestation Information
[1737615324.458] [44082:44117] [DMG] ICR moving to [AwaitingDe]
[1737615324.555] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615324.561] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615324.561] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.659] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615324.659] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.659] [44082:44117] [EM] >>> [E:15635i S:35766 M:99421352] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:417)
[1737615324.659] [44082:44117] [EM] Found matching exchange: 15635i, Delegate: 0x7388b000fa08
[1737615324.659] [44082:44117] [DMG] ICR moving to [ResponseRe]
[1737615324.659] [44082:44117] [DMG] InvokeResponseMessage =
[1737615324.659] [44082:44117] [DMG] {
[1737615324.659] [44082:44117] [DMG] suppressResponse = false,
[1737615324.659] [44082:44117] [DMG] InvokeResponseIBs =
[1737615324.659] [44082:44117] [DMG] [
[1737615324.659] [44082:44117] [DMG] InvokeResponseIB =
[1737615324.659] [44082:44117] [DMG] CommandDataIB =
[1737615324.659] [44082:44117] [DMG] CommandPathIB =
[1737615324.659] [44082:44117] [DMG] EndpointId = 0x0,
[1737615324.659] [44082:44117] [DMG] ClusterId = 0x3e,
[1737615324.659] [44082:44117] [DMG] CommandId = 0x1,
[1737615324.659] [44082:44117] [DMG] },
[1737615324.659] [44082:44117] [DMG] CommandFields =
[1737615324.659] [44082:44117] [DMG] 0x0 = [
[1737615324.659] [44082:44117] [DMG] 0x15, 0x30, 0x01, 0xf3, 0x30, 0x81, 0xf0, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x81, 0xe2, 0x30, 0x81, 0xdf, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x4c, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x3f, 0x04, 0x3d, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0x3d, 0x14, 0x36, 0x02, 0x05, 0x01, 0x10, 0x18, 0x25, 0x03, 0x0a, 0x01, 0x2c, 0x04, 0x13, 0x43, 0x53, 0x41, 0x32, 0x33, 0x35, 0x38, 0x37, 0x4d, 0x41, 0x54, 0x34, 0x31, 0x31, 0x30, 0x30, 0x2d, 0x32, 0x34, 0x24, 0x05, 0x00, 0x24, 0x06, 0x00, 0x24, 0x07, 0x01, 0x24, 0x08, 0x02, 0x25, 0x09, 0x1b, 0x13, 0x25, 0x0a, 0x08, 0x80, 0x18, 0x31, 0x7d, 0x30, 0x7b, 0x02, 0x01, 0x03, 0x80, 0x14, 0x47, 0x10, 0x35, 0xe7, 0xc0, 0x4e, 0xaa, 0xa8, 0xbe, 0x7c, 0x4d, 0x4c, 0x13, 0xe3, 0xe4, 0xc2, 0x09, 0x95, 0xa8, 0x4b, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x04, 0x47, 0x30, 0x45, 0x02, 0x20, 0x3b, 0x4a, 0x32, 0xb6, 0x17, 0xec, 0x1c, 0x98, 0x22, 0xec, 0x4f, 0x0d, 0xf5, 0xa5, 0xc4, 0x43, 0xff, 0x2c, 0x5b, 0x45, 0x91, 0xc5, 0xa6, 0xb4, 0x41, 0x3a, 0x60, 0x3f, 0x32, 0x85, 0xa8, 0xf7, 0x02, 0x21, 0x00, 0x98, 0xb8, 0x5b, 0xfe, 0x82, 0xf3, 0xd6, 0xf9, 0x43, 0xb1, 0xe2, 0xd4, 0x99, 0xbf, 0xaa, 0x53, 0x56, 0x7d, 0x2d, 0xde, 0x20, 0x6f, 0xe5, 0xbe, 0xe1, 0x76, 0xb9, 0x9a, 0x2e, 0x7b, 0xc3, 0x86, 0x30, 0x02, 0x20, 0xb1, 0xa9, 0x2e, 0xeb, 0xc2, 0xd9, 0xe2, 0x16, 0xfd, 0x0e, 0x70, 0x35, 0x0a, 0x22, 0x14, 0xd3, 0x2d, 0x85, 0xd5, 0xa0, 0x64, 0x2f, 0x1b, 0xca, 0x99, 0xe8, 0x06, 0xfb, 0x8c, 0xb3, 0xd7, 0x8d, 0x24, 0x
[1737615324.659] [44082:44117] [DMG] ] (286 bytes)
[1737615324.659] [44082:44117] [DMG] 0x1 = [
[1737615324.659] [44082:44117] [DMG] 0xd0, 0x14, 0x6b, 0x1f, 0x52, 0x51, 0x8c, 0xa4, 0x7e, 0xa9, 0x03, 0x9a, 0x3c, 0x0e, 0x64, 0xfc, 0xf4, 0x00, 0x75, 0xe2, 0xb5, 0x31, 0x70, 0x13, 0xe0, 0xfe, 0xfa, 0xa2, 0xef, 0xef, 0xe8, 0x0e, 0x89, 0x56, 0xb5, 0xa4, 0x0b, 0x12, 0x3a, 0x27, 0x55, 0xf9, 0x78, 0x43, 0x3b, 0xda, 0x48, 0x18, 0x4c, 0xcd, 0x94, 0x21, 0x1f, 0x72, 0x72, 0x32, 0x79, 0x1c, 0xad, 0xa2, 0x1b, 0xdf, 0xa5, 0x6a,
[1737615324.659] [44082:44117] [DMG] ] (64 bytes)
[1737615324.660] [44082:44117] [DMG]
[1737615324.660] [44082:44117] [DMG] ],
[1737615324.660] [44082:44117] [DMG] InteractionModelRevision = 1
[1737615324.660] [44082:44117] [DMG] },
[1737615324.660] [44082:44117] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1737615324.660] [44082:44117] [CTL] Received Attestation Information from the device
[1737615324.660] [44082:44117] [CTL] Successfully finished commissioning step 'SendAttestationRequest'
[1737615324.660] [44082:44117] [CTL] AutoCommissioner setting attestationElements buffer size 286/286
[1737615324.660] [44082:44117] [CTL] Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1737615324.660] [44082:44117] [CTL] Performing next commissioning step 'AttestationVerification'
[1737615324.660] [44082:44117] [CTL] Verifying attestation
[1737615324.667] [44082:44117] [CTL] Error on commissioning step 'AttestationVerification': 'src/controller/CHIPDeviceController.cpp:1283: CHIP Error 0x000000AC: Internal error'
[1737615324.667] [44082:44117] [CTL] Failed verifying attestation information. Now checking DAC chain revoked status.
[1737615324.667] [44082:44117] [CTL] Commissioning stage next step: 'AttestationVerification' -> 'AttestationRevocationCheck'
[1737615324.667] [44082:44117] [CTL] Performing next commissioning step 'AttestationRevocationCheck' with completion status = 'src/controller/CHIPDeviceController.cpp:1283: CHIP Error 0x000000AC: Internal error'
[1737615324.667] [44082:44117] [CTL] Verifying device's DAC chain revocation status
[1737615324.667] [44082:44117] [CTL] Failed in verifying 'Attestation Information' command received from the device: err 101. Look at AttestationVerificationResult enum to understand the errors
[1737615324.667] [44082:44117] [CTL] Error on commissioning step 'AttestationRevocationCheck': 'src/controller/CHIPDeviceController.cpp:1332: CHIP Error 0x000000AC: Internal error'
[1737615324.667] [44082:44117] [CTL] Going from commissioning step 'AttestationRevocationCheck' with lastErr = 'src/controller/CHIPDeviceController.cpp:1332: CHIP Error 0x000000AC: Internal error' -> 'Cleanup'
[1737615324.667] [44082:44117] [CTL] Performing next commissioning step 'Cleanup' with completion status = 'src/controller/CHIPDeviceController.cpp:1332: CHIP Error 0x000000AC: Internal error'
[1737615324.667] [44082:44117] [CTL] Disarming failsafe on device 0x7388b000e360
[1737615324.667] [44082:44117] [DMG] ICR moving to [AddingComm]
[1737615324.667] [44082:44117] [DMG] ICR moving to [AddedComma]
[1737615324.667] [44082:44117] [EM] <<< [E:15636i S:35766 M:148821844] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
[1737615324.667] [44082:44117] [DMG] ICR moving to [AwaitingRe]
[1737615324.667] [44082:44117] [DMG] ICR moving to [AwaitingDe]
[1737615324.755] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16389
[1737615324.757] [44082:44116] [DL] Indication received, conn = 0x7388a001d560
[1737615324.757] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16391
[1737615324.757] [44082:44117] [EM] >>> [E:15636i S:35766 M:99421353] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
[1737615324.757] [44082:44117] [EM] Found matching exchange: 15636i, Delegate: 0x7388b0002c58
[1737615324.757] [44082:44117] [DMG] ICR moving to [ResponseRe]
[1737615324.757] [44082:44117] [DMG] InvokeResponseMessage =
[1737615324.757] [44082:44117] [DMG] {
[1737615324.757] [44082:44117] [DMG] suppressResponse = false,
[1737615324.757] [44082:44117] [DMG] InvokeResponseIBs =
[1737615324.757] [44082:44117] [DMG] [
[1737615324.757] [44082:44117] [DMG] InvokeResponseIB =
[1737615324.757] [44082:44117] [DMG] CommandDataIB =
[1737615324.757] [44082:44117] [DMG] CommandPathIB =
[1737615324.757] [44082:44117] [DMG] EndpointId = 0x0,
[1737615324.757] [44082:44117] [DMG] ClusterId = 0x30,
[1737615324.757] [44082:44117] [DMG] CommandId = 0x1,
[1737615324.757] [44082:44117] [DMG] },
[1737615324.757] [44082:44117] [DMG] CommandFields =
[1737615324.757] [44082:44117] [DMG] 0x0 = 0 (unsigned),
[1737615324.757] [44082:44117] [DMG] 0x1 = "" (0 chars),
[1737615324.757] [44082:44117] [DMG] ],
[1737615324.757] [44082:44117] [DMG] InteractionModelRevision = 1
[1737615324.757] [44082:44117] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1737615324.757] [44082:44117] [CTL] Failsafe disarmed
[1737615324.757] [44082:44117] [CTL] Successfully finished commissioning step 'Cleanup'
[1737615324.757] [44082:44117] [DIS] Closing all BLE connections
[1737615324.757] [44082:44117] [IN] Clearing BLE pending packets.
[1737615324.757] [44082:44117] [BLE] Auto-closing end point's BLE connection.
[1737615324.757] [44082:44117] [DL] Closing BLE GATT connection (con 0x7388a001d560)
[1737615324.757] [44082:44116] [DL] Close BLE connection: peer=C1:83:D7:27:41:CB
[1737615327.405] [44082:44117] [IN] SecureSession[0x7388b0000df0]: MarkForEviction Type:1 LSID:35766
[1737615327.405] [44082:44117] [SC] SecureSession[0x7388b0000df0, LSID:35766]: State change 'kActive' --> 'kPendingEviction'
[1737615327.406] [44082:44117] [CTL] Commissioning complete for node ID 0x0000000000000457: src/controller/CHIPDeviceController.cpp:1332: CHIP Error 0x000000AC: Internal error
[1737615327.406] [44082:44117] [TOO] Device commissioning Failure: src/controller/CHIPDeviceController.cpp:1332: CHIP Error 0x000000AC: Internal error
[1737615327.406] [44082:44117] [DMG] ICR moving to [AwaitingDe]
[1737615327.406] [44082:44117] [IN] SecureSession[0x7388b0000df0]: Released - Type:1 LSID:35766
[1737615327.406] [44082:44117] [DL] Long dispatch time: 2649 ms, for event type 16391
[1737615327.406] [44082:44117] [DL] HandlePlatformSpecificBLEEvent 16390
[1737615327.406] [44082:44117] [BLE] No endpoint for unsubscribe complete
[1737615327.406] [44082:44082] [CTL] Shutting down the commissioner
[1737615327.406] [44082:44082] [CTL] Shutting down the controller
[1737615327.406] [44082:44082] [IN] Expiring all sessions for fabric 0x1!!
[1737615327.406] [44082:44082] [FP] Forgetting fabric 0x1
[1737615327.407] [44082:44082] [TS] Pending Last Known Good Time: 2023-10-14T01:16:48
[1737615327.407] [44082:44082] [TS] Previous Last Known Good Time: 2023-10-14T01:16:48
[1737615327.407] [44082:44082] [TS] Reverted Last Known Good Time to previous value
[1737615327.407] [44082:44082] [CTL] Shutting down the commissioner
[1737615327.407] [44082:44116] [DL] BLE connection closed: conn=0x7388a001d560
[1737615327.407] [44082:44082] [CTL] Shutting down the controller
[1737615327.407] [44082:44082] [CTL] Shutting down the System State, this will teardown the CHIP Stack
[1737615327.407] [44082:44082] [DMG] All ReadHandler-s are clean, clear GlobalDirtySet
[1737615327.408] [44082:44082] [FP] Shutting down FabricTable
[1737615327.408] [44082:44082] [TS] Pending Last Known Good Time: 2023-10-14T01:16:48
[1737615327.408] [44082:44082] [TS] Previous Last Known Good Time: 2023-10-14T01:16:48
[1737615327.408] [44082:44082] [TS] Reverted Last Known Good Time to previous value
[1737615327.416] [44082:44082] [DL] Wrote settings to /tmp/chip_counters.ini
[1737615327.416] [44082:44082] [DL] NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1737615327.416] [44082:44082] [DL] Inet Layer shutdown
[1737615327.416] [44082:44082] [DL] BLE Layer shutdown
[1737615327.417] [44082:44082] [DL] System Layer shutdown
[1737615327.418] [44082:44082] [TOO] Run command failure: src/controller/CHIPDeviceController.cpp:1332: CHIP Error 0x000000AC: Internal error
Post
