I recently updated from NCS 2.6.0 to NCS 2.9.0 which had lots of changes. I believe I ported from child_image to sysbuild with success, as my main application on app core of nrf5340 custom board boots normally over MCUboot, and network core has b0n + hci_ipc and also seems to boot since I see that the controller responds to the first HCI commands sent by the host (versions. manufacturer etc...) I seemed to have adapted to also any HCI device tree changes for both cpuapp and cpunet.dts, as everything compiles, boots, and BLE host seem to be able to communicate with controller over HCI IPC.
The issue I've noticed is that in hci_core.c, there is a net_buf pool of size 10 (CONFIG_BT_BUF_CMD_TX_COUNT) that gets full and then the next attempt to allocate a net_buf fails. I tracked it down and it seems that there is a net_buf leak issue that the net_buf ref count never reaches 0 when bt_hci_cmd_send_sync() is called to send the commands, so after 10 calls of it in the HCI initialization, it blocks forever since K_FOREVER is used as timeout when not called for sysworkq.
Some details :
- bt_enable() is called with NULL as callback to execute it in synchronous manner (and not from sysworkq)
- I have a sysbuild/hci_ipc.conf file correctly picked by build system with these flags ->
CONFIG_BT_CTLR=y CONFIG_BT_CTLR_ADV_EXT=n # Check that CONFIG_BT_EXT_ADV is enabled in Host if this is enabled CONFIG_BT_CTLR_CONN_RSSI=y CONFIG_BT_CTLR_DATA_LENGTH_MAX=251 CONFIG_BT_BUF_ACL_RX_SIZE=502 CONFIG_BT_BUF_ACL_TX_SIZE=502 CONFIG_BT_MAX_CONN=1 CONFIG_MBOX_NRFX_IPC=y
And here is BT related flags in my prj.conf file :
CONFIG_BT=y CONFIG_BT_LOG_LEVEL_ERR=y CONFIG_BT_SMP=y CONFIG_BT_SIGNING=n CONFIG_BT_PERIPHERAL=y CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24 CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40 CONFIG_BT_PERIPHERAL_PREF_LATENCY=0 CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=600 CONFIG_BT_CENTRAL=n CONFIG_BT_ATT_PREPARE_COUNT=5 CONFIG_BT_BAS=y CONFIG_BT_DEVICE_NAME_DYNAMIC=y CONFIG_BT_DEVICE_NAME_MAX=65 CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=n CONFIG_BT_MAX_PAIRED=1 CONFIG_BT_KEYS_OVERWRITE_OLDEST=y CONFIG_BT_PRIVACY=n CONFIG_BT_MAX_CONN=1 CONFIG_BT_BUF_ACL_RX_SIZE=502 CONFIG_BT_BUF_ACL_TX_SIZE=502 CONFIG_BT_L2CAP_TX_MTU=498 CONFIG_BT_L2CAP_TX_BUF_COUNT=10 CONFIG_BT_EXT_ADV=n CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=100 CONFIG_BT_GATT_CLIENT=y CONFIG_BT_GATT_AUTO_SEC_REQ=n # Android is not able to handle this CONFIG_BT_AUTO_PHY_UPDATE=n # Let central initiate PHY update CONFIG_SETTINGS=y CONFIG_BT_SETTINGS=y CONFIG_SETTINGS_NVS=y
And finally, Kconfig.sysbuild flags for n5340 based devices :
if SOC_SERIES_NRF53X config DFU_MULTI_IMAGE_PACKAGE_NET default y config SECURE_BOOT_NETCORE default y config NETCORE_APP_UPDATE default y config MCUBOOT_UPDATEABLE_IMAGES default 2 choice MCUBOOT_MODE default MCUBOOT_MODE_OVERWRITE_ONLY endchoice endif # SOC_SERIES_NRF53X endif # BOOTLOADER_MCUBOOT if SOC_SERIES_NRF53X choice NETCORE default NETCORE_HCI_IPC endchoice endif # SOC_SERIES_NRF53X
I have zephyr,bt-hci = &bt_hci_ipc0; in the cpuapp DTS file and zephyr,bt-hci-ipc = &ipc0; in the cpunet DTS as chosen properties, as the nrf5340dk does.
Any help would be much appreciated.
Jimmy
