K_sleep from main function
It seems like my system is crushing before going to deep sleep,
I have noticed that if I remove a k_sleep of 500 ms, just before going to deep sleep the system does not crush.
I was wondering if it is allowed to call k_sleep from main function. I know in other rtos is is not allowed since main is not running in a thread context. I would like to know if this the case in zephyr as well
    I have found the root cause, it was a bug in our code,
    Thank you for your support,
  • It's great that you have it working. Records about that warning message is pretty scarce, so if you can, please share what you have found with the community.
  • The process of shutting down the system (entering deep sleep):
    enter_deep_sleep:
        if (exit_reason != SYSTEM_EXIT_CODE_RESTART_REQUIRED) {
            LOG_WRN("entering deep sleep ...");
            if (IS_ENABLED(CONFIG_APP_HAL_REGULATOR)) {
                hal_regulator_exit();
    #if DT_NODE_HAS_STATUS(DT_INST(0, nordic_qspi_nor), okay)
            const struct device *const qspi_device = DEVICE_DT_GET(DT_INST(0, nordic_qspi_nor));
            if (device_is_ready(qspi_device)) {
                if (pm_device_action_run(qspi_device, PM_DEVICE_ACTION_SUSPEND) < 0) {
                    LOG_WRN("could not suspend nordic qspi");
            if (IS_ENABLED(CONFIG_I2C)) {
                const struct device *const i2c_device = DEVICE_DT_GET(DT_NODELABEL(i2c1));
                if (device_is_ready(i2c_device)) {
                    if (pm_device_action_run(i2c_device, PM_DEVICE_ACTION_SUSPEND) < 0) {
                        LOG_WRN("could not suspend i2c1");
            if (IS_ENABLED(CONFIG_SERIAL)) {
                const struct device *const serial_device = DEVICE_DT_GET(DT_CHOSEN(zephyr_console));
                if (device_is_ready(serial_device)) {
                    if (pm_device_action_run(serial_device, PM_DEVICE_ACTION_SUSPEND) < 0) {
                        LOG_WRN("could not suspend serial console");
            /* put the system in deep sleep */
            k_sleep(K_MSEC(500));
            sys_poweroff();
    1. suspending QSPI
    2. 500 ms delay
    3. another task tries to write to flash (using QSPI) - causing a crush
    I have moved the delay to be before suspending the QSPI and problem solved
