Cellular monitor, Thiny 91, Failed to connect to port
2025-01-24T09:34:33.711Z INFO Initialising the bundled nrfutil device
2025-01-24T09:34:33.748Z DEBUG Application data folder: /home/tonivanjak/.config/nrfconnect/pc-nrfconnect-cellularmonitor
2025-01-24T09:34:33.808Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2025-01-24T09:34:33.808Z DEBUG App pc-nrfconnect-cellularmonitor v2.4.3 (official)
2025-01-24T09:34:33.809Z DEBUG App path: /home/tonivanjak/.nrfconnect-apps/node_modules/pc-nrfconnect-cellularmonitor
2025-01-24T09:34:33.809Z DEBUG nRFConnect 5.1.0, required by the app is (>=5.0.2)
2025-01-24T09:34:33.809Z DEBUG nRFConnect path: /tmp/.mount_nrfconLKiyCT/resources/app.asar
2025-01-24T09:34:33.809Z DEBUG HomeDir: /home/tonivanjak
2025-01-24T09:34:33.809Z DEBUG TmpDir: /tmp
2025-01-24T09:34:33.832Z WARN Required component nrf-udev is not detected. Install it from https://github.com/NordicSemiconductor/nrf-udev and restart the application
2025-01-24T09:34:33.843Z DEBUG Could not locate Wireshark executable
2025-01-24T09:34:33.849Z DEBUG Could not locate Wireshark executable
2025-01-24T09:34:33.855Z DEBUG Could not locate Wireshark executable
2025-01-24T09:34:33.941Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2025-01-24T09:34:34.200Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2025-01-24T09:34:34.201Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2025-01-24T09:34:34.207Z DEBUG Sending event "cellularmonitor: running nrfutil device"
2025-01-24T09:34:34.208Z INFO Using the bundled core version for nrfutil device: 7.13.0
2025-01-24T09:34:34.322Z INFO Using nrfutil-device version: 2.6.4
2025-01-24T09:34:34.322Z INFO Using nrf-device-lib version: 0.17.35
2025-01-24T09:34:34.322Z INFO Using nrfjprog DLL version: 10.24.2
2025-01-24T09:34:34.322Z INFO Using JLink version: JLink_V7.94i
2025-01-24T09:34:48.964Z INFO Getting serial port options from the persistent store for THINGY91_EF3490783AFD.pc-nrfconnect-cellularmonitor
2025-01-24T09:34:48.966Z INFO Getting serial port options from the persistent store for THINGY91_EF3490783AFD.pc-nrfconnect-cellularmonitor
2025-01-24T09:34:48.967Z DEBUG Sending event "cellularmonitor: device connected"
2025-01-24T09:34:48.968Z DEBUG Sending event "cellularmonitor: device connected"
2025-01-24T09:34:53.225Z INFO Selecting device with the serial number THINGY91_EF3490783AFD
2025-01-24T09:34:53.233Z DEBUG Could not locate Wireshark executable
2025-01-24T09:34:53.240Z INFO Selected device with the serial number THINGY91_EF3490783AFD
2025-01-24T09:34:53.240Z INFO Selected device with s/n THINGY91_EF3490783AFD
2025-01-24T09:34:53.245Z DEBUG Terminal Serial Port: Will attempt to auto-connect to serial port /dev/ttyACM0
2025-01-24T09:34:53.253Z DEBUG Sending event "cellularmonitor: device selected"
2025-01-24T09:34:53.261Z ERROR Failed to connect to port: /dev/ttyACM0. Make sure the port is not already taken, if you are not sure, try to power cycle the device and try to connect again.
2025-01-24T09:34:53.261Z ERROR Terminal Serial Port: Port could not be opened. Verify it is not used by some other applications
2025-01-24T09:34:53.492Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.4_trace-db.json
2025-01-24T09:34:53.492Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.4-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.492Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.5_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.1.5-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.3_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.3-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.7_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.7-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.8_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.2.8-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.0_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.0-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.1_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.1-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.2_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.2-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.3_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.3-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.4_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.4-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.5_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.5-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.6_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.6-FOTA-TEST_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.7_trace-db.json
2025-01-24T09:34:53.493Z DEBUG Trace database already downloaded: mfw_nrf9160_1.3.7-FOTA-TEST_trace-db.json
2025-01-24T09:35:06.807Z INFO Deselected device
2025-01-24T09:35:06.807Z INFO Closing device
2025-01-24T09:35:06.821Z DEBUG Could not locate Wireshark executable
2025-01-24T09:35:06.830Z DEBUG Could not locate Wireshark executable
2025-01-24T09:37:53.055Z DEBUG Could not locate Wireshark executable
2025-01-24T09:37:53.061Z DEBUG Could not locate Wireshark executable
2025-01-24T09:38:23.018Z INFO Getting serial port options from the persistent store for THINGY91_EF3490783AFD.pc-nrfconnect-cellularmonitor
2025-01-24T09:38:23.029Z INFO Getting serial port options from the persistent store for THINGY91_EF3490783AFD.pc-nrfconnect-cellularmonitor
2025-01-24T09:38:23.030Z DEBUG Sending event "cellularmonitor: device connected"
2025-01-24T09:38:39.362Z INFO Getting serial port options from the persistent store for THINGY91_EF3490783AFD.pc-nrfconnect-cellularmonitor
2025-01-24T09:38:39.363Z INFO Getting serial port options from the persistent store for THINGY91_EF3490783AFD.pc-nrfconnect-cellularmonitor
2025-01-24T09:38:39.372Z DEBUG Sending event "cellularmonitor: device connected"
2025-01-24T09:38:39.373Z DEBUG Sending event "cellularmonitor: device connected"
2025-01-24T09:38:47.009Z INFO Selecting device with the serial number THINGY91_EF3490783AFD
2025-01-24T09:38:47.018Z DEBUG Could not locate Wireshark executable
2025-01-24T09:38:47.024Z INFO Selected device with the serial number THINGY91_EF3490783AFD
2025-01-24T09:38:47.025Z INFO Selected device with s/n THINGY91_EF3490783AFD
2025-01-24T09:38:47.029Z DEBUG Terminal Serial Port: Will attempt to auto-connect to serial port /dev/ttyACM0
2025-01-24T09:38:47.035Z DEBUG Sending event "cellularmonitor: device selected"
2025-01-24T09:38:47.042Z ERROR Failed to connect to port: /dev/ttyACM0. Make sure the port is not already taken, if you are not sure, try to power cycle the device and try to connect again.
2025-01-24T09:38:47.042Z ERROR Terminal Serial Port: Port could not be opened. Verify it is not used by some other applications
2025-01-24T09:38:53.679Z ERROR Failed to connect to port: /dev/ttyACM1. Make sure the port is not already taken, if you are not sure, try to power cycle the device and try to connect again.
2025-01-24T09:38:53.679Z ERROR Terminal Serial Port: Port could not be opened. Verify it is not used by some other applications
2025-01-24T09:39:43.980Z INFO Deselected device
2025-01-24T09:39:43.980Z INFO Closing device
2025-01-24T09:39:43.990Z DEBUG Could not locate Wireshark executable
2025-01-24T09:39:43.997Z DEBUG Could not locate Wireshark executable
2025-01-24T09:41:53.790Z INFO Getting serial port options from the persistent store for THINGY91_EF3490783AFD.pc-nrfconnect-cellularmonitor
2025-01-24T09:41:53.804Z DEBUG Sending event "cellularmonitor: device connected"
2025-01-24T09:41:53.893Z INFO Getting serial port options from the persistent store for THINGY91_EF3490783AFD.pc-nrfconnect-cellularmonitor
2025-01-24T09:41:53.894Z DEBUG Sending event "cellularmonitor: device connected"
2025-01-24T09:41:59.483Z INFO Selecting device with the serial number THINGY91_EF3490783AFD
2025-01-24T09:41:59.492Z DEBUG Could not locate Wireshark executable
2025-01-24T09:41:59.499Z INFO Selected device with the serial number THINGY91_EF3490783AFD
2025-01-24T09:41:59.499Z INFO Selected device with s/n THINGY91_EF3490783AFD
2025-01-24T09:41:59.502Z DEBUG Terminal Serial Port: Will attempt to auto-connect to serial port /dev/ttyACM0
2025-01-24T09:41:59.516Z DEBUG Sending event "cellularmonitor: device selected"
2025-01-24T09:41:59.523Z ERROR Failed to connect to port: /dev/ttyACM0. Make sure the port is not already taken, if you are not sure, try to power cycle the device and try to connect again.
2025-01-24T09:41:59.523Z ERROR Terminal Serial Port: Port could not be opened. Verify it is not used by some other applications
2025-01-24T09:42:12.558Z ERROR Failed to connect to port: /dev/ttyACM1. Make sure the port is not already taken, if you are not sure, try to power cycle the device and try to connect again.
2025-01-24T09:42:12.559Z ERROR Terminal Serial Port: Port could not be opened. Verify it is not used by some other applications
When I try to program the Thingy:91 in cellular mode, it always gives the message 'Failed to connect to port.' I’ve tried different ports, but I get the same result.
