'PM_mcuboot_primary_ID' undeclared when trying to build USB DFU example
I'm trying to follow this example (Serial DFU), on a nRF52840 custom board, but I'm getting the following error:
[32/350] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj
C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DK_HEAP_MEM_POOL_SIZE=512 -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -DZCBOR_ASSERTS -D_ANSI_SOURCE -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.9.0/zephyr/kernel/include -IC:/ncs/v2.9.0/zephyr/arch/arm/include -IC:/ProgramData/Repositories/fft-microwave-sensor/build/fft-microwave-sensor/zephyr/include/generated/zephyr -IC:/ncs/v2.9.0/zephyr/include -IC:/ProgramData/Repositories/fft-microwave-sensor/build/fft-microwave-sensor/zephyr/include/generated -IC:/ncs/v2.9.0/zephyr/soc/nordic -IC:/ncs/v2.9.0/zephyr/lib/libc/newlib/include -IC:/ncs/v2.9.0/zephyr/soc/nordic/nrf52/. -IC:/ncs/v2.9.0/zephyr/soc/nordic/common/. -IC:/ncs/v2.9.0/zephyr/subsys/mgmt/mcumgr/util/include -IC:/ncs/v2.9.0/zephyr/subsys/mgmt/mcumgr/transport/include -IC:/ncs/v2.9.0/zephyr/subsys/usb/device -IC:/ncs/v2.9.0/zephyr/subsys/bluetooth/controller/ll_sw/nordic/hal/nrf5/nrfx_glue -IC:/ncs/v2.9.0/zephyr/subsys/bluetooth -IC:/ncs/v2.9.0/zephyr/subsys/settings/include -IC:/ncs/v2.9.0/zephyr/drivers/usb/common/nrf_usbd_common/. -IC:/ncs/v2.9.0/nrf/include -IC:/ncs/v2.9.0/nrf/tests/include -IC:/ncs/v2.9.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.9.0/zephyr/modules/cmsis/. -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.9.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.9.0/modules/debug/segger/SEGGER -IC:/ncs/v2.9.0/modules/debug/segger/Config -IC:/ncs/v2.9.0/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.9.0/modules/lib/zcbor/include -IC:/ncs/v2.9.0/nrfxlib/nfc/include -IC:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/zephyr/.. -IC:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/zephyr/../include -IC:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem C:/ncs/v2.9.0/zephyr/lib/libc/common/include -isystem C:/ncs/v2.9.0/nrfxlib/crypto/nrf_cc310_platform/include -Os -DNDEBUG -fno-strict-aliasing -Os -imacros C:/ProgramData/Repositories/fft-microwave-sensor/build/fft-microwave-sensor/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.9.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ProgramData/Repositories/fft-microwave-sensor=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.9.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.9.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj -MF zephyr\CMakeFiles\zephyr.dir\subsys\dfu\img_util\flash_img.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj -c C:/ncs/v2.9.0/zephyr/subsys/dfu/img_util/flash_img.c
In file included from C:/ncs/v2.9.0/zephyr/include/zephyr/storage/flash_map.h:300,
                 from C:/ncs/v2.9.0/zephyr/subsys/dfu/img_util/flash_img.c:13:
C:/ncs/v2.9.0/zephyr/subsys/dfu/img_util/flash_img.c: In function 'flash_img_init':
C:/ncs/v2.9.0/nrf/include/flash_map_pm.h:47:22: error: 'PM_mcuboot_primary_ID' undeclared (first use in this function)
   47 | #define PM_ID(label) PM_##label##_ID
C:/ncs/v2.9.0/nrf/include/flash_map_pm.h:52:35: note: in expansion of macro 'PM_ID'
   52 | #define FIXED_PARTITION_ID(label) PM_ID(label)
C:/ncs/v2.9.0/zephyr/subsys/dfu/img_util/flash_img.c:33:30: note: in expansion of macro 'FIXED_PARTITION_ID'
   33 | #define UPLOAD_FLASH_AREA_ID FIXED_PARTITION_ID(UPLOAD_FLASH_AREA_LABEL)
C:/ncs/v2.9.0/zephyr/subsys/dfu/img_util/flash_img.c:150:39: note: in expansion of macro 'UPLOAD_FLASH_AREA_ID'
  150 |         return flash_img_init_id(ctx, UPLOAD_FLASH_AREA_ID);
C:/ncs/v2.9.0/nrf/include/flash_map_pm.h:47:22: note: each undeclared identifier is reported only once for each function it appears in
C:/ncs/v2.9.0/zephyr/subsys/dfu/img_util/flash_img.c:151:1: warning: control reaches end of non-void function [-Wreturn-type]
  151 | }
[43/350] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/dfu/usb_dfu.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/dfu/usb_dfu.c.obj
C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DK_HEAP_MEM_POOL_SIZE=512 -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=1 -DZCBOR_ASSERTS -D_ANSI_SOURCE -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.9.0/zephyr/kernel/include -IC:/ncs/v2.9.0/zephyr/arch/arm/include -IC:/ProgramData/Repositories/fft-microwave-sensor/build/fft-microwave-sensor/zephyr/include/generated/zephyr -IC:/ncs/v2.9.0/zephyr/include -IC:/ProgramData/Repositories/fft-microwave-sensor/build/fft-microwave-sensor/zephyr/include/generated -IC:/ncs/v2.9.0/zephyr/soc/nordic -IC:/ncs/v2.9.0/zephyr/lib/libc/newlib/include -IC:/ncs/v2.9.0/zephyr/soc/nordic/nrf52/. -IC:/ncs/v2.9.0/zephyr/soc/nordic/common/. -IC:/ncs/v2.9.0/zephyr/subsys/mgmt/mcumgr/util/include -IC:/ncs/v2.9.0/zephyr/subsys/mgmt/mcumgr/transport/include -IC:/ncs/v2.9.0/zephyr/subsys/usb/device -IC:/ncs/v2.9.0/zephyr/subsys/bluetooth/controller/ll_sw/nordic/hal/nrf5/nrfx_glue -IC:/ncs/v2.9.0/zephyr/subsys/bluetooth -IC:/ncs/v2.9.0/zephyr/subsys/settings/include -IC:/ncs/v2.9.0/zephyr/drivers/usb/common/nrf_usbd_common/. -IC:/ncs/v2.9.0/nrf/include -IC:/ncs/v2.9.0/nrf/tests/include -IC:/ncs/v2.9.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.9.0/zephyr/modules/cmsis/. -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.9.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.9.0/modules/debug/segger/SEGGER -IC:/ncs/v2.9.0/modules/debug/segger/Config -IC:/ncs/v2.9.0/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.9.0/modules/lib/zcbor/include -IC:/ncs/v2.9.0/nrfxlib/nfc/include -IC:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/zephyr/.. -IC:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/zephyr/../include -IC:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem C:/ncs/v2.9.0/zephyr/lib/libc/common/include -isystem C:/ncs/v2.9.0/nrfxlib/crypto/nrf_cc310_platform/include -Os -DNDEBUG -fno-strict-aliasing -Os -imacros C:/ProgramData/Repositories/fft-microwave-sensor/build/fft-microwave-sensor/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.9.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ProgramData/Repositories/fft-microwave-sensor=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.9.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.9.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/dfu/usb_dfu.c.obj -MF zephyr\CMakeFiles\zephyr.dir\subsys\usb\device\class\dfu\usb_dfu.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/class/dfu/usb_dfu.c.obj -c C:/ncs/v2.9.0/zephyr/subsys/usb/device/class/dfu/usb_dfu.c
                 from C:/ncs/v2.9.0/zephyr/subsys/usb/device/class/dfu/usb_dfu.c:46:
C:/ncs/v2.9.0/nrf/include/flash_map_pm.h:47:22: error: 'PM_mcuboot_primary_ID' undeclared here (not in a function)
C:/ncs/v2.9.0/zephyr/subsys/usb/device/class/dfu/usb_dfu.c:333:40: note: in expansion of macro 'FIXED_PARTITION_ID'
  333 |         #define DOWNLOAD_FLASH_AREA_ID FIXED_PARTITION_ID(SLOT0_PARTITION)
C:/ncs/v2.9.0/zephyr/subsys/usb/device/class/dfu/usb_dfu.c:340:26: note: in expansion of macro 'DOWNLOAD_FLASH_AREA_ID'
  340 |         .flash_area_id = DOWNLOAD_FLASH_AREA_ID,
I couldn't find any relevant information and also, the Exercise 2 of the nRF SDK Connect Intermediate Course is not available for SDK v2.7.0+. That might be a problem, since I'm using v2.9.0 right now.
With that, my question is, how do I implement DFU over USB now?
I'm attaching the proj.conf file just as reference, if needed:
CONFIG_NEWLIB_LIBC=y
# Enable GPIO and SPI
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_SPI_NRFX=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_SPI_NOR_SFDP_RUNTIME=y
# Enable Flash support
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_MULTITHREADING=y
CONFIG_FLASH_PAGE_LAYOUT=y
# Enable I²C support
CONFIG_I2C=y
# Enable RTC support
CONFIG_RTC=y
CONFIG_RTC_RV8263=y
# Enable ADC
CONFIG_ADC=y
# Enable RTT and console support
CONFIG_CONSOLE=y
# Increase RTT buffer sizes for better performance
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=28000
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=14000
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# Enable printk and STDOUT for RTT
CONFIG_PRINTK=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_MODE_DEFERRED=y
# Enable USB stack
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="FFT Gen IV"
# Enable CDC ACM class
CONFIG_USB_CDC_ACM=y
CONFIG_SERIAL=y
# Enable NFC
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_NFC_T4T_NRFXLIB=y
CONFIG_NFC_NDEF=y
CONFIG_NFC_NDEF_MSG=y
CONFIG_NFC_NDEF_RECORD=y
CONFIG_NFC_NDEF_LE_OOB_REC=y
CONFIG_NFC_NDEF_CH_MSG=y
CONFIG_NFC_NDEF_TNEP_RECORD=y
CONFIG_NFC_TNEP_TAG=y
CONFIG_NFC_NDEF_PARSER=y
CONFIG_NFC_NDEF_CH_PARSER=y
CONFIG_NFC_NDEF_LE_OOB_REC_PARSER=y
CONFIG_NFC_TNEP_CH=y
# Enable Bluetooth
CONFIG_BT=y
CONFIG_BT_SMP=y
CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="FFT Gen IV"
CONFIG_BT_DIS=y
CONFIG_BT_DIS_PNP=y
CONFIG_BT_DIS_MANUF="Fringe Field Technologies"
CONFIG_BT_DIS_PNP_VID_SRC=2
CONFIG_BT_DIS_PNP_VID=0x1915
CONFIG_BT_DIS_PNP_PID=0xEEEB
CONFIG_BT_DIS_PNP_VER=0x0100
CONFIG_MAIN_STACK_SIZE=3072
CONFIG_BT_SETTINGS=y
CONFIG_POLL=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_USB_DFU_CLASS=y
CONFIG_USB_DFU_ENABLE_UPLOAD=y
CONFIG_STREAM_FLASH=y
CONFIG_IMG_MANAGER=y
CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
# Enable MCUmgr and dependencies.
CONFIG_MCUMGR=y
CONFIG_NET_BUF=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
# Enable most core commands.
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
# Enable the serial mcumgr transport.
CONFIG_MCUMGR_TRANSPORT_UART=y
CONFIG_BASE64=y
# Disable UART Console and enable the RTT console
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
# Some command handlers require a large stack.
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
My .dts file is here as well:
/dts-v1/;
#include <mem.h>
#include <nordic/nrf52840.dtsi>
#include "FFTv03-NRF52840-pinctrl.dtsi"
	model = "Custom Board auto generated by nRF Connect for VS Code";
	compatible = "SMART-Labs,custom-board-name";
	chosen {
		zephyr,console = &cdc_acm_uart;
		zephyr,shell-uart = &cdc_acm_uart;
		zephyr,uart-mcumgr = &cdc_acm_uart;
		zephyr,bt-mon-uart = &cdc_acm_uart;
		zephyr,bt-c2h-uart = &cdc_acm_uart;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
	soc {
		compatible = "nordic,nrf52840", "nordic,nrf52", "simple-bus";
	leds {
		compatible = "gpio-leds";
		red_led: led_0 {
			gpios = <&gpio1 11 GPIO_ACTIVE_LOW>;
			label = "RED LED";
		green_led: led_1 {
			gpios = <&gpio1 14 GPIO_ACTIVE_LOW>;
			label = "GREEN LED";
		blue_led: led_2 {
			gpios = <&gpio1 13 GPIO_ACTIVE_LOW>;
			label = "BLUE LED";
	crystal_oscilator {
		compatible = "gpio-keys";
		crystal_oscilator_enable: crystal-oscilator-enable {
			gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
			label = "CRYSTAL_OSCILATOR_ENABLE";
	adf4350_pins {
		muxout: muxout {
			gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>;
			label = "ADF4350_MUXOUT";
		ld: ld {
			gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>;
			label = "ADF4350_LD";
		ce: ce {
			gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>;
			label = "ADF4350_CE";
		pdbrf: pdbrf {
			gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>;
			label = "ADF4350_PDBRF";
	lmh2110_pins {
		pwr_det_en: pwr-det-en {
			gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>;
			label = "Plmh2110_EN";
	lmh2110_out {
		pwr_det_out: pwr-det-out {
			io-channels = <&adc 4>;
			label = "lmh2110_OUT";
	vbatt {
		compatible = "voltage-divider";
		io-channels = <&adc 1>;
		output-ohms = <2000000>;
		full-ohms = <(2000000 + 2000000)>;
		power-gpios = <&gpio0 3 GPIO_ACTIVE_HIGH>;
	aliases {
		red-led = &red_led;
		green-led = &green_led;
		blue-led = &blue_led;
		crystal-enable = &crystal_oscilator_enable;
		adf4350-muxout = &muxout;
		adf4350-ld = &ld;
		adf4350-ce = &ce;
		adf4350-pdbrf = &pdbrf;
		lmh2110-en = &pwr_det_en;
		lmh2110-out = &pwr_det_out;
		rtc = &rv8263;
&adc {
	status = "okay";
	compatible = "nordic,nrf-saadc";
	#address-cells = <1>;
	#size-cells = <0>;
	channel@0 {
		reg = <0>;
		zephyr,gain = "ADC_GAIN_1_6";
		zephyr,reference = "ADC_REF_INTERNAL";
		zephyr,acquisition-time = <ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 3)>;
		zephyr,input-positive = <NRF_SAADC_AIN2>;
		zephyr,resolution = <12>;
&gpio0 {
	status = "okay";
&gpio1 {
	status = "okay";
&gpiote {
	status = "okay";
&i2c0 {
	status = "okay";
	clock-frequency = <I2C_BITRATE_FAST>;
	zephyr,concat-buf-size = <512>;
	pinctrl-0 = <&i2c0_default>;
	pinctrl-1 = <&i2c0_sleep>;
	rv8263: rv8263@51 {
		compatible = "microcrystal,rv-8263-c8";
		reg = <0x51>;
		int-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>;
&spi1 {
	status = "okay";
	cs-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&spi1_default>;
	pinctrl-names = "default";
	adf4350: adf4350@0 {
		compatible = "vnd,spi-device";
		reg = <0>;
		spi-max-frequency = <8000000>;
		label = "ADF4350";
&spi2 {
	status = "okay";
	cs-gpios = <&gpio1 3 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&spi2_default>;
	pinctrl-1 = <&spi2_sleep>;
	ext_flash: ext_flash@0 {
		compatible = "jedec,spi-nor";
		reg = <0>;
		jedec-id = [ C2 25 37  ];
		hold-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>;
		wp-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
		size = <0x800000>;
		// sfdp-bfp = [00 FF C2 00 01 04 10 01 00 FF 84 00 01 02 C0 00
		//             FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF];
zephyr_udc0: &usbd {
	compatible = "nordic,nrf-usbd";
	status = "okay";
	cdc_acm_uart: cdc_acm_uart {
		compatible = "zephyr,cdc-acm-uart";
&flash0 {
	reg = <0x00000000 DT_SIZE_K(1024)>;
	partitions {
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 DT_SIZE_K(48)>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000c000 DT_SIZE_K(472)>;
		slot1_partition: partition@82000 {
			label = "image-1";
			reg = <0x00082000 DT_SIZE_K(472)>;
		storage_partition: partition@f8000 {
			label = "storage";
			reg = <0x000f8000 DT_SIZE_K(32)>;
&sram0 {
	reg = <0x20000000 DT_SIZE_K(256)>;
Thanks in advance.
