BLE Central and Peripheral Passkey Connections.
Hello, I really need some help to connect a central nRF52 DK board to a peripheral that was provided to me. This peripheral can connect to a smartphone using nRF Connect and a passkey. I have the following setup:
#include <zephyr/kernel.h>
#include <bluetooth/services/nus.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/settings/settings.h>
#include <string.h>
#define DEVICE_NAME "SB-3100043"
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
#define PASSKEY 290156  // Predefined passkey
static struct bt_conn *default_conn;
/* Callback for data reception */
static void received(struct bt_conn *conn, const uint8_t *const data, uint16_t len)
    char message[CONFIG_BT_L2CAP_TX_MTU + 1] = "";
    memcpy(message, data, MIN(len, sizeof(message) - 1));
    printk("Received: %s\n", message);
/* Callback structure for NUS */
static struct bt_nus_cb nus_listener = {
    .received = received,
/* Passkey display callback */
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
    printk("Passkey for %s: %06u\n", addr, passkey);
/* Passkey entry callback */
static void auth_passkey_entry(struct bt_conn *conn, unsigned int passkey)
    printk("Passkey entry required. Entering predefined passkey.\n");
    int err = bt_conn_auth_passkey_entry(conn, PASSKEY);
    if (err) {
        printk("Failed to enter passkey (err %d)\n", err);
    } else {
        printk("Passkey entry successful\n");
/* Cancel pairing callback */
static void auth_cancel(struct bt_conn *conn)
    printk("Pairing cancelled: %s\n", addr);
/* Pairing confirm callback */
static void auth_pairing_confirm(struct bt_conn *conn)
    bt_conn_auth_pairing_confirm(conn);
    printk("Pairing confirmed\n");
/* Security change callback */
static void security_changed(struct bt_conn *conn, bt_security_t level, enum bt_security_err err)
    if (!err) {
        printk("Security changed: %s level %u\n", addr, level);
    } else {
        printk("Security failed: %s level %u err %d\n", addr, level, err);
static struct bt_conn_auth_cb auth_cb_display = {
    .passkey_display = auth_passkey_display,
    .passkey_entry = auth_passkey_entry,
    .cancel = auth_cancel,
    .pairing_confirm = auth_pairing_confirm,
/* Connection callback */
static void connected(struct bt_conn *conn, uint8_t err)
    if (err) {
        printk("Connection failed (err %u)\n", err);
        return;
    printk("Connected\n");
    default_conn = bt_conn_ref(conn);
    // Request security level 3 (legacy pairing with encryption)
    int sec_err = bt_conn_set_security(conn, BT_SECURITY_L3);
    if (sec_err) {
        printk("Failed to set security level 3 (err %d)\n", sec_err);
    } else {
        printk("Security level 3 requested successfully\n");
/* Disconnection callback */
    printk("Disconnected (reason %u)\n", reason);
    if (default_conn) {
        bt_conn_unref(default_conn);
        default_conn = NULL;
static struct bt_conn_cb conn_callbacks = {
    .connected = connected,
    .disconnected = disconnected,
    .security_changed = security_changed,
/* Scan callback to match a specific device */
static void scan_device_found(const bt_addr_le_t *addr, int8_t rssi, uint8_t adv_type, struct net_buf_simple *ad)
    char addr_str[BT_ADDR_LE_STR_LEN];
    bt_addr_le_to_str(addr, addr_str, sizeof(addr_str));
    printk("Device found: %s, RSSI: %d\n", addr_str, rssi);
    if (adv_type != BT_GAP_ADV_TYPE_ADV_IND) {
        return;
    for (int i = 0; i < ad->len;) {
        uint8_t len = ad->data[i++];
        if (len == 0 || i + len - 1 > ad->len) {
            printk("Invalid advertisement data length\n");
        uint8_t type = ad->data[i++];
        if (type == BT_DATA_NAME_COMPLETE) {
            char found_name[DEVICE_NAME_LEN + 1];
            memcpy(found_name, &ad->data[i], len - 1);
            found_name[len - 1] = '\0';
            printk("Found device name: %s\n", found_name);
            if (len - 1 == DEVICE_NAME_LEN &&
                memcmp(&ad->data[i], DEVICE_NAME, DEVICE_NAME_LEN) == 0) {
                printk("Matching device found: %s. Attempting to connect...\n", addr_str);
                if (default_conn) {
                    printk("Connection already in progress or established\n");
                    return;
                struct bt_le_conn_param *conn_param = BT_LE_CONN_PARAM_DEFAULT;
                // Stop scanning before attempting to connect
                bt_le_scan_stop();
                int err = bt_conn_le_create(addr, BT_CONN_LE_CREATE_CONN, conn_param, &default_conn);
                if (err) {
                    printk("Failed to create connection (err %d)\n", err);
                } else {
                    printk("Connection successfully created\n");
                return;
        i += len - 1;
    int err;
    printk("Starting Nordic UART Service with Bonding\n");
    // Initialize Bluetooth
    err = bt_enable(NULL);
    if (err) {
        printk("Bluetooth init failed (err %d)\n", err);
        return err;
    // Clear any stale bonding information
    bt_unpair(BT_ID_DEFAULT, NULL);
    printk("Cleared all bonding information\n");
    // Load settings
    err = settings_load();
    if (err) {
        printk("Settings load failed (err %d)\n", err);
        return err;
    // Register connection and authentication callbacks
    bt_conn_cb_register(&conn_callbacks);
    bt_conn_auth_cb_register(&auth_cb_display);
    // Register NUS service
    err = bt_nus_init(&nus_listener);
    if (err) {
        printk("Failed to init NUS (err %d)\n", err);
        return err;
    printk("Bluetooth initialized\n");
    // Start scanning
    err = bt_le_scan_start(BT_LE_SCAN_ACTIVE, scan_device_found);
    if (err) {
        printk("Scanning failed to start (err %d)\n", err);
        return err;
    printk("Scanning started\n");
    while (true) {
        k_sleep(K_SECONDS(3));
And the error I keep getting is: Device found: EB:E1:BD:6F:9F:82 (random), RSSI: -56
Found device name: SB-3100043
Matching device found: EB:E1:BD:6F:9F:82 (random). Attempting to connect...
Connected
[00:00:05.337,890] [1;31m<err> bt_smp: pairing failed (peer reason 0x8)[0m
Security failed: EB:E1:BD:6F:9F:82 (random) level 1 err 9
