Can't get nRF52811 based sample projects to display on Segger J-Link RTT Viewer
I am working on an FCC cert of our product which is nRF52811 based.  We are currently on SDK 2.0.0.  I have copied from the nrf samples bluetooth area the projects peripheral_uart and direct_test_mode and have been trying (in vain) to get them to send LOG_INF output to the RTT display.  Our main FW on nRF52811 sends the data fine but for some reason I can't get the other two test projects to do that.
I really need the direct_test_mode project to work that so I can test out the 52811 before we go to the RF Lab to check it out.  The peripheral_uart sample seems to be where our current pre-production FW originated from, so I have been trying to use that one to get the RTT display working.  I had to basically lobotomize it as far as BT is concerned since the 52811 is such a small SOC.
Here's the proj.conf from peripheral_uart:
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_HEAP_MEM_POOL_SIZE=2048
#CONFIG_BT=y
#CONFIG_BT_PERIPHERAL=y
#CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
#CONFIG_BT_DEVICE_APPEARANCE=833
#CONFIG_BT_MAX_CONN=1
#CONFIG_BT_MAX_PAIRED=1
# Enable the NUS service
#CONFIG_BT_NUS=y
# Enable bonding
#CONFIG_BT_SETTINGS=y
#CONFIG_FLASH=y
#CONFIG_FLASH_PAGE_LAYOUT=y
#CONFIG_FLASH_MAP=y
#CONFIG_NVS=y
#CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
#CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_ASSERT=y
# hml extra stuff:
CONFIG_BT_NUS_SECURITY_ENABLED=n
CONFIG_LOG_MODE_IMMEDIATE=n
CONFIG_RTT_CONSOLE=y
The main configs that seem to be important for RTT display appear to be CONFIG_SERIAL, CONFIG_LOG, and CONFIG_USE_SEGGER_RTT.
I have the log.h setup in my main.c and have the other setups.  Here's a partial in main:
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME, LOG_LEVEL_INF);
void main(void)
while(true) {
k_msleep(1000);
LOG_INF("EXECUTING MAIN AFTER WAITING 5 SECONDS");
Any help would be appreciated.
h.
