Delays in Sending Data Over TCP on LTE Connection, Depending on Data Size with Thingy 91
I am experiencing delays when sending data over a TCP connection on an LTE network. The issue seems to be related to the size of the data being sent – larger payloads result in noticeably higher delays before they are transmitted.
 * Copyright (c) 2016 Intel Corporation
/* Controlling LEDs through UART. Press 1-3 on your keyboard to toggle LEDS 1-3
 * on your development kit */
#include <dk_buttons_and_leds.h>
#include <modem/lte_lc.h>
#include <modem/nrf_modem_lib.h>
#include <ncs_version.h>
#include <stdio.h>
#include <zephyr/device.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/kernel.h>
#include <zephyr/net/socket.h>
#define SSTRLEN(s) (sizeof(s) - 1)
#define MESSAGE_SIZE 1024
static int sock;
static struct sockaddr_storage server;
K_SEM_DEFINE(lte_connected, 0, 1);
K_MUTEX_DEFINE(mutex);
LOG_MODULE_REGISTER(Proxy, LOG_LEVEL_DBG);
#define SLEEP_TIME_MS 1
#define RECEIVE_BUFF_SIZE 1024
#define RECEIVE_TIMEOUT 1000
const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart1));
static uint8_t rx_buf[RECEIVE_BUFF_SIZE] = {0};
#define MAX_RETRIES 3
static int server_resolve(void) {
  int err;
  struct addrinfo *result;
  struct addrinfo hints = {.ai_family = AF_INET, .ai_socktype = SOCK_STREAM};
  LOG_INF("Resolving server name: %s, port: %s", SERVER_HOSTNAME, SERVER_PORT);
  err = getaddrinfo(SERVER_HOSTNAME, SERVER_PORT, &hints, &result);
  if (err != 0) {
    LOG_ERR("ERROR: getaddrinfo failed %d: %s\n", err, gai_strerror(err));
    return -EIO;
  if (result == NULL) {
    LOG_ERR("ERROR: Address not found\n");
    return -ENOENT;
  struct sockaddr_in *server4 = ((struct sockaddr_in *)&server);
  server4->sin_addr.s_addr =
      ((struct sockaddr_in *)result->ai_addr)->sin_addr.s_addr;
  server4->sin_family = AF_INET;
  server4->sin_port = ((struct sockaddr_in *)result->ai_addr)->sin_port;
  char ipv4_addr[NET_IPV4_ADDR_LEN];
  inet_ntop(AF_INET, &server4->sin_addr.s_addr, ipv4_addr, sizeof(ipv4_addr));
  LOG_INF("IPv4 Address found %s", ipv4_addr);
  freeaddrinfo(result);
  return 0;
static int server_connect(void) {
  int err;
  int retries = 0;
  while (retries < MAX_RETRIES) {
    LOG_INF("Creating socket");
    sock = socket(AF_INET, SOCK_STREAM,
                  /* IPPROTO_IP */ IPPROTO_TCP);
    if (sock < 0) {
      LOG_ERR("Failed to create socket: %d.\n", errno);
      return -errno;
    LOG_INF("Connecting to server");
    err = connect(sock, (struct sockaddr *)&server, sizeof(struct sockaddr_in));
    if (err < 0) {
      LOG_ERR("Connect failed : %d\n", errno);
      close(sock);
      retries++;
      k_sleep(K_SECONDS(1));
    } else {
      LOG_INF("Successfully connected to server");
      return 0;
  LOG_ERR("Failed to connect to server after %d retries", MAX_RETRIES);
  return -ETIMEDOUT;
static void lte_handler(const struct lte_lc_evt *const evt) {
  switch (evt->type) {
  case LTE_LC_EVT_NW_REG_STATUS:
    if ((evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_HOME) &&
        (evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_ROAMING)) {
    LOG_INF("Network registration status: %s",
            evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME
                ? "Connected - home network"
                : "Connected - roaming");
    k_sem_give(&lte_connected);
  case LTE_LC_EVT_RRC_UPDATE:
    LOG_INF("RRC mode: %s",
            evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED ? "Connected" : "Idle");
static int modem_configure(void) {
  int err;
  LOG_INF("Initializing modem library");
  err = nrf_modem_lib_init();
  if (err) {
    LOG_ERR("Failed to initialize the modem library, error: %d", err);
    return err;
  LOG_INF("Disabling PSM and eDRX");
  err = lte_lc_psm_req(false);
  if (err) {
    LOG_ERR("Failed to disable PSM, error: %d", err);
    return err;
  err = lte_lc_edrx_req(false);
  if (err) {
    LOG_ERR("Failed to disable eDRX, error: %d", err);
    return err;
  LOG_INF("Connecting to LTE network");
  err = lte_lc_connect_async(lte_handler);
  if (err) {
    LOG_ERR("Error in lte_lc_connect_async, error: %d", err);
    return err;
  k_sem_take(&lte_connected, K_FOREVER);
  LOG_INF("Connected to LTE network");
  return 0;
int main(void) {
  int ret;
  int err;
  err = modem_configure();
  if (err) {
    LOG_ERR("Failed to configure the modem");
    return 0;
  if (server_resolve() != 0) {
    LOG_ERR("Failed to resolve server name");
    return 0;
  if (server_connect() != 0) {
    LOG_ERR("Failed to initialize client");
    return 0;
  const uint8_t buffer[] =
      "$VAL$2025-01-27 09:11:39.234       "
      "ABCDEFGHIJKLMNOPQRSTUVWXYZ123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ123456789"
      // "ABCDEFGHIJKLMNOPQRSTUVWXYZ123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ123456789"
      "ABCDEFGHIJKLMNOPQRSTUVWXYZ123456789\r\n";
  while (1) {
    int err = send(sock, buffer, sizeof(buffer), 0);
    const int end_ms = k_uptime_get_32();
    if (err < 0) {
      LOG_ERR("Failed to send message, %d", errno);
        return 0;
      // return 0;
    LOG_INF("%dms Sent: %dms %dbytes", start_ms, end_ms - start_ms,
            sizeof(buffer));
    k_msleep(100 - (k_uptime_get_32() - start_ms));
  (void)close(sock);
These are some logs during correct working.
I: 448855ms Sent: 0ms 143bytes
I: 448955ms Sent: 0ms 143bytes
I: 449055ms Sent: 0ms 143bytes
I: 449155ms Sent: 0ms 143bytes
I: 449255ms Sent: 0ms 143bytes
I: 449355ms Sent: 0ms 143bytes
I: 449455ms Sent: 0ms 143bytes
I: 449555ms Sent: 0ms 143bytes
I: 449655ms Sent: 1ms 143bytes
I: 449755ms Sent: 1ms 143bytes
I: 449855ms Sent: 1ms 143bytes
I: 449955ms Sent: 1ms 143bytes
I: 450055ms Sent: 1ms 143bytes
I: 450156ms Sent: 0ms 143bytes
I: 450257ms Sent: 0ms 143bytes
I: 450357ms Sent: 0ms 143bytes
I: 450457ms Sent: 0ms 143bytes
I: 450557ms Sent: 0ms 143bytes
I: 450657ms Sent: 0ms 143bytes
I: 450757ms Sent: 0ms 143bytes
I: 450857ms Sent: 1ms 143bytes
And here with a bigger buffer:
I: 4456ms Sent: 0ms 353bytes
I: 4556ms Sent: 0ms 353bytes
I: 4656ms Sent: 0ms 353bytes
I: 4756ms Sent: 0ms 353bytes
I: 4856ms Sent: 0ms 353bytes
I: 4956ms Sent: 0ms 353bytes
I: 5056ms Sent: 0ms 353bytes
I: 5156ms Sent: 0ms 353bytes
I: 5256ms Sent: 0ms 353bytes
I: 5356ms Sent: 0ms 353bytes
I: 5456ms Sent: 0ms 353bytes
I: 5556ms Sent: 0ms 353bytes
I: 5656ms Sent: 0ms 353bytes
I: 5756ms Sent: 0ms 353bytes
I: 5856ms Sent: 0ms 353bytes
I: 5956ms Sent: 0ms 353bytes
I: 6056ms Sent: 0ms 353bytes
I: 6156ms Sent: 0ms 353bytes
I: 6256ms Sent: 200ms 353bytes
I: 6459ms Sent: 0ms 353bytes
I: 6560ms Sent: 0ms 353bytes
I: 6660ms Sent: 0ms 353bytes
I: 6760ms Sent: 1604ms 353bytes
I: 8367ms Sent: 0ms 353bytes
I: 8468ms Sent: 0ms 353bytes
I: 8568ms Sent: 1ms 353bytes
I: RRC mode: Idle
I: RRC mode: Connected
I: 8669ms Sent: 4816ms 353bytes
I: 13487ms Sent: 1ms 353bytes
I: 13587ms Sent: 1ms 353bytes
I: 13687ms Sent: 1ms 353bytes
I: 13788ms Sent: 197ms 353bytes
I: 13988ms Sent: 0ms 353bytes
I: 14089ms Sent: 0ms 353bytes
I: 14189ms Sent: 717ms 353bytes
Has anyone else encountered similar issues with TCP data transmission delays over LTE, especially with varying data sizes? If so, could you share any insights or solutions on how to optimize data transmission for consistent and minimal delays?
Any advice or suggestions would be greatly appreciated!
