nrf52832 DCDC & __WFE problem
Hi, I am editing my question:
I have seen some strange behaviuor I could not explain. In order to test it I have made the next test program: I am using the application timer module to create 2 timers: one timer of 33.3 ms in repeat mode, and another of 2 ms in single shot mode, which is triggered once inside the 33.3 ms cycle (my code is attached below). inside the 2 ms timer I put the CPU to low power mode, using __WFE.
when I work with the debugger connected, I see the expected behaviour (see Logic image:) image description
but when I run the program without the debugger connected, this is what I get (program is stack after a few cycles): image description
I have also noticed that disabling __WFE in the 2 ms loop, or disabling the dc-dc solves this issue (see Logic images)
no WFE: image description
no dc-dc: image description
this is my code:
void timers_create(void)
  // Initialize timer module.
  APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS,    APP_TIMER_OP_QUEUE_SIZE, false);
  // Create timer for cycles (33.3 ms)
  g_err_code = app_timer_create(&m_cycle_timer_timer_id, APP_TIMER_MODE_REPEATED, cycle_timeout_handler);
  APP_ERROR_CHECK(g_err_code);
  // Create timer for delays
  g_err_code = app_timer_create(&m_delay_timer_id, APP_TIMER_MODE_SINGLE_SHOT, delay_timeout_handler);
void cycle_timer_start(void)
  g_err_code = app_timer_start(m_cycle_timer_timer_id, CYCLE_INTERVAL, NULL);
void main()
  NRF_POWER->DCDCEN = 1;
  g_err_code = nrf_drv_clock_init(NULL);
  // start LFCLK
  nrf_drv_clock_lfclk_request();
  timers_create();
  nrf_gpio_cfg_output(25);
  nrf_gpio_pin_clear(25);
  nrf_gpio_cfg_output(26);
  nrf_gpio_pin_clear(26);
  cycle_timer_start();  // 33 ms cycle
  while(1)
    // wait for fglag
    while(!g_activate_flag)  {};
    nrf_gpio_pin_toggle(25);
    g_activate_flag = false;
    // delay timer start
    app_timer_start(m_delay_timer_id, 66, NULL);
    nrf_gpio_pin_set(26);
    while (!g_delay_ended)
      // Wait for event
      __WFE();
    g_delay_ended = false;
Can someone explain this behaviour? Thanks Yaron
  • Something is not right here. You were right, seems like DCDC has some issues. I have sent this issue to the hardware engineer to look into it. I will update this thread after he comes back with more info.
