Hello everyone, I'm trying to create a sample code for a central unit on the NRF52840 to work with two services simultaneously, from a single connection with the peripheral.
My tests manage to connect between the central and peripheral devices, but I can't discover all the services on the central unit side and be able to use all the services provided by the peripheral server.
I'll describe my code here, I hope you can help me, thank you in advance.
# On the Peripheral side
I start the BAS, HTS and LBS services.
# On the Central side
In the discovery part, I implement the callbacks, discovery_completed_cb(), discovery_service_not_found_cb((), void discovery_error_found_cb(), and gatt_discover() to use in application,
and call the method bt_gatt_dm_start(conn, NULL, &discovery_cb, NULL); with NULL in the second field to discover all the services.
in the discovery_completed_cb() callback, I don't know how I should manipulate the attributes, see the attributes of the three services (BAS, HTS and LBS) and make their service methods available in the application.
static void discovery_completed_cb(struct bt_gatt_dm *dm, void *context)
const struct bt_gatt_dm_attr *attr = bt_gatt_dm_service_get(dm); // Obtém o primeiro atributo de serviço
const struct bt_gatt_service_val *service_val;
//const struct bt_gatt_dm_attr *desc;
//char uuid_str[BT_UUID_STR_LEN];
printf("Descoberta de serviços, características e descritores concluída:\n");
// Itera sobre os serviços e características usando bt_gatt_dm_attr_next
while (attr) {
printk("Handle: %d\n",attr->handle);
//printk("Permi: %d\n",attr->perm);
// Buffer para converter o UUID para string
bt_uuid_to_str(attr->uuid, uuid_str, sizeof(uuid_str));
printk("UUID: %s\n\n",uuid_str);
if (attr->uuid == 2800){
service_val = bt_gatt_dm_attr_service_val(attr);
attr = bt_gatt_dm_attr_next(dm, attr);
bt_gatt_dm_data_release(dm);
static void discovery_service_not_found_cb(struct bt_conn *conn, void *context)
printk("The service could not be found during the discovery\n");
static void discovery_error_found_cb(struct bt_conn *conn, int err, void *context)
printk("The discovery procedure failed with %d\n", err);
static struct bt_gatt_dm_cb discovery_cb = {
.completed = discovery_completed_cb,
.service_not_found = discovery_service_not_found_cb,
.error_found = discovery_error_found_cb,
static void gatt_discover(struct bt_conn *conn)
int err;
if (conn != default_conn) {
return;
err = bt_gatt_dm_start(conn, NULL, &discovery_cb, NULL);
if (err) {
printk("Could not start the discovery procedure, error code: %d\n", err);
