Bytes are lost when sending with nrfx_uarte_tx in uarte_handler
I´m trying to send a paket of databytes. For some reasons I need to send it byte by byte (that´s not changeable).
I have inited the uarte with a handler:
nrfx_uarte_init(&m_uarte1_inst, &m_uarte1_config, uarte1_handler);
The first byte is sent in the main-thread. After that I´m using the handler for the following bytes.
In the handler I´m checking the event-Type and on EVT_TX_DONE I´m trying to send the next byte.
switch (p_event->type)
  case NRFX_UARTE_EVT_ERROR:
  case NRFX_UARTE_EVT_RX_DONE:
  case NRFX_UARTE_EVT_TX_DONE:
    LOG_DBG("HW %02x", txData);
    ret = nrfx_uarte_tx(p_current_uarte, &txData, 1, 0);
    if (ret != NRFX_SUCCESS)
    LOG_DBG("TX-Error");
Sometimes there are Bytes missing in the transmission (checked with a logic-analyser at the output-pin). In the LOG I can see the bytes correctly. And there are no "TX-Error"-Messages. So the bytes seems to be transmitted to the uarte-peripheral correctly, but it are not always sent out.
Are there any hints that I could follow?
    Often errors like this comes from calling functions from interrupt contexts. This can interfere with peripheral timing.
    See how the nrfx_prs sample uses a semaphore to check if the transfer is done, set in the DONE callback instead of calling nrfx_uarte_tx directly.
    Sigurd Hellesvik
  • Yes, it seems to be a timing problem. I tested to use a workqueue to send the next byte. This seems to be ok, but now there is a delay between the bytes (as expected), so I would like to get it back to the ISR.
    Could you explain it more detailed why it is a problem to use the function in the interrupt context? Is there a function that can be used?
    As you can see in nrfx_uarte_tx(), the function has some loops waiting for stuff. In other words, it is blocking. And blocking functions is generally not a good idea in an interrupt context.
    The delay is likely because the workqueue is scheduled by the Zephyr scheduler. To make it faster, either do not use the scheduler but a polling function and global variable or semaphore to be really fast, or give the workqueue a higher priority.
