We want to use PSA crypto to generate a persistent key that can't be read out and use this for encryption/decryption.
We have of course tried the persistent_key_usage sample both with and without TF-M ITS. The problem for us is that when enabling TF-M ITS 40% of the available RAM for our target nRF54L10 is consumed. As an alternative CONFIG_TRUSTED_STORAGE could be used, but there are some reasons why we don't want to use this path.
As I interprete this documentation, it should be possible to use the KMU slots directly using PSA crypto API:
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/device_guides/nrf54l/cryptography.html#ug-nrf54l-crypto-kmu-supported-key-types
By doing so we don't need the extra storage partitions etc needed for TF-M ITS and I would assume it would require less RAM.
But I can't get it to work. Have tried various config etc, but calling psa_generate_key() it returns -134 PSA_ERROR_NOT_SUPPORTED.
Here is my code:
#include <psa/crypto.h>
#include <cracen_psa_kmu.h>
static int crypto_test(void)
psa_key_id_t keyId;
psa_status_t status;
psa_key_attributes_t attributes = PSA_KEY_ATTRIBUTES_INIT;
status = psa_crypto_init();
if (status != PSA_SUCCESS) {
return status;
// Set the key as persistent
psa_set_key_lifetime(&attributes, PSA_KEY_LIFETIME_FROM_PERSISTENCE_AND_LOCATION(
PSA_KEY_PERSISTENCE_DEFAULT,
PSA_KEY_LOCATION_CRACEN_KMU));
// Set a fixed key ID
psa_set_key_id(&attributes, PSA_KEY_HANDLE_FROM_CRACEN_KMU_SLOT(CRACEN_KMU_KEY_USAGE_SCHEME_PROTECTED, 2));
psa_set_key_usage_flags(&attributes, PSA_KEY_USAGE_ENCRYPT | PSA_KEY_USAGE_DECRYPT);
psa_set_key_algorithm(&attributes, PSA_ALG_CBC_NO_PADDING);
psa_set_key_type(&attributes, PSA_KEY_TYPE_AES);
psa_set_key_bits(&attributes, 128);
status = psa_generate_key(&attributes, &keyId);
printf("psa_generate_key: %d\n", status);
return status;
}and config:
# Enable Trusted Firmware CONFIG_TFM_PROFILE_TYPE_MINIMAL=y CONFIG_NRF_SECURITY=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y CONFIG_PSA_WANT_GENERATE_RANDOM=y CONFIG_PSA_WANT_KEY_TYPE_AES=y CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y CONFIG_PSA_CRYPTO_DRIVER_OBERON=n CONFIG_PSA_CRYPTO_DRIVER_CRACEN=y
So am I missing something?
