Unstable ZMS
I am facing an issue with unsuccessful zms initialization. For my case, it always seems like each of my boards can only work with zms in one project; I can update the code within the original project all I want, but switching to another program with zms will result in a failure, and switching back to the original is fine. For my development purposes, I have also tried to implement a button callback that calls zms_delete(), and pressing that will also result in the same failure problem.
To resolve this issue, I have tried to:
- rebuilding the project, and flash it onto the board again.
- erase and reset with nRF Connect Desktop, then rebuilding and flash again.
- pressing the reset button on the board.
- disconnecting the board from the PC, then reconnecting it again.
- restarting my PC entirely.
Out of the above attempts, only restarting the PC entirely solves the problem; but this simply seems too complicated for a problem like this.
My setup:
Microsoft Windows 10 Pro, nRF Connect SDK v2.8.0, nRF52840dk & nRF54L15
Below are the error messages:
- flash_nrf: invalid address: 0x00100fe0:16
- fs_zms: zms not initialized.
  • Edit: Now restarting the PC entirely won't even fix the issue. I built another project that uses zms, and everything works out there. Thus, I replaced everything within my old directory with the content of the new project, and it still fails. How come the directory affects the success of zms initialization?
    Q1: Which sample are you using to recreate this scenario? I would like to recreate this on my end as well.
    Q2: are you performing a full erase of the device when moving from one project with zms to another?
    The reason I ask is because they can overlap in address area between applications.
    Check your build-folder/partitions.yml and see if the "zms_storage" is changed between the two samples.
    Preferably share both .yml files.
    Q3: I suspect these are logs from a nRF52840 device?
    If yes, then the 0x100fe0 is out-of-bounds of the flash itself, indicating that there's something with the originating fs structure (addr + size variables).
    Håkon
  • Hi!
    I have based my work off of the Thread CLI sample, and I have been building off of that for quite a while now. The ZMS project that works was built as a new project.
    Here's the yml file from the project that does not work:
    app:
      address: 0x0
      end_address: 0xf8000
      region: flash_primary
    nvs_storage:
      address: 0xf8000
      end_address: 0xfe000
      placement:
        before:
        - end
    settings_storage:
      address: 0xfe000
      end_address: 0x100000
      placement:
        align:
          start: 0x1000
        before:
        - end
    sram_primary:
      address: 0x20000000
      end_address: 0x20040000
      region: sram_primary
    and the yml file from the project that does work:
    app:
      address: 0x0
      end_address: 0xfa000
    sram_primary:
      address: 0x20000000
    zms_storage:
      address: 0xfa000
      placement:
        before:
        - end
    Yes, I am indeed working on an nRF52840 board!
    I would appreciate any further help! Thanks!
  • An update:
    I copied the successful yml file to the unsuccessful project, and it still gave the same error of invalid address: 0x00100fe0:16 while trying to mount ZMS, even though I believe the address has made it clear that this is an invalid address.
    Could you try to declare a zms_settings partition?
    This yaml file does not seem to have a zms_storage partition:
    app:
      address: 0x0
    nvs_storage:
      address: 0xf8000
      placement:
        before:
        - end
    settings_storage:
      address: 0xfe000
      placement:
        align:
          start: 0x1000
        before:
        - end
    sram_primary:
      address: 0x20000000
     If you create a pm_static.yml file in your application/ folder containing this:
    zms_storage:
      address: 0xfa000
      placement:
        before:
        - end
    And nothing else; it should adjust other partitions as needed in the new_build-folder/partitions.yml.
    PS: You need to do a new build (not pristine) for such static partition layout to be included.
    Håkon
