I'm currently attempting to register a service and it's subsequent characteristics statically using variables and not hard coded GATT tabel , I can successfully register an struct array of service UUIDs when I use the macro
BT_GATT_PRIMARY_SERVICE, below is the code that I was using
// generating UUID struct from array and registering service
for (int i = 0; i < 3; i++) {
printk("\n serv no:\n");
fnInitUuid128(&uuids_struct[i], uuid_bytesArray[i]);
attrs[i] = (struct bt_gatt_attr)BT_GATT_PRIMARY_SERVICE(&uuids_struct[i]);
services[i] = (struct bt_gatt_service) { .attrs = &attrs[i], .attr_count = 1 };
int result = bt_gatt_service_register(&services[i]);
if (result) {
LOG_ERR("Failed to register service %d (err %d)", i, result);
}else {
LOG_INF("Service %d registered successfully result %d", i,result);
}Each service is successfully registered as the error message returned is zero and the services appear on the nrf connect mobile app. But when I attempt to register a single service and characteristic using the macro BT_GATT_CHARACTERISTIC in the code below:
int serv_uuid=0;
int characteristic_uuid=1;
fnInitUuid128(&uuids_struct[serv_uuid], uuid_bytesArray[serv_uuid]);
attrs[serv_uuid] = (struct bt_gatt_attr)BT_GATT_PRIMARY_SERVICE(&uuids_struct[serv_uuid]);
attrs[characteristic_uuid] = (struct bt_gatt_attr)BT_GATT_CHARACTERISTIC(&uuids_struct[characteristic_uuid],BT_GATT_CHRC_READ, BT_GATT_PERM_READ, NULL, NULL, NULL);;
services[serv_uuid] = (struct bt_gatt_service) { .attrs = &attrs, .attr_count = 2 };
int result = bt_gatt_service_register(&services[serv_uuid]);
if (result) {
LOG_ERR("Failed to register service %d (err %d)", serv_uuid, result);
} else {
LOG_INF("Service %d registered successfully result %d", serv_uuid,result);
error:
348 | attrs[characteristic_uuid] = (struct bt_gatt_attr)BT_GATT_CHARACTERISTIC(&uuids_struct[characteristic_uuid],BT_GATT_CHRC_READ, BT_GATT_PERM_READ, NULL, NULL, NULL);;
C:/ncs/v2.9.0/zephyr/include/zephyr/bluetooth/gatt.h:1191:22: note: in definition of macro 'BT_GATT_ATTRIBUTE'
1191 | .user_data = _user_data, \
C:/ncs/v2.9.0/zephyr/include/zephyr/bluetooth/gatt.h:912:33: note: in expansion of macro 'BT_GATT_CHRC_INIT'
912 | BT_GATT_CHRC_INIT(_uuid, 0U, _props), \
C:src/main.c:348:67: note: in expansion of macro 'BT_GATT_CHARACTERISTIC'
C:/src/main.c:348:90: note: (near initialization for '(anonymous)[0].uuid')
C:/src/main.c:348:67: note: in expansion of macro 'BT_GATT_CHARACTERISTIC'
C:/ncs/v2.9.0/zephyr/include/zephyr/bluetooth/gatt.h:1187:1: error: expected expression before '{' token
1187 | { \
C:/ncs/v2.9.0/zephyr/include/zephyr/bluetooth/gatt.h:914:9: note: in expansion of macro 'BT_GATT_ATTRIBUTE'
914 | BT_GATT_ATTRIBUTE(_uuid, _perm, _read, _write, _user_data)
C:/src/main.c:349:67: warning: initialization of 'struct bt_gatt_attr *' from incompatible pointer type 'struct bt_gatt_attr (*)[3]' [-Wincompatible-pointer-types]
349 | services[serv_uuid] = (struct bt_gatt_service) { .attrs = &attrs, .attr_count = 2 };
1187 | { \
