When using l2cap to stream data at a high rate from device to an app we are seeing a hard fault in l2cap_data_pull when there is queued l2cap send data.
I also added a check that struct bt_l2cap_le_chan chan_ops disconnected has not been called before we call bt_l2cap_chan_send.
So I think the send data is queued up the ble stack before the disconnect happens.
Just to check to see if bt_conn_unref was the issue, I commented that out to test. The same hard fault in l2cap_data_pull occurs. So doesn't seem to be an issue with an early unref.
Could you try the suggested code snippet?
I can't do that exactly because I'm using the l2cap calls, but I did test adding a ref/unref around the send and the same hard fault still happens.
It might be a race condition between l2cap_data_pull and bt_l2cap_chan_del or l2cap_chan_shutdown. It should not happen since l2cap_data_pull runs on the system work queue, which is forced to be non-preemptible by the Bluetooth subsystem Kconfig. Have you overridden this restriction and made the system work queue preemtible?
