When using l2cap to stream data at a high rate from device to an app we are seeing a hard fault in l2cap_data_pull when there is queued l2cap send data.
We have not modified the SYSTEM_WORKQUEUE_PRIORITY configuration.
Could you try to surround bt_l2cap_dyn_chan_send in a k_sched_lock as a step toward debugging? This makes the thread temporarily cooperative. It can be done by applying the attached diff to NCS v2.9.0.
#!/usr/bin/env -S git apply
# Attachment to Nordic Devzone https://devzone.nordicsemi.com/f/nordic-q-a/118471/l2cap_data_pull-hard-fault-on-disconnect-with-queued-tx-data
diff --git a/subsys/bluetooth/host/l2cap.c b/subsys/bluetooth/host/l2cap.c
index ed185d12fd7..58bb4cf13aa 100644
--- a/subsys/bluetooth/host/l2cap.c
+++ b/subsys/bluetooth/host/l2cap.c
@@ -3283,7 +3283,18 @@ static int bt_l2cap_dyn_chan_send(struct bt_l2cap_le_chan *le_chan, struct net_b
return 0;
-int bt_l2cap_chan_send(struct bt_l2cap_chan *chan, struct net_buf *buf)
+static int bt_l2cap_chan_send_(struct bt_l2cap_chan *chan, struct net_buf *buf);
+int bt_l2cap_chan_send(struct bt_l2cap_chan *chan, struct net_buf *buf)
+ int err;
+ k_sched_lock();
+ err = bt_l2cap_chan_send_(chan, buf);
+ k_sched_unlock();
+ return err;
if (!buf || !chan) {
return -EINVAL;
Please let me know if it can work or not.
I added that change and was still able to reproduce the issue.
Could you provide a simple project to help us reproduce the issue?
