Hello.
The problems with starting advertising started after I wanted to add NVS (most likely). The error occurs in the bt_le_adv_start function
What does this error mean and how can I fix it?
Here is my overlay for new memory partition (sensor_data_in_partition here for NVS):
/delete-node/ &slot0_partition;
/delete-node/ &slot1_partition;
/delete-node/ &storage_partition;
&flash0 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x00000000 DT_SIZE_K(48)>;
slot0_partition: partition@c000 {
label = "image-0";
reg = <0x0000c000 DT_SIZE_K(204)>;
slot1_partition: partition@3f000 {
label = "image-1";
reg = <0x003f000 DT_SIZE_K(204)>;
storage_partition: partition@72000 {
label = "storage";
reg = <0x00072000 DT_SIZE_K(24)>;
sensor_data_in_partition: partition@78000 {
label = "sensor_data";
reg = <0x00078000 DT_SIZE_K(24)>;
Here is prj.conf
CONFIG_LOG=y # Button and LED library CONFIG_DK_LIBRARY=y # Bluetooth LE CONFIG_BT=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="MY_LBS1" CONFIG_BT_SMP=y # Increase stack size for the main thread and System Workqueue CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_MAIN_STACK_SIZE=2048 CONFIG_NVS=y CONFIG_BT_NSMS=y CONFIG_SPI=y CONFIG_GPIO=y CONFIG_PRINTK=y CONFIG_USE_SEGGER_RTT=y
I use ncs 2.8.0 with the custom board with an nrf52832 chip.
I would be grateful for help.
