Unity testing fail to run examples in nrf sdk
Hello!
We have developed a product that we would like to add some testing for and I have looked at both ztest and unity testing. Currently I am struggling with running the examples for unity testing that is available under the nrf sdk in "ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module". I am navigating to the path and then trying to run it with both twister and west but can't get it to work. I am running this under WSL in windows and I am able to build and flash devices but not to run this tests. Followed this guide: docs.nordicsemi.com/.../unit_test.html
twister -T . -p native_sim
or
west build -b native_sim -t run
error: Aborting due to Kconfig warnings
CMake Error at /home/hd/zephyrproject/zephyr/cmake/modules/kconfig.cmake:396 (message):
  command failed with return code: 1
  /home/hd/zephyrproject/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
  /home/hd/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /home/hd/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:9 (find_package)
INFO    - /home/haddek/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/qemu_cortex_m3_ti_lm3s6965/zephyr/asset_tracker_v2.debug_module_test.tester/build.log
INFO    - Total complete:    1/   1  100%  built (not run):    0, filtered:    0, failed:    0, error:    1
INFO    - 1 test scenarios (1 configurations) selected, 0 configurations filtered (0 by static filter, 0 at runtime).
INFO    - 0 of 1 executed test configurations passed (0.00%), 0 built (not run), 0 failed, 1 errored, with no warnings in 8.09 seconds.
INFO    - 0 of 1 executed test cases passed (0.00%), 1 errored on 1 out of total 926 platforms (0.11%).
INFO    - 0 test configurations executed on platforms, 1 test configurations were only built.
INFO    - Saving reports...
INFO    - Writing JSON report /home/haddek/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/twister.json
INFO    - Writing xunit report /home/haddek/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/twister.xml...
INFO    - Writing xunit report /home/haddek/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/twister_report.xml...
INFO    - -+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+
INFO    - The following issues were found (showing the top 10 items):
INFO    - 1) asset_tracker_v2.debug_module_test.tester on qemu_cortex_m3/ti_lm3s6965 error (CMake build failure)
INFO    -
INFO    - To rerun the tests, call twister using the following commandline:
INFO    - west twister -p <PLATFORM> -s <TEST ID>, for example:
INFO    -
INFO    - west twister -p qemu_cortex_m3/ti_lm3s6965 -s asset_tracker_v2.debug_module_test.tester
INFO    - or with west:
INFO    - west build -p -b qemu_cortex_m3/ti_lm3s6965 . -T asset_tracker_v2.debug_module_test.tester
INFO    - Run completed
  /home/hd/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
FATAL ERROR: command exited with status 1: /usr/bin/cmake -DWEST_PYTHON=/home/haddek/zephyrproject/.venv/bin/python3 -B/home/haddek/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/build -GNinja -S/home/haddek/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module
I then tried checked the logs (or ran with -i and got following):
Renaming output directory to /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out.2
INFO    - Using Ninja..
INFO    - Zephyr version: v4.0.0-4212-gefe94a9a291c
INFO    - Using 'zephyr' toolchain.
INFO    - Building initial testsuite list...
INFO    - Writing JSON report /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/testplan.json
INFO    - JOBS: 16
INFO    - Adding tasks to the queue...
INFO    - Added initial list of jobs to queue
ERROR   - CMake build failure: /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module for qemu_cortex_m3/ti_lm3s6965
ERROR   - qemu_cortex_m3/ti_lm3s6965 asset_tracker_v2.debug_module_test.tester          ERROR: CMake build failure
INFO    - /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/qemu_cortex_m3_ti_lm3s6965/zephyr/asset_tracker_v2.debug_module_test.tester/build.log
ERROR   - Loading Zephyr default modules (Zephyr base).
-- Application: /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module
-- CMake version: 3.28.3
-- Found Python3: /home/hd/zephyrproject/.venv/bin/python3 (found suitable version "3.12.3", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /home/hd/.cache/zephyr
-- Zephyr version: 4.0.99 (/home/hd/zephyrproject/zephyr)
-- Found west (found suitable version "1.3.0", minimum required is "0.14.0")
-- Board: qemu_cortex_m3, qualifiers: ti_lm3s6965
-- Found host-tools: zephyr 0.17.0 (/home/hd/zephyr-sdk-0.17.0)
-- Found toolchain: zephyr 0.17.0 (/home/hd/zephyr-sdk-0.17.0)
-- Found Dtc: /home/hd/zephyr-sdk-0.17.0/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/hd/zephyrproject/zephyr/boards/qemu/cortex_m3/qemu_cortex_m3.dts
-- Generated zephyr.dts: /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/qemu_cortex_m3_ti_lm3s6965/zephyr/asset_tracker_v2.debug_module_test.tester/zephyr/zephyr.dts
-- Generated pickled edt: /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/qemu_cortex_m3_ti_lm3s6965/zephyr/asset_tracker_v2.debug_module_test.tester/zephyr/edt.pickle
-- Generated devicetree_generated.h: /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/qemu_cortex_m3_ti_lm3s6965/zephyr/asset_tracker_v2.debug_module_test.tester/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/qemu_cortex_m3_ti_lm3s6965/zephyr/asset_tracker_v2.debug_module_test.tester/zephyr/dts.cmake
/home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/prj.conf:7: warning: attempt to assign the value 'y' to the undefined symbol UNITY
/home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/prj.conf:14: warning: attempt to assign the value 'y' to the undefined symbol APP_EVENT_MANAGER
Parsing /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/Kconfig
Loaded configuration '/home/hd/zephyrproject/zephyr/boards/qemu/cortex_m3/qemu_cortex_m3_defconfig'
Merged configuration '/home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/prj.conf'
Merged configuration '/home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/qemu_cortex_m3_ti_lm3s6965/zephyr/asset_tracker_v2.debug_module_test.tester/zephyr/misc/generated/extra_kconfig_options.conf'
INFO    - 0 of 1 executed test configurations passed (0.00%), 0 built (not run), 0 failed, 1 errored, with no warnings in 4.93 seconds.
INFO    - Writing JSON report /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/twister.json
INFO    - Writing xunit report /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/twister.xml...
INFO    - Writing xunit report /home/hd/ncs/v2.5.3/nrf/applications/asset_tracker_v2/tests/debug_module/twister-out/twister_report.xml...
I tried also to setup a test using ZTEST and this I got to work with having very simple asert true is true,but when I tried to include my project headers in the code it started to complain about missing includes "bluetooth/gatt_dm.h: No such file or directory" even if I had in the prj file set up CONFIG_BT=y.
