nrfutil CLI issues
I'm working on a testbench to flash product with nRF5340 and nRF52840 chips.
In order to erase/flash both I'm using JLink Base compact and nrfutils CLI. But I have fews issues:
  •  Sometimes, the JLink didn't reset successfully (led switch to orange) and the next command line will fail with the error code: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
    • Below the output of the command performed few times in a row where we can se that sometimes operations ends without issue and sometimes error is raised
      > rfutil.exe device recover --serial-number 822007655 --x-family nrf53
      v Recovered 822007655
      > nrfutil.exe device recover --serial-number 822007655 --x-family nrf53
      x Failed to recover 822007655, [jlink] JLINKARM_DLL_ERROR
      Error: One or more recover tasks failed:
       * 822007655: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
  • Commands runnning forever. In some case operation doesn't stop and the only solution is to disconnect/reconnect the JLink. Is there a way to use timeout as parameters in the command lines ? I didn't find topic about that
  • JLink not found with nrfutil:
    • >./nrfutil.exe device list
      FTDPOE5G
      product         TTL232R-3V3
      ports           COM24
      traits          serialPorts, usb
      FTDPOGGJ
      product         TTL232R-3V3
      ports           COM21
      777641824
      product         J-Link
      ports           COM20
      traits          jlink, seggerUsb, serialPorts, usb
    • Here we can see that only one JLink is find while 2 are connected as shown with J-Link Configurator
Any helps on this topics will be appreciated !
Below are some details:
  • nrfutils --version
    • nrfutil 7.12.0 (39003c9 2024-06-10)
    • commit-hash: 39003c9d0e5d946af0f417cfadf4ac55a6d03c19
    • commit-date: 2024-06-10
    • host: x86_64-pc-windows-msvc
    • build-timestamp: 2024-06-10T15:56:55.227746900Z
    • classification: nrf-external
  • SEGGER Tools version V8.12d
I was initialy running the command line in python with subprocess.Popen where I first saw the issues and I was able to reproduce the errors using usual consol (MobaXTerm)
Antoine
  • Hi Jared,
    Thanks for your feedback.
    Plase find the log with the 'trace' settings:
    > ./nrfutil.exe device erase --serial-number 851003768 --log-level trace --log-output stdout --json
    {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 2.7.12, platform = x86_64-pc-windows-msvc) invoked with erase --serial-number 851003768 --log-level trace --log-output stdout --json ","timestamp":"2025-02-03T15:30:09.361Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false","timestamp":"2025-02-03T15:30:09.361Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device","timestamp":"2025-02-03T15:30:09.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:09.379268Z] J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-03T15:30:09.379Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:09.383705Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-03T15:30:09.383Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-02-03T15:30:09.537Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-02-03T15:30:09.537Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-02-03T15:30:09.642Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-02-03T15:30:09.642Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-02-03T15:30:09.642Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-02-03T15:30:09.642Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-02-03T15:30:09.642Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-02-03T15:30:09.642Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command open executed for 101 milliseconds with result 0","timestamp":"2025-02-03T15:30:09.648Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] jlink_dll_version","timestamp":"2025-02-03T15:30:09.648Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0","timestamp":"2025-02-03T15:30:09.649Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command open executed for 6 milliseconds with result 0","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] dll_version","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-02-03T15:30:09.653Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command close executed for 25 milliseconds with result 0","timestamp":"2025-02-03T15:30:09.675Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-03T15:30:09.675Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command terminate executed for 13 milliseconds with result 0","timestamp":"2025-02-03T15:30:09.689Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command close executed for 24 milliseconds with result 0","timestamp":"2025-02-03T15:30:09.690Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-03T15:30:09.720Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 30 milliseconds","timestamp":"2025-02-03T15:30:09.720Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-02-03T15:30:09.773Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-02-03T15:30:09.774Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Executed 4 commands for 139 milliseconds","timestamp":"2025-02-03T15:30:09.774Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-03T15:30:09.774Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"operation to get devices for : Ok(\"{\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"erase\\\",\\\"option\\\":{\\\"chip_erase_mode\\\":\\\"ERASE_ALL\\\",\\\"ext_mem_erase_mode\\\":\\\"ERASE_NONE\\\"}},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")","timestamp":"2025-02-03T15:30:09.779Z"}}
    {"type":"log","data":{"level":"TRACE","message":"Operations required by a device to do: {\"erase\"}","timestamp":"2025-02-03T15:30:09.779Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Checking future_status of enumerate_task_status","timestamp":"2025-02-03T15:30:09.779Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Waiting for enumeration to complete","timestamp":"2025-02-03T15:30:09.779Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: Start","timestamp":"2025-02-03T15:30:09.780Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate","timestamp":"2025-02-03T15:30:09.780Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: enumerate","timestamp":"2025-02-03T15:30:09.781Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0101#000851003768#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.781Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{2CEFC42C-7FE9-5924-A529-2D0ADF8CCB59}'","timestamp":"2025-02-03T15:30:09.781Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {2CEFC42C-7FE9-5924-A529-2D0ADF8CCB59}","timestamp":"2025-02-03T15:30:09.781Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_13D3&PID_56CB#200901010001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.783Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-02-03T15:30:09.783Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-03T15:30:09.783Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-03T15:30:09.784Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-03T15:30:09.784Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-03T15:30:09.784Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_046D&PID_C52B#5&2495b8dd&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.784Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{DA3A406E-66A7-11EF-A018-00090FFE0001}'","timestamp":"2025-02-03T15:30:09.784Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {DA3A406E-66A7-11EF-A018-00090FFE0001}","timestamp":"2025-02-03T15:30:09.784Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-03T15:30:09.785Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0BDA&PID_0129#20100201396000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.785Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-02-03T15:30:09.785Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_8087&PID_0026#5&2495b8dd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Received `0` as descriptor index","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Received `0` as descriptor index","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0105#000777641824#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{3F79306E-37BB-551B-B94B-0FDD0DFF00ED}'","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {3F79306E-37BB-551B-B94B-0FDD0DFF00ED}","timestamp":"2025-02-03T15:30:09.786Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.787Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{E32B6560-907F-59AB-81F9-F77302D6FE1C}'","timestamp":"2025-02-03T15:30:09.787Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {E32B6560-907F-59AB-81F9-F77302D6FE1C}","timestamp":"2025-02-03T15:30:09.787Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.792Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}'","timestamp":"2025-02-03T15:30:09.792Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}","timestamp":"2025-02-03T15:30:09.792Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_20CE&PID_0011#6&28b98d9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.797Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A5762EC0-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-02-03T15:30:09.797Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {A5762EC0-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-02-03T15:30:09.797Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-03T15:30:09.798Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_072F&PID_224F#7&161d3976&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-03T15:30:09.798Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A57630D5-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-02-03T15:30:09.798Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {A57630D5-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-02-03T15:30:09.798Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 1 and serial number: 'FTDPOE5G'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 2 and serial number: 'NONE'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 3 and serial number: 'NONE'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 4 and serial number: 'NONE'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 5 and serial number: '000777641824'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 6 and serial number: '000851003768'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 7 and serial number: 'NONE'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 8 and serial number: 'NONE'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 9 and serial number: 'FTDPOGGJ'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 10 and serial number: 'NONE'","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: After async_lister->enumerate","timestamp":"2025-02-03T15:30:09.799Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'devkit' took 3 ms","timestamp":"2025-02-03T15:30:09.803Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:09.803877Z] J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-03T15:30:09.803Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:09.804157Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-03T15:30:09.804Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:09.816225Z] Found 2 attached J-Link devices","timestamp":"2025-02-03T15:30:09.816Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'Probe' took 12 ms","timestamp":"2025-02-03T15:30:09.816Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] JLinkPlugin::enumerate","timestamp":"2025-02-03T15:30:09.816Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-02-03T15:30:09.964Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-02-03T15:30:09.964Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-02-03T15:30:10.055Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-02-03T15:30:10.055Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-02-03T15:30:10.055Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-02-03T15:30:10.055Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-02-03T15:30:10.055Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-02-03T15:30:10.055Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command open executed for 93 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.061Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] enum_emu_snr","timestamp":"2025-02-03T15:30:10.061Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-02-03T15:30:10.069Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-02-03T15:30:10.069Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command open executed for 6 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.069Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] enum_emu_snr","timestamp":"2025-02-03T15:30:10.069Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-03T15:30:10.069Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr","timestamp":"2025-02-03T15:30:10.069Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr","timestamp":"2025-02-03T15:30:10.069Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus","timestamp":"2025-02-03T15:30:10.069Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 17 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.079Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Found 2 J-Link devices connected","timestamp":"2025-02-03T15:30:10.079Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-03T15:30:10.080Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 15 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.080Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-02-03T15:30:10.095Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-03T15:30:10.095Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-02-03T15:30:10.095Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-02-03T15:30:10.095Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-02-03T15:30:10.095Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-02-03T15:30:10.095Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command close executed for 31 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.111Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-03T15:30:10.111Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.111Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command close executed for 30 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.126Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.126Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 51 milliseconds","timestamp":"2025-02-03T15:30:10.126Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-02-03T15:30:10.158Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-02-03T15:30:10.160Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Executed 4 commands for 141 milliseconds","timestamp":"2025-02-03T15:30:10.160Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-03T15:30:10.160Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'jlink' took 354 ms","timestamp":"2025-02-03T15:30:10.170Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'BOARDCONTROLLER' took 18 ms","timestamp":"2025-02-03T15:30:10.188Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-02-03T15:30:10.191Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"000770602132\", \"000773105148\", \"000777641824\"]","timestamp":"2025-02-03T15:30:10.191Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000770602132 -> GUID: {3ee8b8ef-c412-5b75-917a-0a2f66a13d7a}","timestamp":"2025-02-03T15:30:10.191Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000773105148 -> GUID: {592aca26-535d-56bc-b0cb-33014efdce30}","timestamp":"2025-02-03T15:30:10.191Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000777641824 -> GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-02-03T15:30:10.191Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"000777641824\")","timestamp":"2025-02-03T15:30:10.191Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\USB#VID_1366&PID_0105&MI_00#7&74C87DB&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_1366&PID_0105#000777641824#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-03T15:30:10.191Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-02-03T15:30:10.193Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-02-03T15:30:10.194Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-02-03T15:30:10.194Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-02-03T15:30:10.194Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOGGJ\")","timestamp":"2025-02-03T15:30:10.194Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOGGJA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-03T15:30:10.194Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-02-03T15:30:10.195Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-02-03T15:30:10.195Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-02-03T15:30:10.195Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-02-03T15:30:10.195Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-02-03T15:30:10.195Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-02-03T15:30:10.195Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-02-03T15:30:10.195Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-02-03T15:30:10.195Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOE5G\")","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOE5GA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] try to map FTDI to segger device","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] found FTDI","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: '000777641824'","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOE5G'","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOGGJ'","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'serialport' took 7 ms","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'sdfu' took 0 ms","timestamp":"2025-02-03T15:30:10.196Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'mcuBoot' took 0 ms","timestamp":"2025-02-03T15:30:10.197Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[broken] BrokenPlugin::enumerate","timestamp":"2025-02-03T15:30:10.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'broken' took 0 ms","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: 'FTDPOE5G'","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: device registered to device list","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '<unknown>'","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '000777641824'","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '000851003768'","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: 'FTDPOGGJ'","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Finished in 417 ms","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Completed waiting for enumeration","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: done","timestamp":"2025-02-03T15:30:10.198Z"}}
    {"type":"task_begin","data":{"task":{"id":"83babc43ff6a4adeb076eca63aef9f1a","description":"Erase 851003768","name":"erase","data":{"serialNumber":"000851003768"}}}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.199022Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it","timestamp":"2025-02-03T15:30:10.199Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.199038Z] The device is recognized as a device with a supported probe. Need to run device identification to determine the device family","timestamp":"2025-02-03T15:30:10.199Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.203215Z] Looking for file in C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-02-03T15:30:10.203Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.203406Z] Found file at C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-02-03T15:30:10.203Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.205767Z] Created IPC server 90ceb09f-a777-4202-9a0e-ea8529e40cd7","timestamp":"2025-02-03T15:30:10.206Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.282670Z] Spawned worker process with id 6228","timestamp":"2025-02-03T15:30:10.282Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.284385Z] Accepting IPC connection","timestamp":"2025-02-03T15:30:10.284Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.324609Z] Accepted IPC connection","timestamp":"2025-02-03T15:30:10.324Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.324641Z] The worker supervisor's role is finished","timestamp":"2025-02-03T15:30:10.324Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.327671Z] Received signal from master, returning alive worker.","timestamp":"2025-02-03T15:30:10.327Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.327735Z] Handshake signatures match","timestamp":"2025-02-03T15:30:10.327Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.328294Z] Connection with Probe worker established.","timestamp":"2025-02-03T15:30:10.328Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.329430Z] Starting trace thread","timestamp":"2025-02-03T15:30:10.329Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.323044Z] {jlink_usb_000851003768} nrf-probe version 0.30.0","timestamp":"2025-02-03T15:30:10.330Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.323102Z] {jlink_usb_000851003768} Sending IPC handshake response from worker...","timestamp":"2025-02-03T15:30:10.330Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.323399Z] {jlink_usb_000851003768} Started worker message processing loop","timestamp":"2025-02-03T15:30:10.330Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.328753Z] {jlink_usb_000851003768} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: TargetConfig { adac_timeout: None, swd_clock_frequency: None } }, firmware_config: None, target_family: None, override_detection: None })","timestamp":"2025-02-03T15:30:10.330Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.328832Z] {jlink_usb_000851003768} -> new","timestamp":"2025-02-03T15:30:10.330Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.328937Z] {jlink_usb_000851003768} J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-03T15:30:10.330Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.329137Z] {jlink_usb_000851003768} -> new_from_path","timestamp":"2025-02-03T15:30:10.330Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.340437Z] {jlink_usb_000851003768} Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-03T15:30:10.340Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.340463Z] {jlink_usb_000851003768} <- new_from_path","timestamp":"2025-02-03T15:30:10.340Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.340472Z] {jlink_usb_000851003768} <- new","timestamp":"2025-02-03T15:30:10.340Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.340489Z] {jlink_usb_000851003768} Setting up JLink interface.","timestamp":"2025-02-03T15:30:10.340Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.340501Z] {jlink_usb_000851003768} -> connect","timestamp":"2025-02-03T15:30:10.340Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.340513Z] {jlink_usb_000851003768} Selecting J-Link with serial number 000851003768","timestamp":"2025-02-03T15:30:10.340Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347321Z] {jlink_usb_000851003768} ExecCommand SuppressInfoUpdateFW","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347450Z] {jlink_usb_000851003768} ExecCommand SuppressInfoUpdateFW returned 0","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347462Z] {jlink_usb_000851003768} ExecCommand DisableAutoUpdateFW","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347479Z] {jlink_usb_000851003768} ExecCommand DisableAutoUpdateFW returned 0","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347491Z] {jlink_usb_000851003768} Applied firmware settings to JLink","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347500Z] {jlink_usb_000851003768} ExecCommand SetBatchMode 1","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347515Z] {jlink_usb_000851003768} ExecCommand SetBatchMode 1 returned 0","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347521Z] {jlink_usb_000851003768} ExecCommand SuppressGUI","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347532Z] {jlink_usb_000851003768} ExecCommand SuppressGUI returned 0","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347538Z] {jlink_usb_000851003768} ExecCommand SetAllowFlashCache = 0","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.347557Z] {jlink_usb_000851003768} ExecCommand SetAllowFlashCache = 0 returned 1","timestamp":"2025-02-03T15:30:10.347Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.361142Z] {jlink_usb_000851003768} ExecCommand DisableInfoWinFlashDL","timestamp":"2025-02-03T15:30:10.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.361170Z] {jlink_usb_000851003768} ExecCommand DisableInfoWinFlashDL returned 0","timestamp":"2025-02-03T15:30:10.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.361176Z] {jlink_usb_000851003768} ExecCommand SetRestartOnClose 0","timestamp":"2025-02-03T15:30:10.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.361201Z] {jlink_usb_000851003768} ExecCommand SetRestartOnClose 0 returned 1","timestamp":"2025-02-03T15:30:10.361Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.362884Z] {jlink_usb_000851003768} Speed info: JLINKARM_SPEED_INFO { SizeOfStruct: 12, BaseFreq: 180000000, MinDiv: 12, SupportAdaptive: 1 }","timestamp":"2025-02-03T15:30:10.362Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.362904Z] {jlink_usb_000851003768} Max frequency: 15000 kHz","timestamp":"2025-02-03T15:30:10.362Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.363198Z] {jlink_usb_000851003768} Clock frequency was set to 2000 kHz","timestamp":"2025-02-03T15:30:10.363Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.363219Z] {jlink_usb_000851003768} Retrieved JLink firmware string: J-Link V11 compiled Oct  9 2024 10:52:20","timestamp":"2025-02-03T15:30:10.363Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.363272Z] {jlink_usb_000851003768} Emulator Usb(JLinkSerialNumber(851003768)) running firmware: J-Link V11 compiled Oct  9 2024 10:52:20","timestamp":"2025-02-03T15:30:10.363Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.363286Z] {jlink_usb_000851003768} <- connect","timestamp":"2025-02-03T15:30:10.363Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.363477Z] {jlink_usb_000851003768} Probe worker received message: Request(DeviceInformation)","timestamp":"2025-02-03T15:30:10.363Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.363964Z] {jlink_usb_000851003768} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3306, tck: 0, tdi: 0, tdo: 0, tms: 0, tres: 1, trst: 0 }","timestamp":"2025-02-03T15:30:10.364Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.363977Z] {jlink_usb_000851003768} CORESIGHT_Configure","timestamp":"2025-02-03T15:30:10.364Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.364807Z] {jlink_usb_000851003768} -> Powering up sys and debug region","timestamp":"2025-02-03T15:30:10.364Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.364834Z] {jlink_usb_000851003768} -> write_dp_unchecked","timestamp":"2025-02-03T15:30:10.364Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.365247Z] {jlink_usb_000851003768} DP wrote 0x00000000 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.365Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.365262Z] {jlink_usb_000851003768} <- write_dp_unchecked","timestamp":"2025-02-03T15:30:10.365Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.365276Z] {jlink_usb_000851003768} -> read_dp","timestamp":"2025-02-03T15:30:10.365Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.365763Z] {jlink_usb_000851003768} DP read 0xf0000000 from CTRL/STAT","timestamp":"2025-02-03T15:30:10.365Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.365774Z] {jlink_usb_000851003768} <- read_dp","timestamp":"2025-02-03T15:30:10.365Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.365815Z] {jlink_usb_000851003768} Powered up sys and dbg regions in 0 ms","timestamp":"2025-02-03T15:30:10.365Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.365823Z] {jlink_usb_000851003768} <- Powering up sys and debug region","timestamp":"2025-02-03T15:30:10.365Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.367009Z] {jlink_usb_000851003768} -> detect device family","timestamp":"2025-02-03T15:30:10.367Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.367030Z] {jlink_usb_000851003768} -> read_dp","timestamp":"2025-02-03T15:30:10.367Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.367371Z] {jlink_usb_000851003768} DP read 0x6ba02477 from DPIDR","timestamp":"2025-02-03T15:30:10.367Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.367387Z] {jlink_usb_000851003768} <- read_dp","timestamp":"2025-02-03T15:30:10.367Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.367421Z] {jlink_usb_000851003768} -> read_ap","timestamp":"2025-02-03T15:30:10.367Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.367429Z] {jlink_usb_000851003768} -> write_dp","timestamp":"2025-02-03T15:30:10.367Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.368341Z] {jlink_usb_000851003768} DP wrote 0x00000000 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.368Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.368357Z] {jlink_usb_000851003768} <- write_dp","timestamp":"2025-02-03T15:30:10.368Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[ProbeLib] [2025-02-03 15:30:10.468752Z] {jlink_usb_000851003768} J-Link: Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:10.468Z"}}
    {"type":"log","data":{"level":"WARN","message":"[ProbeLib] [2025-02-03 15:30:10.468787Z] {jlink_usb_000851003768} Read access of AccessPort register 0 failed: Unknown Error in J-Link DLL (error code =-2)","timestamp":"2025-02-03T15:30:10.468Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.468806Z] {jlink_usb_000851003768} Aborting debug operation, writing 0x1FF to ABORT register","timestamp":"2025-02-03T15:30:10.468Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.469387Z] {jlink_usb_000851003768} <- read_ap","timestamp":"2025-02-03T15:30:10.469Z"}}
    {"type":"log","data":{"level":"WARN","message":"[ProbeLib] [2025-02-03 15:30:10.469439Z] {jlink_usb_000851003768} Failed reading AP 0: Failed to read AccessPort register 0: Unknown Error in J-Link DLL (error code =-2)","timestamp":"2025-02-03T15:30:10.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.469461Z] {jlink_usb_000851003768} -> read_ap","timestamp":"2025-02-03T15:30:10.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.469469Z] {jlink_usb_000851003768} -> write_dp","timestamp":"2025-02-03T15:30:10.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.470479Z] {jlink_usb_000851003768} DP wrote 0x01000000 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.470Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.470497Z] {jlink_usb_000851003768} <- write_dp","timestamp":"2025-02-03T15:30:10.470Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.471092Z] {jlink_usb_000851003768} AP 1 read 0x43000002 from CSW(mem-ap) or RESET(ctrl-ap)","timestamp":"2025-02-03T15:30:10.471Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.471108Z] {jlink_usb_000851003768} <- read_ap","timestamp":"2025-02-03T15:30:10.471Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.471117Z] {jlink_usb_000851003768} -> read_ap","timestamp":"2025-02-03T15:30:10.471Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.471123Z] {jlink_usb_000851003768} -> write_dp","timestamp":"2025-02-03T15:30:10.471Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.472128Z] {jlink_usb_000851003768} DP wrote 0x010000f0 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.472Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.472157Z] {jlink_usb_000851003768} <- write_dp","timestamp":"2025-02-03T15:30:10.472Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.472673Z] {jlink_usb_000851003768} AP 1 read 0x84770001 from IDR","timestamp":"2025-02-03T15:30:10.472Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.472690Z] {jlink_usb_000851003768} <- read_ap","timestamp":"2025-02-03T15:30:10.472Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.472702Z] {jlink_usb_000851003768} -> read_ap","timestamp":"2025-02-03T15:30:10.472Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.472710Z] {jlink_usb_000851003768} -> write_dp","timestamp":"2025-02-03T15:30:10.472Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.473586Z] {jlink_usb_000851003768} DP wrote 0x02000000 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.473Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.473603Z] {jlink_usb_000851003768} <- write_dp","timestamp":"2025-02-03T15:30:10.473Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[ProbeLib] [2025-02-03 15:30:10.573675Z] {jlink_usb_000851003768} J-Link: Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:10.573Z"}}
    {"type":"log","data":{"level":"WARN","message":"[ProbeLib] [2025-02-03 15:30:10.573711Z] {jlink_usb_000851003768} Read access of AccessPort register 0 failed: Unknown Error in J-Link DLL (error code =-2)","timestamp":"2025-02-03T15:30:10.573Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.573724Z] {jlink_usb_000851003768} Aborting debug operation, writing 0x1FF to ABORT register","timestamp":"2025-02-03T15:30:10.573Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.574119Z] {jlink_usb_000851003768} <- read_ap","timestamp":"2025-02-03T15:30:10.574Z"}}
    {"type":"log","data":{"level":"WARN","message":"[ProbeLib] [2025-02-03 15:30:10.574138Z] {jlink_usb_000851003768} Failed reading AP 2: Failed to read AccessPort register 0: Unknown Error in J-Link DLL (error code =-2)","timestamp":"2025-02-03T15:30:10.574Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.574182Z] {jlink_usb_000851003768} -> read_ap","timestamp":"2025-02-03T15:30:10.574Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.574197Z] {jlink_usb_000851003768} -> write_dp","timestamp":"2025-02-03T15:30:10.574Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.575088Z] {jlink_usb_000851003768} DP wrote 0x03000000 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.575Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.575103Z] {jlink_usb_000851003768} <- write_dp","timestamp":"2025-02-03T15:30:10.575Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.575550Z] {jlink_usb_000851003768} AP 3 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)","timestamp":"2025-02-03T15:30:10.575Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.575566Z] {jlink_usb_000851003768} <- read_ap","timestamp":"2025-02-03T15:30:10.575Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.575574Z] {jlink_usb_000851003768} -> read_ap","timestamp":"2025-02-03T15:30:10.575Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.575580Z] {jlink_usb_000851003768} -> write_dp","timestamp":"2025-02-03T15:30:10.575Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.576410Z] {jlink_usb_000851003768} DP wrote 0x030000f0 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.576Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.576424Z] {jlink_usb_000851003768} <- write_dp","timestamp":"2025-02-03T15:30:10.576Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.576858Z] {jlink_usb_000851003768} AP 3 read 0x12880000 from IDR","timestamp":"2025-02-03T15:30:10.576Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.576869Z] {jlink_usb_000851003768} <- read_ap","timestamp":"2025-02-03T15:30:10.576Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.576945Z] {jlink_usb_000851003768} Detected CTRL-AP revision 1 at AP 3","timestamp":"2025-02-03T15:30:10.577Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.576988Z] {jlink_usb_000851003768} -> read_ap","timestamp":"2025-02-03T15:30:10.577Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.576996Z] {jlink_usb_000851003768} -> write_dp","timestamp":"2025-02-03T15:30:10.577Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.577924Z] {jlink_usb_000851003768} DP wrote 0x03000030 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.577Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.577938Z] {jlink_usb_000851003768} <- write_dp","timestamp":"2025-02-03T15:30:10.578Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.578332Z] {jlink_usb_000851003768} AP 3 read 0x00000007 from Unknown AP address 0x30","timestamp":"2025-02-03T15:30:10.578Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.578352Z] {jlink_usb_000851003768} <- read_ap","timestamp":"2025-02-03T15:30:10.578Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.578361Z] {jlink_usb_000851003768} -> read_ap","timestamp":"2025-02-03T15:30:10.578Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.578370Z] {jlink_usb_000851003768} -> write_dp","timestamp":"2025-02-03T15:30:10.578Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.579210Z] {jlink_usb_000851003768} DP wrote 0x03000030 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.579Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.579226Z] {jlink_usb_000851003768} <- write_dp","timestamp":"2025-02-03T15:30:10.579Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.579641Z] {jlink_usb_000851003768} AP 3 read 0x00000005 from Unknown AP address 0x34","timestamp":"2025-02-03T15:30:10.579Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.579656Z] {jlink_usb_000851003768} <- read_ap","timestamp":"2025-02-03T15:30:10.579Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.579666Z] {jlink_usb_000851003768} Device detection: partno 0x00000007 hwrevision 0x00000005","timestamp":"2025-02-03T15:30:10.579Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.579675Z] {jlink_usb_000851003768} <- detect device family","timestamp":"2025-02-03T15:30:10.579Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.583162Z] Got regular response.","timestamp":"2025-02-03T15:30:10.583Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.583203Z] Device family nRF53 not NRF54H/NRF54L, not supported by probe-plugin","timestamp":"2025-02-03T15:30:10.583Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.583537Z] Expecting trace channel to disconnect.","timestamp":"2025-02-03T15:30:10.583Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.583561Z] Terminating worker with id 6228","timestamp":"2025-02-03T15:30:10.583Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.583586Z] Waiting for worker to exit.","timestamp":"2025-02-03T15:30:10.583Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.583626Z] {jlink_usb_000851003768} Probe worker received message: Shutdown","timestamp":"2025-02-03T15:30:10.583Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.583679Z] {jlink_usb_000851003768} -> Powering down debug region","timestamp":"2025-02-03T15:30:10.583Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.583692Z] {jlink_usb_000851003768} -> write_dp_unchecked","timestamp":"2025-02-03T15:30:10.583Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584072Z] {jlink_usb_000851003768} DP wrote 0x00000000 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.584Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584088Z] {jlink_usb_000851003768} <- write_dp_unchecked","timestamp":"2025-02-03T15:30:10.584Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584098Z] {jlink_usb_000851003768} -> read_dp","timestamp":"2025-02-03T15:30:10.584Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584491Z] {jlink_usb_000851003768} DP read 0xf0000040 from CTRL/STAT","timestamp":"2025-02-03T15:30:10.584Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584505Z] {jlink_usb_000851003768} <- read_dp","timestamp":"2025-02-03T15:30:10.584Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584527Z] {jlink_usb_000851003768} -> write_dp_unchecked","timestamp":"2025-02-03T15:30:10.584Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584910Z] {jlink_usb_000851003768} DP wrote 0x00000000 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.584Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584923Z] {jlink_usb_000851003768} <- write_dp_unchecked","timestamp":"2025-02-03T15:30:10.585Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.584930Z] {jlink_usb_000851003768} -> read_dp","timestamp":"2025-02-03T15:30:10.585Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.585342Z] {jlink_usb_000851003768} DP read 0xf0000040 from CTRL/STAT","timestamp":"2025-02-03T15:30:10.585Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.585379Z] Waiting for worker to exit.","timestamp":"2025-02-03T15:30:10.585Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.585355Z] {jlink_usb_000851003768} <- read_dp","timestamp":"2025-02-03T15:30:10.585Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.585366Z] {jlink_usb_000851003768} -> write_dp_unchecked","timestamp":"2025-02-03T15:30:10.585Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.585815Z] {jlink_usb_000851003768} DP wrote 0x00000000 to CTRL/STAT = 0x04","timestamp":"2025-02-03T15:30:10.585Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.585828Z] {jlink_usb_000851003768} <- write_dp_unchecked","timestamp":"2025-02-03T15:30:10.585Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.586941Z] Waiting for worker to exit.","timestamp":"2025-02-03T15:30:10.586Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.587927Z] {jlink_usb_000851003768} -> write_dp_unchecked","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.588421Z] {jlink_usb_000851003768} DP wrote 0x00000000 to SELECT = 0x08","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.588439Z] {jlink_usb_000851003768} <- write_dp_unchecked","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.588454Z] {jlink_usb_000851003768} -> read_dp","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.588824Z] {jlink_usb_000851003768} DP read 0x00000040 from CTRL/STAT","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.588838Z] {jlink_usb_000851003768} <- read_dp","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.588873Z] {jlink_usb_000851003768} Powered down sys and dbg regions in 4 ms","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.588884Z] {jlink_usb_000851003768} <- Powering down debug region","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.588902Z] {jlink_usb_000851003768} Closing emulator connection","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.588911Z] {jlink_usb_000851003768} Closing connection to J-Link","timestamp":"2025-02-03T15:30:10.588Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.589055Z] Waiting for worker to exit.","timestamp":"2025-02-03T15:30:10.589Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.592641Z] Waiting for worker to exit.","timestamp":"2025-02-03T15:30:10.592Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.598655Z] Waiting for worker to exit.","timestamp":"2025-02-03T15:30:10.598Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-03 15:30:10.601426Z] {jlink_usb_000851003768} Probe worker stopped.","timestamp":"2025-02-03T15:30:10.601Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.605671Z] Trace channel disconnected as expected.","timestamp":"2025-02-03T15:30:10.605Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.605749Z] Trace thread ends now...","timestamp":"2025-02-03T15:30:10.605Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.607635Z] Waiting for worker to exit.","timestamp":"2025-02-03T15:30:10.607Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-03 15:30:10.620979Z] Worker exited successfully","timestamp":"2025-02-03T15:30:10.621Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-03 15:30:10.621012Z] Joined trace thread.","timestamp":"2025-02-03T15:30:10.621Z"}}
    {"type":"log","data":{"level":"INFO","message":"Loaded plugin C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl; starting to resolve symbols","timestamp":"2025-02-03T15:30:10.622Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] NRFDL::JLinkPlugin::JLinkPLugin()","timestamp":"2025-02-03T15:30:10.622Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Initializing the J-Link debug probe for device {\"id\":6,\"probe\":{},\"serialNumber\":\"000851003768\",\"traits\":{\"boardController\":false,\"broken\":false,\"devkit\":false,\"jlink\":true,\"mcuBoot\":false,\"modem\":false,\"nordicDfu\":false,\"nordicUsb\":false,\"seggerUsb\":true,\"serialPorts\":false,\"usb\":true},\"usb\":{\"device\":{\"address\":37,\"busNumber\":1,\"descriptor\":{\"bDescriptorType\":1,\"bcdDevice\":256,\"idProduct\":257,\"idVendor\":4966}},\"manufacturer\":\"SEGGER\",\"osDevicePath\":\"\\\\\\\\?\\\\USB#VID_1366&PID_0101#000851003768#{a5dcbf10-6530-11d2-901f-00c04fb951ed}\",\"product\":\"J-Link\",\"serialNumber\":\"000851003768\"},\"usbIdentifier\":\"\\\\\\\\?\\\\USB#VID_1366&PID_0101#000851003768#{A5DCBF10-6530-11D2-901F-00C04FB951ED}\"} with serial number: 000851003768","timestamp":"2025-02-03T15:30:10.622Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Opening J-Link DLL","timestamp":"2025-02-03T15:30:10.623Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] open","timestamp":"2025-02-03T15:30:10.775Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] start","timestamp":"2025-02-03T15:30:10.775Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] jprog progress event disabled","timestamp":"2025-02-03T15:30:10.862Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Logger sink registered in Segger backend logger","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][000851003768] Logger sink registered in JLink logger","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000851003768] open","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000851003768] just_check_family","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] open_dll","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] jprog progress event disabled","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][000851003768] Command open executed for 91 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] connect_to_emu_with_snr","timestamp":"2025-02-03T15:30:10.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] jprog progress event disabled","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Set batch mode","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] dll_version","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][000851003768] Command open executed for 6 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000851003768] connect_to_emu_with_snr","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] is_connected_to_emu","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] connect_to_emu_with_snr","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_enum_emu_snr","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_get_num_emus","timestamp":"2025-02-03T15:30:10.879Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_connect_to_emu_with_snr","timestamp":"2025-02-03T15:30:10.891Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_connect_to_emu_without_snr","timestamp":"2025-02-03T15:30:10.902Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Segger logging enabled.","timestamp":"2025-02-03T15:30:10.902Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Firmware: J-Link V11 compiled Oct  9 2024 10:52:20","timestamp":"2025-02-03T15:30:10.923Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Hardware: V11.00","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] S/N: 851003768","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] OEM: SEGGER","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Bootloader: 2019 Jul 04","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] USB speed mode: High speed (480 MBit/s)","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] TELNET listener socket opened on port 19021","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] WEBSRV WEBSRV_Init(): Starting webserver thread(s)","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] WEBSRV Webserver running on local port 19080","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Looking for J-Link GUI Server exe at: C:\\Program Files\\SEGGER\\JLink\\JLinkGUIServer.exe ","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Forking J-Link GUI Server: C:\\Program Files\\SEGGER\\JLink\\JLinkGUIServer.exe ","timestamp":"2025-02-03T15:30:10.935Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] J-Link GUI Server info: \"J-Link GUI server V8.10f \" ","timestamp":"2025-02-03T15:30:10.988Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][000851003768] Command connect_to_emu_with_snr executed for 124 milliseconds with result 0","timestamp":"2025-02-03T15:30:10.994Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] read_device_family","timestamp":"2025-02-03T15:30:10.994Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 79.652ms returns \"O.K.\"  ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_Lock()  ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_ExecCommand(\"SetRestartOnClose = 0\", ...).   ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.001ms returns 0x01  ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_ExecCommand(\"DisableFlashDL\", ...).   ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.000ms returns 0x00  ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_ExecCommand(\"ExcludeFlashCacheRange 0x0-0xFFFFFFFF\", ...).   ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.002ms returns 0x00  ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_SetHookUnsecureDialog  ","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_SetHookUnsecureDialog(...)","timestamp":"2025-02-03T15:30:11.000Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.012ms returns 0  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_TIF_Select(JLINKARM_TIF_SWD)  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 1.782ms returns 0x00  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_GetSpeedInfo()  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] 180000000 Hz / n, n >= 12","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.013ms   ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Connected emulator supports SWD speeds up to 15000kHz","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_SetSpeed(2000)  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.305ms   ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_GetSpeed()  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.004ms returns 2000  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] SWD clock set to 2000kHz","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_GetSN()  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.006ms returns 851003768  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.026ms   ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000851003768] read_device_family","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][000851003768] Command connect_to_emu_with_snr executed for 122 milliseconds with result 0","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] is_connected_to_emu","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_IsOpen()  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.004ms returns 0x01  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_Lock()  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_debug_port_idr","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_debug_port_register","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_debug_port_register","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] coresight_configure","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_GetHWStatus(...)  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.407ms returns 0  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_Configure()  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.801ms returns 0  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_debug_port_register","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.549ms returns 0  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x6BA02477","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.449ms returns 0  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.511ms returns 0  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_is_debug_region_powered","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0xF0000040","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.523ms returns 0  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x000000F0)  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.480ms returns 0  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.001Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.231ms returns -2  ","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.482ms returns 0  ","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.109Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.128ms returns -2  ","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.579ms returns 0  ","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.208Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.409ms returns -2  ","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.821ms returns 0  ","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.011ms returns -2  ","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.577ms returns 0  ","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.411Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.307ms returns -2  ","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.526ms returns 0  ","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.535ms returns -2  ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.538ms returns 0  ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 1, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)  ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.462ms returns 0  ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x84770001","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.590ms returns 0  ","timestamp":"2025-02-03T15:30:11.606Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 1, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)  ","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.364ms returns 0  ","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x43000002","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.428ms returns 0  ","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 2, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x020000F0)  ","timestamp":"2025-02-03T15:30:11.607Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.311ms returns 0  ","timestamp":"2025-02-03T15:30:11.616Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.617Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.617Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 99.823ms returns -2  ","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.437ms returns 0  ","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.717Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 99.659ms returns -2  ","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.632ms returns 0  ","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.814Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.099ms returns -2  ","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.531ms returns 0  ","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:11.912Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.717ms returns -2  ","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.807ms returns 0  ","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.020Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 99.790ms returns -2  ","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.529ms returns 0  ","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.117Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.625ms returns -2  ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.738ms returns 0  ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 3, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x030000F0)  ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.720ms returns 0  ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x12880000","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.596ms returns 0  ","timestamp":"2025-02-03T15:30:12.213Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.214Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 3, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.214Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x03000000)  ","timestamp":"2025-02-03T15:30:12.214Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.534ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x00000000","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.541ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 4, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x040000F0)  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.507ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.890ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 4, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x04000000)  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.791ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.584ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 5, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x050000F0)  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.550ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.604ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 5, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x05000000)  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.530ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.582ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 6, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x060000F0)  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.569ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.481ms returns 0  ","timestamp":"2025-02-03T15:30:12.225Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 6, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x06000000)  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.522ms returns 0  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x00000000","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.502ms returns 0  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 7, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x070000F0)  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.466ms returns 0  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.529ms returns 0  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 7, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x07000000)  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.473ms returns 0  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 8, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x080000F0)  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.440ms returns 0  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.578ms returns 0  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 8, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x08000000)  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.444ms returns 0  ","timestamp":"2025-02-03T15:30:12.226Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x00000000","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.552ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 9, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x090000F0)  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.533ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.579ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 9, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x09000000)  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.492ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.511ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 10, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0A0000F0)  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.468ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.453ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 10, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0A000000)  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.536ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.510ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 11, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0B0000F0)  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.509ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.440ms returns 0  ","timestamp":"2025-02-03T15:30:12.240Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 11, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0B000000)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.439ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x00000000","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.466ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 12, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0C0000F0)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.421ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.463ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 12, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0C000000)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.429ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.461ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 13, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0D0000F0)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.437ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 13, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0D000000)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.449ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.446ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 14, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0E0000F0)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.398ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.470ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 14, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0E000000)  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.510ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.540ms returns 0  ","timestamp":"2025-02-03T15:30:12.241Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 15, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0F0000F0)  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.431ms returns 0  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x00000000","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.485ms returns 0  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 15, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0F000000)  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.409ms returns 0  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.470ms returns 0  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 16, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x100000F0)  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.521ms returns 0  ","timestamp":"2025-02-03T15:30:12.242Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][000851003768] Command read_device_family executed for 1250 milliseconds with result 0","timestamp":"2025-02-03T15:30:12.245Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] select_family","timestamp":"2025-02-03T15:30:12.247Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][000851003768] Command select_family executed for 4 milliseconds with result 0","timestamp":"2025-02-03T15:30:12.252Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Executing erase on device {\"id\":6,\"probe\":{},\"serialNumber\":\"000851003768\",\"traits\":{\"boardController\":false,\"broken\":false,\"devkit\":false,\"jlink\":true,\"mcuBoot\":false,\"modem\":false,\"nordicDfu\":false,\"nordicUsb\":false,\"seggerUsb\":true,\"serialPorts\":false,\"usb\":true},\"usb\":{\"device\":{\"address\":37,\"busNumber\":1,\"descriptor\":{\"bDescriptorType\":1,\"bcdDevice\":256,\"idProduct\":257,\"idVendor\":4966}},\"manufacturer\":\"SEGGER\",\"osDevicePath\":\"\\\\\\\\?\\\\USB#VID_1366&PID_0101#000851003768#{a5dcbf10-6530-11d2-901f-00c04fb951ed}\",\"product\":\"J-Link\",\"serialNumber\":\"000851003768\"},\"usbIdentifier\":\"\\\\\\\\?\\\\USB#VID_1366&PID_0101#000851003768#{A5DCBF10-6530-11D2-901F-00C04FB951ED}\"}","timestamp":"2025-02-03T15:30:12.253Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] parsed_options = {\"option\":{\"chip_erase_mode\":\"ERASE_ALL\",\"ext_mem_erase_mode\":\"ERASE_NONE\"},\"type\":\"erase\"}","timestamp":"2025-02-03T15:30:12.253Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] read_memory_descriptors","timestamp":"2025-02-03T15:30:12.253Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x00000000","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.436ms returns 0  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 16, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x10000000)  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.466ms returns 0  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.518ms returns 0  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_idr","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 17, DP Bank 0, AP Bank 15","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x110000F0)  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.467ms returns 0  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.465ms returns 0  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 17, DP Bank 0, AP Bank 0","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x11000000)  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.440ms returns 0  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.403ms returns 0  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 3, DP Bank 0, AP Bank 3","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x03000030)  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.463ms returns 0  ","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x00000007","timestamp":"2025-02-03T15:30:12.254Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.521ms returns 0  ","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] jprog progress event disabled","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.024ms   ","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][000851003768] Command read_device_family executed for 1249 milliseconds with result 0","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000851003768] Just_load_coprocessor_data","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] set_core_data","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Set core data:","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768]   Device ID: Cortex-M33","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768]   Expected core: 235012351","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768]   Existing Expected core: 4294967295","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768]   Coprocessor: APPLICATION","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768]   AHB AP index: 0","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768]   Core base address: 4294967295","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---set_coresight_ahb_ap_index","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_ExecCommand(\"CORESIGHT_SetIndexAHBAPToUse = 0\", ...).   ","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.447ms returns 0x00  ","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_ExecCommand(\"device = Cortex-M33\", ...).   ","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Device \"CORTEX-M33\" selected.","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.850ms returns 0x00  ","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][000851003768] Command select_family executed for 1 milliseconds with result 0","timestamp":"2025-02-03T15:30:12.255Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000851003768] read_memory_descriptors","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] is_connected_to_emu","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_IsOpen()  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.010ms returns 0x01  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_Lock()  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000851003768] Just_read_memory_descriptors","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000851003768] Just_readback_status","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] read_access_port_register","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_access_port_register","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_is_debug_region_powered","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_debug_port_register","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_debug_port_register","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.490ms returns 0  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0xF0000040","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.469ms returns 0  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_access_port_register","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.264Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.533ms returns -2  ","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.493ms returns 0  ","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.361Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.266ms returns -2  ","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.397ms returns 0  ","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.469Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.565Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 99.606ms returns -2  ","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.553ms returns 0  ","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.566Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.664Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.664Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.664Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.351ms returns -2  ","timestamp":"2025-02-03T15:30:12.664Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.664Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.664Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.664Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.664Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.665Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.795ms returns 0  ","timestamp":"2025-02-03T15:30:12.665Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.665Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.665Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.100ms returns -2  ","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.402ms returns 0  ","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)  ","timestamp":"2025-02-03T15:30:12.764Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][Client][000851003768] Encountered error -102: Command read_memory_descriptors executed for 608 milliseconds with result -102","timestamp":"2025-02-03T15:30:12.862Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768]    ***** Error: ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] failed","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 100.825ms returns -2  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][JLink][000851003768] Not supported by current CPU + target interface combination.","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_abort_debug_action","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Attempting to clear any configuration errors in debug port before closing connection. ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.902ms returns 0  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.116ms   ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"ERROR","message":"[jlink] [NRFJPROG][Worker][000851003768] Failed to read access port 0 register 0.\nThis indicates that the debug port is available, but the access port is not.\nAn unknown error.","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][000851003768] Command read_memory_descriptors executed for 606 milliseconds with result -102","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000851003768] close","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] is_connected_to_emu","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_IsOpen()  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.007ms returns 0x01  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_Lock()  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] close","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] disconnect_from_emu","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_disconnect_from_emu","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] is_connected_to_device","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_is_debug_region_powered","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_read_debug_port_register","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_select_debug_port_register","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.573ms returns 0  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0xF0000000","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.546ms returns 0  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] unpower_debug_and_system_regions","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] ---just_write_debug_port_register","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.826ms returns 0  ","timestamp":"2025-02-03T15:30:12.871Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] Value=0x00000000","timestamp":"2025-02-03T15:30:12.872Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.597ms returns 0  ","timestamp":"2025-02-03T15:30:12.872Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_HasError()  ","timestamp":"2025-02-03T15:30:12.872Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] - 0.008ms   ","timestamp":"2025-02-03T15:30:12.872Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][JLink][000851003768] JLINK_Close()  ","timestamp":"2025-02-03T15:30:12.882Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][000851003768] Command close executed for 47 milliseconds with result 0","timestamp":"2025-02-03T15:30:12.910Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] terminate","timestamp":"2025-02-03T15:30:12.910Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000851003768] Segger Backend closed.","timestamp":"2025-02-03T15:30:12.925Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][000851003768] Command terminate executed for 14 milliseconds with result 0","timestamp":"2025-02-03T15:30:12.925Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000851003768] nRF family DLL closed","timestamp":"2025-02-03T15:30:12.925Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][000851003768] Command close executed for 46 milliseconds with result 0","timestamp":"2025-02-03T15:30:12.925Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][000851003768] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-03T15:30:12.956Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][000851003768] Executed 7 commands for 2030 milliseconds","timestamp":"2025-02-03T15:30:12.956Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] Worker process exited with code: 0","timestamp":"2025-02-03T15:30:12.957Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] Child process terminated with result 0","timestamp":"2025-02-03T15:30:12.959Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][000851003768] Executed 7 commands for 2138 milliseconds","timestamp":"2025-02-03T15:30:12.959Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000851003768] terminate","timestamp":"2025-02-03T15:30:12.959Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"~async_task id: 2183052676090","timestamp":"2025-02-03T15:30:12.970Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Task 2183052676090 is already completed","timestamp":"2025-02-03T15:30:12.970Z"}}
    {"type":"log","data":{"level":"INFO","message":"~plugin_container(0x236d35f9330): close plugin dll at path: C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl","timestamp":"2025-02-03T15:30:12.970Z"}}
    {"type":"task_end","data":{"task":{"id":"83babc43ff6a4adeb076eca63aef9f1a","description":"Erase 851003768","name":"erase","data":{"serialNumber":"000851003768"}},"message":"Failed to erase 851003768, [jlink] JLINKARM_DLL_ERROR","result":"fail","error":{"code":9,"description":"Nrfjlink"}}}
    {"type":"log","data":{"level":"DEBUG","message":"~plugin_container(0x236d35f9330): closed plugin dll at path: C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl","timestamp":"2025-02-03T15:30:12.970Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::shutDown()","timestamp":"2025-02-03T15:30:12.970Z"}}
    Error: One or more erase tasks failed:
     * 851003768: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
    I was initially using a J-Link Base Compact and just tried with J-Link PLUS compact but same issue.
    The target is powered through testbench interface. This is a custom PCBA with nRF53 and nRF52. Before the programming step (recover, erase program), all the target voltages are measured so power supply should be ok arriving at the programming step. (And using J-Flash voltage is reported as 3.3V on the chip)
    EDIT:
    The issues seems to be caused by the chip protection (that's why I'm using 'recover' function). After erasing the chip using J-Flash Lite, I'm able to run nrfutils command without fail. How the security can output issue with recover command ?
    Antoine Bricard
    Regarding this issue:
    Here we can see that only one JLink is find while 2 are connected as shown with J-Link Configurator
    We've found an issue in enumeration when running
    device list
     which will be fixed in the next release.
    Antoine.B said:
    Thanks for your feedback.
    Plase find the log with the 'trace' settings:
    I've shared the log with our developers and they noticed that there seem to be cases where the application core is not accessible, and other cases where it's not possible to communicate with the chip.
    Questions:
    1. Does `nrfutil recover --core Network` work more reliably? This will erase the application core as well as the network core.
    2. Does adding a pin reset
      --reset-kind RESET_PIN
       after the recover operation improve stability? If you don't have pin reset available, just try a normal reset with nrfutil, but we prefer a pinreset if possible.
    3. Does the problem happen with any kind of firmware? E.g. does a simple blinky example from the SDK show this behavior?
    4. Do you see this behavior on only specific produced samples or on all of your samples?
    best regards
    Jared
  • Hi Jared,
    Ok, good news. Waiting for the next release then.
    Please find below my replies:
    1. I tried to recover network and core separately as proposed in this thread ( Unable to recover device using nrfutil or nrfjprog but desktop GUI works) but this doesn't work neither. Here are the log:
    > ./nrfutil.exe device recover --core Network --serial-number 822007655 --log-level trace --log-o      {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 2.7.12, platform = x86_64-pc-windows-msvc) invoked with recover --core Network --serial-number 822007655 --log-level trace --log-output stdout --json ","timestamp":"2025-02-07T11:38:55.112Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false","timestamp":"2025-02-07T11:38:55.112Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device","timestamp":"2025-02-07T11:38:55.112Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.127056Z] J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-07T11:38:55.127Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.130791Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-07T11:38:55.130Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-02-07T11:38:55.280Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-02-07T11:38:55.280Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-02-07T11:38:55.364Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-02-07T11:38:55.364Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-02-07T11:38:55.364Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-02-07T11:38:55.364Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-02-07T11:38:55.364Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-02-07T11:38:55.364Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command open executed for 84 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.368Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] jlink_dll_version","timestamp":"2025-02-07T11:38:55.368Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.368Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command open executed for 5 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] dll_version","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-02-07T11:38:55.375Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command close executed for 25 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.394Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-07T11:38:55.394Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command close executed for 23 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.408Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command terminate executed for 13 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.408Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.424Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 28 milliseconds","timestamp":"2025-02-07T11:38:55.424Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-02-07T11:38:55.426Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-02-07T11:38:55.427Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Executed 4 commands for 122 milliseconds","timestamp":"2025-02-07T11:38:55.427Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-07T11:38:55.427Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"operation to get devices for : Ok(\"{\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"recover\\\"},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_NETWORK\\\"}]}\")","timestamp":"2025-02-07T11:38:55.437Z"}}
    {"type":"log","data":{"level":"TRACE","message":"Operations required by a device to do: {\"recover\"}","timestamp":"2025-02-07T11:38:55.437Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Checking future_status of enumerate_task_status","timestamp":"2025-02-07T11:38:55.437Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Waiting for enumeration to complete","timestamp":"2025-02-07T11:38:55.437Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: Start","timestamp":"2025-02-07T11:38:55.438Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate","timestamp":"2025-02-07T11:38:55.438Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: enumerate","timestamp":"2025-02-07T11:38:55.438Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_13D3&PID_56CB#200901010001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.438Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-02-07T11:38:55.438Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-07T11:38:55.438Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:38:55.439Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:38:55.439Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:38:55.439Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_1020#000822007655#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.439Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{09126C94-2B5D-5FCC-A627-3EE878ACF089}'","timestamp":"2025-02-07T11:38:55.439Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {09126C94-2B5D-5FCC-A627-3EE878ACF089}","timestamp":"2025-02-07T11:38:55.440Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_20CE&PID_0011#6&28b98d9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.440Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A5762EC0-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-02-07T11:38:55.440Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {A5762EC0-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-02-07T11:38:55.440Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0BDA&PID_0129#20100201396000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_8087&PID_0026#5&2495b8dd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Received `0` as descriptor index","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Received `0` as descriptor index","timestamp":"2025-02-07T11:38:55.441Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-07T11:38:55.442Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_046D&PID_C52B#7&161d3976&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.442Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{102FF28B-5E07-11EF-A017-00090FFE0001}'","timestamp":"2025-02-07T11:38:55.442Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {102FF28B-5E07-11EF-A017-00090FFE0001}","timestamp":"2025-02-07T11:38:55.442Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-07T11:38:55.443Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0105#000770208553#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.443Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{9C391A66-09CA-5984-9054-0EF374429BDE}'","timestamp":"2025-02-07T11:38:55.443Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {9C391A66-09CA-5984-9054-0EF374429BDE}","timestamp":"2025-02-07T11:38:55.443Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTE1GLU7#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.444Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{E6493F94-5729-5E6F-80AC-EA9D4F34F3D3}'","timestamp":"2025-02-07T11:38:55.444Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {E6493F94-5729-5E6F-80AC-EA9D4F34F3D3}","timestamp":"2025-02-07T11:38:55.444Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTE1HXK3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:38:55.448Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{F2CA1033-9FDA-5A27-A589-E0A6C30F5A41}'","timestamp":"2025-02-07T11:38:55.448Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {F2CA1033-9FDA-5A27-A589-E0A6C30F5A41}","timestamp":"2025-02-07T11:38:55.448Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 1 and serial number: 'NONE'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 2 and serial number: 'NONE'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 3 and serial number: 'FTE1GLU7'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 4 and serial number: 'NONE'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 5 and serial number: 'NONE'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 6 and serial number: '000770208553'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 7 and serial number: '000822007655'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 8 and serial number: 'FTE1HXK3'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 9 and serial number: 'NONE'","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: After async_lister->enumerate","timestamp":"2025-02-07T11:38:55.453Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'devkit' took 3 ms","timestamp":"2025-02-07T11:38:55.457Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.457433Z] J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-07T11:38:55.457Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.457611Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-07T11:38:55.457Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.464381Z] Found 2 attached J-Link devices","timestamp":"2025-02-07T11:38:55.464Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'Probe' took 7 ms","timestamp":"2025-02-07T11:38:55.464Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] JLinkPlugin::enumerate","timestamp":"2025-02-07T11:38:55.464Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-02-07T11:38:55.620Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-02-07T11:38:55.620Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-02-07T11:38:55.703Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-02-07T11:38:55.703Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-02-07T11:38:55.703Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-02-07T11:38:55.703Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-02-07T11:38:55.703Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-02-07T11:38:55.703Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command open executed for 85 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.708Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] enum_emu_snr","timestamp":"2025-02-07T11:38:55.708Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-02-07T11:38:55.714Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-02-07T11:38:55.714Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command open executed for 5 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.714Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] enum_emu_snr","timestamp":"2025-02-07T11:38:55.714Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-07T11:38:55.714Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr","timestamp":"2025-02-07T11:38:55.714Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr","timestamp":"2025-02-07T11:38:55.714Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus","timestamp":"2025-02-07T11:38:55.714Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 12 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.721Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Found 2 J-Link devices connected","timestamp":"2025-02-07T11:38:55.721Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-07T11:38:55.725Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 12 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.725Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-02-07T11:38:55.725Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-02-07T11:38:55.725Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-02-07T11:38:55.725Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-02-07T11:38:55.725Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-02-07T11:38:55.738Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command close executed for 17 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.739Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-07T11:38:55.739Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.739Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command close executed for 16 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.754Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:38:55.754Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 33 milliseconds","timestamp":"2025-02-07T11:38:55.754Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-02-07T11:38:55.786Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-02-07T11:38:55.787Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Executed 4 commands for 114 milliseconds","timestamp":"2025-02-07T11:38:55.787Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-07T11:38:55.787Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'jlink' took 335 ms","timestamp":"2025-02-07T11:38:55.800Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'BOARDCONTROLLER' took 17 ms","timestamp":"2025-02-07T11:38:55.817Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {9c391a66-09ca-5984-9054-0ef374429bde}","timestamp":"2025-02-07T11:38:55.820Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"000770208553\", \"000770602132\", \"000773105148\", \"000777641824\"]","timestamp":"2025-02-07T11:38:55.820Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000770208553 -> GUID: {9c391a66-09ca-5984-9054-0ef374429bde}","timestamp":"2025-02-07T11:38:55.820Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"000770208553\")","timestamp":"2025-02-07T11:38:55.820Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\USB#VID_1366&PID_0105&MI_00#7&31D7DF8B&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_1366&PID_0105#000770208553#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-07T11:38:55.820Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {e6493f94-5729-5e6f-80ac-ea9d4f34f3d3}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOE9B\", \"FTDPOGGJ\", \"FTE1GLU7\", \"FTE1HXJX\", \"FTE1HXK3\"]","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE9B -> GUID: {bd8763ce-455f-59b8-939a-ea597447f3dc}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTE1GLU7 -> GUID: {e6493f94-5729-5e6f-80ac-ea9d4f34f3d3}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTE1GLU7\")","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTE1GLU7A#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTE1GLU7#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-07T11:38:55.822Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {f2ca1033-9fda-5a27-a589-e0a6c30f5a41}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOE9B\", \"FTDPOGGJ\", \"FTE1GLU7\", \"FTE1HXJX\", \"FTE1HXK3\"]","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE9B -> GUID: {bd8763ce-455f-59b8-939a-ea597447f3dc}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTE1GLU7 -> GUID: {e6493f94-5729-5e6f-80ac-ea9d4f34f3d3}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTE1HXJX -> GUID: {9c3d734a-a1ff-5292-96e0-29a60a93a060}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTE1HXK3 -> GUID: {f2ca1033-9fda-5a27-a589-e0a6c30f5a41}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTE1HXK3\")","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTE1HXK3A#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTE1HXK3#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-07T11:38:55.824Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] try to map FTDI to segger device","timestamp":"2025-02-07T11:38:55.825Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] found FTDI","timestamp":"2025-02-07T11:38:55.825Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: '000770208553'","timestamp":"2025-02-07T11:38:55.825Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTE1GLU7'","timestamp":"2025-02-07T11:38:55.825Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTE1HXK3'","timestamp":"2025-02-07T11:38:55.825Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'serialport' took 7 ms","timestamp":"2025-02-07T11:38:55.825Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'sdfu' took 0 ms","timestamp":"2025-02-07T11:38:55.825Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'mcuBoot' took 0 ms","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[broken] BrokenPlugin::enumerate","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'broken' took 0 ms","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '<unknown>'","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: 'FTE1GLU7'","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: device registered to device list","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '000770208553'","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '000822007655'","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: 'FTE1HXK3'","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Finished in 388 ms","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Completed waiting for enumeration","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: done","timestamp":"2025-02-07T11:38:55.826Z"}}
    {"type":"task_begin","data":{"task":{"id":"ee63a8e977a9476e9180432d189a0519","description":"Recover 822007655","name":"recover","data":{"serialNumber":"000822007655"}}}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.827336Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it","timestamp":"2025-02-07T11:38:55.827Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.827351Z] The device is recognized as a device with a supported probe. Need to run device identification to determine the device family","timestamp":"2025-02-07T11:38:55.827Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.827381Z] Looking for file in C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-02-07T11:38:55.827Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.827465Z] Found file at C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-02-07T11:38:55.827Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.827557Z] Created IPC server cca6872c-1f3b-4ae4-b6fb-298cd9667422","timestamp":"2025-02-07T11:38:55.827Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.830997Z] Spawned worker process with id 23576","timestamp":"2025-02-07T11:38:55.831Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.831119Z] Accepting IPC connection","timestamp":"2025-02-07T11:38:55.831Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.852543Z] Accepted IPC connection","timestamp":"2025-02-07T11:38:55.852Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.852566Z] The worker supervisor's role is finished","timestamp":"2025-02-07T11:38:55.852Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.862050Z] Received signal from master, returning alive worker.","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.862174Z] Handshake signatures match","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.862349Z] Connection with Probe worker established.","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.862430Z] Starting trace thread","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.852338Z] {jlink_usb_000822007655} nrf-probe version 0.30.0","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.852377Z] {jlink_usb_000822007655} Sending IPC handshake response from worker...","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.852624Z] {jlink_usb_000822007655} Started worker message processing loop","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.862461Z] {jlink_usb_000822007655} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: TargetConfig { adac_timeout: None, swd_clock_frequency: None } }, firmware_config: None, target_family: None, override_detection: None })","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.862535Z] {jlink_usb_000822007655} -> new","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.862618Z] {jlink_usb_000822007655} J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.862789Z] {jlink_usb_000822007655} -> new_from_path","timestamp":"2025-02-07T11:38:55.862Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.870688Z] {jlink_usb_000822007655} Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-07T11:38:55.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.870705Z] {jlink_usb_000822007655} <- new_from_path","timestamp":"2025-02-07T11:38:55.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.870711Z] {jlink_usb_000822007655} <- new","timestamp":"2025-02-07T11:38:55.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.870723Z] {jlink_usb_000822007655} Setting up JLink interface.","timestamp":"2025-02-07T11:38:55.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.870731Z] {jlink_usb_000822007655} -> connect","timestamp":"2025-02-07T11:38:55.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.870741Z] {jlink_usb_000822007655} Selecting J-Link with serial number 000822007655","timestamp":"2025-02-07T11:38:55.870Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.874871Z] {jlink_usb_000822007655} ExecCommand SuppressInfoUpdateFW","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875011Z] {jlink_usb_000822007655} ExecCommand SuppressInfoUpdateFW returned 0","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875019Z] {jlink_usb_000822007655} ExecCommand DisableAutoUpdateFW","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875046Z] {jlink_usb_000822007655} ExecCommand DisableAutoUpdateFW returned 0","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875056Z] {jlink_usb_000822007655} Applied firmware settings to JLink","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875087Z] {jlink_usb_000822007655} ExecCommand SetBatchMode 1","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875098Z] {jlink_usb_000822007655} ExecCommand SetBatchMode 1 returned 0","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875103Z] {jlink_usb_000822007655} ExecCommand SuppressGUI","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875110Z] {jlink_usb_000822007655} ExecCommand SuppressGUI returned 0","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875116Z] {jlink_usb_000822007655} ExecCommand SetAllowFlashCache = 0","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.875130Z] {jlink_usb_000822007655} ExecCommand SetAllowFlashCache = 0 returned 1","timestamp":"2025-02-07T11:38:55.875Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.884864Z] {jlink_usb_000822007655} ExecCommand DisableInfoWinFlashDL","timestamp":"2025-02-07T11:38:55.885Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.884917Z] {jlink_usb_000822007655} ExecCommand DisableInfoWinFlashDL returned 0","timestamp":"2025-02-07T11:38:55.885Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.884927Z] {jlink_usb_000822007655} ExecCommand SetRestartOnClose 0","timestamp":"2025-02-07T11:38:55.885Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.884950Z] {jlink_usb_000822007655} ExecCommand SetRestartOnClose 0 returned 1","timestamp":"2025-02-07T11:38:55.885Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.885927Z] {jlink_usb_000822007655} Speed info: JLINKARM_SPEED_INFO { SizeOfStruct: 12, BaseFreq: 180000000, MinDiv: 12, SupportAdaptive: 1 }","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.885946Z] {jlink_usb_000822007655} Max frequency: 15000 kHz","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.886127Z] {jlink_usb_000822007655} Clock frequency was set to 2000 kHz","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.886163Z] {jlink_usb_000822007655} Retrieved JLink firmware string: J-Link V12 compiled Dec  4 2024 17:53:50","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.886194Z] {jlink_usb_000822007655} Emulator Usb(JLinkSerialNumber(822007655)) running firmware: J-Link V12 compiled Dec  4 2024 17:53:50","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.886203Z] {jlink_usb_000822007655} <- connect","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.886400Z] {jlink_usb_000822007655} Probe worker received message: Request(DeviceInformation)","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.886679Z] {jlink_usb_000822007655} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3331, tck: 0, tdi: 0, tdo: 0, tms: 0, tres: 0, trst: 0 }","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.886689Z] {jlink_usb_000822007655} CORESIGHT_Configure","timestamp":"2025-02-07T11:38:55.886Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.989323Z] {jlink_usb_000822007655} -> Powering up sys and debug region","timestamp":"2025-02-07T11:38:55.989Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.989367Z] {jlink_usb_000822007655} -> write_dp_unchecked","timestamp":"2025-02-07T11:38:55.989Z"}}
    {"type":"log","data":{"level":"WARN","message":"[ProbeLib] [2025-02-07 11:38:55.991469Z] {jlink_usb_000822007655} DAP write error: DebugPort,  register 2 = 0x00000000, err: Unknown Error in J-Link DLL (error code =-1)","timestamp":"2025-02-07T11:38:55.991Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.991504Z] {jlink_usb_000822007655} Aborting debug operation, writing 0x1FF to ABORT register","timestamp":"2025-02-07T11:38:55.991Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.992108Z] {jlink_usb_000822007655} <- write_dp_unchecked","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:55.992143Z] {jlink_usb_000822007655} <- Powering up sys and debug region","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.992245Z] Got device error response","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.992279Z] Expecting trace channel to disconnect.","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.992298Z] Terminating worker with id 23576","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.992328Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:55.992368Z] {jlink_usb_000822007655} Probe worker received message: Shutdown","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.992401Z] {jlink_usb_000822007655} Closing emulator connection","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.992410Z] {jlink_usb_000822007655} Closing connection to J-Link","timestamp":"2025-02-07T11:38:55.992Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.993411Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:38:55.993Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.995433Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:38:55.995Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:55.998184Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:38:55.998Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:56.002216Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:38:56.002Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:56.007801Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:38:56.007Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:56.016825Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:38:56.016Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:38:56.021117Z] {jlink_usb_000822007655} Probe worker stopped.","timestamp":"2025-02-07T11:38:56.021Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:56.024998Z] Trace channel disconnected as expected.","timestamp":"2025-02-07T11:38:56.025Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:56.025031Z] Trace thread ends now...","timestamp":"2025-02-07T11:38:56.025Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:38:56.030762Z] Worker exited successfully","timestamp":"2025-02-07T11:38:56.030Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:38:56.030795Z] Joined trace thread.","timestamp":"2025-02-07T11:38:56.030Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Task 0 is already completed","timestamp":"2025-02-07T11:38:56.030Z"}}
    {"type":"task_end","data":{"task":{"id":"ee63a8e977a9476e9180432d189a0519","description":"Recover 822007655","name":"recover","data":{"serialNumber":"000822007655"}},"message":"Failed to recover 822007655, [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1)","result":"fail","error":{"code":1,"description":"Generic"}}}
    {"type":"log","data":{"level":"ERROR","message":" NRFDLException(1): [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1)","timestamp":"2025-02-07T11:38:56.031Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::shutDown()","timestamp":"2025-02-07T11:38:56.031Z"}}
    Error: One or more recover tasks failed:
     * 822007655: [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1), code: Generic
    2. I have similar issue with reset command (note that this command was performed after a NOK recover command):
    > ./nrfutil.exe device reset --reset-kind RESET_HARD --serial-number 822007655 --log-level trace --log {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 2.7.12, platform = x86_64-pc-windows-msvc) invoked with reset --reset-kind RESET_HARD --serial-number 822007655 --log-level trace --log-output stdout --json ","timestamp":"2025-02-07T11:42:16.663Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false","timestamp":"2025-02-07T11:42:16.663Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device","timestamp":"2025-02-07T11:42:16.663Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:16.679589Z] J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-07T11:42:16.679Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:16.683511Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-07T11:42:16.683Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-02-07T11:42:16.828Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-02-07T11:42:16.828Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-02-07T11:42:16.909Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-02-07T11:42:16.909Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-02-07T11:42:16.909Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-02-07T11:42:16.909Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-02-07T11:42:16.909Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-02-07T11:42:16.909Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command open executed for 82 milliseconds with result 0","timestamp":"2025-02-07T11:42:16.915Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] jlink_dll_version","timestamp":"2025-02-07T11:42:16.915Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command jlink_dll_version executed for 2 milliseconds with result 0","timestamp":"2025-02-07T11:42:16.918Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command open executed for 6 milliseconds with result 0","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] dll_version","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command jlink_dll_version executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-02-07T11:42:16.921Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-02-07T11:42:16.941Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-02-07T11:42:16.941Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command close executed for 38 milliseconds with result 0","timestamp":"2025-02-07T11:42:16.956Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-07T11:42:16.956Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:42:16.956Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command close executed for 38 milliseconds with result 0","timestamp":"2025-02-07T11:42:16.971Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:42:16.972Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 44 milliseconds","timestamp":"2025-02-07T11:42:16.972Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-02-07T11:42:17.004Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-02-07T11:42:17.005Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Executed 4 commands for 122 milliseconds","timestamp":"2025-02-07T11:42:17.005Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-07T11:42:17.005Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"operation to get devices for : Ok(\"{\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"reset\\\",\\\"option\\\":\\\"RESET_HARD\\\"},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"TRACE","message":"Operations required by a device to do: {\"reset\"}","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Checking future_status of enumerate_task_status","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Waiting for enumeration to complete","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: Start","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: Before async_lister->enumerate","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: enumerate","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_13D3&PID_56CB#200901010001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-02-07T11:42:17.019Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-07T11:42:17.020Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:42:17.021Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:42:17.021Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:42:17.021Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_1020#000822007655#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.021Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{09126C94-2B5D-5FCC-A627-3EE878ACF089}'","timestamp":"2025-02-07T11:42:17.021Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {09126C94-2B5D-5FCC-A627-3EE878ACF089}","timestamp":"2025-02-07T11:42:17.021Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_20CE&PID_0011#6&28b98d9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.023Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A5762EC0-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-02-07T11:42:17.023Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {A5762EC0-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-02-07T11:42:17.023Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-07T11:42:17.023Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0BDA&PID_0129#20100201396000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.023Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-02-07T11:42:17.023Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_8087&PID_0026#5&2495b8dd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Received `0` as descriptor index","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Received `0` as descriptor index","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_046D&PID_C52B#7&161d3976&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{102FF28B-5E07-11EF-A017-00090FFE0001}'","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {102FF28B-5E07-11EF-A017-00090FFE0001}","timestamp":"2025-02-07T11:42:17.024Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-02-07T11:42:17.026Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0105#000770208553#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.026Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{9C391A66-09CA-5984-9054-0EF374429BDE}'","timestamp":"2025-02-07T11:42:17.026Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {9C391A66-09CA-5984-9054-0EF374429BDE}","timestamp":"2025-02-07T11:42:17.026Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTE1GLU7#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.026Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{E6493F94-5729-5E6F-80AC-EA9D4F34F3D3}'","timestamp":"2025-02-07T11:42:17.026Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {E6493F94-5729-5E6F-80AC-EA9D4F34F3D3}","timestamp":"2025-02-07T11:42:17.027Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTE1HXK3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-02-07T11:42:17.031Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{F2CA1033-9FDA-5A27-A589-E0A6C30F5A41}'","timestamp":"2025-02-07T11:42:17.031Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {F2CA1033-9FDA-5A27-A589-E0A6C30F5A41}","timestamp":"2025-02-07T11:42:17.031Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 1 and serial number: '000822007655'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 2 and serial number: 'NONE'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 3 and serial number: 'NONE'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 4 and serial number: 'FTE1GLU7'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 5 and serial number: '000770208553'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 6 and serial number: 'NONE'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 7 and serial number: 'FTE1HXK3'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 8 and serial number: 'NONE'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 9 and serial number: 'NONE'","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate::enumerate_task: After async_lister->enumerate","timestamp":"2025-02-07T11:42:17.036Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'devkit' took 3 ms","timestamp":"2025-02-07T11:42:17.040Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.040700Z] J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-07T11:42:17.040Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.040940Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-07T11:42:17.040Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.046809Z] Found 2 attached J-Link devices","timestamp":"2025-02-07T11:42:17.046Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'Probe' took 6 ms","timestamp":"2025-02-07T11:42:17.046Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] JLinkPlugin::enumerate","timestamp":"2025-02-07T11:42:17.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-02-07T11:42:17.218Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-02-07T11:42:17.218Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-02-07T11:42:17.302Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-02-07T11:42:17.302Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-02-07T11:42:17.302Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-02-07T11:42:17.302Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-02-07T11:42:17.302Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-02-07T11:42:17.302Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command open executed for 86 milliseconds with result 0","timestamp":"2025-02-07T11:42:17.308Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] enum_emu_snr","timestamp":"2025-02-07T11:42:17.308Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-02-07T11:42:17.312Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-02-07T11:42:17.312Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command open executed for 6 milliseconds with result 0","timestamp":"2025-02-07T11:42:17.312Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] enum_emu_snr","timestamp":"2025-02-07T11:42:17.312Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-07T11:42:17.312Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr","timestamp":"2025-02-07T11:42:17.312Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr","timestamp":"2025-02-07T11:42:17.312Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus","timestamp":"2025-02-07T11:42:17.312Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command enum_emu_snr executed for 13 milliseconds with result 0","timestamp":"2025-02-07T11:42:17.321Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Found 2 J-Link devices connected","timestamp":"2025-02-07T11:42:17.321Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-02-07T11:42:17.322Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command enum_emu_snr executed for 12 milliseconds with result 0","timestamp":"2025-02-07T11:42:17.322Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-02-07T11:42:17.322Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-02-07T11:42:17.322Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-02-07T11:42:17.322Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-02-07T11:42:17.348Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-02-07T11:42:17.348Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command close executed for 43 milliseconds with result 0","timestamp":"2025-02-07T11:42:17.365Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-07T11:42:17.365Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Command terminate executed for 12 milliseconds with result 0","timestamp":"2025-02-07T11:42:17.378Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command close executed for 41 milliseconds with result 0","timestamp":"2025-02-07T11:42:17.379Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Command terminate executed for 0 milliseconds with result 0","timestamp":"2025-02-07T11:42:17.394Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Worker][-] Executed 4 commands for 59 milliseconds","timestamp":"2025-02-07T11:42:17.394Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-02-07T11:42:17.426Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-02-07T11:42:17.427Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[jlink] [NRFJPROG][Client][-] Executed 4 commands for 154 milliseconds","timestamp":"2025-02-07T11:42:17.427Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-02-07T11:42:17.427Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'jlink' took 394 ms","timestamp":"2025-02-07T11:42:17.441Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'BOARDCONTROLLER' took 13 ms","timestamp":"2025-02-07T11:42:17.455Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {9c391a66-09ca-5984-9054-0ef374429bde}","timestamp":"2025-02-07T11:42:17.457Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"000770208553\", \"000770602132\", \"000773105148\", \"000777641824\"]","timestamp":"2025-02-07T11:42:17.457Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000770208553 -> GUID: {9c391a66-09ca-5984-9054-0ef374429bde}","timestamp":"2025-02-07T11:42:17.457Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"000770208553\")","timestamp":"2025-02-07T11:42:17.457Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\USB#VID_1366&PID_0105&MI_00#7&31D7DF8B&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_1366&PID_0105#000770208553#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-07T11:42:17.457Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {e6493f94-5729-5e6f-80ac-ea9d4f34f3d3}","timestamp":"2025-02-07T11:42:17.458Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOE9B\", \"FTDPOGGJ\", \"FTE1GLU7\", \"FTE1HXJX\", \"FTE1HXK3\"]","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE9B -> GUID: {bd8763ce-455f-59b8-939a-ea597447f3dc}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTE1GLU7 -> GUID: {e6493f94-5729-5e6f-80ac-ea9d4f34f3d3}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTE1GLU7\")","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTE1GLU7A#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTE1GLU7#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-07T11:42:17.459Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {f2ca1033-9fda-5a27-a589-e0a6c30f5a41}","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOE9B\", \"FTDPOGGJ\", \"FTE1GLU7\", \"FTE1HXJX\", \"FTE1HXK3\"]","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-02-07T11:42:17.460Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE9B -> GUID: {bd8763ce-455f-59b8-939a-ea597447f3dc}","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTE1GLU7 -> GUID: {e6493f94-5729-5e6f-80ac-ea9d4f34f3d3}","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTE1HXJX -> GUID: {9c3d734a-a1ff-5292-96e0-29a60a93a060}","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTE1HXK3 -> GUID: {f2ca1033-9fda-5a27-a589-e0a6c30f5a41}","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTE1HXK3\")","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTE1HXK3A#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTE1HXK3#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] try to map FTDI to segger device","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] found FTDI","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTE1HXK3'","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTE1GLU7'","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: '000770208553'","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'serialport' took 5 ms","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'sdfu' took 0 ms","timestamp":"2025-02-07T11:42:17.461Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'mcuBoot' took 0 ms","timestamp":"2025-02-07T11:42:17.462Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[broken] BrokenPlugin::enumerate","timestamp":"2025-02-07T11:42:17.462Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'broken' took 0 ms","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '000822007655'","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: device registered to device list","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '<unknown>'","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: 'FTE1GLU7'","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: '000770208553'","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Found device with serial number: 'FTE1HXK3'","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Finished in 443 ms","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: Completed waiting for enumeration","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::enumerate: done","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"task_begin","data":{"task":{"id":"91c20696751d4f6a9979c2a7b57fe9a3","description":"Reset 822007655","name":"reset","data":{"serialNumber":"000822007655"}}}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.463841Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.463867Z] The device is recognized as a device with a supported probe. Need to run device identification to determine the device family","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.463913Z] Looking for file in C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-02-07T11:42:17.463Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.464057Z] Found file at C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-02-07T11:42:17.464Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.464213Z] Created IPC server 3e9affba-95c0-44f9-8d41-efb99f01cf5e","timestamp":"2025-02-07T11:42:17.464Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.467795Z] Spawned worker process with id 20012","timestamp":"2025-02-07T11:42:17.467Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.467944Z] Accepting IPC connection","timestamp":"2025-02-07T11:42:17.467Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.491128Z] Accepted IPC connection","timestamp":"2025-02-07T11:42:17.491Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.491155Z] The worker supervisor's role is finished","timestamp":"2025-02-07T11:42:17.491Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.499516Z] Received signal from master, returning alive worker.","timestamp":"2025-02-07T11:42:17.499Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.499621Z] Handshake signatures match","timestamp":"2025-02-07T11:42:17.499Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.499765Z] Connection with Probe worker established.","timestamp":"2025-02-07T11:42:17.499Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.499918Z] Starting trace thread","timestamp":"2025-02-07T11:42:17.499Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.490869Z] {jlink_usb_000822007655} nrf-probe version 0.30.0","timestamp":"2025-02-07T11:42:17.500Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.490937Z] {jlink_usb_000822007655} Sending IPC handshake response from worker...","timestamp":"2025-02-07T11:42:17.500Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.491230Z] {jlink_usb_000822007655} Started worker message processing loop","timestamp":"2025-02-07T11:42:17.500Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.499852Z] {jlink_usb_000822007655} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: TargetConfig { adac_timeout: None, swd_clock_frequency: None } }, firmware_config: None, target_family: None, override_detection: None })","timestamp":"2025-02-07T11:42:17.500Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.499911Z] {jlink_usb_000822007655} -> new","timestamp":"2025-02-07T11:42:17.500Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.499982Z] {jlink_usb_000822007655} J-Link installation directory configured in registry: Computer\\HKEY_CURRENT_USER\\SOFTWARE\\SEGGER\\J-Link=\"C:\\\\Program Files\\\\SEGGER\\\\JLink\"","timestamp":"2025-02-07T11:42:17.500Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.500181Z] {jlink_usb_000822007655} -> new_from_path","timestamp":"2025-02-07T11:42:17.500Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.508064Z] {jlink_usb_000822007655} Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-02-07T11:42:17.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.508097Z] {jlink_usb_000822007655} <- new_from_path","timestamp":"2025-02-07T11:42:17.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.508103Z] {jlink_usb_000822007655} <- new","timestamp":"2025-02-07T11:42:17.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.508115Z] {jlink_usb_000822007655} Setting up JLink interface.","timestamp":"2025-02-07T11:42:17.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.508123Z] {jlink_usb_000822007655} -> connect","timestamp":"2025-02-07T11:42:17.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.508133Z] {jlink_usb_000822007655} Selecting J-Link with serial number 000822007655","timestamp":"2025-02-07T11:42:17.508Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511482Z] {jlink_usb_000822007655} ExecCommand SuppressInfoUpdateFW","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511584Z] {jlink_usb_000822007655} ExecCommand SuppressInfoUpdateFW returned 0","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511593Z] {jlink_usb_000822007655} ExecCommand DisableAutoUpdateFW","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511607Z] {jlink_usb_000822007655} ExecCommand DisableAutoUpdateFW returned 0","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511616Z] {jlink_usb_000822007655} Applied firmware settings to JLink","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511622Z] {jlink_usb_000822007655} ExecCommand SetBatchMode 1","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511644Z] {jlink_usb_000822007655} ExecCommand SetBatchMode 1 returned 0","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511648Z] {jlink_usb_000822007655} ExecCommand SuppressGUI","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511654Z] {jlink_usb_000822007655} ExecCommand SuppressGUI returned 0","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511658Z] {jlink_usb_000822007655} ExecCommand SetAllowFlashCache = 0","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.511670Z] {jlink_usb_000822007655} ExecCommand SetAllowFlashCache = 0 returned 1","timestamp":"2025-02-07T11:42:17.511Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.521423Z] {jlink_usb_000822007655} ExecCommand DisableInfoWinFlashDL","timestamp":"2025-02-07T11:42:17.521Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.521450Z] {jlink_usb_000822007655} ExecCommand DisableInfoWinFlashDL returned 0","timestamp":"2025-02-07T11:42:17.521Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.521458Z] {jlink_usb_000822007655} ExecCommand SetRestartOnClose 0","timestamp":"2025-02-07T11:42:17.521Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.521485Z] {jlink_usb_000822007655} ExecCommand SetRestartOnClose 0 returned 1","timestamp":"2025-02-07T11:42:17.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.522434Z] {jlink_usb_000822007655} Speed info: JLINKARM_SPEED_INFO { SizeOfStruct: 12, BaseFreq: 180000000, MinDiv: 12, SupportAdaptive: 1 }","timestamp":"2025-02-07T11:42:17.522Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.522464Z] {jlink_usb_000822007655} Max frequency: 15000 kHz","timestamp":"2025-02-07T11:42:17.522Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.522627Z] {jlink_usb_000822007655} Clock frequency was set to 2000 kHz","timestamp":"2025-02-07T11:42:17.522Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.522647Z] {jlink_usb_000822007655} Retrieved JLink firmware string: J-Link V12 compiled Dec  4 2024 17:53:50","timestamp":"2025-02-07T11:42:17.522Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.522668Z] {jlink_usb_000822007655} Emulator Usb(JLinkSerialNumber(822007655)) running firmware: J-Link V12 compiled Dec  4 2024 17:53:50","timestamp":"2025-02-07T11:42:17.522Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.522678Z] {jlink_usb_000822007655} <- connect","timestamp":"2025-02-07T11:42:17.522Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.522769Z] {jlink_usb_000822007655} Probe worker received message: Request(DeviceInformation)","timestamp":"2025-02-07T11:42:17.522Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.523007Z] {jlink_usb_000822007655} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3326, tck: 0, tdi: 0, tdo: 0, tms: 0, tres: 0, trst: 0 }","timestamp":"2025-02-07T11:42:17.523Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.523018Z] {jlink_usb_000822007655} CORESIGHT_Configure","timestamp":"2025-02-07T11:42:17.523Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.625737Z] {jlink_usb_000822007655} -> Powering up sys and debug region","timestamp":"2025-02-07T11:42:17.625Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.625786Z] {jlink_usb_000822007655} -> write_dp_unchecked","timestamp":"2025-02-07T11:42:17.625Z"}}
    {"type":"log","data":{"level":"WARN","message":"[ProbeLib] [2025-02-07 11:42:17.627971Z] {jlink_usb_000822007655} DAP write error: DebugPort,  register 2 = 0x00000000, err: Unknown Error in J-Link DLL (error code =-1)","timestamp":"2025-02-07T11:42:17.628Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.628013Z] {jlink_usb_000822007655} Aborting debug operation, writing 0x1FF to ABORT register","timestamp":"2025-02-07T11:42:17.628Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.628664Z] {jlink_usb_000822007655} <- write_dp_unchecked","timestamp":"2025-02-07T11:42:17.628Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.628705Z] {jlink_usb_000822007655} <- Powering up sys and debug region","timestamp":"2025-02-07T11:42:17.628Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.628808Z] Got device error response","timestamp":"2025-02-07T11:42:17.628Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.628832Z] Expecting trace channel to disconnect.","timestamp":"2025-02-07T11:42:17.628Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.628847Z] Terminating worker with id 20012","timestamp":"2025-02-07T11:42:17.628Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.628875Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:42:17.628Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.628905Z] {jlink_usb_000822007655} Probe worker received message: Shutdown","timestamp":"2025-02-07T11:42:17.629Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.628948Z] {jlink_usb_000822007655} Closing emulator connection","timestamp":"2025-02-07T11:42:17.629Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.628958Z] {jlink_usb_000822007655} Closing connection to J-Link","timestamp":"2025-02-07T11:42:17.629Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.630067Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:42:17.630Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.631514Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:42:17.631Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.633999Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:42:17.634Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.637402Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:42:17.637Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.642922Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:42:17.642Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.651896Z] Waiting for worker to exit.","timestamp":"2025-02-07T11:42:17.651Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-02-07 11:42:17.653974Z] {jlink_usb_000822007655} Probe worker stopped.","timestamp":"2025-02-07T11:42:17.654Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.658437Z] Trace channel disconnected as expected.","timestamp":"2025-02-07T11:42:17.658Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.658464Z] Trace thread ends now...","timestamp":"2025-02-07T11:42:17.658Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-02-07 11:42:17.665918Z] Worker exited successfully","timestamp":"2025-02-07T11:42:17.665Z"}}
    {"type":"log","data":{"level":"TRACE","message":"[ProbeLib] [2025-02-07 11:42:17.665947Z] Joined trace thread.","timestamp":"2025-02-07T11:42:17.666Z"}}
    {"type":"log","data":{"level":"ERROR","message":" NRFDLException(1): [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1)","timestamp":"2025-02-07T11:42:17.666Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Task 0 is already completed","timestamp":"2025-02-07T11:42:17.666Z"}}
    {"type":"task_end","data":{"task":{"id":"91c20696751d4f6a9979c2a7b57fe9a3","description":"Reset 822007655","name":"reset","data":{"serialNumber":"000822007655"}},"message":"Failed to reset 822007655, [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1)","result":"fail","error":{"code":1,"description":"Generic"}}}
    {"type":"log","data":{"level":"TRACE","message":"DeviceLister::shutDown()","timestamp":"2025-02-07T11:42:17.666Z"}}
    Error: One or more reset tasks failed:
    3. In fact I only face this issue with client firmware that enable the memory protection. Using RF test firmware I able to run recover, erase and program command without issue (except issue when J-Link is not found anymore)
    4.Unfortunaly I only have a single sample for now. But following point 3. I assume that everything work well on the device as without readback protection I'm able to connect to the chip. Or can it still be hardware issue you think ?
    Antoine
    Feedback from our developers after sharing the log is that they show two kind of "error states" in the logs:
    1. The debug interface is not accessible
    2. The debug interface parts for the application core are inaccessible.
    It's expected that any interaction with the debug interface such as recover --core Network will fail if the debug interface is not accessible.
    However
    reset --reset-kind RESET_PIN
    Should work since execute reset trough the reset pin. Have you routed out the reset pin to the debugger interface on your custom board? Is it enabled in your application?
    What kind of protection are you using? Is it APPROTECT in UICR or are you also using SPU?
    If you modify the client firmware so that it disabled the memory protection. Does everything work as expected?
    regards
    Jared
  • Hi Jared,
    Sorry for the late reply.
    We receive a new PCBA and the issues is not reproductible. So, even if I could flash test firmware sometimes, it seems to be an hardware issue.
    But I had the issue where the JLink is not found anymore by nrfutil. Do you know when the new release will be shared ?
    Antoine
