nrfutil CLI issues
I'm working on a testbench to flash product with nRF5340 and nRF52840 chips.
In order to erase/flash both I'm using JLink Base compact and nrfutils CLI. But I have fews issues:
  •  Sometimes, the JLink didn't reset successfully (led switch to orange) and the next command line will fail with the error code: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
    • Below the output of the command performed few times in a row where we can se that sometimes operations ends without issue and sometimes error is raised
      > rfutil.exe device recover --serial-number 822007655 --x-family nrf53
      v Recovered 822007655
      > nrfutil.exe device recover --serial-number 822007655 --x-family nrf53
      x Failed to recover 822007655, [jlink] JLINKARM_DLL_ERROR
      Error: One or more recover tasks failed:
       * 822007655: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
  • Commands runnning forever. In some case operation doesn't stop and the only solution is to disconnect/reconnect the JLink. Is there a way to use timeout as parameters in the command lines ? I didn't find topic about that
  • JLink not found with nrfutil:
    • >./nrfutil.exe device list
      FTDPOE5G
      product         TTL232R-3V3
      ports           COM24
      traits          serialPorts, usb
      FTDPOGGJ
      product         TTL232R-3V3
      ports           COM21
      777641824
      product         J-Link
      ports           COM20
      traits          jlink, seggerUsb, serialPorts, usb
    • Here we can see that only one JLink is find while 2 are connected as shown with J-Link Configurator
Any helps on this topics will be appreciated !
Below are some details:
  • nrfutils --version
    • nrfutil 7.12.0 (39003c9 2024-06-10)
    • commit-hash: 39003c9d0e5d946af0f417cfadf4ac55a6d03c19
    • commit-date: 2024-06-10
    • host: x86_64-pc-windows-msvc
    • build-timestamp: 2024-06-10T15:56:55.227746900Z
    • classification: nrf-external
  • SEGGER Tools version V8.12d
I was initialy running the command line in python with subprocess.Popen where I first saw the issues and I was able to reproduce the errors using usual consol (MobaXTerm)
Antoine
  • Hi Antoine,
    Can you run something like:
    nrfutil device recover --log-level debug --log-output stdout --json
    And then share the log when it fails?
    What commands are you thinking of? nrfutil device list for example has a timeout parameter, recover doesn't, but I think that should time out eventually if it's not able to recover the board.
    The Jlink device that is missing, is it always the same device or does it change which one of the 2 that it don't list?
    regards
    Jared
  • Hi Jared,
    Thanks for your response.
    Please find below the asked tasks:
    • Below is output with successfull "recover" command followed by NOK "recover" command (without changing hardware/connections)
      • > ./nrfutil.exe device recover --serial-number 822007655 --log-level debug --log-output stdout --json
        {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 2.7.12, platform = x86_64-pc-windows-msvc) invoked with recover --serial-number 822007655 --log-level debug --log-output stdout --json ","timestamp":"2025-01-31T10:31:40.794Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false","timestamp":"2025-01-31T10:31:40.795Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device","timestamp":"2025-01-31T10:31:40.795Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:40.849848Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.12d","timestamp":"2025-01-31T10:31:40.849Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T10:31:41.288Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T10:31:41.288Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T10:31:41.432Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T10:31:41.432Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T10:31:41.432Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T10:31:41.432Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T10:31:41.432Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T10:31:41.432Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] jlink_dll_version","timestamp":"2025-01-31T10:31:41.432Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] dll_version","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T10:31:41.442Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T10:31:41.464Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T10:31:41.521Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T10:31:41.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T10:31:41.524Z"}}
        {"type":"log","data":{"level":"WARN","message":"[JlinkARM] nrfutil device commands were tested using SEGGER J-Link version JLink_V8.10f, but the J-Link version you are using is JLink_V8.12d. Your installed version will most likely work fine, but if you get issues related to J-Link with your devices, use the tested version","timestamp":"2025-01-31T10:31:41.538Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"operation to get devices for : Ok(\"{\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"recover\\\"},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")","timestamp":"2025-01-31T10:31:41.539Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: enumerate","timestamp":"2025-01-31T10:31:41.540Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_13D3&PID_56CB#200901010001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.541Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T10:31:41.541Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T10:31:41.542Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:41.543Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:41.543Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:41.543Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_046D&PID_C52B#5&2495b8dd&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.543Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{DA3A406E-66A7-11EF-A018-00090FFE0001}'","timestamp":"2025-01-31T10:31:41.543Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {DA3A406E-66A7-11EF-A018-00090FFE0001}","timestamp":"2025-01-31T10:31:41.544Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:41.545Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0BDA&PID_0129#20100201396000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.545Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T10:31:41.545Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T10:31:41.545Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_8087&PID_0026#5&2495b8dd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0105#000777641824#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{3F79306E-37BB-551B-B94B-0FDD0DFF00ED}'","timestamp":"2025-01-31T10:31:41.546Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {3F79306E-37BB-551B-B94B-0FDD0DFF00ED}","timestamp":"2025-01-31T10:31:41.547Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.547Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{E32B6560-907F-59AB-81F9-F77302D6FE1C}'","timestamp":"2025-01-31T10:31:41.547Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {E32B6560-907F-59AB-81F9-F77302D6FE1C}","timestamp":"2025-01-31T10:31:41.548Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.552Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}'","timestamp":"2025-01-31T10:31:41.552Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}","timestamp":"2025-01-31T10:31:41.553Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_20CE&PID_0011#6&28b98d9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.557Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A5762EC0-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T10:31:41.557Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {A5762EC0-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T10:31:41.558Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:41.559Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_072F&PID_224F#7&161d3976&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.559Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A57630D5-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T10:31:41.559Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {A57630D5-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T10:31:41.559Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:41.560Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_1020#000822007655#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:41.560Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{09126C94-2B5D-5FCC-A627-3EE878ACF089}'","timestamp":"2025-01-31T10:31:41.560Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {09126C94-2B5D-5FCC-A627-3EE878ACF089}","timestamp":"2025-01-31T10:31:41.560Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 1 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:41.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 2 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:41.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 3 and serial number: 'FTDPOE5G'","timestamp":"2025-01-31T10:31:41.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 4 and serial number: '000822007655'","timestamp":"2025-01-31T10:31:41.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 5 and serial number: '000777641824'","timestamp":"2025-01-31T10:31:41.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 6 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:41.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 7 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:41.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 8 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:41.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 9 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:41.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 10 and serial number: 'FTDPOGGJ'","timestamp":"2025-01-31T10:31:41.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'devkit' took 9 ms","timestamp":"2025-01-31T10:31:41.573Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:41.574928Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.12d","timestamp":"2025-01-31T10:31:41.575Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:41.590257Z] Found 2 attached J-Link devices","timestamp":"2025-01-31T10:31:41.590Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'Probe' took 16 ms","timestamp":"2025-01-31T10:31:41.590Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T10:31:41.912Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T10:31:41.912Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] enum_emu_snr","timestamp":"2025-01-31T10:31:42.083Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T10:31:42.083Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T10:31:42.083Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T10:31:42.084Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T10:31:42.084Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T10:31:42.084Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T10:31:42.084Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T10:31:42.093Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T10:31:42.094Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] enum_emu_snr","timestamp":"2025-01-31T10:31:42.094Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T10:31:42.094Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr","timestamp":"2025-01-31T10:31:42.094Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr","timestamp":"2025-01-31T10:31:42.094Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus","timestamp":"2025-01-31T10:31:42.094Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] Found 2 J-Link devices connected","timestamp":"2025-01-31T10:31:42.123Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T10:31:42.126Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T10:31:42.126Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T10:31:42.126Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T10:31:42.126Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T10:31:42.143Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T10:31:42.143Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T10:31:42.159Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T10:31:42.208Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T10:31:42.211Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T10:31:42.211Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'jlink' took 630 ms","timestamp":"2025-01-31T10:31:42.221Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'BOARDCONTROLLER' took 21 ms","timestamp":"2025-01-31T10:31:42.243Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T10:31:42.249Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"000770602132\", \"000773105148\", \"000777641824\"]","timestamp":"2025-01-31T10:31:42.249Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000770602132 -> GUID: {3ee8b8ef-c412-5b75-917a-0a2f66a13d7a}","timestamp":"2025-01-31T10:31:42.249Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000773105148 -> GUID: {592aca26-535d-56bc-b0cb-33014efdce30}","timestamp":"2025-01-31T10:31:42.249Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000777641824 -> GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T10:31:42.249Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"000777641824\")","timestamp":"2025-01-31T10:31:42.249Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\USB#VID_1366&PID_0105&MI_00#7&74C87DB&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_1366&PID_0105#000777641824#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T10:31:42.249Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOGGJ\")","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOGGJA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T10:31:42.254Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T10:31:42.258Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T10:31:42.258Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T10:31:42.258Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T10:31:42.258Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T10:31:42.258Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T10:31:42.258Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T10:31:42.258Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T10:31:42.258Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOE5G\")","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOE5GA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] try to map FTDI to segger device","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] found FTDI","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOGGJ'","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOE5G'","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: '000777641824'","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'serialport' took 15 ms","timestamp":"2025-01-31T10:31:42.259Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'sdfu' took 0 ms","timestamp":"2025-01-31T10:31:42.260Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'mcuBoot' took 1 ms","timestamp":"2025-01-31T10:31:42.262Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'broken' took 0 ms","timestamp":"2025-01-31T10:31:42.263Z"}}
        {"type":"task_begin","data":{"task":{"id":"d4a57be118ce4c1aafa037b17e7cfe3b","description":"Recover 822007655","name":"recover","data":{"serialNumber":"000822007655"}}}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.265480Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it","timestamp":"2025-01-31T10:31:42.265Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.265519Z] The device is recognized as a device with a supported probe. Need to run device identification to determine the device family","timestamp":"2025-01-31T10:31:42.265Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.265613Z] Looking for file in C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-01-31T10:31:42.265Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.265925Z] Found file at C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-01-31T10:31:42.266Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.274008Z] Spawned worker process with id 17392","timestamp":"2025-01-31T10:31:42.274Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.338698Z] Received signal from master, returning alive worker.","timestamp":"2025-01-31T10:31:42.338Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.338793Z] Handshake signatures match","timestamp":"2025-01-31T10:31:42.338Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.339179Z] Connection with Probe worker established.","timestamp":"2025-01-31T10:31:42.339Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.337703Z] {jlink_usb_000822007655} nrf-probe version 0.30.0","timestamp":"2025-01-31T10:31:42.339Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.337811Z] {jlink_usb_000822007655} Sending IPC handshake response from worker...","timestamp":"2025-01-31T10:31:42.339Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.338429Z] {jlink_usb_000822007655} Started worker message processing loop","timestamp":"2025-01-31T10:31:42.339Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.339430Z] {jlink_usb_000822007655} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: TargetConfig { adac_timeout: None, swd_clock_frequency: None } }, firmware_config: None, target_family: None, override_detection: None })","timestamp":"2025-01-31T10:31:42.340Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.363437Z] {jlink_usb_000822007655} Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.12d","timestamp":"2025-01-31T10:31:42.363Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.398802Z] {jlink_usb_000822007655} Speed info: JLINKARM_SPEED_INFO { SizeOfStruct: 12, BaseFreq: 180000000, MinDiv: 12, SupportAdaptive: 1 }","timestamp":"2025-01-31T10:31:42.398Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.398993Z] {jlink_usb_000822007655} Max frequency: 15000 kHz","timestamp":"2025-01-31T10:31:42.399Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.399263Z] {jlink_usb_000822007655} Clock frequency was set to 2000 kHz","timestamp":"2025-01-31T10:31:42.399Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.399362Z] {jlink_usb_000822007655} Emulator Usb(JLinkSerialNumber(822007655)) running firmware: J-Link V12 compiled Dec  4 2024 17:53:50","timestamp":"2025-01-31T10:31:42.399Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.399592Z] {jlink_usb_000822007655} Probe worker received message: Request(DeviceInformation)","timestamp":"2025-01-31T10:31:42.399Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.399882Z] {jlink_usb_000822007655} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3325, tck: 0, tdi: 0, tdo: 0, tms: 0, tres: 1, trst: 0 }","timestamp":"2025-01-31T10:31:42.399Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.400551Z] {jlink_usb_000822007655} -> Powering up sys and debug region","timestamp":"2025-01-31T10:31:42.400Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.401206Z] {jlink_usb_000822007655} Powered up sys and dbg regions in 0 ms","timestamp":"2025-01-31T10:31:42.401Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.401217Z] {jlink_usb_000822007655} <- Powering up sys and debug region","timestamp":"2025-01-31T10:31:42.401Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.403814Z] {jlink_usb_000822007655} -> detect device family","timestamp":"2025-01-31T10:31:42.403Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.413629Z] {jlink_usb_000822007655} Detected CTRL-AP revision 1 at AP 2","timestamp":"2025-01-31T10:31:42.413Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.415214Z] {jlink_usb_000822007655} Device detection: partno 0x00000007 hwrevision 0x00000005","timestamp":"2025-01-31T10:31:42.415Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.415230Z] {jlink_usb_000822007655} <- detect device family","timestamp":"2025-01-31T10:31:42.415Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.418952Z] Device family nRF53 not NRF54H/NRF54L, not supported by probe-plugin","timestamp":"2025-01-31T10:31:42.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.419031Z] Terminating worker with id 17392","timestamp":"2025-01-31T10:31:42.419Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.419072Z] {jlink_usb_000822007655} Probe worker received message: Shutdown","timestamp":"2025-01-31T10:31:42.419Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.419105Z] {jlink_usb_000822007655} -> Powering down debug region","timestamp":"2025-01-31T10:31:42.419Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.423577Z] {jlink_usb_000822007655} Powered down sys and dbg regions in 3 ms","timestamp":"2025-01-31T10:31:42.423Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.423586Z] {jlink_usb_000822007655} <- Powering down debug region","timestamp":"2025-01-31T10:31:42.423Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:42.448896Z] {jlink_usb_000822007655} Probe worker stopped.","timestamp":"2025-01-31T10:31:42.449Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:42.476093Z] Worker exited successfully","timestamp":"2025-01-31T10:31:42.476Z"}}
        {"type":"log","data":{"level":"INFO","message":"Loaded plugin C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl; starting to resolve symbols","timestamp":"2025-01-31T10:31:42.480Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] Initializing the J-Link debug probe for device {\"id\":4,\"probe\":{},\"serialNumber\":\"000822007655\",\"traits\":{\"boardController\":false,\"broken\":false,\"devkit\":false,\"jlink\":true,\"mcuBoot\":false,\"modem\":false,\"nordicDfu\":false,\"nordicUsb\":false,\"seggerUsb\":true,\"serialPorts\":false,\"usb\":true},\"usb\":{\"device\":{\"address\":62,\"busNumber\":1,\"descriptor\":{\"bDescriptorType\":1,\"bcdDevice\":256,\"idProduct\":4128,\"idVendor\":4966}},\"manufacturer\":\"SEGGER\",\"osDevicePath\":\"\\\\\\\\?\\\\USB#VID_1366&PID_1020#000822007655#{a5dcbf10-6530-11d2-901f-00c04fb951ed}\",\"product\":\"J-Link\",\"serialNumber\":\"000822007655\"},\"usbIdentifier\":\"\\\\\\\\?\\\\USB#VID_1366&PID_1020#000822007655#{A5DCBF10-6530-11D2-901F-00C04FB951ED}\"} with serial number: 000822007655","timestamp":"2025-01-31T10:31:42.481Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] Opening J-Link DLL","timestamp":"2025-01-31T10:31:42.481Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] open","timestamp":"2025-01-31T10:31:42.804Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] start","timestamp":"2025-01-31T10:31:42.804Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T10:31:43.022Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][000822007655] Logger sink registered in JLink logger","timestamp":"2025-01-31T10:31:43.022Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000822007655] open","timestamp":"2025-01-31T10:31:43.022Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000822007655] just_check_family","timestamp":"2025-01-31T10:31:43.022Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] open_dll","timestamp":"2025-01-31T10:31:43.022Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T10:31:43.022Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] connect_to_emu_with_snr","timestamp":"2025-01-31T10:31:43.037Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Set batch mode","timestamp":"2025-01-31T10:31:43.048Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] dll_version","timestamp":"2025-01-31T10:31:43.048Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000822007655] connect_to_emu_with_snr","timestamp":"2025-01-31T10:31:43.048Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_emu","timestamp":"2025-01-31T10:31:43.048Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] connect_to_emu_with_snr","timestamp":"2025-01-31T10:31:43.048Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_enum_emu_snr","timestamp":"2025-01-31T10:31:43.048Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_get_num_emus","timestamp":"2025-01-31T10:31:43.048Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_emu_with_snr","timestamp":"2025-01-31T10:31:43.081Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_emu_without_snr","timestamp":"2025-01-31T10:31:43.092Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Segger logging enabled.","timestamp":"2025-01-31T10:31:43.092Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] read_device_family","timestamp":"2025-01-31T10:31:43.299Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Connected emulator supports SWD speeds up to 15000kHz","timestamp":"2025-01-31T10:31:43.300Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] SWD clock set to 2000kHz","timestamp":"2025-01-31T10:31:43.300Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000822007655] read_device_family","timestamp":"2025-01-31T10:31:43.300Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_emu","timestamp":"2025-01-31T10:31:43.300Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_debug_port_idr","timestamp":"2025-01-31T10:31:43.300Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_debug_port_register","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_debug_port_register","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] coresight_configure","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_debug_port_idr","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_idr","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_is_debug_region_powered","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.310Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_idr","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 1, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 1, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 3, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 3, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.311Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.312Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 4, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.312Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.312Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.312Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 4, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.312Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_idr","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 5, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 5, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 6, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 6, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 7, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 7, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_idr","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 8, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 8, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 9, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 9, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 10, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 10, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 11, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 11, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 12, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.323Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.324Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.324Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.324Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 12, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.324Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_idr","timestamp":"2025-01-31T10:31:43.333Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.333Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.333Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.333Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 13, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.333Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 13, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.333Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 14, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 14, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_idr","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 15, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 15, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] select_family","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 16, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 16, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 17, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:43.334Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.335Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 17, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.335Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.335Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.335Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 0, AP Bank 3","timestamp":"2025-01-31T10:31:43.335Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] Attempting to recover device; attempt #0","timestamp":"2025-01-31T10:31:43.338Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] Getting recovery image for family NRF53_FAMILY and core NRFDL_DEVICE_CORE_APPLICATION","timestamp":"2025-01-31T10:31:43.338Z"}}
        {"type":"log","data":{"level":"INFO","message":"[jlink] Using firmware image for recovery to keep the device unlocked.","timestamp":"2025-01-31T10:31:43.340Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] JLink from buffer.","timestamp":"2025-01-31T10:31:43.340Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] JLink from file C:\\Users\\antoine.bricard\\AppData\\Roaming\\MobaXterm\\slash\\tmp\\temp_program_fw17383195033404170001.hex.","timestamp":"2025-01-31T10:31:43.342Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] recover","timestamp":"2025-01-31T10:31:43.342Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_load_coprocessor_data","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] set_core_data","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Set core data:","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655]   Device ID: Cortex-M33","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655]   Expected core: 235012351","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655]   Existing Expected core: 4294967295","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655]   Coprocessor: APPLICATION","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655]   AHB AP index: 0","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655]   Core base address: 4294967295","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---set_coresight_ahb_ap_index","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] recover","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_emu","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] just_recover","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_is_eraseprotect_enabled","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_is_debug_region_powered","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_debug_port_register","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.344Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 0, AP Bank 1","timestamp":"2025-01-31T10:31:43.345Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Eraseaprotect is disabled","timestamp":"2025-01-31T10:31:43.355Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_disable_accessportprotect","timestamp":"2025-01-31T10:31:43.355Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_access_port_register","timestamp":"2025-01-31T10:31:43.355Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:43.355Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.355Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:43.355Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:43.853Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:43.853Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:43.853Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.359Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.359Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.359Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_read_device_version","timestamp":"2025-01-31T10:31:44.359Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 0, AP Bank 3","timestamp":"2025-01-31T10:31:44.359Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_decode_device_version","timestamp":"2025-01-31T10:31:44.359Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Device identified as NRF5340_xxAA_REV1","timestamp":"2025-01-31T10:31:44.360Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_debug_reset_coprocessor","timestamp":"2025-01-31T10:31:44.360Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_access_port_register","timestamp":"2025-01-31T10:31:44.360Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.360Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.360Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:44.360Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_readback_status","timestamp":"2025-01-31T10:31:44.369Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Protection status for ahb-ap 0 read as NONE","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] halt","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_enable_coprocessor","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---set_coresight_ahb_ap_index","timestamp":"2025-01-31T10:31:44.370Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_halt","timestamp":"2025-01-31T10:31:44.417Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] sys_reset","timestamp":"2025-01-31T10:31:44.417Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.417Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.417Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_sys_reset","timestamp":"2025-01-31T10:31:44.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T10:31:44.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_u32","timestamp":"2025-01-31T10:31:44.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_invalidate_cache","timestamp":"2025-01-31T10:31:44.418Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_power_ram_all","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_readback_status","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Protection status for ahb-ap 0 read as NONE","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.497Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.509Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.509Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.509Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.510Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.511Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.512Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.524Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.525Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.526Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.527Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.536Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_clear_resetreas","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x50003814: secure state of peripheral from SPU @0x50003000 (S) (slave index 5).","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.537Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.538Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.538Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.538Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] Running NRFJPROG_program.","timestamp":"2025-01-31T10:31:44.540Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] program","timestamp":"2025-01-31T10:31:44.540Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50005400 has secure properties Selectable Secure","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] program","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_emu","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] program_file","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] init_device_info","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_memory_list","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_read_device_version","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_is_debug_region_powered","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_debug_port_register","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 0, AP Bank 3","timestamp":"2025-01-31T10:31:44.550Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_decode_device_version","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Device identified as NRF5340_xxAA_REV1","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] read_device_info","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_read_device_version","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] hex_file_is_valid","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] read_region_0_size_and_source.","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_read_region_0_size_and_source","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] is_bprot_enabled","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_is_bprot_enabled","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_readback_status","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Protection status for ahb-ap 0 read as NONE","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] halt","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_halt","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] init_device_info","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_memory_list","timestamp":"2025-01-31T10:31:44.551Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.552Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.552Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 2, DP Bank 255, AP Bank 3","timestamp":"2025-01-31T10:31:44.552Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.552Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_decode_device_version","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Device identified as NRF5340_xxAA_REV1","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Memory list already constructed. Skipping.","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] read_device_info","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_read_device_version","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_u32","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_u32","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_invalidate_cache","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] just_is_mpu_enabled_m33","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_read_u32","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_halt","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] loop_image","timestamp":"2025-01-31T10:31:44.562Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_write","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_halt","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_nvmc_config_control","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.563Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50039584 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50039504 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.564Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_nvmc_wait_for_ready","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50039400 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T10:31:44.574Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_u32","timestamp":"2025-01-31T10:31:44.575Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.575Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.575Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_u32","timestamp":"2025-01-31T10:31:44.575Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_invalidate_cache","timestamp":"2025-01-31T10:31:44.575Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_nvmc_wait_for_ready","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.605Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50039400 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_u32","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_u32","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_invalidate_cache","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_nvmc_config_control","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50039584 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T10:31:44.606Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.607Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.607Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T10:31:44.607Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50039504 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.617Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] write_u32","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_nvmc_wait_for_ready","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_secure_debug_available","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_access_port_register","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_access_port_register","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_access_port_register","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] update_periph_secure_state","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ahb_read_u32","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_access_port_register","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T10:31:44.618Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] Peripheral at address 0x50039400 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] read_u32","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_connect_to_device","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_device","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_u32","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_invalidate_cache","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] close","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] is_connected_to_emu","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] close","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] disconnect_from_emu","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_disconnect_from_emu","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_is_debug_region_powered","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_debug_port_register","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.619Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Disable trace before closing connection.","timestamp":"2025-01-31T10:31:44.628Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_u32","timestamp":"2025-01-31T10:31:44.628Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.628Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.628Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T10:31:44.628Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_is_debug_region_powered","timestamp":"2025-01-31T10:31:44.628Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Shortcut, lock is on and debug region is powered.","timestamp":"2025-01-31T10:31:44.628Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] unpower_debug_and_system_regions","timestamp":"2025-01-31T10:31:44.629Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_write_debug_port_register","timestamp":"2025-01-31T10:31:44.629Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_select_debug_port_register","timestamp":"2025-01-31T10:31:44.629Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_is_debug_region_powered","timestamp":"2025-01-31T10:31:44.629Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] ---just_read_debug_port_register","timestamp":"2025-01-31T10:31:44.629Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007655] Segger Backend closed.","timestamp":"2025-01-31T10:31:44.671Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007655] nRF family DLL closed","timestamp":"2025-01-31T10:31:44.671Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] terminate","timestamp":"2025-01-31T10:31:44.689Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] Worker process exited with code: 0","timestamp":"2025-01-31T10:31:44.752Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] Child process terminated with result 0","timestamp":"2025-01-31T10:31:44.755Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007655] terminate","timestamp":"2025-01-31T10:31:44.755Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"~async_task id: 1905937921796","timestamp":"2025-01-31T10:31:44.769Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Task 1905937921796 is already completed","timestamp":"2025-01-31T10:31:44.769Z"}}
        {"type":"log","data":{"level":"INFO","message":"~plugin_container(0x209d14d85f0): close plugin dll at path: C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl","timestamp":"2025-01-31T10:31:44.769Z"}}
        {"type":"task_end","data":{"task":{"id":"d4a57be118ce4c1aafa037b17e7cfe3b","description":"Recover 822007655","name":"recover","data":{"serialNumber":"000822007655"}},"message":"Recovered 822007655","result":"success","error":null}}
        {"type":"log","data":{"level":"DEBUG","message":"~plugin_container(0x209d14d85f0): closed plugin dll at path: C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl","timestamp":"2025-01-31T10:31:44.769Z"}}
        âś“
        > nrfutil.exe device recover --serial-number 822007655 --log-level debug --log-output stdout --json
        {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 2.7.12, platform = x86_64-pc-windows-msvc) invoked with recover --serial-number 822007655 --log-level debug --log-output stdout --json ","timestamp":"2025-01-31T10:31:51.781Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false","timestamp":"2025-01-31T10:31:51.781Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device","timestamp":"2025-01-31T10:31:51.781Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:51.819282Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.12d","timestamp":"2025-01-31T10:31:51.819Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T10:31:52.161Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T10:31:52.161Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T10:31:52.372Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T10:31:52.372Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T10:31:52.372Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T10:31:52.372Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T10:31:52.372Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T10:31:52.372Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] jlink_dll_version","timestamp":"2025-01-31T10:31:52.373Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T10:31:52.382Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T10:31:52.382Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] dll_version","timestamp":"2025-01-31T10:31:52.382Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T10:31:52.382Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T10:31:52.382Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T10:31:52.383Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T10:31:52.383Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T10:31:52.383Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T10:31:52.405Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T10:31:52.405Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T10:31:52.406Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T10:31:52.455Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T10:31:52.457Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T10:31:52.457Z"}}
        {"type":"log","data":{"level":"WARN","message":"[JlinkARM] nrfutil device commands were tested using SEGGER J-Link version JLink_V8.10f, but the J-Link version you are using is JLink_V8.12d. Your installed version will most likely work fine, but if you get issues related to J-Link with your devices, use the tested version","timestamp":"2025-01-31T10:31:52.475Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"operation to get devices for : Ok(\"{\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"recover\\\"},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")","timestamp":"2025-01-31T10:31:52.475Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: enumerate","timestamp":"2025-01-31T10:31:52.476Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_13D3&PID_56CB#200901010001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.477Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T10:31:52.477Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T10:31:52.477Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:52.479Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:52.479Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:52.479Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_046D&PID_C52B#5&2495b8dd&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.479Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{DA3A406E-66A7-11EF-A018-00090FFE0001}'","timestamp":"2025-01-31T10:31:52.479Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {DA3A406E-66A7-11EF-A018-00090FFE0001}","timestamp":"2025-01-31T10:31:52.479Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:52.480Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0BDA&PID_0129#20100201396000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.480Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T10:31:52.480Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_8087&PID_0026#5&2495b8dd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0105#000777641824#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{3F79306E-37BB-551B-B94B-0FDD0DFF00ED}'","timestamp":"2025-01-31T10:31:52.481Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {3F79306E-37BB-551B-B94B-0FDD0DFF00ED}","timestamp":"2025-01-31T10:31:52.482Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.483Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{E32B6560-907F-59AB-81F9-F77302D6FE1C}'","timestamp":"2025-01-31T10:31:52.483Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {E32B6560-907F-59AB-81F9-F77302D6FE1C}","timestamp":"2025-01-31T10:31:52.483Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.488Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}'","timestamp":"2025-01-31T10:31:52.488Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}","timestamp":"2025-01-31T10:31:52.488Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_20CE&PID_0011#6&28b98d9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.493Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A5762EC0-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T10:31:52.493Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {A5762EC0-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T10:31:52.493Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:52.494Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_072F&PID_224F#7&161d3976&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.494Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A57630D5-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T10:31:52.494Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {A57630D5-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T10:31:52.495Z"}}
        {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T10:31:52.495Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_1020#000822007655#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T10:31:52.495Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{09126C94-2B5D-5FCC-A627-3EE878ACF089}'","timestamp":"2025-01-31T10:31:52.495Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {09126C94-2B5D-5FCC-A627-3EE878ACF089}","timestamp":"2025-01-31T10:31:52.496Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 1 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:52.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 2 and serial number: '000777641824'","timestamp":"2025-01-31T10:31:52.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 3 and serial number: '000822007655'","timestamp":"2025-01-31T10:31:52.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 4 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:52.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 5 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:52.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 6 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:52.498Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 7 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:52.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 8 and serial number: 'FTDPOE5G'","timestamp":"2025-01-31T10:31:52.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 9 and serial number: 'NONE'","timestamp":"2025-01-31T10:31:52.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 10 and serial number: 'FTDPOGGJ'","timestamp":"2025-01-31T10:31:52.499Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'devkit' took 8 ms","timestamp":"2025-01-31T10:31:52.508Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:52.509302Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.12d","timestamp":"2025-01-31T10:31:52.509Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:52.522454Z] Found 2 attached J-Link devices","timestamp":"2025-01-31T10:31:52.522Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'Probe' took 14 ms","timestamp":"2025-01-31T10:31:52.522Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T10:31:52.834Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T10:31:52.834Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T10:31:53.024Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T10:31:53.024Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T10:31:53.024Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T10:31:53.024Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T10:31:53.024Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T10:31:53.024Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] enum_emu_snr","timestamp":"2025-01-31T10:31:53.025Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T10:31:53.035Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T10:31:53.035Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] enum_emu_snr","timestamp":"2025-01-31T10:31:53.035Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T10:31:53.035Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr","timestamp":"2025-01-31T10:31:53.035Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr","timestamp":"2025-01-31T10:31:53.035Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus","timestamp":"2025-01-31T10:31:53.035Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] Found 2 J-Link devices connected","timestamp":"2025-01-31T10:31:53.062Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T10:31:53.067Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T10:31:53.068Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T10:31:53.068Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T10:31:53.068Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T10:31:53.068Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T10:31:53.085Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T10:31:53.085Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T10:31:53.085Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T10:31:53.134Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T10:31:53.136Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T10:31:53.136Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'jlink' took 627 ms","timestamp":"2025-01-31T10:31:53.150Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'BOARDCONTROLLER' took 20 ms","timestamp":"2025-01-31T10:31:53.171Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T10:31:53.177Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"000770602132\", \"000773105148\", \"000777641824\"]","timestamp":"2025-01-31T10:31:53.177Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000770602132 -> GUID: {3ee8b8ef-c412-5b75-917a-0a2f66a13d7a}","timestamp":"2025-01-31T10:31:53.178Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000773105148 -> GUID: {592aca26-535d-56bc-b0cb-33014efdce30}","timestamp":"2025-01-31T10:31:53.178Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000777641824 -> GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T10:31:53.178Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"000777641824\")","timestamp":"2025-01-31T10:31:53.178Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\USB#VID_1366&PID_0105&MI_00#7&74C87DB&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_1366&PID_0105#000777641824#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T10:31:53.178Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T10:31:53.182Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOGGJ\")","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOGGJA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T10:31:53.183Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T10:31:53.187Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOE5G\")","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOE5GA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] try to map FTDI to segger device","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] found FTDI","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOGGJ'","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOE5G'","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: '000777641824'","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'serialport' took 16 ms","timestamp":"2025-01-31T10:31:53.188Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'sdfu' took 0 ms","timestamp":"2025-01-31T10:31:53.189Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'mcuBoot' took 1 ms","timestamp":"2025-01-31T10:31:53.191Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'broken' took 0 ms","timestamp":"2025-01-31T10:31:53.193Z"}}
        {"type":"task_begin","data":{"task":{"id":"7a1cf569d4b5469a83698e8488638292","description":"Recover 822007655","name":"recover","data":{"serialNumber":"000822007655"}}}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.195046Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it","timestamp":"2025-01-31T10:31:53.195Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.195085Z] The device is recognized as a device with a supported probe. Need to run device identification to determine the device family","timestamp":"2025-01-31T10:31:53.195Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.195158Z] Looking for file in C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-01-31T10:31:53.195Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.195406Z] Found file at C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-01-31T10:31:53.195Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.203658Z] Spawned worker process with id 23932","timestamp":"2025-01-31T10:31:53.203Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.268169Z] Received signal from master, returning alive worker.","timestamp":"2025-01-31T10:31:53.268Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.268277Z] Handshake signatures match","timestamp":"2025-01-31T10:31:53.268Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.268628Z] Connection with Probe worker established.","timestamp":"2025-01-31T10:31:53.268Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.266958Z] {jlink_usb_000822007655} nrf-probe version 0.30.0","timestamp":"2025-01-31T10:31:53.269Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.267100Z] {jlink_usb_000822007655} Sending IPC handshake response from worker...","timestamp":"2025-01-31T10:31:53.269Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.267675Z] {jlink_usb_000822007655} Started worker message processing loop","timestamp":"2025-01-31T10:31:53.269Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.268858Z] {jlink_usb_000822007655} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: TargetConfig { adac_timeout: None, swd_clock_frequency: None } }, firmware_config: None, target_family: None, override_detection: None })","timestamp":"2025-01-31T10:31:53.269Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.291328Z] {jlink_usb_000822007655} Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.12d","timestamp":"2025-01-31T10:31:53.291Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.321785Z] {jlink_usb_000822007655} Speed info: JLINKARM_SPEED_INFO { SizeOfStruct: 12, BaseFreq: 180000000, MinDiv: 12, SupportAdaptive: 1 }","timestamp":"2025-01-31T10:31:53.321Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.321834Z] {jlink_usb_000822007655} Max frequency: 15000 kHz","timestamp":"2025-01-31T10:31:53.322Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.321972Z] {jlink_usb_000822007655} Clock frequency was set to 2000 kHz","timestamp":"2025-01-31T10:31:53.322Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.322041Z] {jlink_usb_000822007655} Emulator Usb(JLinkSerialNumber(822007655)) running firmware: J-Link V12 compiled Dec  4 2024 17:53:50","timestamp":"2025-01-31T10:31:53.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.322251Z] {jlink_usb_000822007655} Probe worker received message: Request(DeviceInformation)","timestamp":"2025-01-31T10:31:53.322Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.322581Z] {jlink_usb_000822007655} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3326, tck: 0, tdi: 0, tdo: 0, tms: 0, tres: 0, trst: 0 }","timestamp":"2025-01-31T10:31:53.322Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.425083Z] {jlink_usb_000822007655} -> Powering up sys and debug region","timestamp":"2025-01-31T10:31:53.425Z"}}
        {"type":"log","data":{"level":"WARN","message":"[ProbeLib] [2025-01-31 10:31:53.427564Z] {jlink_usb_000822007655} DAP write error: DebugPort,  register 2 = 0x00000000, err: Unknown Error in J-Link DLL (error code =-1)","timestamp":"2025-01-31T10:31:53.427Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.427604Z] {jlink_usb_000822007655} Aborting debug operation, writing 0x1FF to ABORT register","timestamp":"2025-01-31T10:31:53.427Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.428288Z] {jlink_usb_000822007655} <- Powering up sys and debug region","timestamp":"2025-01-31T10:31:53.428Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.428456Z] Terminating worker with id 23932","timestamp":"2025-01-31T10:31:53.428Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.428556Z] {jlink_usb_000822007655} Probe worker received message: Shutdown","timestamp":"2025-01-31T10:31:53.428Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 10:31:53.453289Z] {jlink_usb_000822007655} Probe worker stopped.","timestamp":"2025-01-31T10:31:53.453Z"}}
        {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 10:31:53.466596Z] Worker exited successfully","timestamp":"2025-01-31T10:31:53.466Z"}}
        {"type":"log","data":{"level":"ERROR","message":" NRFDLException(1): [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1)","timestamp":"2025-01-31T10:31:53.466Z"}}
        {"type":"log","data":{"level":"DEBUG","message":"Task 0 is already completed","timestamp":"2025-01-31T10:31:53.466Z"}}
        {"type":"task_end","data":{"task":{"id":"7a1cf569d4b5469a83698e8488638292","description":"Recover 822007655","name":"recover","data":{"serialNumber":"000822007655"}},"message":"Failed to recover 822007655, [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1)","result":"fail","error":{"code":1,"description":"Generic"}}}
        Error: One or more recover tasks failed:
         * 822007655: [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1), code: Generic
    • I'm only using 'recover', 'erase' and 'flash' command. Using the --help I didn't find the timeout option, is there documentation about it ?
      • It happens that command timed out themself after few seconds but I also had case where command does not stop after minutes and I had to disconnec/reconnect the JLink to generate error
    • It's only the JLink Base compact that is missing (I use this one to erase/flash device, the second JLink -with COM port- is a STM32L432 Nucleo). But I tried with another JLink Base compact and doesn't seems to improve my test (both are brand new one)
    Antoine
    Can you test with J-link v8.10.f?
    That is the version that we have used during testing,
    regards
    Jared
  • Hi Jared,
    I just change J-Link version to the 8.10.f. Please find the below output (two commands in a row one successfull and the second NOK -still without changing hardware/connexion between both-) :
    >./nrfutil.exe device recover --serial-number 822007649 --log-level debug --log-output stdout --json
    {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 2.7.12, platform = x86_64-pc-windows-msvc) invoked with recover --serial-number 822007649 --log-level debug --log-output stdout --json ","timestamp":"2025-01-31T15:20:25.728Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false","timestamp":"2025-01-31T15:20:25.728Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device","timestamp":"2025-01-31T15:20:25.728Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:25.748541Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-01-31T15:20:25.748Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T15:20:25.909Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T15:20:25.909Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T15:20:25.998Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T15:20:25.998Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T15:20:25.998Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T15:20:25.998Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T15:20:25.998Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T15:20:25.998Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] jlink_dll_version","timestamp":"2025-01-31T15:20:26.005Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T15:20:26.009Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T15:20:26.009Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] dll_version","timestamp":"2025-01-31T15:20:26.009Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T15:20:26.009Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T15:20:26.009Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T15:20:26.009Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T15:20:26.009Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:20:26.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T15:20:26.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T15:20:26.024Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T15:20:26.040Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T15:20:26.041Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:20:26.042Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"operation to get devices for : Ok(\"{\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"recover\\\"},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")","timestamp":"2025-01-31T15:20:26.049Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: enumerate","timestamp":"2025-01-31T15:20:26.049Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_13D3&PID_56CB#200901010001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.050Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T15:20:26.050Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:20:26.050Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:26.051Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:26.051Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:26.051Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_046D&PID_C52B#5&2495b8dd&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.051Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{DA3A406E-66A7-11EF-A018-00090FFE0001}'","timestamp":"2025-01-31T15:20:26.051Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {DA3A406E-66A7-11EF-A018-00090FFE0001}","timestamp":"2025-01-31T15:20:26.051Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:26.052Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0BDA&PID_0129#20100201396000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.052Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T15:20:26.052Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:20:26.052Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:26.052Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:26.052Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:26.052Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_8087&PID_0026#5&2495b8dd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.052Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:20:26.053Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:26.053Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:26.053Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:26.053Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0105#000777641824#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.053Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{3F79306E-37BB-551B-B94B-0FDD0DFF00ED}'","timestamp":"2025-01-31T15:20:26.053Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {3F79306E-37BB-551B-B94B-0FDD0DFF00ED}","timestamp":"2025-01-31T15:20:26.053Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.054Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{E32B6560-907F-59AB-81F9-F77302D6FE1C}'","timestamp":"2025-01-31T15:20:26.054Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {E32B6560-907F-59AB-81F9-F77302D6FE1C}","timestamp":"2025-01-31T15:20:26.054Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.058Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}'","timestamp":"2025-01-31T15:20:26.058Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}","timestamp":"2025-01-31T15:20:26.059Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_20CE&PID_0011#6&28b98d9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.063Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A5762EC0-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T15:20:26.063Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {A5762EC0-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T15:20:26.063Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:26.064Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_072F&PID_224F#7&161d3976&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.064Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A57630D5-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T15:20:26.064Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {A57630D5-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T15:20:26.064Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:26.065Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_1020#000822007649#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:26.065Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{AB6F325D-3D32-52C9-812E-40776ABB11AA}'","timestamp":"2025-01-31T15:20:26.065Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {AB6F325D-3D32-52C9-812E-40776ABB11AA}","timestamp":"2025-01-31T15:20:26.065Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 1 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 2 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 3 and serial number: 'FTDPOGGJ'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 4 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 5 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 6 and serial number: '000822007649'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 7 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 8 and serial number: 'FTDPOE5G'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 9 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 10 and serial number: '000777641824'","timestamp":"2025-01-31T15:20:26.067Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'devkit' took 4 ms","timestamp":"2025-01-31T15:20:26.072Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.072961Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-01-31T15:20:26.072Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.079672Z] Found 2 attached J-Link devices","timestamp":"2025-01-31T15:20:26.079Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'Probe' took 7 ms","timestamp":"2025-01-31T15:20:26.079Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T15:20:26.242Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T15:20:26.243Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T15:20:26.335Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T15:20:26.335Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T15:20:26.335Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T15:20:26.335Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T15:20:26.335Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T15:20:26.335Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] enum_emu_snr","timestamp":"2025-01-31T15:20:26.341Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T15:20:26.347Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T15:20:26.347Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] enum_emu_snr","timestamp":"2025-01-31T15:20:26.347Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T15:20:26.347Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr","timestamp":"2025-01-31T15:20:26.347Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr","timestamp":"2025-01-31T15:20:26.347Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus","timestamp":"2025-01-31T15:20:26.347Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Found 2 J-Link devices connected","timestamp":"2025-01-31T15:20:26.356Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T15:20:26.358Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T15:20:26.358Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T15:20:26.358Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T15:20:26.358Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T15:20:26.372Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T15:20:26.372Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:20:26.387Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T15:20:26.433Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T15:20:26.435Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:20:26.435Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'jlink' took 368 ms","timestamp":"2025-01-31T15:20:26.448Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'BOARDCONTROLLER' took 18 ms","timestamp":"2025-01-31T15:20:26.466Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T15:20:26.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"000770602132\", \"000773105148\", \"000777641824\"]","timestamp":"2025-01-31T15:20:26.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000770602132 -> GUID: {3ee8b8ef-c412-5b75-917a-0a2f66a13d7a}","timestamp":"2025-01-31T15:20:26.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000773105148 -> GUID: {592aca26-535d-56bc-b0cb-33014efdce30}","timestamp":"2025-01-31T15:20:26.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000777641824 -> GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T15:20:26.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"000777641824\")","timestamp":"2025-01-31T15:20:26.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\USB#VID_1366&PID_0105&MI_00#7&74C87DB&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_1366&PID_0105#000777641824#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:20:26.469Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOGGJ\")","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOGGJA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:20:26.471Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOE5G\")","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOE5GA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:20:26.472Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] try to map FTDI to segger device","timestamp":"2025-01-31T15:20:26.473Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] found FTDI","timestamp":"2025-01-31T15:20:26.473Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOGGJ'","timestamp":"2025-01-31T15:20:26.473Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: '000777641824'","timestamp":"2025-01-31T15:20:26.473Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOE5G'","timestamp":"2025-01-31T15:20:26.473Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'serialport' took 5 ms","timestamp":"2025-01-31T15:20:26.473Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'sdfu' took 0 ms","timestamp":"2025-01-31T15:20:26.473Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'mcuBoot' took 0 ms","timestamp":"2025-01-31T15:20:26.474Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'broken' took 0 ms","timestamp":"2025-01-31T15:20:26.474Z"}}
    {"type":"task_begin","data":{"task":{"id":"4d14cadab76747e8bce7cc029a6610f7","description":"Recover 822007649","name":"recover","data":{"serialNumber":"000822007649"}}}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.475331Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it","timestamp":"2025-01-31T15:20:26.475Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.475347Z] The device is recognized as a device with a supported probe. Need to run device identification to determine the device family","timestamp":"2025-01-31T15:20:26.475Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.475378Z] Looking for file in C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-01-31T15:20:26.475Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.475463Z] Found file at C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-01-31T15:20:26.475Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.479251Z] Spawned worker process with id 10248","timestamp":"2025-01-31T15:20:26.479Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.511623Z] Received signal from master, returning alive worker.","timestamp":"2025-01-31T15:20:26.511Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.511744Z] Handshake signatures match","timestamp":"2025-01-31T15:20:26.511Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.511953Z] Connection with Probe worker established.","timestamp":"2025-01-31T15:20:26.511Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.501852Z] {jlink_usb_000822007649} nrf-probe version 0.30.0","timestamp":"2025-01-31T15:20:26.512Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.501890Z] {jlink_usb_000822007649} Sending IPC handshake response from worker...","timestamp":"2025-01-31T15:20:26.512Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.502095Z] {jlink_usb_000822007649} Started worker message processing loop","timestamp":"2025-01-31T15:20:26.512Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.512061Z] {jlink_usb_000822007649} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: TargetConfig { adac_timeout: None, swd_clock_frequency: None } }, firmware_config: None, target_family: None, override_detection: None })","timestamp":"2025-01-31T15:20:26.512Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.522786Z] {jlink_usb_000822007649} Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-01-31T15:20:26.522Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.539809Z] {jlink_usb_000822007649} Speed info: JLINKARM_SPEED_INFO { SizeOfStruct: 12, BaseFreq: 180000000, MinDiv: 12, SupportAdaptive: 1 }","timestamp":"2025-01-31T15:20:26.539Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.539823Z] {jlink_usb_000822007649} Max frequency: 15000 kHz","timestamp":"2025-01-31T15:20:26.539Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.540041Z] {jlink_usb_000822007649} Clock frequency was set to 2000 kHz","timestamp":"2025-01-31T15:20:26.540Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.540089Z] {jlink_usb_000822007649} Emulator Usb(JLinkSerialNumber(822007649)) running firmware: J-Link V12 compiled Dec  4 2024 17:53:50","timestamp":"2025-01-31T15:20:26.540Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.540284Z] {jlink_usb_000822007649} Probe worker received message: Request(DeviceInformation)","timestamp":"2025-01-31T15:20:26.540Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.540580Z] {jlink_usb_000822007649} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3324, tck: 0, tdi: 0, tdo: 0, tms: 0, tres: 1, trst: 0 }","timestamp":"2025-01-31T15:20:26.540Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.541277Z] {jlink_usb_000822007649} -> Powering up sys and debug region","timestamp":"2025-01-31T15:20:26.541Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.541838Z] {jlink_usb_000822007649} Powered up sys and dbg regions in 0 ms","timestamp":"2025-01-31T15:20:26.541Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.541843Z] {jlink_usb_000822007649} <- Powering up sys and debug region","timestamp":"2025-01-31T15:20:26.541Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.542891Z] {jlink_usb_000822007649} -> detect device family","timestamp":"2025-01-31T15:20:26.542Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.548806Z] {jlink_usb_000822007649} Detected CTRL-AP revision 1 at AP 2","timestamp":"2025-01-31T15:20:26.548Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.550002Z] {jlink_usb_000822007649} Device detection: partno 0x00000007 hwrevision 0x00000005","timestamp":"2025-01-31T15:20:26.550Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.550006Z] {jlink_usb_000822007649} <- detect device family","timestamp":"2025-01-31T15:20:26.550Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.550135Z] Device family nRF53 not NRF54H/NRF54L, not supported by probe-plugin","timestamp":"2025-01-31T15:20:26.550Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.550157Z] Terminating worker with id 10248","timestamp":"2025-01-31T15:20:26.550Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.550177Z] {jlink_usb_000822007649} Probe worker received message: Shutdown","timestamp":"2025-01-31T15:20:26.550Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.550195Z] {jlink_usb_000822007649} -> Powering down debug region","timestamp":"2025-01-31T15:20:26.550Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.553640Z] {jlink_usb_000822007649} Powered down sys and dbg regions in 3 ms","timestamp":"2025-01-31T15:20:26.553Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.553645Z] {jlink_usb_000822007649} <- Powering down debug region","timestamp":"2025-01-31T15:20:26.553Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:26.574583Z] {jlink_usb_000822007649} Probe worker stopped.","timestamp":"2025-01-31T15:20:26.574Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:26.586681Z] Worker exited successfully","timestamp":"2025-01-31T15:20:26.586Z"}}
    {"type":"log","data":{"level":"INFO","message":"Loaded plugin C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl; starting to resolve symbols","timestamp":"2025-01-31T15:20:26.587Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Initializing the J-Link debug probe for device {\"id\":6,\"probe\":{},\"serialNumber\":\"000822007649\",\"traits\":{\"boardController\":false,\"broken\":false,\"devkit\":false,\"jlink\":true,\"mcuBoot\":false,\"modem\":false,\"nordicDfu\":false,\"nordicUsb\":false,\"seggerUsb\":true,\"serialPorts\":false,\"usb\":true},\"usb\":{\"device\":{\"address\":28,\"busNumber\":1,\"descriptor\":{\"bDescriptorType\":1,\"bcdDevice\":256,\"idProduct\":4128,\"idVendor\":4966}},\"manufacturer\":\"SEGGER\",\"osDevicePath\":\"\\\\\\\\?\\\\USB#VID_1366&PID_1020#000822007649#{a5dcbf10-6530-11d2-901f-00c04fb951ed}\",\"product\":\"J-Link\",\"serialNumber\":\"000822007649\"},\"usbIdentifier\":\"\\\\\\\\?\\\\USB#VID_1366&PID_1020#000822007649#{A5DCBF10-6530-11D2-901F-00C04FB951ED}\"} with serial number: 000822007649","timestamp":"2025-01-31T15:20:26.587Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Opening J-Link DLL","timestamp":"2025-01-31T15:20:26.587Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] open","timestamp":"2025-01-31T15:20:26.747Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] start","timestamp":"2025-01-31T15:20:26.747Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T15:20:26.843Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][000822007649] Logger sink registered in JLink logger","timestamp":"2025-01-31T15:20:26.843Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000822007649] open","timestamp":"2025-01-31T15:20:26.843Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000822007649] just_check_family","timestamp":"2025-01-31T15:20:26.843Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] open_dll","timestamp":"2025-01-31T15:20:26.843Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T15:20:26.843Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] connect_to_emu_with_snr","timestamp":"2025-01-31T15:20:26.844Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Set batch mode","timestamp":"2025-01-31T15:20:26.854Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] dll_version","timestamp":"2025-01-31T15:20:26.854Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000822007649] connect_to_emu_with_snr","timestamp":"2025-01-31T15:20:26.854Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_emu","timestamp":"2025-01-31T15:20:26.854Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] connect_to_emu_with_snr","timestamp":"2025-01-31T15:20:26.854Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_enum_emu_snr","timestamp":"2025-01-31T15:20:26.854Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_get_num_emus","timestamp":"2025-01-31T15:20:26.854Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_emu_with_snr","timestamp":"2025-01-31T15:20:26.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_emu_without_snr","timestamp":"2025-01-31T15:20:26.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Segger logging enabled.","timestamp":"2025-01-31T15:20:26.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] read_device_family","timestamp":"2025-01-31T15:20:26.958Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Connected emulator supports SWD speeds up to 15000kHz","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] SWD clock set to 2000kHz","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][000822007649] read_device_family","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_emu","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_debug_port_idr","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_debug_port_register","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_debug_port_register","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] coresight_configure","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_idr","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_is_debug_region_powered","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.965Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_idr","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 1, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 1, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 3, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 3, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 4, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 4, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 5, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 5, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 6, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 6, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.966Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_idr","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] select_family","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 7, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 7, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 8, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 8, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 9, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.977Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 9, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_idr","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 10, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 10, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 11, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 11, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 12, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 12, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 13, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 13, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 14, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 14, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 15, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 15, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 16, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 16, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 17, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 17, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.978Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 0, AP Bank 3","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_load_coprocessor_data","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] set_core_data","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Set core data:","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649]   Device ID: Cortex-M33","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649]   Expected core: 235012351","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649]   Existing Expected core: 4294967295","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649]   Coprocessor: APPLICATION","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649]   AHB AP index: 0","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649]   Core base address: 4294967295","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---set_coresight_ahb_ap_index","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Attempting to recover device; attempt #0","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Getting recovery image for family NRF53_FAMILY and core NRFDL_DEVICE_CORE_APPLICATION","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"INFO","message":"[jlink] Using firmware image for recovery to keep the device unlocked.","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] JLink from buffer.","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] JLink from file C:\\Users\\antoine.bricard\\AppData\\Roaming\\MobaXterm\\slash\\tmp\\temp_program_fw17383368269784296001.hex.","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] recover","timestamp":"2025-01-31T15:20:26.979Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] recover","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_emu","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] just_recover","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_is_eraseprotect_enabled","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_is_debug_region_powered","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_debug_port_register","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 0, AP Bank 1","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Eraseaprotect is disabled","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_disable_accessportprotect","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write_access_port_register","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:26.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:27.485Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:27.485Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:27.485Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:27.992Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:27.992Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:27.992Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_read_device_version","timestamp":"2025-01-31T15:20:27.992Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 0, AP Bank 3","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_decode_device_version","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Device identified as NRF5340_xxAA_REV1","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_debug_reset_coprocessor","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write_access_port_register","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:27.993Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_readback_status","timestamp":"2025-01-31T15:20:28.004Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.004Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.004Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.004Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:28.004Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Protection status for ahb-ap 0 read as NONE","timestamp":"2025-01-31T15:20:28.004Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] halt","timestamp":"2025-01-31T15:20:28.005Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.005Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.005Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_enable_coprocessor","timestamp":"2025-01-31T15:20:28.005Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---set_coresight_ahb_ap_index","timestamp":"2025-01-31T15:20:28.005Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_halt","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] sys_reset","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_sys_reset","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_u32","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_invalidate_cache","timestamp":"2025-01-31T15:20:28.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_power_ram_all","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_readback_status","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Protection status for ahb-ap 0 read as NONE","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_periph_secure_state","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ahb_read_u32","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write_u32","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_u32","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_debug_port_register","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:28.116Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write_u32","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_u32","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_debug_port_register","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_periph_secure_state","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ahb_read_u32","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:28.128Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ahb_read_u32","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write_u32","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_u32","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_debug_port_register","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_periph_secure_state","timestamp":"2025-01-31T15:20:28.129Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Running NRFJPROG_program.","timestamp":"2025-01-31T15:20:28.136Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] program","timestamp":"2025-01-31T15:20:28.136Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50081000 has secure properties Selectable Secure","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write_u32","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_u32","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_debug_port_register","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_periph_secure_state","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x50003A04: secure state of peripheral from SPU @0x50003000 (S) (slave index 129).","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ahb_read_u32","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_clear_resetreas","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x50003814: secure state of peripheral from SPU @0x50003000 (S) (slave index 5).","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50005400 has secure properties Selectable Secure","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] program","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_emu","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] program_file","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] init_device_info","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_memory_list","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_read_device_version","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_is_debug_region_powered","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_debug_port_register","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 0, AP Bank 3","timestamp":"2025-01-31T15:20:28.139Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.140Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_decode_device_version","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Device identified as NRF5340_xxAA_REV1","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] read_device_info","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_read_device_version","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] hex_file_is_valid","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] read_region_0_size_and_source.","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_read_region_0_size_and_source","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] is_bprot_enabled","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_is_bprot_enabled","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_readback_status","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Protection status for ahb-ap 0 read as NONE","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] halt","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_halt","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] init_device_info","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_memory_list","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 2, DP Bank 255, AP Bank 3","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Memory list already constructed. Skipping.","timestamp":"2025-01-31T15:20:28.152Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_decode_device_version","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Device identified as NRF5340_xxAA_REV1","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_u32","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_u32","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_invalidate_cache","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] just_is_mpu_enabled_m33","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_read_u32","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_halt","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] loop_image","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_write","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_nvmc_config_control","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_periph_secure_state","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ahb_read_u32","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50039584 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50039504 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write_u32","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_u32","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_debug_port_register","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:28.153Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_debug_port_register","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_nvmc_wait_for_ready","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_periph_secure_state","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ahb_read_u32","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50039400 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_u32","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_u32","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_invalidate_cache","timestamp":"2025-01-31T15:20:28.154Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_nvmc_wait_for_ready","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 255, AP Bank 0","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_periph_secure_state","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ahb_read_u32","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50039400 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_u32","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_u32","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_invalidate_cache","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_nvmc_config_control","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50039584 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 0","timestamp":"2025-01-31T15:20:28.186Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_access_port_register","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_access_port_register","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_access_port_register","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 0, DP Bank 0, AP Bank 15","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50039504 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] write_u32","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_connect_to_device","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_u32","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_debug_port_register","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_nvmc_wait_for_ready","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_secure_debug_available","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_access_port_register","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Just_get_secure_nonsecure_address","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] update_periph_secure_state","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Reading addr 0x500038E4: secure state of peripheral from SPU @0x50003000 (S) (slave index 57).","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ahb_read_u32","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] Peripheral at address 0x50039400 has secure properties Fixed Secure, (split)","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] read_u32","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_u32","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_invalidate_cache","timestamp":"2025-01-31T15:20:28.187Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] close","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_emu","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] close","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] disconnect_from_emu","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_disconnect_from_emu","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] is_connected_to_device","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_is_debug_region_powered","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_read_debug_port_register","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_select_debug_port_register","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Select AP 255, DP Bank 0, AP Bank 255","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Disable trace before closing connection.","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_u32","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] ---just_write_debug_port_register","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Shortcut, lock is on and debug region is powered.","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] unpower_debug_and_system_regions","timestamp":"2025-01-31T15:20:28.197Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][000822007649] Segger Backend closed.","timestamp":"2025-01-31T15:20:28.218Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRF53][000822007649] nRF family DLL closed","timestamp":"2025-01-31T15:20:28.218Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] terminate","timestamp":"2025-01-31T15:20:28.228Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] Worker process exited with code: 0","timestamp":"2025-01-31T15:20:28.290Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] Child process terminated with result 0","timestamp":"2025-01-31T15:20:28.291Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][000822007649] terminate","timestamp":"2025-01-31T15:20:28.291Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Task 1923262062114 is already completed","timestamp":"2025-01-31T15:20:28.305Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"~async_task id: 1923262062114","timestamp":"2025-01-31T15:20:28.305Z"}}
    {"type":"log","data":{"level":"INFO","message":"~plugin_container(0x275a0884000): close plugin dll at path: C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl","timestamp":"2025-01-31T15:20:28.305Z"}}
    {"type":"task_end","data":{"task":{"id":"4d14cadab76747e8bce7cc029a6610f7","description":"Recover 822007649","name":"recover","data":{"serialNumber":"000822007649"}},"message":"Recovered 822007649","result":"success","error":null}}
    {"type":"log","data":{"level":"DEBUG","message":"~plugin_container(0x275a0884000): closed plugin dll at path: C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\10-nrfdl-jlink-plugin.nrfdl","timestamp":"2025-01-31T15:20:28.305Z"}}
        âś“
    > nrffutil.exe device recover --serial-number 822007649 --log-level debug --log-output stdout --json
    {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 2.7.12, platform = x86_64-pc-windows-msvc) invoked with recover --serial-number 822007649 --log-level debug --log-output stdout --json ","timestamp":"2025-01-31T15:20:32.141Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false","timestamp":"2025-01-31T15:20:32.141Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device","timestamp":"2025-01-31T15:20:32.141Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.159422Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-01-31T15:20:32.159Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T15:20:32.317Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T15:20:32.317Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T15:20:32.405Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T15:20:32.405Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T15:20:32.405Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T15:20:32.405Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T15:20:32.405Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T15:20:32.405Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] jlink_dll_version","timestamp":"2025-01-31T15:20:32.411Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T15:20:32.415Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T15:20:32.415Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] dll_version","timestamp":"2025-01-31T15:20:32.415Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T15:20:32.415Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T15:20:32.416Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T15:20:32.416Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T15:20:32.416Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T15:20:32.416Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T15:20:32.416Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T15:20:32.416Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:20:32.440Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T15:20:32.488Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T15:20:32.490Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:20:32.490Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"operation to get devices for : Ok(\"{\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"recover\\\"},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")","timestamp":"2025-01-31T15:20:32.502Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: enumerate","timestamp":"2025-01-31T15:20:32.503Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_13D3&PID_56CB#200901010001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.503Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T15:20:32.503Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:20:32.504Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:32.504Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:32.504Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:32.504Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_046D&PID_C52B#5&2495b8dd&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.504Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{DA3A406E-66A7-11EF-A018-00090FFE0001}'","timestamp":"2025-01-31T15:20:32.504Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {DA3A406E-66A7-11EF-A018-00090FFE0001}","timestamp":"2025-01-31T15:20:32.504Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0BDA&PID_0129#20100201396000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_8087&PID_0026#5&2495b8dd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0105#000777641824#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{3F79306E-37BB-551B-B94B-0FDD0DFF00ED}'","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {3F79306E-37BB-551B-B94B-0FDD0DFF00ED}","timestamp":"2025-01-31T15:20:32.506Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.507Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{E32B6560-907F-59AB-81F9-F77302D6FE1C}'","timestamp":"2025-01-31T15:20:32.507Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {E32B6560-907F-59AB-81F9-F77302D6FE1C}","timestamp":"2025-01-31T15:20:32.507Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.512Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}'","timestamp":"2025-01-31T15:20:32.512Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}","timestamp":"2025-01-31T15:20:32.512Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_20CE&PID_0011#6&28b98d9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.517Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A5762EC0-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T15:20:32.517Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {A5762EC0-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T15:20:32.518Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:32.518Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_072F&PID_224F#7&161d3976&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.518Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A57630D5-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T15:20:32.518Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {A57630D5-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T15:20:32.519Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:20:32.519Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_1020#000822007649#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:20:32.519Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{AB6F325D-3D32-52C9-812E-40776ABB11AA}'","timestamp":"2025-01-31T15:20:32.519Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {AB6F325D-3D32-52C9-812E-40776ABB11AA}","timestamp":"2025-01-31T15:20:32.520Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 1 and serial number: '000822007649'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 2 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 3 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 4 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 5 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 6 and serial number: '000777641824'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 7 and serial number: 'FTDPOGGJ'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 8 and serial number: 'FTDPOE5G'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 9 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 10 and serial number: 'NONE'","timestamp":"2025-01-31T15:20:32.521Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'devkit' took 3 ms","timestamp":"2025-01-31T15:20:32.524Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.525408Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-01-31T15:20:32.525Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.533271Z] Found 2 attached J-Link devices","timestamp":"2025-01-31T15:20:32.533Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'Probe' took 8 ms","timestamp":"2025-01-31T15:20:32.533Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T15:20:32.679Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T15:20:32.679Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T15:20:32.768Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T15:20:32.768Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T15:20:32.769Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T15:20:32.769Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T15:20:32.769Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T15:20:32.769Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] enum_emu_snr","timestamp":"2025-01-31T15:20:32.769Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T15:20:32.780Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T15:20:32.780Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] enum_emu_snr","timestamp":"2025-01-31T15:20:32.780Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T15:20:32.780Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr","timestamp":"2025-01-31T15:20:32.781Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr","timestamp":"2025-01-31T15:20:32.781Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus","timestamp":"2025-01-31T15:20:32.781Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] Found 2 J-Link devices connected","timestamp":"2025-01-31T15:20:32.785Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T15:20:32.791Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T15:20:32.791Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T15:20:32.791Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T15:20:32.791Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T15:20:32.791Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T15:20:32.791Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:20:32.803Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T15:20:32.835Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T15:20:32.837Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:20:32.837Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'jlink' took 313 ms","timestamp":"2025-01-31T15:20:32.846Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'BOARDCONTROLLER' took 14 ms","timestamp":"2025-01-31T15:20:32.861Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T15:20:32.864Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"000770602132\", \"000773105148\", \"000777641824\"]","timestamp":"2025-01-31T15:20:32.864Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000770602132 -> GUID: {3ee8b8ef-c412-5b75-917a-0a2f66a13d7a}","timestamp":"2025-01-31T15:20:32.864Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000773105148 -> GUID: {592aca26-535d-56bc-b0cb-33014efdce30}","timestamp":"2025-01-31T15:20:32.864Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000777641824 -> GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T15:20:32.864Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"000777641824\")","timestamp":"2025-01-31T15:20:32.864Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\USB#VID_1366&PID_0105&MI_00#7&74C87DB&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_1366&PID_0105#000777641824#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:20:32.864Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOGGJ\")","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOGGJA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:20:32.866Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOE5G\")","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOE5GA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] try to map FTDI to segger device","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] found FTDI","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOGGJ'","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOE5G'","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: '000777641824'","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'serialport' took 6 ms","timestamp":"2025-01-31T15:20:32.868Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'sdfu' took 0 ms","timestamp":"2025-01-31T15:20:32.869Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'mcuBoot' took 0 ms","timestamp":"2025-01-31T15:20:32.869Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'broken' took 0 ms","timestamp":"2025-01-31T15:20:32.870Z"}}
    {"type":"task_begin","data":{"task":{"id":"4183a33043fd4eaf8e9d5b304465a9a2","description":"Recover 822007649","name":"recover","data":{"serialNumber":"000822007649"}}}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.870824Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it","timestamp":"2025-01-31T15:20:32.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.870838Z] The device is recognized as a device with a supported probe. Need to run device identification to determine the device family","timestamp":"2025-01-31T15:20:32.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.870894Z] Looking for file in C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-01-31T15:20:32.870Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.870998Z] Found file at C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device\\plugin-probe-worker.exe","timestamp":"2025-01-31T15:20:32.871Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.874403Z] Spawned worker process with id 30440","timestamp":"2025-01-31T15:20:32.874Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.906845Z] Received signal from master, returning alive worker.","timestamp":"2025-01-31T15:20:32.906Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.906905Z] Handshake signatures match","timestamp":"2025-01-31T15:20:32.906Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.907131Z] Connection with Probe worker established.","timestamp":"2025-01-31T15:20:32.907Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.898281Z] {jlink_usb_000822007649} nrf-probe version 0.30.0","timestamp":"2025-01-31T15:20:32.907Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.898322Z] {jlink_usb_000822007649} Sending IPC handshake response from worker...","timestamp":"2025-01-31T15:20:32.907Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.898535Z] {jlink_usb_000822007649} Started worker message processing loop","timestamp":"2025-01-31T15:20:32.907Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.907271Z] {jlink_usb_000822007649} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: TargetConfig { adac_timeout: None, swd_clock_frequency: None } }, firmware_config: None, target_family: None, override_detection: None })","timestamp":"2025-01-31T15:20:32.907Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.917053Z] {jlink_usb_000822007649} Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-01-31T15:20:32.917Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.935617Z] {jlink_usb_000822007649} Speed info: JLINKARM_SPEED_INFO { SizeOfStruct: 12, BaseFreq: 180000000, MinDiv: 12, SupportAdaptive: 1 }","timestamp":"2025-01-31T15:20:32.935Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.935631Z] {jlink_usb_000822007649} Max frequency: 15000 kHz","timestamp":"2025-01-31T15:20:32.935Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.935872Z] {jlink_usb_000822007649} Clock frequency was set to 2000 kHz","timestamp":"2025-01-31T15:20:32.935Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:32.935909Z] {jlink_usb_000822007649} Emulator Usb(JLinkSerialNumber(822007649)) running firmware: J-Link V12 compiled Dec  4 2024 17:53:50","timestamp":"2025-01-31T15:20:32.935Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.936105Z] {jlink_usb_000822007649} Probe worker received message: Request(DeviceInformation)","timestamp":"2025-01-31T15:20:32.936Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:32.936375Z] {jlink_usb_000822007649} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3335, tck: 0, tdi: 0, tdo: 0, tms: 0, tres: 1, trst: 0 }","timestamp":"2025-01-31T15:20:32.936Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:33.038062Z] {jlink_usb_000822007649} -> Powering up sys and debug region","timestamp":"2025-01-31T15:20:33.038Z"}}
    {"type":"log","data":{"level":"WARN","message":"[ProbeLib] [2025-01-31 15:20:33.039491Z] {jlink_usb_000822007649} DAP write error: DebugPort,  register 2 = 0x00000000, err: Unknown Error in J-Link DLL (error code =-1)","timestamp":"2025-01-31T15:20:33.039Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:33.039510Z] {jlink_usb_000822007649} Aborting debug operation, writing 0x1FF to ABORT register","timestamp":"2025-01-31T15:20:33.039Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:33.040022Z] {jlink_usb_000822007649} <- Powering up sys and debug region","timestamp":"2025-01-31T15:20:33.040Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:33.040174Z] Terminating worker with id 30440","timestamp":"2025-01-31T15:20:33.040Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:33.040269Z] {jlink_usb_000822007649} Probe worker received message: Shutdown","timestamp":"2025-01-31T15:20:33.040Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[ProbeLib] [2025-01-31 15:20:33.055178Z] {jlink_usb_000822007649} Probe worker stopped.","timestamp":"2025-01-31T15:20:33.055Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:20:33.062602Z] Worker exited successfully","timestamp":"2025-01-31T15:20:33.062Z"}}
    {"type":"log","data":{"level":"ERROR","message":" NRFDLException(1): [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1)","timestamp":"2025-01-31T15:20:33.062Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Task 0 is already completed","timestamp":"2025-01-31T15:20:33.062Z"}}
    {"type":"task_end","data":{"task":{"id":"4183a33043fd4eaf8e9d5b304465a9a2","description":"Recover 822007649","name":"recover","data":{"serialNumber":"000822007649"}},"message":"Failed to recover 822007649, [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1)","result":"fail","error":{"code":1,"description":"Generic"}}}
    Error: One or more recover tasks failed:
     * 822007649: [Probe] Device error: Failed to write DebugPort register 2: Unknown Error in J-Link DLL (error code =-1), code: Generic
    And below are some log of command that fail because the JLink is not detected anymore by nrfutils (while still detected by J-Flash/J-Link):
    > ./nrfutil.exe device erase --serial-number 822007649 --log-level debug --log-output stdout --json
    {"type":"log","data":{"level":"INFO","message":"nrfutil-device (version = 2.7.12, platform = x86_64-pc-windows-msvc) invoked with erase --serial-number 822007649 --log-level debug --log-output stdout --json ","timestamp":"2025-01-31T15:25:27.610Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false","timestamp":"2025-01-31T15:25:27.610Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\\Users\\antoine.bricard\\.nrfutil\\lib\\nrfutil-device","timestamp":"2025-01-31T15:25:27.610Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:25:27.630672Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-01-31T15:25:27.630Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] open","timestamp":"2025-01-31T15:25:27.783Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] start","timestamp":"2025-01-31T15:25:27.783Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger","timestamp":"2025-01-31T15:25:27.892Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger","timestamp":"2025-01-31T15:25:27.892Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] open","timestamp":"2025-01-31T15:25:27.892Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] just_check_family","timestamp":"2025-01-31T15:25:27.892Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] open_dll","timestamp":"2025-01-31T15:25:27.892Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.","timestamp":"2025-01-31T15:25:27.892Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] jlink_dll_version","timestamp":"2025-01-31T15:25:27.892Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Set batch mode","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] dll_version","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] dll_version","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] close","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] close","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed","timestamp":"2025-01-31T15:25:27.901Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:25:27.909Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Worker process exited with code: 0","timestamp":"2025-01-31T15:25:27.955Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] Child process terminated with result 0","timestamp":"2025-01-31T15:25:27.956Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[jlink] [NRFJPROG][Client][-] terminate","timestamp":"2025-01-31T15:25:27.956Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"operation to get devices for : Ok(\"{\\\"operations\\\":[{\\\"operation\\\":{\\\"type\\\":\\\"erase\\\",\\\"option\\\":{\\\"chip_erase_mode\\\":\\\"ERASE_ALL\\\",\\\"ext_mem_erase_mode\\\":\\\"ERASE_NONE\\\"}},\\\"core\\\":\\\"NRFDL_DEVICE_CORE_APPLICATION\\\"}]}\")","timestamp":"2025-01-31T15:25:27.971Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: enumerate","timestamp":"2025-01-31T15:25:27.971Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_13D3&PID_56CB#200901010001#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.972Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T15:25:27.972Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 5, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:25:27.972Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:25:27.973Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:25:27.973Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:25:27.973Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_046D&PID_C52B#5&2495b8dd&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.973Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{DA3A406E-66A7-11EF-A018-00090FFE0001}'","timestamp":"2025-01-31T15:25:27.973Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {DA3A406E-66A7-11EF-A018-00090FFE0001}","timestamp":"2025-01-31T15:25:27.973Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:25:27.974Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0BDA&PID_0129#20100201396000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.974Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{00000000-0000-0000-FFFF-FFFFFFFFFFFF}'","timestamp":"2025-01-31T15:25:27.974Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:25:27.974Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:25:27.974Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:25:27.974Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: Un p├®riph├®rique attach├® au syst├¿me ne fonctionne pas correctement. (0x8007001F)","timestamp":"2025-01-31T15:25:27.974Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_8087&PID_0026#5&2495b8dd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.974Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#ROOT_HUB30#4&F40ED3B&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}","timestamp":"2025-01-31T15:25:27.975Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Received `0` as descriptor index","timestamp":"2025-01-31T15:25:27.975Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Received `0` as descriptor index","timestamp":"2025-01-31T15:25:27.975Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:25:27.975Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_0105#000777641824#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.975Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{3F79306E-37BB-551B-B94B-0FDD0DFF00ED}'","timestamp":"2025-01-31T15:25:27.975Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {3F79306E-37BB-551B-B94B-0FDD0DFF00ED}","timestamp":"2025-01-31T15:25:27.975Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.976Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{E32B6560-907F-59AB-81F9-F77302D6FE1C}'","timestamp":"2025-01-31T15:25:27.976Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {E32B6560-907F-59AB-81F9-F77302D6FE1C}","timestamp":"2025-01-31T15:25:27.976Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.981Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}'","timestamp":"2025-01-31T15:25:27.981Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {2B8E9E6E-C460-51FF-97B6-CEB0BC90E3AD}","timestamp":"2025-01-31T15:25:27.981Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_20CE&PID_0011#6&28b98d9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.986Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A5762EC0-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T15:25:27.986Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#5&2495B8DD&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {A5762EC0-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T15:25:27.986Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Received `0` as descriptor index","timestamp":"2025-01-31T15:25:27.987Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_072F&PID_224F#7&161d3976&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.987Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{A57630D5-DCA2-11EF-A022-00090FFE0001}'","timestamp":"2025-01-31T15:25:27.987Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {A57630D5-DCA2-11EF-A022-00090FFE0001}","timestamp":"2025-01-31T15:25:27.987Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Enumerating device 'DeviceInstanceId(\\\\?\\USB#VID_1366&PID_1020#000822007649#{a5dcbf10-6530-11d2-901f-00c04fb951ed})'","timestamp":"2025-01-31T15:25:27.987Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Container ID: '{AB6F325D-3D32-52C9-812E-40776ABB11AA}'","timestamp":"2025-01-31T15:25:27.987Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"usb-lister-rs: Hub device path: \\\\?\\USB#VID_05E3&PID_0610#6&28B98D9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {AB6F325D-3D32-52C9-812E-40776ABB11AA}","timestamp":"2025-01-31T15:25:27.988Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for manufacturer: Failed request to `DeviceIoControl`: LÔÇÖop├®ration dÔÇÖentr├®e/sortie a ├®t├® abandonn├®e en raison de lÔÇÖarr├¬t dÔÇÖun thread ou ├á la demande dÔÇÖune application. (0x800703E3)","timestamp":"2025-01-31T15:25:32.988Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for product: Failed request to `DeviceIoControl`: LÔÇÖop├®ration dÔÇÖentr├®e/sortie a ├®t├® abandonn├®e en raison de lÔÇÖarr├¬t dÔÇÖun thread ou ├á la demande dÔÇÖune application. (0x800703E3)","timestamp":"2025-01-31T15:25:37.988Z"}}
    {"type":"log","data":{"level":"WARN","message":"usb-lister-rs: Failed to get device descriptor for serial number: Failed request to `DeviceIoControl`: LÔÇÖop├®ration dÔÇÖentr├®e/sortie a ├®t├® abandonn├®e en raison de lÔÇÖarr├¬t dÔÇÖun thread ou ├á la demande dÔÇÖune application. (0x800703E3)","timestamp":"2025-01-31T15:25:42.988Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 1 and serial number: 'FTDPOGGJ'","timestamp":"2025-01-31T15:25:42.989Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 2 and serial number: 'NONE'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 3 and serial number: 'NONE'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 4 and serial number: 'NONE'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 5 and serial number: 'NONE'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 6 and serial number: '000777641824'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 7 and serial number: 'NONE'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 8 and serial number: 'FTDPOE5G'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 9 and serial number: 'NONE'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"USBLister: Adding new device with ID 10 and serial number: 'NONE'","timestamp":"2025-01-31T15:25:42.990Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'devkit' took 10 ms","timestamp":"2025-01-31T15:25:43.002Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:25:43.004188Z] Opened J-Link DLL at C:\\Program Files\\SEGGER\\JLink\\JLink_x64.dll with version 8.10f","timestamp":"2025-01-31T15:25:43.004Z"}}
    {"type":"log","data":{"level":"INFO","message":"[ProbeLib] [2025-01-31 15:25:43.020576Z] Found 2 attached J-Link devices","timestamp":"2025-01-31T15:25:43.020Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'Probe' took 17 ms","timestamp":"2025-01-31T15:25:43.020Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'jlink' took 0 ms","timestamp":"2025-01-31T15:25:43.021Z"}}
    {"type":"log","data":{"level":"ERROR","message":"plugin(jlink) enumerate failed with error: 1, msg: [jlink] [json.exception.type_error.302] type must be string, but is null","timestamp":"2025-01-31T15:25:43.021Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'BOARDCONTROLLER' took 16 ms","timestamp":"2025-01-31T15:25:43.038Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T15:25:43.042Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"000770602132\", \"000773105148\", \"000777641824\"]","timestamp":"2025-01-31T15:25:43.042Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000770602132 -> GUID: {3ee8b8ef-c412-5b75-917a-0a2f66a13d7a}","timestamp":"2025-01-31T15:25:43.042Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000773105148 -> GUID: {592aca26-535d-56bc-b0cb-33014efdce30}","timestamp":"2025-01-31T15:25:43.042Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 000777641824 -> GUID: {3f79306e-37bb-551b-b94b-0fdd0dff00ed}","timestamp":"2025-01-31T15:25:43.042Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"000777641824\")","timestamp":"2025-01-31T15:25:43.042Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\USB#VID_1366&PID_0105&MI_00#7&74C87DB&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_1366&PID_0105#000777641824#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:25:43.042Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOGGJ -> GUID: {e32b6560-907f-59ab-81f9-f77302d6fe1c}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOGGJ\")","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOGGJA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOGGJ#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:25:43.045Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Looking for GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial numbers found: [\"52WC\", \"AU05CKWD\", \"AV0LFLX1\", \"AV0LFQVL\", \"FTDF6EQ7\", \"FTDF6G7N\", \"FTDF6J6X\", \"FTDF9CAF\", \"FTDPOE5G\", \"FTDPOGGJ\"]","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: 52WC -> GUID: {71f2d39b-d53f-5cbc-8ea0-bb0104568a4e}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AU05CKWD -> GUID: {dd64377d-0e83-50c8-8004-91f8f8ca2773}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFLX1 -> GUID: {ad517d7e-e822-58df-a567-be90672a2c59}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: AV0LFQVL -> GUID: {a8b6bdf3-d556-5014-93ca-4674a47a4f14}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6EQ7 -> GUID: {3e701f25-a361-5dec-80a5-e19aff210ee8}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6G7N -> GUID: {a13ed9bb-b82b-592a-afa2-ea3b80f5cc09}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF6J6X -> GUID: {76de3d8a-e1f9-5375-9d73-34d6e412a382}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDF9CAF -> GUID: {c966740f-2ddf-56ec-a712-d8d44555e7c8}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Serial number: FTDPOE5G -> GUID: {2b8e9e6e-c460-51ff-97b6-ceb0bc90e3ad}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] Matching serial number? Some(\"FTDPOE5G\")","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serial port \\\\?\\FTDIBUS#VID_0403+PID_6001+FTDPOE5GA#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\\\?\\USB#VID_0403&PID_6001#FTDPOE5G#{A5DCBF10-6530-11D2-901F-00C04FB951ED}","timestamp":"2025-01-31T15:25:43.047Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] try to map FTDI to segger device","timestamp":"2025-01-31T15:25:43.048Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] found FTDI","timestamp":"2025-01-31T15:25:43.048Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOGGJ'","timestamp":"2025-01-31T15:25:43.048Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: '000777641824'","timestamp":"2025-01-31T15:25:43.048Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"[serialport] serialport enumerate update device: 'FTDPOE5G'","timestamp":"2025-01-31T15:25:43.048Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'serialport' took 8 ms","timestamp":"2025-01-31T15:25:43.048Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'sdfu' took 0 ms","timestamp":"2025-01-31T15:25:43.049Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'mcuBoot' took 0 ms","timestamp":"2025-01-31T15:25:43.050Z"}}
    {"type":"log","data":{"level":"DEBUG","message":"Enumeration for plugin 'broken' took 0 ms","timestamp":"2025-01-31T15:25:43.050Z"}}
    Error: No devices with requested serial number(s) or trait(s) found
    Using J-Flash Lite I'm always able to erase the chip so I assume that all the connections are corrects.
    Don't hesitate if you want me to perform other test.
    Antoine
  • Hi Antoine,
    Thank you for providing these logs, could you repeat it again but use --trace instead of --debug as I instructed earlier, I think that would give us a more verbose log and help us understanding the issue better:
    nrfutil device recover --log-level trace --log-output stdout --json
    Antoine.B said:
    Below is output with successfull "recover" command followed by NOK "recover" command (without changing hardware/connections)
    I shared this log with our developers and they noticed that this log stops earlier and with a different error message then the one you posted in your original problem description. Would you be able to share the log when you get the same error message as in the original ticket? :
    > nrfutil.exe device recover --serial-number 822007655 --x-family nrf53
    x Failed to recover 822007655, [jlink] JLINKARM_DLL_ERROR
     * 822007655: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
    They also noticed that the log you shared failed while writing to a register to prepare for powerup. So maybe there is an issue with the power supply to the board? Can you describe how your board is powered?
    regards
    Jared
