The DevAcademy fundamentals lesson 6, example 1 shows how to connect a bme280 to a DK.
Then in lesson 6, example 2 it shows how to connect to an onboard light sensor found on the thingy91.
I'm looking at making a third example where a bme280 is connected externally to a thingy91 using P6 found on the thingy91.
This case hinted at using pins 26 & 27 on P6.
The pin map for thingy91 shows pins 26 & 27 as SPARE3 and SPARE4, or from HW file as pins 3 and pins 4 on P6 (same spot as shown in the above case).
Looking at the thingy91_nrf9160_ns.overlay file in VS sdk v2.9.0 > Devicetree > Overlay file,
it shows p26 and p27 occupied by button0 and bh1749 respectively (same light sensor bh1749 as in lesson 6 example 2).
When adding to the overlay file,
&i2c2 {
status = "okay";
pinctrl-0 = <&i2c2_default>;
pinctrl-1 = <&i2c2_sleep>;
mysensor: mysensor@77{
compatible = "i2c-device";
status = "okay";
reg = < 0x77 >;
&pinctrl {
/omit-if-no-ref/ i2c2_default: i2c2_default {
group1 {
psels = <NRF_PSEL(TWIM_SCL, 0, 26)>,
<NRF_PSEL(TWIM_SDA, 0, 27)>;
/omit-if-no-ref/ i2c2_sleep: i2c2_sleep {
group1 {
low-power-enable;
The overlay then indicates an error that 'Multiple pin users are assigned!'.
What piece is missing here to get the pins properly mapped to P6 on thingy91?
thank-you,
