Enabling DCDC regulation with Fanstel BT840F for lower power consumption
Hello !
I am using using the chip BT840F of Fanstel (based on the nrf52840) powered by an external 3.0 v battery for my beacon BLE application.
Regarding power consumption, the specifications say "You can enable DCDC converter to have lower power consumption."
This is what I have done to enable the dcdc converter but not so sure if I am doing everything right :
             1- I have put this in the prj.conf
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_BOARD_ENABLE_DCDC=y
             2- I have put this in the Kconfig board file
config BOARD_ENABLE_DCDC
    bool "DCDC mode"
    select SOC_DCDC_NRF52X
    default yETT_WT_02_01_NRF52840
config BOARD_ENABLE_DCDC_HV
    bool "Enable High Voltage DCDC converter"
    default y
    select SOC_DCDC_NRF52X_HV
    depends on BOARD_NRF52840DK_NRF52840
It seems that ppk2 measurment shows that the current load dropped from 8 mC to 5 mC.
not sure if it is relevent to enable the DCDC_HV in my case with 3.0 v battery.
Is there anything to add to the overlay file ?
Am I doing the right configurations ?
Thanks in advance.
Yanis
