Extended Advertising with FEM/MPSL
SDK: 2.6.1 (2.9 seems to give an HCI build error , undefined reference to `__device_dts_ord_135',  when enabled  CONFIG_BT_LL_SW_SPLIT, CONFIG_BT_LLL_VENDOR_NORDIC ?)
SOC:NRF52840
I am using the Ezurio/Laird BL654PA, but I found an issue when enabled  the FEM and using the Extended Advertising to allow advertising on the Coded phy.
Overlay - this seems to provide a strong RSSI using standard advertising phy:
    nrf_radio_fem: name_of_fem_node {
        compatible = "skyworks,sky66112-11", "generic-fem-two-ctrl-pins";
        ctx-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>; // p1.02
        crx-gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>; // p1.04
        tx-gain-db = <4>;  // db of 4 plus CONFIG_BT_CTLR_TX_PWR_PLUS_8 seems the highest?
&radio {
    fem = <&nrf_radio_fem>;
If I add the FEM support in the prf.conf file with Advertising extensions, I get an HCI error.
If i disable CONFIG_MPSL_FEM, and CONFIG_MPSL, the extended advertising works well.
Is there a way to allow both Coded Phy advertising to work with FEM? Thanks!
prj.conf
CONFIG_MPSL_FEM=y
CONFIG_MPSL=y
CONFIG_BT_EXT_ADV=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_AUTO_PHY_UPDATE=y
CONFIG_BT_LLL_VENDOR_NORDIC=y
CONFIG_BT_LL_SW_SPLIT=y
Error output:
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:331
        command opcode 0x0c03 timeout with err -11
    It would be interesting to solve this issue instead of using an old SDK, see here.
    This config is used to enable the Zephyr BLE link layer, and that is not supported.
    If you are trying to use CONFIG_BT_LL_SW_SPLIT that will not work in combination with the MPSL, the MPSL only works with the SoftDevice Controller (which is the one you should use).
    Yes, that should not be a problem. But make sure you do not change to Zephyr LL. See Enabling support for front-end modules using Simple GPIO interface.
  • I only enabled the SW_SPLIT because I thought I needed this to enable two advertising sets, one for standard 1mbps phy and one for coded phy. Per the warning below:
    warning: BT_CTLR_ADV_AUX_SET (defined at subsys/bluetooth/controller/Kconfig.ll_sw_split:319) was
    assigned the value '2' but got the value ''. Check these unsatisfied dependencies: BT_LL_SW_SPLIT
    (=n). See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BT_CTLR_ADV_AUX_SET and/or look
    up BT_CTLR_ADV_AUX_SET in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    Perhaps it will work just with the following settings and not need the SW_SPLIT?
    CONFIG_BT_EXT_ADV_MAX_ADV_SET=2
    CONFIG_BT_EXT_ADV=y
    Update:
    Removing the SW_SPLIT and CONFIG_BT_CTLR_ADV_AUX_SET seems to still allow both standard and coded phy advertising on two different advertising sets. I can find the device scanning on LE 1M and coded phy.
    I do get this odd error message that setting the phy fails "Failed LE Set PHY (-5)".  This may not be a problem because the phy update reports the connection is using the coded phy.  It might be coming from
    bt_conn_le_phy_update call.  I would like to request the coded phy even if the connection was initiated on the 1Mbps phy.
    Connection (1) - Initial Tx Power = 8
    [00:00:27.780,364] <inf> ble_periph: Gap connected peripheral id: 0, handle: 1.
    [00:00:27.780,975] <wrn> bt_hci_core: opcode 0x2032 status 0x3a
    [00:00:27.780,975] <err> bt_hci_core: Failed LE Set PHY (-5)
    [00:00:28.023,986] <inf> main: Conn 0 RSSI is -30 db.
    [00:00:28.697,235] <inf> ble_main: Phy Updated to RX=4 TX=4
    [00:00:29.024,353] <inf> main: Conn 0 RSSI is -32 db.
    Updated MTU: TX: 517 RX: 498 bytes
    [00:00:30.024,810] <inf> main: Conn 0 RSSI is -35 db.
    [00:00:31.025,177] <inf> main: Conn 0 RSSI is -35 db.
    I am glad to hear it is working. Regarding the error, it is printed here in conn.c. This is only calle dwith CONFIG_BT_AUTO_PHY_UPDATE, and if that is not something you need or want (it is handled explicitly by the application or the peer,), you can set CONFIG_BT_AUTO_PHY_UPDATE=n in your project configuration. That said, following this further down I think it comes from here, but it could be interesting to confirm that with a debugger, and see what else you can find that way if you want CONFIG_BT_AUTO_PHY_UPDATE enabled.
