Output of my Audio DK is noisy/clipping when coming via i2s
I am quite new to the nRF5340 Audio DK and used  's project on https://github.com/ace-johnny/nrfadk-hello_codec to get me started.
The overall project goal is to process audio data coming via line-in on the nRF5340 to add filters, effects, etc. and output again via the headphone.
In order to achieve this I transmit the data from the codec via i2s to the MCU, process it there and send it back. However, something in this chain is introducting a lot of noise/clipping and I can't find the reason for this. Right now my processing of the received data is just copying it 1:1 to the transmit buffer - no change whatsoever.
When I directly route the line-in input to the output and not going via i2s to the MCU and back everything is crystal clear.
This is the code I use:
 * @file        main.c
 * @brief       Audio DK HW_CODEC test using I2S loop and tone/noise generators.
#include <zephyr/kernel.h>
#include <nrf.h>
#include <nrfx_clock.h>
#include "cs47l63_comm.h"
// NRFX_CLOCKS
#define HFCLKAUDIO_12_288_MHZ 0x9BA6
#define ENABLE_LINEIN
#undef ENABLE_MIC
 * @brief       Initialize the high-frequency clocks and wait for each to start.
 * @details     HFCLK =         128,000,000 Hz
 *              HFCLKAUDIO =     12,288,000 Hz
static int nrfadk_hfclocks_init(void)
	nrfx_err_t err;
	// HFCLK
	err = nrfx_clock_divider_set(NRF_CLOCK_DOMAIN_HFCLK, NRF_CLOCK_HFCLK_DIV_1);
	if (err != NRFX_SUCCESS) return (err - NRFX_ERROR_BASE_NUM);
	nrfx_clock_start(NRF_CLOCK_DOMAIN_HFCLK);
	while (!nrfx_clock_is_running(NRF_CLOCK_DOMAIN_HFCLK, NULL)) k_msleep(1);
	// HFCLKAUDIO
	nrfx_clock_hfclkaudio_config_set(HFCLKAUDIO_12_288_MHZ);
	nrfx_clock_start(NRF_CLOCK_DOMAIN_HFCLKAUDIO);
	while (!nrfx_clock_is_running(NRF_CLOCK_DOMAIN_HFCLKAUDIO, NULL)) k_msleep(1);
	return 0;
// NRF_I2S
#define MCKFREQ_6_144_MHZ 0x66666000
#define I2S_BUFF_SIZE 256  // Define an appropriate buffer size
static int16_t rx_buffer[I2S_BUFF_SIZE];  // Buffer for received data
static int16_t tx_buffer[I2S_BUFF_SIZE];
void process_audio(int16_t *rx, int16_t *tx, size_t size)
    for (size_t i = 0; i < size; i++) {
		tx[i] = rx[i];  // Simple passthrough (modify as needed)
        	//tx[i] = (int16_t)(rx[i]*0.1);  // Volume control
		//tx[size-1-i] = rx[i];  // Reverse - doesn't work... -> only outputs silence...?
 * @brief       Initialize and start the I2S peripheral using NRF registers.
 * @details     I2S master, 48kHz 16bit, Left mono, TX only.
static int nrfadk_i2s_reg_init(void)
	// Configure and enable
	NRF_I2S0->CONFIG.CLKCONFIG =    I2S_CONFIG_CLKCONFIG_CLKSRC_ACLK;
	NRF_I2S0->CONFIG.MCKFREQ =      MCKFREQ_6_144_MHZ;
	NRF_I2S0->CONFIG.RATIO =        I2S_CONFIG_RATIO_RATIO_128X;
	NRF_I2S0->CONFIG.CHANNELS =     I2S_CONFIG_CHANNELS_CHANNELS_Left;
	NRF_I2S0->CONFIG.TXEN =         I2S_CONFIG_TXEN_TXEN_Enabled;  // Send audio samples to the nRF5340
	NRF_I2S0->CONFIG.RXEN = 	I2S_CONFIG_RXEN_RXEN_Enabled;  // Enable RX to receive the data from the nRF5340
	NRF_I2S0->ENABLE =              I2S_ENABLE_ENABLE_Enabled;
	// Start TX buffer
	NRF_I2S0->RXD.PTR = 		(uint32_t)rx_buffer;
	NRF_I2S0->TXD.PTR = 		(uint32_t)tx_buffer;
	NRF_I2S0->RXTXD.MAXCNT =        I2S_BUFF_SIZE / sizeof(uint32_t);
        // Clear pending events
    	NRF_I2S0->EVENTS_RXPTRUPD = 0;
	    NRF_I2S0->EVENTS_TXPTRUPD = 0;
	NRF_I2S0->TASKS_START =         I2S_TASKS_START_TASKS_START_Trigger;
	return 0;
void i2s_polling_loop(void)
    while (1)
        // Wait for new RX data
        while (NRF_I2S0->EVENTS_RXPTRUPD == 0);
        // Clear RX event
        // Process audio data
        process_audio(rx_buffer, tx_buffer, I2S_BUFF_SIZE); // For now, just set tx_buffer == rx_buffer
        // Ensure we restart I2S for continuous operation
	while (NRF_I2S0->EVENTS_TXPTRUPD == 0);
// HW_CODEC
/** CS47L63 driver state handle. */
static cs47l63_t cs47l63_driver;
/** CS47L63 subsystems configuration. */
static const uint32_t cs47l63_cfg[][2] =
	// Audio Serial Port 1 (I2S slave, 48kHz 16bit, Left mono, RX and TX)
	{ CS47L63_ASP1_CONTROL2,
		(0x10  << CS47L63_ASP1_RX_WIDTH_SHIFT) |        // 16bit
		(0x10  << CS47L63_ASP1_TX_WIDTH_SHIFT) |        // 16bit
		(0b010 << CS47L63_ASP1_FMT_SHIFT)               // I2S
	{ CS47L63_ASP1_CONTROL3,
		(0b00 << CS47L63_ASP1_DOUT_HIZ_CTRL_SHIFT)      // Always 0
	// Enable the various channels for RX and TX
	{ CS47L63_ASP1_ENABLES1,
		(0 << CS47L63_ASP1_RX2_EN_SHIFT) |              // Disabled
		(1 << CS47L63_ASP1_RX1_EN_SHIFT) |              // Enabled
		(0 << CS47L63_ASP1_TX2_EN_SHIFT) |              // Disabled
		//(0 << CS47L63_ASP1_TX1_EN_SHIFT)                // Disabled
		(1 << CS47L63_ASP1_TX1_EN_SHIFT)                // Enabled - we want to send something to the nRF5340
#ifdef ENABLE_LINEIN
	// Enable line-in
	{ CS47L63_INPUT2_CONTROL1, 0x00050020 },/* MODE=analog */
	{ CS47L63_IN2L_CONTROL1, 0x10000000 },  /* SRC=IN2LP */
	{ CS47L63_IN2R_CONTROL1, 0x10000000 },  /* SRC=IN2RP */
	{ CS47L63_INPUT_CONTROL, 0x0000000C },  /* IN2_EN=1 */
	// Set volume for line-in
	{ CS47L63_IN2L_CONTROL2, 0x00800080 },  /* VOL=0dB, MUTE=0 */
	{ CS47L63_IN2R_CONTROL2, 0x00800080 },  /* VOL=0dB, MUTE=0 */
	{ CS47L63_INPUT_CONTROL3, 0x20000000 }, /* VU=1 */
	// Important
	/* Route IN2L and IN2R to I2S */
	{ CS47L63_ASP1TX1_INPUT1, 0x800012 },
	{ CS47L63_ASP1TX2_INPUT1, 0x800013 },
	// Output 1 Left (reduced MIX_VOLs to prevent clipping summed signals)
	// this here is only there so we hear also that i2s data is sent
	{ CS47L63_OUT1L_INPUT1,
		(0x2B  << CS47L63_OUT1LMIX_VOL1_SHIFT) |        // quite weak
		(0x020 << CS47L63_OUT1L_SRC1_SHIFT)             // ASP1_RX1 // from MCU (currently a sine wave only)
	{ CS47L63_OUT1L_INPUT2,
		(0x2B  << CS47L63_OUT1LMIX_VOL2_SHIFT) |        //
		(0x021 << CS47L63_OUT1L_SRC2_SHIFT)             // ASP1_RX2
#undef ENABLE_LINEIN
	// We need both channels here, even if we only have one output channel
	// If we uncomment the next two {} we won´t get any line in pass-through, only i2s
		CS47L63_OUT1L_INPUT3,
		(0x2B  << CS47L63_OUT1LMIX_VOL3_SHIFT) |
		(0x012 << CS47L63_OUT1L_SRC3_SHIFT)    // 0x12=IN2L
		CS47L63_OUT1L_INPUT4,
		(0x2B  << CS47L63_OUT1LMIX_VOL4_SHIFT) |
		(0x013 << CS47L63_OUT1L_SRC4_SHIFT)    // 0x13=IN2R
	{ CS47L63_OUTPUT_ENABLE_1,
		(1 << CS47L63_OUT1L_EN_SHIFT)                   // Enabled
 * @brief       Write a configuration array to multiple CS47L63 registers.
 * @param[in]   config: Array of address/data pairs.
 * @param[in]   length: Number of registers to write.
 * @retval      `CS47L63_STATUS_OK`     The operation was successful.
 * @retval      `CS47L63_STATUS_FAIL`   Writing to the control port failed.
static int nrfadk_hwcodec_config(const uint32_t config[][2], uint32_t length)
	int ret;
	uint32_t addr;
	uint32_t data;
	for (int i = 0; i < length; i++)
		addr = config[i][0];
		data = config[i][1];
		ret = cs47l63_write_reg(&cs47l63_driver, addr, data);
		if (ret) return ret;
	return CS47L63_STATUS_OK;
 * @brief       Initialize the CS47L63, start clocks, and configure subsystems.
 * @details     MCLK1 =   6,144,000 Hz  (I2S MCK = CONFIG.MCKFREQ)
 *              FSYNC =      48,000 Hz  (I2S LRCK = MCK / CONFIG.RATIO)
 *              BCLK =    1,536,000 Hz  (I2S SCK = LRCK * CONFIG.SWIDTH * 2)
 *              FLL1 =   49,152,000 Hz  (MCLK1 * 8)
 *              SYSCLK = 98,304,000 Hz  (FLL1 * 2)
 * @retval      `CS47L63_STATUS_FAIL`   Initializing the CS47L63 failed.
 * @note        I2S MCK must already be running before calling this function.
static int nrfadk_hwcodec_init(void)
	int ret = CS47L63_STATUS_OK;
	// Initialize driver
	ret += cs47l63_comm_init(&cs47l63_driver);
	// Start FLL1 and SYSCLK
	ret += cs47l63_fll_config(&cs47l63_driver, CS47L63_FLL1,
	                          CS47L63_FLL_SRC_MCLK1, 6144000, 49152000);
	ret += cs47l63_fll_enable(&cs47l63_driver, CS47L63_FLL1);
	ret += cs47l63_fll_wait_for_lock(&cs47l63_driver, CS47L63_FLL1);
	ret += cs47l63_update_reg(&cs47l63_driver, CS47L63_SYSTEM_CLOCK1,
	                          CS47L63_SYSCLK_EN_MASK, CS47L63_SYSCLK_EN);
	// Configure subsystems
	ret += nrfadk_hwcodec_config(cs47l63_cfg, ARRAY_SIZE(cs47l63_cfg));
	return ret;
// MAIN
	// Initialize Audio DK
	if (nrfadk_hfclocks_init() ||
	    nrfadk_i2s_reg_init()  ||
	    nrfadk_hwcodec_init())
		printk("\nError initializing Audio DK\n");
		return -1;
	printk("\nAudio DK initialized\n");
	k_msleep(1250);
	// Unmute OUT1L I2S playback and enable NOISE/TONE1 generators
	cs47l63_update_reg(&cs47l63_driver, CS47L63_OUT1L_VOLUME_1,
	                   CS47L63_OUT_VU_MASK | CS47L63_OUT1L_MUTE_MASK,
	                   CS47L63_OUT_VU | 0);
	printk("\nOUT1L unmuted for 5000ms\n");
	k_msleep(5000);
	i2s_polling_loop(); // We actually never return from here (testing)
	while(1);
	                   CS47L63_OUT_VU | CS47L63_OUT1L_MUTE);
	printk("OUT1L muted\n");
	k_msleep(1250);
	// Shutdown Audio DK (reverse order initialized)
	cs47l63_update_reg(&cs47l63_driver, CS47L63_OUTPUT_ENABLE_1,
	                   CS47L63_OUT1L_EN_MASK, 0);
	printk("\nOUT1L disabled\n");
	k_msleep(250);
	                   CS47L63_SYSCLK_EN_MASK, 0);
	printk("SYSCLK disabled\n");
	k_msleep(250);
	cs47l63_fll_disable(&cs47l63_driver, CS47L63_FLL1);
	printk("FLL1 disabled\n");
	k_msleep(250);
	NRF_I2S0->TASKS_STOP =  I2S_TASKS_STOP_TASKS_STOP_Trigger;
	NRF_I2S0->ENABLE =      I2S_ENABLE_ENABLE_Disabled;
	printk("I2S disabled\n");
	k_msleep(250);
	nrfx_clock_stop(NRF_CLOCK_DOMAIN_HFCLKAUDIO);
	while (nrfx_clock_is_running(NRF_CLOCK_DOMAIN_HFCLKAUDIO, NULL)) k_msleep(1);
	printk("HFCLKAUDIO stopped\n");
	k_msleep(250);
	nrfx_clock_stop(NRF_CLOCK_DOMAIN_HFCLK);
	while (nrfx_clock_is_running(NRF_CLOCK_DOMAIN_HFCLK, NULL)) k_msleep(1);
	printk("HFCLK stopped\n");
	k_msleep(250);
	printk("\nAudio DK shutdown\n\n");
	k_msleep(100);
	return 0;
process_audio() is the simple function which just sets the TX buffer to the RX buffer's values.
(Here I want eventually to add my processing)
nrfadk_i2s_reg_init() initializes the i2s on the nRF5340 side. I've added here also the reception of the data from the codec
i2s_polling_loop() constantly checks if i2s data is present, then copies it over and starts the back transmission
cs47l63_cfg() configures the line-in input, the i2s in the ASP1 and the output channel coming from i2s
My assumption is that the error is in one of those regions:
i2s_polling_loop() - maybe done completely wrong at all?
cs47l63_cfg() - I am confused - do I have a stereo input with line-in or only mono? Will I need ASP1RX1,2 and ASP1TX1,2 then or just ASP1RX1 and ASP1TX1?
Is it OK to use int16_t as the values in the buffer but uint32_t to address the elements? Does the i2s config in the codec match?
Is the noise maybe just a result of the MCU not being able to keep up?
The audio is properly played back in genereal but there is noise/clipping present all the time - not only during loud parts of the music.
  • In case someone wants to debug the i2s himself via a Logic analyzer, this is my setup:
    ASP1_DOUT/GPIO1 TP49 DOUT == P0.15 on P5
    ASP1_DIN/GPIO2 TP50 DIN == P0.13 on P5
    ASP1_BCLK/GPIO3 TP51 BCLK == P0.14 on P5
    ASP1_FSYNC/GPIO4 TP52 FSYNC == P0.16 on P5
    MCLK1 TP48 MCLK == P0.12 on P5
    Sample with logic analyzer (I used Saleae LogicPro 8) at 500M/s at 3.3V with 4 probes
    DOUT, DIN, BCLK, FSYNC
    Dissector: Use i2s/pcm
    Configure dissector like this: (Change Signed/Unsigned -> Signed!)
    View as decimal values.
    Once done, export to txt/csv e.g. as "audioexport.txt"
    Use this tool to convert from i2s CSV to PCM file: https://github.com/roel0/PCM2Wav-py
    PS C:\Users\daubsi> pip install PCM2Wav
    PS C:\Users\daubsi> python
    from PCM2Wav import *
    output = PCM2Wav(PCM2Wav.saleae.I2S, "d:\\audioexport.txt", "d:\\example.wav")
    Hope this helps
  • It seems that just increasing the value of I2S_BUFF_SIZE from 256 to e.g. 4096 makes the result already much less noisy! Not sure why that is... Maybe the constant switching between RX/TX of such a small buffer and the minimal delays for this actually cause the noise...?
  • Thanks for those additional details. I'll have a look at those next. Today I added the annotations for the constants for setting up the PDM (the digital microphone) but I have to say that those are the most esoteric so far, because the whole concept of the LDO and MICBIAS is a foreign to me.
    #ifdef ENABLE_MIC
    	// Enable digital MIC
    	/* Set MICBIASes */
    	{ CS47L63_LDO2_CTRL1, 0x0005 },     // p165, 0b00000101 -> Bit 0, LDO2_EN=1, Bit 2, LDO2_DISCH=1, Voltage = 0x0 (default) 2.4V
    	{ CS47L63_MICBIAS_CTRL1, 0x00EC },  // p166, 0b11101100 -> Bit 2, MICB1_DISCH=1, discharge when disable, (default = 1)
    	                                    //                     Bit 3, MICB1_RATE=1, 1 = Pop-free start-up/shutdown (default = 0)
    										//                     Bit 5-7 = 0x7 = 2.2V (default)
    	{ CS47L63_MICBIAS_CTRL5, 0x0272 },  // p166, 0b0010 0111 0010 -> Bit 1 MICB1A_DISCH=1, discharge when disable (default)
    	                                    //                        -> Bit 4 MICB1B_EN=1
    										//                        -> Bit 5 MICB1B_DISCH=1, discharge when disable (default)
    										//                        -> Bit 6 MICB1B_SRC=1 = VDD_A (default 0, MICBIAS regulator)
    										//                        -> Bit 9 MICB1C_DISCH=1, discharge when disable (default)
    	/* Enable IN1L */
    	{ CS47L63_INPUT_CONTROL, 0x000F },  // p29, 0b00001111 -> Bit 0, IN1R_EN,
    										//                    Bit 1, IN1L_EN,
    										//                    Bit 2, IN2R_EN,
    										//                    Bit 3, IN2L_EN
    	/* Enable PDM mic as digital input */
    	{ CS47L63_INPUT1_CONTROL1, 0x50021 }, // p31, 0b0101 00000000 0010 0001 -> Bit 0, Input Path 1 Mode=Digital input
    	                                      //                                -> Bit 5, fixed at according to p181? (see also p30 "Note")
    										  //                                -> Bit 16-18 Input Path 1 Oversample control, p27
    										  //                                   = 0b101 = 3.072 MHz, controls IN1_PDMCLK freq
    	/* Un-mute and set gain to 0dB */
    	{ CS47L63_IN1L_CONTROL2, 0x800080 },  // p31 & p34, p181 0b1000 0000 0000 0000 1000 0000
    	  									  // Bit 1-7 = 0x40 = 0dB Input Path 1L PGA Volume (analog only)
    	                                      // Bit 16-23 = 0x80 = default 0dB Input Path 1L Digial volume
    										  // Bit 28 = 0 (default 1), unmute
    	{ CS47L63_IN1R_CONTROL2, 0x800080 },  // p31 & p34, p181 0b1000 0000 0000 0000 1000 0000
    										  // Bit 1-7 = 0x40 = 0dB Input Path 1R PGA Volume (analog only)
    	                                      // Bit 16-23 = 0x80 = default 0dB Input Path 1R Digial volume
    	/* Volume Update */
    	{ CS47L63_INPUT_CONTROL3, 0x20000000 }, // p181, set IN_VU to 1
    	/* Send PDM MIC to I2S Tx */
    	//{ CS47L63_ASP1TX1_INPUT1, 0x800010 },
    	//{ CS47L63_ASP1TX2_INPUT1, 0x800011 },
    For example I dont understand why there are MICB1A,1B,1C involved. Does a single microphone need 3 biases (== power supply?). Or is this overly generic?
    With CS47L63_INPUT_CONTROL, 0x000F, we also enable IN1L, IN1R, IN2L, IN2R although we only configure IN1L and IN1R if I am not mistaken. (CS47L63_IN1L_CONTROL2, CS47L63_IN1R_CONTROL2)
    I couldn´t test the code yet. My goal right now would be to get the PDM also up and running just for completeness sake and then turn to the interrupt driven handling of the I2S. I just have to assume that the CS47L63_LDO2_CTRL1, CS47L63_MICBIAS_CTRL1, CS47L63_MICBIAS_CTRL5 settings are generic and do not require a special clock setup which isn´t present in your base bone example.
    Progress will be slower through the week and I will probably not be able to work on a daily basis on this.
  • Thanks, I actually had a look at that file/schematic when I was trying to understand your point in another discussion with the ASP2 setup ( Error in nRF5340 Audio DK sample application ), and to verify/understand where the but I didn't bother to look again for the PDM. Thanks for your insights about how it is all wired internally.
    The MICBIAS generator has 3 outputs ABC, and only 2 are used: B drives the onboard mic, and C drives the aux PDM input. A is not used, but could conceivably drive an analog mic if one were wired to the available analog IN1(LR) test points.
    So that means in the excerpt from the original Nordic code I annotated above, if I ONLY want the onboard digital microphone I would only need MICBIAS3 and I actually would only need IN1L as the IN1R is not used anyway? Same for IN2* as it's not related to the PDM?
    /* Enable IN1L */
    // Bit 1, IN1L_EN,
    // Bit 2, IN2R_EN,
    // Bit 3, IN2L_EN
    Actually I was only able to make sense out of the various control registers by looking a the long explicit listing of all the registers at the end of the datasheet where each and every bit is shown at the same place and not scattered through various pages.
    What I don't get for example is:
    CS47L63_INPUT1_CONTROL1 also configures the oversampling rate. Is this something which only is applicable to a microphone? Don't we have/need this for line-in?
    I fully agree it would be very nice to have like 3,4,5 minimalistic samples from Nordic how to use the codec on THEIR board with THEIR defined setup (what is wired where), like "route line-in via i2s to MCU", "send i2s to codec for output", etc. etc. That would really speed up the learning with this board.
    Another question you might have an answer for:
    Currently I use the codec to output to headphones, but is it also possible to connect to Apple AirPods via BLE from the MCU? My stretch goal is to write a simple Guitar FX processor by doing the FXs (chorus, echo, reverb, ...) on the ARM core and then connect to my AirPods for audio output. I know the compatibility of the BLE audio was something which was intensively discussed during the Nordic Techtour 2 years ago with Apple being proprietary but I can easily connect the pods to my Linux and Windows PC like-wise without problems so it probably is not very special? Or is it then standard Bluetooth and not BLE? Any ideas?
