Help with BLE DFU FOTA on External Flash (nRF52840, NCS 2.5.2)
I am trying to get DFU FOTA over BLE to work using external flash on an nRF52840 DK with NCS 2.5.2. I followed multiple sources, but I am unsure about the correct configuration.
1. Configuration Steps
I started by adding these to prj.conf
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
This already causes compilation errors, but I will get back to that later.
You can get the same errors by modifying the fs_sample and adding:
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
2. Partition configuration
I have seen projects using pm_static.yml and others defining partitions in overlay, but I am not sure what the difference is.
Here is my pm_static.yml
external_flash:
  address: 0xf4000
  end_address: 0x800000
  region: external_flash
mcuboot_secondary:
  address: 0x00000
  device: MX25R64
  end_address: 0xf4000
At the same time, my overlay file contains:
&mx25r64 {
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        /* 8MB external storage partition */
        external_partition: partition@0 {
            reg = <0x00000000 0x0800000>;
    msc_disk0 {
        status = "okay";
        compatible = "zephyr,flash-disk";
        partition = <&external_partition>;
        disk-name = "NAND";
        /* cache-size == page erase size */
        cache-size = <4096>;
Then I add this at the end of the overlay file:
    chosen {
        nordic,pm-ext-flash = &mx25r64;
Does this conflict with pm_static.yml?
3. MCUBoot configuration
Inside child_image/mcuboot.conf I added
CONFIG_FLASH=y
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_BOOT_MAX_IMG_SECTORS=256
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y
CONFIG_MCUBOOT_LOG_LEVEL_WRN=y
CONFIG_CBPRINTF_NANO=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
4. Compilation errors
When compiling, I get these errors:
/opt/nordic/ncs/v2.5.2/zephyr/drivers/disk/flashdisk.c:484:1: error: return type defaults to 'int' [-Werror=implicit-int]
484 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_CACHE)
/opt/nordic/ncs/v2.5.2/zephyr/drivers/disk/flashdisk.c:524:39: error: 'DEFINE_FLASHDISKS_DEVICE' undeclared (first use in this function)
524 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_DEVICE)
5. Questions
1. Should I use pm_static.yml or overlay or both?
 - Are my external flash partitions conflicting between these two files
2. Why does MCUBoot fail to compile with these errors?
 - Is there a missing configuration option for flash-disk or QSPI
