Inquiry on ST7789V MIPI-DBI Driver Configuration in NCS 2.9.0
Dear,
I recently upgraded my project from NCS 2.4.0 to NCS 2.9.0 and encountered an issue with the ST7789V display driver.
Previously, I used SPI0 to interface with the ST7789V display, and the configuration in my device tree worked fine. However, after upgrading to NCS 2.9.0, I noticed that the driver type for ST7789V has changed to MIPI-DBI, and my previous device tree configuration is no longer applicable.
I have reviewed the nRF Connect SDK documentation, but I could not find any clear guidance on how to correctly configure MIPI-DBI for ST7789V in the new version. Below is my previous device tree configuration that worked in NCS 2.4.0:
&spi0 {
	st7789v@0 {
		compatible = "sitronix,st7789v";
		reg = <0x0>;
		cmd-data-gpios = <&gpio0 31 GPIO_ACTIVE_LOW>;
		label = "ST7789V";
		status = "okay";
		spi-max-frequency = <2000000>;
		width = <240>;
		height = <280>;
		x-offset = <0>;
		y-offset = <20>;
		vcom = <0x32>;
		gctrl = <0x35>;
		vrhs = <0x15>;
		mdac = <0x00>;
		gamma = <0x01>;
		colmod = <0x55>;
		lcm = <0x2c>;
		porch-param = [0c 0c 00 33 33];
		cmd2en-param = [5a 69 02 01];
		pwctrl1-param = [a4 a1];
		pvgam-param = [d0 08 0e 09 09 05 31 33 48 17 14 15 31 34];
		nvgam-param = [d0 08 0e 09 09 15 31 33 48 17 14 15 31 34];
		ram-param = [00 f8];
		rgb-param = [cd 08 14];
		vdvs = <0x20>;
		reset-gpios = <&gpio0 28 GPIO_ACTIVE_LOW>;
		supply-gpios = <&gpio0 29 GPIO_ACTIVE_LOW>;
	status = "okay";
	cs-gpios = <&gpio0 30 GPIO_ACTIVE_LOW>;
&spi0_default {
	group1 {
		psels = <NRF_PSEL(SPIM_SCK, 0, 3)>, <NRF_PSEL(SPIM_MOSI, 0, 4)>;
	chosen {
		zephyr,display = &{/soc/spi@40003000/st7789v@0/};
Could you please advise on:
  1. How to correctly configure the device tree for ST7789V using MIPI-DBI in NCS 2.9.0?
  2. Are there any specific changes in the SPI or display subsystem that I need to consider?
  3. Is there an example or reference documentation available for migrating from the old driver to the new one?
I appreciate your support and look forward to your guidance.
emmovo
  • Hello Nanag,
    You need to change the parameters following way
    1. mipi-mode:
      The value should be an integer macro, not a string. For 4-wire SPI, use <MIPI_DBI_MODE_SPI_4WIRE>.
      Make sure you include the correct header:
      #include <zephyr/dt-bindings/mipi_dbi/mipi_dbi.h>
    2. mipi-max-frequency:
      Use a direct integer value (e.g., <8000000>) instead of DT_FREQ_M(8) unless you have that macro defined.
      This is the overlay file after this change
      #include <zephyr/dt-bindings/display/panel.h>
          chosen {
              zephyr,display = &st7789v;
          leds {
              compatible = "gpio-leds";
              lcd_backlight: lcd_backlight {
                  gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
                  label = "LCD Backlight";
          mipi_dbi {
              compatible = "zephyr,mipi-dbi-spi";
              status = "okay";
              reset-gpios = <&gpio0 27 GPIO_ACTIVE_LOW>;
              dc-gpios = <&gpio0 31 GPIO_ACTIVE_HIGH>;
              spi-dev = <&spi0>;
              write-only;
              #address-cells = <1>;
              #size-cells = <0>;
              st7789v: st7789v@0 {
                  status = "okay";
                  reg = <0>;
                  mipi-max-frequency = <8000000>;
                  mipi-mode = <MIPI_DBI_MODE_SPI_4WIRE>;
                  width = <240>;
                  height = <240>;
                  x-offset = <0>;
                  y-offset = <0>;
                  vcom = <0x19>;
                  gctrl = <0x35>;
                  vrhs = <0x12>;
                  vdvs = <0x20>;
                  mdac = <0x00>;
                  gamma = <0x01>;
                  colmod = <0x05>;
                  lcm = <0x2c>;
                  pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23];
                  nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23];
                  ram-param = [00 F0];
                  rgb-param = [CD 08 14];
      Besides this also can check if your confif file contains following configurations
      CONFIG_SPI=y
      CONFIG_SPI_NRFX=y
      CONFIG_MIPI_DBI=y
      CONFIG_DISPLAY=y
      CONFIG_LVGL=y  # If using LVGL
  • Hello Abdullah,
    You can upload the overlay file here so I can check.
