characteristic with read & notify repeatedly update in nRF connect app with same value
Continue.
PCA100059,S140,custermize periphral Blinky.
I have changed the value transfered between peripheral & center with
uint8_t* data;
uint16_t dataLen;
The max length set to 50 bytes.
Send 10 bytes to center every time butten event triggered(down/up).
What I saw in nRF connect app:
1) 50 bytes received, including the 10 bytes from the beginning;
    20 bytes receied for few times(include the 10 bytes too).
2) get update data nearly every 1 second,but the data is same,and I didnot change it in peripheral.
For 1), I have traced into the code,it is OK after called sd_ble_gatts_hvx() : the p_len is 10, that means SDH has sent 10 bytes, and the return code is NRF_SUCCESS.
But the log of nRF connect app showed it received 50 bytes.
For 2),I think nRF connect app should not receive same bytes, I don't know the notify mechanism, this is right or not?
The files:
6378.ble_tgoi.h
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "boards.h"
#include "app_timer.h"
#include "app_button.h"
#include "ble_tgoi.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
#define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
#define DEVICE_NAME                     "Tank_Game_IR"                         /**< Name of device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
//#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(2000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(3000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_TGOI_DEF(m_tgoi);                                                             /**< LED Button Service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scan_response_data,
/**@brief Function for assert macro callback.
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    // Initialize timer module, making it use the scheduler
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    ret_code_t              err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    ble_advdata_t advdata;
    ble_advdata_t srdata;
    ble_uuid_t adv_uuids[] = {{TGOI_UUID_SERVICE, m_tgoi.uuid_type}};
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = true;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    memset(&srdata, 0, sizeof(srdata));
    srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    srdata.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    ble_gap_adv_params_t adv_params;
    // Set advertising parameters.
    memset(&adv_params, 0, sizeof(adv_params));
    adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
    adv_params.duration        = APP_ADV_DURATION;
    adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    adv_params.p_peer_addr     = NULL;
    adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    adv_params.interval        = APP_ADV_INTERVAL;
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling write events to the LED characteristic.
 * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
 * @param[in] led_state Written/desired state of the LED.
static void SIMO_write_handler(uint16_t conn_handle, ble_tgoi_t * p_tgoi, uint8_t* data,uint16_t dataLen)
    /*if (led_state)
        bsp_board_led_on(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED ON!");
        bsp_board_led_off(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED OFF!");
		for(int i=0;i<dataLen;i++){
			for(int j=0;j<0xFFF;j++){};
		//NRF_LOG_INFO((const char*)data,dataLen);//�������Զ��жϽ�β�����ٺ�����
    ble_tgoi_init_t     init     = {0};
    // Initialize LBS.
    init.SIMO_write_handler = SIMO_write_handler;
    err_code = ble_tgoi_init(&m_tgoi, &init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module that
 *          are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply
 *       setting the disconnect_on_fail config parameter, but instead we use the event
 *       handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    bsp_board_led_on(ADVERTISING_LED);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            bsp_board_led_on(CONNECTED_LED);
            bsp_board_led_off(ADVERTISING_LED);
            err_code = app_button_enable();
            NRF_LOG_INFO("Disconnected");
            bsp_board_led_off(CONNECTED_LED);
            err_code = app_button_disable();
            advertising_start();
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
uint8_t testCnt = 1;
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
	  uint8_t data[10] = {0xFF,0xFF,0xFF,0xFF,5,6,0xFF,0xFF,0xFF,0xFF};
    switch (pin_no)
        case LEDBUTTON_BUTTON:
            NRF_LOG_INFO("Send button state change.");
				    //���ԣ����°�ťʱ����10���ֽڵ����ݣ����͸�server
						data[4] = testCnt++;
				    data[5] = testCnt++;
            err_code = ble_tgoi_on_SOMI_change(m_conn_handle, &m_tgoi, data,sizeof(data));
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE &&
                err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
    //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                               BUTTON_DETECTION_DELAY);
static void log_init(void)
        nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
    // Initialize.
    log_init();
    leds_init();
    timers_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    NRF_LOG_INFO("Blinky example started.");
    // Enter main loop.
    for (;;)
        idle_state_handle();
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(BLE_TGOI)
/**@brief Function for handling the Write event.
 * @param[in] p_lbs      LED Button Service structure.
 * @param[in] p_ble_evt  Event received from the BLE stack.
static void on_write(ble_tgoi_t * p_tgoi, ble_evt_t const * p_ble_evt)
    ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
	  //����server�����ݴ��������Ϊһ�����ݰ����ȣ����ݰ������DZ仯�ģ������ڽ��ʱ��Ҫ�����������жϼ�����
	  //������г��ȳ����ж�û��Ҫ
    if (   (p_evt_write->handle == p_tgoi->SIMO_char_handles.value_handle)
        //&& (p_evt_write->len == 1)
        && (p_tgoi->SIMO_write_handler != NULL))
			  //�յ����ݺ�Ĵ��������call�˺��������µ�Ӧ����Ӧ�ð��������ܡ������CRC��֤����ԺϷ����ݵ�ҵ����
        p_tgoi->SIMO_write_handler(p_ble_evt->evt.gap_evt.conn_handle, p_tgoi, (uint8_t*)(p_evt_write->data),p_evt_write->len);
//���BLE�¼��Ĵ����
//����ֻ������tgoi�йص��¼���Ҳ��������server�����ݰ���һ�������Ϊ����������
//�˺����ڳ�ʼ������ʱ����Ϊ�������ݸ�SDH��SDH���յ�BLE�¼����call�˺���
void ble_tgoi_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
    ble_tgoi_t * p_tgoi = (ble_tgoi_t *)p_context;
        case BLE_GATTS_EVT_WRITE:
            on_write(p_tgoi, p_ble_evt);
uint32_t ble_tgoi_init(ble_tgoi_t * p_tgoi, const ble_tgoi_init_t * p_tgoi_init)
    uint32_t              err_code;
    ble_uuid_t            ble_uuid;
    ble_add_char_params_t add_char_params;
    // Initialize service structure.
    p_tgoi->SIMO_write_handler = p_tgoi_init->SIMO_write_handler;
    // Add service.
    ble_uuid128_t base_uuid = {TGOI_UUID_BASE};
    err_code = sd_ble_uuid_vs_add(&base_uuid, &p_tgoi->uuid_type);
    VERIFY_SUCCESS(err_code);
    ble_uuid.type = p_tgoi->uuid_type;
    ble_uuid.uuid = TGOI_UUID_SERVICE;
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_tgoi->service_handle);
    // Add characteristic:SOMI,client�ϴ�������
    memset(&add_char_params, 0, sizeof(add_char_params));
    add_char_params.uuid              = TGOI_UUID_SOMI_CHAR;
    add_char_params.uuid_type         = p_tgoi->uuid_type;
    add_char_params.init_len          = sizeof(uint8_t);
    add_char_params.max_len           = 50;//test only sizeof(uint8_t);
		//�ṩ���ݵ�Ϊserver��һ��peripheral�ṩ���ݣ�������Ϊserver����Ϊserver�������ܽ����κβ���
		//ֻ�ж���Ҫ���ʵ�client�Ż����Ȩ�����ơ����з��ʵ�һ����center�����Ľ�ɫΪclient��
    add_char_params.char_props.read   = 1;
    add_char_params.char_props.notify = 1;
    add_char_params.read_access       = SEC_OPEN;
    add_char_params.cccd_write_access = SEC_OPEN;
    err_code = characteristic_add(p_tgoi->service_handle,
                                  &add_char_params,
                                  &p_tgoi->SOMI_char_handles);
    if (err_code != NRF_SUCCESS)
        return err_code;
    // Add characteristic: SIMO,�������Է�����������
    add_char_params.uuid             = TGOI_UUID_SIMO_CHAR;
    add_char_params.max_len          = 50;//test sizeof(uint8_t);
    add_char_params.char_props.write = 1;
    add_char_params.write_access = SEC_OPEN;
    return characteristic_add(p_tgoi->service_handle, &add_char_params, &p_tgoi->SIMO_char_handles);
uint32_t ble_tgoi_on_SOMI_change(uint16_t conn_handle, ble_tgoi_t * p_tgoi, uint8_t* data,uint16_t dataLen)
    ble_gatts_hvx_params_t params;
    memset(&params, 0, sizeof(params));
    params.type   = BLE_GATT_HVX_NOTIFICATION;
    params.handle = p_tgoi->SOMI_char_handles.value_handle;
    params.p_data = data;
    params.p_len  = &dataLen;
    return sd_ble_gatts_hvx(conn_handle, &params);
#endif // NRF_MODULE_ENABLED(BLE_LBS)
8015.ble_app_blinky_pca10059_s140.uvprojx
    Before calling characteristic_add(), can you set:
    add_char_params.is_var_len = true; /**< Indicates if the characteristic value has variable length.*/
    Kenneth
  • Nice, it receives only 10 bytes now.
    But,why It repeatedly send the last data?
    It will not send any data if I never send data,and it will repeatedly send the last data if I send data once.
  • I can't think of anything, unless you somewhere are calling sd_ble_gatts_hvx(). If you have a sniffer log that might help.
    Kenneth
  • In my code as showed in attahed files,there only 1 place to call sd_ble_gatts_hvx():
    	  ble_gatts_value_t p_value;
        p_value.len = dataLen;
        p_value.offset = 0;
        p_value.p_value = data;
    	  return sd_ble_gatts_value_set(conn_handle,p_tgoi->SOMI_char_handles.value_handle,&p_value);
    and this function called in button event handler:
        switch (pin_no)
    				    //测试,按下按钮时生成10个字节的数据,发送给server
    I have set break point in these functions,no stop during repeatedly sending last data.
    That means those 2 functions not been executed.
    Any other attributes can be set to control the data transfering between peripheral & center?
  • I have tested the orignal Blinky again, same. The nRF connect app will repeatedly update the LED state and button state.Looks like this is app's intentionally action.
    So ignore it now, I will check with center app later.
    By the way, about debug log, can I use the USB to output log to PC?
    I have no JLink, only a 3rd vendor's CMSIS-DAP debugger.
    I just tried JLink viewer with my debugger, it can't find the debugger.
    And I don't want to connect another board between PCA10059 and PC.
    Thanks.
