MQTT Not Receiving Subscribe Message for 30+ Seconds
My setup:
SDK version: 2.5.0.v
Modem version: 1.3.0.
I am using MQTT to subscribe to a topic, for example, the LED state. The plan is to set the LED state on the server side and send the new state to the device. I need a relatively fast reaction time, so I am not using any power-saving modes (e.g., eDRX or PSM). Usually, I receive this message within 2.54 seconds, as the RRC idle time PDCCH check occurs every 2.54 seconds. I am using an LTE-M network, and my MQTT keep-alive time is 3 minutes.
This setup works well most of the time. However, occasionally, I experience a long delay in receiving the message—between 30 and 60 seconds, which is unacceptable for my use case.
What could be causing this delay?
I also have captured the trace when this problem happens.
1. Between timestamps 606 and 744, I published the new state from the server, but the message was not received.
2. At timestamps 754 and 757, I sent the button state from the device to the server to check if the TCP communication was still open. The server successfully received the device state.
3. Finally, at timestamp 793, I received the delayed publish message from the server.
PS:
In the trace file, I also see a lot of TCP retransmission errors, etc. Is this normal?
PS1:
I also check MQTT broker debug log on the server side, I did not see any delays etc. Everything looks OK.
UPDATE:
I found one more interesting thing. The modem is constantly switching between two towers. The SNR of one tower is somewhere between 8 dB (fair) and 10 dB (good), while the other tower's SNR ranges from -5 dB to 0 dB (poor). When the device missed the message, it was connected to the tower with poor SNR. This could explain why the MQTT message was not received.
 7838.output2.pcapng
