Custom characteristics are not appearing when I attempt iterate through the attributes
the code below successfully complies and returns 3 services with 1 characteristic each, I have copied the uuid for the primary services and characteristic and that doesn't seem to have caused an issue in the nrf connect app
struct bt_gatt_attr attrs1[10]; // Adjust size as needed
struct bt_gatt_attr attrs2[10]; // Adjust size as needed
struct bt_gatt_attr attrs3[10]; // Adjust size as needed
struct bt_gatt_service services[4]; // Assuming 3 services
for (int i = 0; i < 3; i++) {
    int attr_count = 0; // Reset attr_count for each service
    struct bt_gatt_attr *attrs;
    // Assign the correct attrs array for each service
    if (i == 0) {
        attrs = attrs1;
    } else if (i == 1) {
        attrs = attrs2;
    } else {
        attrs = attrs3;
    attrs[attr_count++] = (struct bt_gatt_attr) {
        .uuid = BT_UUID_GATT_PRIMARY,
        .perm = BT_GATT_PERM_READ,
        .read = bt_gatt_attr_read_service,
        .user_data = uuids_struct[i].val,
    attrs[(attr_count)++] = (struct bt_gatt_attr) {
        .uuid = BT_UUID_GATT_CHRC,
        .read = bt_gatt_attr_read_chrc,
        .user_data = &(struct bt_gatt_chrc) {
            .properties = BT_GATT_CHRC_READ | BT_GATT_CHRC_WRITE,
            .uuid = uuids_struct[i].val,
        .perm = BT_GATT_PERM_READ | BT_GATT_PERM_WRITE,
        .read = NULL,
        .write = NULL,
        .user_data = NULL,
    printk("updated\n");
    services[i] = (struct bt_gatt_service) {
        .attrs = attrs,
        .attr_count = attr_count
    int result = bt_gatt_service_register(&services[i]);
    if (result) {
        LOG_ERR("Failed to register service %d (err %d)", i, result);
    } else {
        LOG_INF("Service %d registered successfully", i);
the code below successfully complies but only displays the services, I'm unsure what the issue maybe
    if (i == 0) {
        attrs = attrs1;
        attrs = attrs2;
    } else {
        attrs = attrs3;
        .user_data = &uuids_struct[i].val,
	for (int j = 0; j < 1; j++){
		printk("entering second loop\n");
				.uuid = &uuids_struct[i].val,
			.read = NULL,
			.write = NULL,
			.user_data = NULL,
        .attrs = attrs,
    if (result) {
    } else {
Parents Reply
  • sorry for the confusion, I'm planning on adding more than one characteristic per service in the future, I simplified the code on the bottom for better readability, but the term j is going to be used to index a struct of uuid array to assign to the characteristics attribute. I was hoping to reduce the amount of lines of code by using iteration as having 10 or more services with approximately 5 attributes each hard coded isn't exactly efficient or readable. I've attempted creating a separate function for the characteristic attribute but the issue persists.
