I am using the LORA Drivers provided by zephyr for testing my SX1762 lora module with NRF52833 Development Kit. I am able to initialize and configure the LORA Peripherals. but when I am trying to send the buffer over LORA, I am coming up with error code -11 which suggests there is no contexts.
This is my main code:
int lora_configure(const struct device *dev, bool transmit)
int ret;
struct lora_modem_config config;
config.frequency = 865100000; //916800000;
config.bandwidth = BW_125_KHZ;
config.datarate = SF_10;
config.preamble_len = 8;
config.coding_rate = CR_4_5;
config.tx_power = 4;
config.iq_inverted = false;
config.public_network = false;
config.tx = transmit;
ret = lora_config(dev, &config);
if (ret < 0) {
printk("LoRa device configuration failed");
return false;
return(true);
const struct device *dev_lora;
int ret=0;
int bytes;
nrf_gpio_cfg_output(AN_SW1);
nrf_gpio_cfg_output(AN_SW2);
nrf_gpio_pin_set(AN_SW1);
nrf_gpio_pin_clear(AN_SW2);
printk("LoRa Point to Point Communications Example\n");
// Setup LoRa Radio Device:
dev_lora = DEVICE_DT_GET(DT_ALIAS(lora0));
if (!device_is_ready(dev_lora)) {
printk("%s: device not ready\n", dev_lora->name);
return -1;
printk("%s: SPI Initialised\n", dev_lora->name);
if (lora_configure(dev_lora, TRANSMIT)) {
printk("LoRa Device Tx Configured\n");
} else {
return -1;
printk("LoRa Device Tx Config Failed\n");
while (1) {
ret = lora_test_cw(dev_lora,865100000,4,3);
if (ret < 0) {
printk("LoRa Test Fail :[%d]\n",ret);
} else {
printk("LoRa Test Success\n");
k_msleep(1000);
// Transmit data
ret = lora_send(dev_lora, data_tx, sizeof(data_tx));
if (ret < 0) {
printk("LoRa send failed:[%d]\n",ret);
} else {
bytes = sizeof(data_tx);
printk("XMIT %d bytes: ", bytes);
for (uint16_t i = 0; i < bytes; i++)
printk("0x%02x ",data_tx[i]);
printk("\n");
k_msleep(2000);
return 0;
int sx12xx_lora_send(const struct device *dev, uint8_t *data,
uint32_t data_len)
struct k_poll_signal done = K_POLL_SIGNAL_INITIALIZER(done);
struct k_poll_event evt = K_POLL_EVENT_INITIALIZER(
K_POLL_TYPE_SIGNAL,
K_POLL_MODE_NOTIFY_ONLY,
&done);
uint32_t air_time;
int ret;
/* Validate that we have a TX configuration */
if (!dev_data.tx_cfg.frequency) {
return -EINVAL;
ret = sx12xx_lora_send_async(dev, data, data_len, &done);
if (ret < 0) {
return ret;
/* Calculate expected airtime of the packet */
air_time = Radio.TimeOnAir(MODEM_LORA,
dev_data.tx_cfg.bandwidth,
dev_data.tx_cfg.datarate,
dev_data.tx_cfg.coding_rate,
dev_data.tx_cfg.preamble_len,
0, data_len, true);
LOG_DBG("Expected air time of %d bytes = %dms", data_len, air_time);
/* Wait for the packet to finish transmitting.
* Use twice the tx duration to ensure that we are actually detecting
* a failed transmission, and not some minor timing variation between
* modem and driver.
ret = k_poll(&evt, 1, K_MSEC(2 * air_time));
if (ret < 0) {
LOG_ERR("Packet transmission failed!");
if (!modem_release(&dev_data)) {
/* TX done interrupt is currently running */
k_poll(&evt, 1, K_FOREVER);
return ret;
int sx12xx_lora_send_async(const struct device *dev, uint8_t *data,
uint32_t data_len, struct k_poll_signal *async)
/* Ensure available, freed by sx12xx_ev_tx_done */
if (!modem_acquire(&dev_data)) {
return -EBUSY;
/* Store signal */
dev_data.operation_done = async;
Radio.SetMaxPayloadLength(MODEM_LORA, data_len);
Radio.Send(data, data_len);
return 0;
static bool modem_release(struct sx12xx_data *data)
/* Increment atomic so both acquire and release will fail */
if (!atomic_cas(&data->modem_usage, STATE_BUSY, STATE_CLEANUP)) {
return false;
/* Put radio back into sleep mode */
Radio.Sleep();
/* Completely release modem */
data->operation_done = NULL;
atomic_clear(&data->modem_usage);
return true;
static inline bool modem_acquire(struct sx12xx_data *data)
return atomic_cas(&data->modem_usage, STATE_FREE, STATE_BUSY);
int sx12xx_lora_test_cw(const struct device *dev, uint32_t frequency,
int8_t tx_power,
uint16_t duration)
/* Ensure available, freed in sx12xx_ev_tx_done */
return -EBUSY;
Radio.SetTxContinuousWave(frequency, tx_power, duration);
return 0;
00> LoRa send failed:[-16]
00> LoRa Test Fail :[-16]
00> [00:15:58.939,605] <dbg> sx12xx_common: sx12xx_lora_send: Expected air time of 10 bytes = 289ms
00> [00:16:00.384,704] <err> sx12xx_common: Packet transmission failed!
00> EINVAL[22] EBUSY[16]
00> LoRa send failed:[-11]
