nRF5340 module flashing failed
Hi, I am trying to flash to a new design which uses ublox NORA-B120 module. I am trying to flash from vsc. But the flashing fails with following error.
-- west flash: rebuilding
[0/23] Performing build step for 'tfm'
ninja: no work to do.
[1/6] Performing build step for '802154_rpmsg_subimage'
[3/3] modules\openthread\build\CMakeFiles\print-ot-config-96e6445.bat 0576bd2f9a3721b3
OPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1
OPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0
OPENTHREAD_CONFIG_ASSERT_ENABLE=0
OPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0
OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0
OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0
OPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0
OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0
OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0
OPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0
OPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0
OPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0
OPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0
OPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0
OPENTHREAD_CONFIG_COAP_API_ENABLE=1
OPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0
OPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0
OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=1
OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1
OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=1
OPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0
OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=1
OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0
OPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0
OPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0
OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1
OPENTHREAD_CONFIG_DIAG_ENABLE=1
OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0
OPENTHREAD_CONFIG_DNS_DSO_ENABLE=0
OPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0
OPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0
OPENTHREAD_CONFIG_DUA_ENABLE=1
OPENTHREAD_CONFIG_ECDSA_ENABLE=1
OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1
OPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0
OPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0
OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1
OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=1
OPENTHREAD_CONFIG_JOINER_ENABLE=1
OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=1
OPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0
OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=1
OPENTHREAD_CONFIG_LINK_RAW_ENABLE=1
OPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0
OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=1
OPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0
OPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0
OPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0
OPENTHREAD_CONFIG_MLR_ENABLE=1
OPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0
OPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0
OPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0
OPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0
OPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0
OPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0
OPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1
OPENTHREAD_CONFIG_OTNS_ENABLE=0
OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1
OPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=0
OPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=1
OPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0
OPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0
OPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0
OPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0
OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1
OPENTHREAD_SETTINGS_RAM=0
OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1
OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0
OPENTHREAD_CONFIG_TCP_ENABLE=0
OPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0
OPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0
OPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0
OPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0
OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1
OPENTHREAD_CONFIG_UPTIME_ENABLE=1
OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_3
OPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL
OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0
OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0
PACKAGE_NAME=OPENTHREAD
OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1
KERNEL
__ZEPHYR__=1
_FORTIFY_SOURCE=1
_ANSI_SOURCE
__LINUX_ERRNO_EXTENSIONS__
USE_PARTITION_MANAGER=1
__PROGRAM_START
NRF5340_XXAA_APPLICATION
NRF_SKIP_FICR_NS_COPY_TO_RAM
NRF_TRUSTZONE_NONSECURE
MBEDTLS_CONFIG_FILE=nrf-config.h
MBEDTLS_PSA_CRYPTO_CONFIG_FILE=nrf-psa-crypto-want-config.h
MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=nrf-psa-crypto-config.h
NRF_802154_SERIALIZATION_HOST=1
NRF_802154_USE_RAW_API=1
NRF_802154_PENDING_SHORT_ADDRESSES=16
NRF_802154_PENDING_EXTENDED_ADDRESSES=16
NRF_802154_RX_BUFFERS=16
NRF_802154_TX_STARTED_NOTIFY_ENABLED=1
NRF_802154_ACK_TIMEOUT_ENABLED=1
NRF_802154_CCA_CORR_LIMIT_DEFAULT=2
NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45
NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45
NRF_802154_SECURITY_KEY_STORAGE_SIZE=3
NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED
NRF_802154_ENCRYPTION_ENABLED=1
NRF_802154_SECURITY_WRITER_ENABLED=1
NRF_802154_IE_WRITER_ENABLED=1
NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0
NRF_802154_CARRIER_FUNCTIONS_ENABLED=0
NRF_802154_ENERGY_DETECTED_VERSION=1
NRF_802154_PLATFORM_ASSERT_INCLUDE=nrf_802154_assert_zephyr.h
NRF_802154_ECB_PRIORITY=-1
NRF_802154_SWI_PRIORITY=1
-- west flash: using runner nrfjprog
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: d:\Projects\nrf\nrf5340_cli\build\zephyr\merged_domains.hex
-- runners.nrfjprog: d:\Projects\nrf\nrf5340_cli\build\zephyr\merged_domains.hex targets both nRF53 coprocessors; splitting it into: d:\Projects\nrf\nrf5340_cli\build\zephyr\GENERATED_CP_NETWORK_merged_domains.hex and d:\Projects\nrf\nrf5340_cli\build\zephyr\GENERATED_CP_APPLICATION_merged_domains.hex
[error] [ Client] - Encountered error -102: Command enable_coprocessor executed for 156 milliseconds with result -102
Failed to enable coprocessor with unknown error.
[error] [ Worker] - An unknown error.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program 'd:\Projects\nrf\nrf5340_cli\build\zephyr\GENERATED_CP_NETWORK_merged_domains.hex' --sectorerase --verify -f NRF53 --coprocessor CP_NETWORK --snr 960064206
*  The terminal process terminated with exit code: 33.
Anyone can help please?
Kaushalya
