Does The Npm2100 Have Wakeup On Interrupt?
Planning on using the npm2100 PMIC as our PMIC for an upcoming asset tracking solution.
We will have an accelerometer that will determine when the main MCU (nrf54) wakes up, when the device gets moved.
However, we would also like to utilize the hibernation mode of the npm2100.
Will the npm2100 feature a wake-up GPIO that can be triggered? If not, what would be the fix?
  • To my experience, the nPM2100 does not implement true edge detection in the strict sense. Instead of detecting an actual signal transition (i.e., a discrete event), it monitors the level of the SHPHLD pin.
    This means the device evaluates whether the pin is high or low, regardless of when that state was reached. As a result, if the pin is already at the active level when the system enters Hibernate mode, the nPM2100 may wake up immediately — even though no edge occurred.
    In other words, the so-called ‘edge’ configuration behaves more like a level-triggered wake-up mechanism rather than a genuine edge-triggered interrupt. So the term ‘edge detection’ in this context is misleading; it is better understood as periodic level sampling rather than event-driven edge sensing.
  • I understand. I didn't pick up what you meant initially, but you are saying that the event will occur if you e.g. set it from low-to-high, and the signal was already high (and didn't change). I was not aware. In that case, I agree. I will take it forward to our pmic team.
    Edvin
