We are using the nRF52832 in a battery such that we have a 3V3 LDO configured to turn off under a certain battery voltage. Now during testing we have discovered that the voltage supervisor circuit which enables or disables the LDO to turn ON or OFF can oscillate back and forth with very small voltage changes. Basically, when the LDO is switched off, the battery voltage can recover slightly causing the LDO to continuously oscillate ON and OFF.
Ideally the circuit turns OFF once and has sufficient hysteresis, but I am wondering if this harmful for the nRF. Is there is a situation where it can lock up or cause adverse effects that are not normally recoverable if the voltage rises to 3v3 or under and then immediately drops to 0V? Is there a min voltage it must rise to before dropping back down to 0V? We may not be able to control the timing of the ON or OFF duration in this scenario.
