NRF9151DK autonomous resets when simultaneously starting LTE connection and GPS on modem FW 2.0.2
I have updated a board (NRF9151DK) from modem FW 2.0.1 to 2.0.2. The board is also equipped with nrf7002-EK, and the support for the wifi driver is enabled (SB_CONFIG_WIFI_NRF70, SB_CONFIG_WIFI_NRF70_SCAN_ONLY, haven't verified if this makes a difference).
The previous version of the application works fine, in which we initialize the modem at startup, and simultaneously initiate an LTE connection and activate the internal GPS. On the new 2.0.2 firmware, this simultaneous action results in an autonomous reset, which can be fixed by e.g. adding a 100msec sleep before activating the internal gps. The same problem occurs on other devkits too (observed on 2 out of 2).
I mainly want to notify you of this difference, because I'll not be the only person suffering from this. I leave it up to you to consider if a fix is possible.
I can try out alternative solutions if necessary.
Sebastiaan
