NRF9151DK autonomous resets when simultaneously starting LTE connection and GPS on modem FW 2.0.2
I have updated a board (NRF9151DK) from modem FW 2.0.1 to 2.0.2. The board is also equipped with nrf7002-EK, and the support for the wifi driver is enabled (SB_CONFIG_WIFI_NRF70, SB_CONFIG_WIFI_NRF70_SCAN_ONLY, haven't verified if this makes a difference).
The previous version of the application works fine, in which we initialize the modem at startup, and simultaneously initiate an LTE connection and activate the internal GPS. On the new 2.0.2 firmware, this simultaneous action results in an autonomous reset, which can be fixed by e.g. adding a 100msec sleep before activating the internal gps. The same problem occurs on other devkits too (observed on 2 out of 2).
I mainly want to notify you of this difference, because I'll not be the only person suffering from this. I leave it up to you to consider if a fix is possible.
I can try out alternative solutions if necessary.
Sebastiaan
  • Hi
    Sorry, but Susheel is not available, and I've been tasked with looking into this ticket while he's away. So sorry that we have to take a couple of steps back as I need some time to get into this case. One thing I'm not able to find info on in this case is which SDK version you're working on here. Can you share some more information on that. I'm currently waiting for some replies internally on ideas as to why the watchdog would misbehave like this. I have not looked at the project you uploaded, but I'll get to that. Just wanted to give you a status update.
    My initial thought, and this is just me taking a stab in the dark, is that the GPS location takes longer time than what the watchdog timeout is set as, and thus the watchdog triggers a reset while you're trying to get a GPS location. Is there a specific reason the WDT is set to 5 seconds, and could you try to increase it substantially to see if that makes a difference? You say that your application works as expected if you disable the WDT. Can you confirm you're able to initialize GPS and get a GPS ping as expected without the WDT?
    Simon
  • Hi Simon,
    Thanks for jumping in.
    The SDK version and toolchain is 2.9.0.
    Actually, the watchdog reset occurs several seconds before a first task timeout can occur. The task timeout is set to 5 seconds, but the system resets after about 2 seconds (without calling the watchdog callback either). So there's no relationship with the duration of the tasks.
    Changing the task timeout to 10 seconds or more does not make any difference: the system still resets after about 2 seconds.
    The application can work completely fine if the watchdog is disabled, or if I put a sleep of 1 second (overkill) before the initialization of the GPS stack, which is the workaround that I'm using now.
    In my opinion, I think it's best to try to reproduce based on the code that I provided. Let me know if I should re-share the code sample.
    The issue is not urgent for me, but I have the feeling that there's something fundamentally wrong that should be understood better or it can cause more issues in the future.
  • Hi
    After a brief look at your project, it seems like your GPS thread completely takes over the main thread, so that the watchdog never gets  fed in the first place. How exactly have you timed these system resets on your end?
    To confirm whether the feeding in the main loop ever is reached, you can try switching it out with a GPIO toggling instead to see if that ever happens. We assume this will be blocked when you run the GPS, and that it just never is fed. Making some changes to the priorities in your application should fix that.
    Simon
  • I don't agree with your conclusions. The GPS thread does not fully take over CPU control since in the internal loop of "app_gps_internal_get_fix", it periodically blocks on a semaphore. Also, again, this whole program runs fine with modem fw 2.0.1 and watchdog enabled.
    I have even changed the watchdog channel period to 20 seconds (20000 msec) and in combination with modem fw 2.0.1, the watchdog kicks in at the expected time if it is not fed. Also, the callback is called (task_wdt_callback) as expected.
    With modem FW 2.0.2 this is not the case, the watchdog resets way sooner, and a callback is not called. The solutions or fixes that can make the application work with FW 2.0.2 are one of those:
    • Delay of gps thread startup with e.g. 1 second
    • Or changing the sleep of the main loop to something like 50 msec instead of 1 second what it was in the past
      • 90 msec also works fine, 100msec does not. By chance (or not?), this is equal to CONFIG_TASK_WDT_MIN_TIMEOUT.
    So please stop asking me to toggle GPIOs. The main loop is running and kicking, but the problem is that the watchdog decides to reset nevertheless, and it resets way before the configured task period of e.g. 5 seconds or 20 seconds. This behavior only occurs with modem fw 2.0.2, not with fw 2.0.1.
  • I'm just an other user.
    AFAIK the watchdog is located on the app CPU not on the modem. If changing the modem firmware fires that watchdog of the app CPU, it is in my experience still an issue in the app.
    What changing the mfw may cause is a slightly different timing, which then may unexpected block. Your countermeasures are pointing to something like that.
    Anyway, it's your time and so your decision.
