So, hello, hopefully I have done my diligence to be able to afford some help, thank you!
Context: driving an ADIN1110 by Analog Devices with an nRF52840 usb dongle. Within VS code the application secure_mqtt_sensor_actuator has been copied a board overlay has been created, compiled and programmed. The hex file runs messages out the USB COM port indicating the default iface has not been initialized or declared with a constant value, the ADIN1110 driven by the spi of the nrf52840. While I have done an extreme amount of application development within VS code utilizing command line operations with was back ifrom SDK_12.0.012f24da to nRF5_SDK_17.0.2_d674dde, therefore just trying to get my head around best practices of the nRFconnect v2.9.0. Within main.c the function net_if_get_default() prints the warning message <wrn> net_if: no default interface found!
Question: how to force the default iface to the spi of the nrf52840 driving the ADIN1110 out the ethernet?
greatly appreciate your thoughts!
Cy
nrf52840dongle_nrf52840.overlay:
/* Device Tree Overlay for nRF52840 USB Dongle connected to ADIN1110 */
&pinctrl {
spi_master_default: spi_master_default {
group1 {
psels = <NRF_PSEL ( SPIM_SCK , 0, 12) >, /* SCK - P0 .12 */
<NRF_PSEL ( SPIM_MOSI , 0, 15) >, /* MOSI - P0 .15 */
<NRF_PSEL ( SPIM_MISO , 0, 13) >; /* MISO - P0 .13 */
spi_master_sleep: spi_master_sleep {
group1 {
low-power-enable ;
/* SPI Master configuration */
&spi3 {
status = "okay";
pinctrl-0 = <&spi_master_default>;
pinctrl-1 = <&spi_master_sleep>;
cs-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>; /* CS - P1 .00 */
/* ADIN1110 Ethernet PHY configuration */
adin1110: ethernet@0 {
status = "okay";
//zephyr,default = "yes";
compatible = "adi,adin1110";
reg = <0>;
spi-max-frequency = <8000000 >;
int-gpios = <&gpio1 15 GPIO_ACTIVE_LOW >; /* IRQ - P1 .15 */
reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW >; /* RST - P1 .10 */
//label = "ADIN1110";
// swpd-en-gpios = <&egpio0 20 GPIO_ACTIVE_LOW>;
// tx2p4-en-gpios = <&egpio0 22 GPIO_ACTIVE_LOW>;
// ts_timer-ms-sel-gpios = <&egpio0 24 GPIO_ACTIVE_HIGH>;
// ts-capt-gpios = <&egpio1 13 GPIO_INPUT GPIO_PULL_UP>;
