This is not a support request.
I just want to share some code that others might find useful. If I post it here then they might find it.
The current RADIO_TEST example has support for remote USB CDC ADM but only for the nrf5340.
Here's how to get it to work on nrf52
Start with the nrf/samples/peripheral/radio_test example from NCS 2.9.0
My custom PCB uses an nrf52840, so I added a build configuration with "nrf52840dk/nrf52840"
Add this to the prj.conf
CONFIG_STDOUT_CONSOLE=y CONFIG_USB_DEVICE_STACK=y CONFIG_USB_DEVICE_PRODUCT="Radio Test" CONFIG_USB_DEVICE_PID=0x0001 CONFIG_LOG=y CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_LINE_CTRL=y CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=y
Add this overlay file
1462.nrf52840dk_nrf52840.overlay
When you connect the PCB to your computer by USB it should appear in device manager under Ports as a "USB Serial Device" with a COM number
You can connect to it using Putty with 115200 baud rate.
And that's it. Hopefully it saves someone a few hours/days to figure this out :)
It would be great if the example could be updated to do this using a CONFIG variable (in the same way as it does for nrf5340)
-Jason
